固件文件名称:ROC-RK3588S-PC_Buildroot_v1.0.6f_230819
固件下载地址:百度网盘
Log日志:启动日志.txt
开发板启动时串口报错,无法启动,日志信息如下,请问是咋回事呢,怎么解决嘞:
启动日志.txt (4.11 KB)
固件下载地址:百度网盘
Log日志:启动日志.txt
启动日志.txt (4.11 KB)
看上去像DDR问题,刷ubuntu22.04最新固件验证
刷的ROC-RK3588S-PC_Ubuntu22.04-Xfce-r31153_v1.4.0g_250114.img固件,报错是下面的:
DDR d5483af87d cym 23/11/23-16:15:24,fwver: v1.15
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
Manufacturer ID:0xff
CH0 RX Vref:28.5%, TX Vref:23.8%,22.8%
CH1 RX Vref:27.9%, TX Vref:22.8%,22.8%
CH2 RX Vref:27.9%, TX Vref:21.8%,0.0%
CH3 RX Vref:28.5%, TX Vref:23.8%,0.0%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-ge4e124926e-230922 #lxh (Sep 25 2023 - 10:58:38), fwver: v1.13
unknown raw ID 0 0 0
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(2e8446f969…) + OK
## Checking uboot 0x00200000 … sha256(afd953fe4e…) + OK
## Checking fdt 0x003694a8 … sha256(a434b1c4fe…) + OK
## Checking atf-2 0xff100000 … sha256(9f75e6ec37…) + OK
## Checking atf-3 0x000f0000 … sha256(c80587de50…) + OK
## Checking optee 0x08400000 … sha256(4b2d406bfc…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 83.608/230.863 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-662-g4acbe711b-dirty:finley.xiao, fwver: v1.44
NOTICE: BL31: Built : 16:44:24, Nov 7 2023
INFO: spec: 0x13
INFO: code: 0x88
INFO: ext 32k is valid
INFO: ddr: stride-en 4CH
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: l3 cache partition cfg-0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-752-g62aa10b78 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Mon Sep 25 10:04:34 CST 2023 aarch64, fwver: v1.15
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: b6cfe2b573)(sdk version: rk3588_linux_release_20250114_v1.4.0g)-gb6cfe2b573-231011 #zzz (Jan 14 2025 - 14:51:37 +0800)
Model: Rockchip RK3588 Evaluation Board
MPIDR: 0x81000000
PreSerial: 2, raw, 0xfeb50000
DRAM: “Error” handler, esr 0xbe000011
x0 : 00000000eb7ffeb8 x1 : 0000000000000000
x2 : 0000000000000148 x3 : 0000000000000038
x4 : 0000000000000000 x5 : 0000000000000110
x6 : 0000000000000000 x7 : 0000000000000000
x8 : 0000000000000000 x9 : 00000000fe680000
x10: 0000000000000058 x11: 00000000ffffffff
x12: 00000000efffffff x13: 00000000f0000000
x14: 00000000003694a8 x15: 0000000000000020
x16: 0000000000000000 x17: 0000000000000000
x18: 000000000057fe30 x19: 00000000002d26b8
x20: 00000000002d25d0 x21: 0000000000000000
x22: 0000000000000000 x23: 0000000000000000
x24: 0000000000000000 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000000000000
x28: 0000000000000000 x29: 000000000057fde0
Call trace:
PC: [< 002c7694 >]
LR: [< 0021a688 >]
Stack:
[< 002c7694 >]
Copy info from “Call trace…” to a file(eg. dump.txt), and run
command in your U-Boot project: ./scripts/stacktrace.sh dump.txt
Resetting CPU …
联系售后
