从零开始~~~Firefly编译环境开荒贴
志摩千岁 发表于 2017-5-24 11:03
Export includes file: frameworks/base/tools/validatekeymaps/Android.mk – out/host/linux-x86/obj32/EXECUTABLES/validatekeymaps_intermediates/export_includes
Export includes file: build/libs/host/Android.mk – out/host/linux-x86/obj32/STATIC_LIBRARIES/libhost_intermediates/export_includes
Import includes file: out/host/linux-x86/obj32/STATIC_LIBRARIES/libhost_intermediates/import_includes
Export includes file: build/tools/acp/Android.mk – out/host/linux-x86/obj32/EXECUTABLES/acp_intermediates/export_includes
Notice file: system/core/libutils/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib64/libutils.a.txt
Notice file: system/core/libutils/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib/libutils.a.txt
Notice file: system/core/libcutils/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib64/libcutils.a.txt
Notice file: system/core/libcutils/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib/libcutils.a.txt
Notice file: system/core/liblog/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib64/liblog.a.txt
Notice file: system/core/liblog/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib/liblog.a.txt
host Java: antlr-runtime (out/host/common/obj/JAVA_LIBRARIES/antlr-runtime_intermediates/classes)
Notice file: external/antlr/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//framework/antlr-runtime.jar.txt
host Java: jsr305lib (out/host/common/obj/JAVA_LIBRARIES/jsr305lib_intermediates/classes)
Notice file: external/guava/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//framework/guavalib.jar.txt
host Java: tagsouplib (out/host/common/obj/JAVA_LIBRARIES/tagsouplib_intermediates/classes)
Notice file: external/doclava/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//framework/doclava.jar.txt
target Java: core-libart (out/target/common/obj/JAVA_LIBRARIES/core-libart_intermediates/classes)
Yacc: aidl <= frameworks/base/tools/aidl/aidl_language_y.y
prebuilts/misc/linux-x86/bison/bison -d -o out/host/linux-x86/obj32/EXECUTABLES/aidl_intermediates/aidl_language_y.cpp frameworks/base/tools/aidl/aidl_language_y.y
prebuilts/misc/linux-x86/bison/bison: m4 子进程失败
build/core/binary.mk:539: recipe for target ‘out/host/linux-x86/obj32/EXECUTABLES/aidl_intermediates/aidl_language_y.cpp’ failed
make: *** [out/host/linux-x86/obj32/EXECUTABLES/aidl_intermediates/aidl_language_y.cpp] Error 1
make: *** 正在等待未完成的任务…
Import includes file: out/host/linux-x86/obj32/EXECUTABLES/aidl_intermediates/import_includes
注: 某些输入文件使用了未经检查或不安全的操作。
注: 有关详细信息, 请使用 -Xlint:unchecked 重新编译。
注: 某些输入文件使用或覆盖了已过时的 API。
注: 有关详细信息, 请使用 -Xlint:deprecation 重新编译。
#### make failed to build some targets (01:29 (mm:ss)) ####
编译环境是最基础的,也有很多的参考资料,哪需要发那么多帖子
从头学起
楼主还在吗 能告诉我你的ubuntu安装步骤吗
谢谢版主~
jacky_shen 发表于 2017-5-16 06:43
楼主,我按照教程输入./java6.sh。然后终端输出如下:
gpg: 钥匙环‘/tmp/tmp2LzLUm/secring.gpg’已建立
应该是网络的选择问题,在设置里面找软件更新,下载自里面选择其他站点,然后选择最佳站点,选定。再重试一下。如果用的是企业或者学校的网,建议在其他环境下试试
初学者,学一下
好资料。给新手开了个传送门~~O(∩_∩)O~
感谢您的分享!!!
学习了,谢谢分享
666
自己搞了好久,在知道有脚本的。。。。顶顶
好贴
感谢分享,新手学习一下。
感谢分享
实用,多谢版主~~~~~~~~~~
楼主,我内核编译能成功,但是安卓编译的时候总是报错,请问是哪里的问题
新手必备,一步一步按照着来,方便快捷啊
还不错,很实用
{:4_89:}
