原Android7.1系统无法刷新/升级新固件
固件文件名称:rk3399_firefly_aiojd4_box-userdebug 7.1.2 NHG47k e
固件下载地址:时间太久找不到了
Log日志:log2026-03-23_ubuntu(GPT).txt
  1. 使用 Upgrade Tool v2.1 升级 Android7.1.2 系统到 Ubuntu20.04 失败。
  2. 使用 Upgrade Tool v2.1 升级 Android 固件也会失败。
    14:17:33 Upgrade Tool v2.1
    14:17:33 Current process in /home/zr/work/firefly/core_3399_JD4/test
    14:17:33 Using /home/zr/work/firefly/core_3399_JD4/test/config.ini
    14:17:33 Command Line: ./upgrade_tool uf /home/zr/work/firefly/core_3399_JD4/AIO-3399JD4_Android7.1.2_HDMI_190428/AIO-3399JD4_Android7.1.2_HDMI_190428.img
    14:17:33 Current Device Location ID:11
    14:17:33 Test Device Start
    14:17:38 Error:RKU_Write failed,err=-7
    14:17:38 ERROR:TestDevice–>RKU_TestDeviceReady failed,RetCode(-3)
    14:17:44 Error:RKU_Write failed,err=-7
    14:17:44 ERROR:TestDevice–>RKU_TestDeviceReady failed,RetCode(-3)
    14:17:50 Error:RKU_Write failed,err=-7
    14:17:50 ERROR:TestDevice–>RKU_TestDeviceReady failed,RetCode(-3)
    14:17:51 Test Device Fail
    14:17:51 Command mode out
  3. 又尝试使用 v1.34 版本的 upgrade_tool 升级 Android 固件就会一直卡在“Test Device Start”没反应:
    Rockusb>uf AIO-3399JD4_Android7.1.2_HDMI_190428.img
    Loading firmware…
    Support Type:RK330C FW Ver:7.1.01 FW Time:2019-04-28 14:05:17
    Loader ver:1.09 Loader Time:2019-04-26 10:00:47
    Test Device Start
    log2026-03-23_ubuntu(GPT).txt (1.57 KB)
