固件文件名称:Firefly_rk3576_android14.0_git_20240721
固件下载地址:https://www.t-firefly.com/doc/download
Log日志:log.txt
请问Firefly_rk3576_android14.0_git_20240721 sdk压缩包解压后,如何同步更新代码,没看到代码出来。
log.txt (2.89 KB)
Log日志:log.txt
log.txt (2.89 KB)
git reset --hard
没看到报错内容,应该在上面
上面没有报错
/home/aplex/Firefly_rk3576_android14.0_git_20240721/firefly_android14
Build exteranl rvcam driver ok!
cp: cannot create regular file '/home/aplex/Firefly_rk3576_android14.0_git_20240721/firefly_android14/out/target/product/rk3576_firefly_roc_rk3576_pc/kernel': No such file or directory
package resoure.img with charger images
Pack ./tools/images/ & ../kernel-6.1/resource.img to resource.img ...
Unpacking old image(../kernel-6.1/resource.img):
rk-kernel.dtb logo.bmp logo_kernel.bmp 3
Pack to resource.img successed!
Packed resources:
rk-kernel.dtb battery_1.bmp battery_2.bmp battery_3.bmp battery_4.bmp battery_5.bmp battery_fail.bmp logo.bmp logo_kernel.bmp battery_0.bmp 10
./resource.img with battery images is ready
start build android
18:38:56 ************************************************************
18:38:56 You are building on a machine with 5.66GB of RAM
18:38:56
18:38:56 The minimum required amount of free memory is around 16GB,
18:38:56 and even with that, some configurations may not work.
18:38:56
18:38:56 If you run into segfaults or other errors, try reducing your
18:38:56 -j value.
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=14
PRODUCT_INCLUDE_TAGS=com.android.mainline
TARGET_PRODUCT=rk3576_firefly_roc_rk3576_pc
TARGET_BUILD_VARIANT=userdebug
TARGET_ARCH=arm64
TARGET_ARCH_VARIANT=armv8-a
TARGET_CPU_VARIANT=generic
TARGET_2ND_ARCH=arm
TARGET_2ND_ARCH_VARIANT=armv8-a
TARGET_2ND_CPU_VARIANT=generic
HOST_OS=linux
HOST_OS_EXTRA=Linux-6.5.0-45-generic-x86_64-Ubuntu-22.04.3-LTS
HOST_CROSS_OS=windows
BUILD_ID=UQ1A.240205.004.B1
OUT_DIR=out
18:39:01 Entire data directory removed.
18:39:01 Deleted images and staging directories.
#### build completed successfully (10 seconds) ####
18:39:06 ************************************************************
18:39:06 You are building on a machine with 5.66GB of RAM
18:39:06
18:39:06 The minimum required amount of free memory is around 16GB,
18:39:06 and even with that, some configurations may not work.
18:39:06
18:39:06 If you run into segfaults or other errors, try reducing your
18:39:06 -j value.
PLATFORM_VERSION=14
TARGET_ARCH=arm64
TARGET_2ND_ARCH=arm
HOST_OS=linux
OUT_DIR=out
[ 99% 433/436] test android/soong/sdk
FAILED: out/host/linux-x86/bin/go/soong-sdk/test/test.passed
out/host/linux-x86/bin/gotestrunner -p build/soong/sdk -f out/host/linux-x86/bin/go/soong-sdk/test/test.passed -- out/host/linux-x86/bin/go/soong-sdk/test/test -test.short
test got signal killed
[ 99% 434/436] converting Android.bp files to BUILD files at out/soong/bp2build
audioflinger want to conditional Compile
devicefactory want to conditional Compile
hw_output_defaults want to conditional Compile
libaudioclient want to conditional Compile
libaudiohal want to conditional Compile
libeptz want to conditional Compile
libgralloc_priv want to conditional Compile
libmpimmz conditional Compile
libpq want to conditional Compile
librga want to conditional Compile
librkvt_win want to conditional Compile
librockx want to conditional Compile
pq_init want to conditional Compile
Rockchip conditional compile
rockit want to conditional Compile
cc_rockit_hw_service want to conditional Compile
tvinput want to conditional Compile
tvinput_defaults pqInitDefaults
platformVersion android "14"
0 -DRKAIQ_ENABLE_CAMGROUP
1 -DRKAIQ_ENABLE_FAKECAM
2 -DRKAIQ_HAVE_AWB_V32=1
3 -DRKAIQ_HAVE_AWB=1
4 -DRKAIQ_HAVE_GIC_V2=1
5 -DRKAIQ_HAVE_GIC=1
6 -DRKAIQ_HAVE_CAC_V11=1
7 -DRKAIQ_HAVE_CAC=1
8 -DRKAIQ_HAVE_CAC_V12=1
9 -DRKAIQ_HAVE_CAC=1
10 -DRKAIQ_HAVE_YNR_V24=1
11 -DRKAIQ_HAVE_YNR=1
12 -DRKAIQ_HAVE_CNR_V31=1
13 -DRKAIQ_HAVE_CNR=1
14 -DRKAIQ_HAVE_SHARP_V34=1
15 -DRKAIQ_HAVE_SHARP=1
16 -DRKAIQ_HAVE_BAYERTNR_V30=1
17 -DRKAIQ_HAVE_BAYERTNR=1
18 -DRKAIQ_HAVE_GAIN_V2=1
19 -DRKAIQ_HAVE_GAIN=1
20 -DRKAIQ_HAVE_BLC_V32=1
21 -DRKAIQ_HAVE_BLC=1
22 -DRKAIQ_HAVE_YUVME_V1=1
23 -DRKAIQ_HAVE_YUVME=1
24 -DRKAIQ_HAVE_PDAF=1
25 -DRKAIQ_HAVE_3DLUT_V1=1
26 -DRKAIQ_HAVE_3DLUT=1
27 -DRKAIQ_HAVE_CCM_V3=1
28 -DRKAIQ_HAVE_CCM=1
29 -DRKAIQ_HAVE_GAMMA_V11=1
30 -DRKAIQ_HAVE_GAMMA=1
31 -DRKAIQ_HAVE_MERGE_V12=1
32 -DRKAIQ_HAVE_MERGE=1
33 -DRKAIQ_HAVE_DRC_V20=1
34 -DRKAIQ_HAVE_DRC=1
35 -DRKAIQ_HAVE_DEHAZE_V14=1
36 -DRKAIQ_HAVE_DEHAZE=1
37 -DRKAIQ_HAVE_RGBIR_REMOSAIC_V10=1
38 -DRKAIQ_HAVE_RGBIR_REMOSAIC=1
39 -DRKAIQ_HAVE_WDR_V1=1
40 -DRKAIQ_HAVE_WDR=1
41 -DRKAIQ_HAVE_LDCH_V21=1
42 -DRKAIQ_HAVE_LDCH=1
43 -DRKAIQ_HAVE_CSM_V1=1
44 -DRKAIQ_HAVE_CSM=1
45 -DRKAIQ_HAVE_CGC_V1=1
46 -DRKAIQ_HAVE_CGC=1
47 -DRKAIQ_HAVE_AE_V1=1
48 -DRKAIQ_HAVE_AE=1
49 -DRKAIQ_HAVE_AFD_V2=1
50 -DRKAIQ_HAVE_AFD=1
51 -DRKAIQ_HAVE_DEBAYER_V3=1
52 -DRKAIQ_HAVE_DEBAYER=1
53 -DRKAIQ_HAVE_LSC_V3=1
54 -DRKAIQ_HAVE_LSC=1
55 -DRKAIQ_HAVE_DPCC_V2=1
56 -DRKAIQ_HAVE_DPCC=1
57 -DRKAIQ_HAVE_ACP_V10=1
58 -DRKAIQ_HAVE_ACP=1
59 -DRKAIQ_HAVE_AIE_V10=1
60 -DRKAIQ_HAVE_AIE=1
61 -DRKAIQ_HAVE_AF=1
62 -DRKAIQ_HAVE_AF_V33=1
cflags size: 63
>>>>>>>>>>>>>>>>>>>>> rk3576
- 34
[hardware/rockchip/libgralloc/bifrost frameworks/native/include system/core/libsync system/core/libsync/include external/libdrm/include/drm] 34
hw_output_defaults HwOutputDefaultsFactory
hw_output_defaults getCflags
BOARD_USES_HWC_PROXY_SERVICE ret:
hw_output_defaults getSharedLibs
libpq enabled on RK3576
pq_init_defaults pqInitDefaults
libeptz disabled on RK3576
rk3576 WILL NOT COMPILE rkaiq_tool_server binary
librockx disabled on RK3576
19:50:17 soong bootstrap failed with: exit status 1
#### failed to build some targets (01:11:17 (hh:mm:ss)) ####
建议在ubuntu20.04 编译
应该是第三方app适配手机端选择竖屏显示,下载适配平板的app应该正常
现在早就没什么HD后缀的应用了
