--- a/kernel/arch/arm64/configs/firefly_defconfig
+++ b/kernel/arch/arm64/configs/firefly_defconfig
@@ -48,7 +48,7 @@ CONFIG_PCI=y
CONFIG_PCI_MSI=y
CONFIG_PCIE_ROCKCHIP=y
CONFIG_PCIEPORTBUS=y
-# CONFIG_PCIEASPM is not set
+CONFIG_PCIEASPM_POWERSAVE=y
# CONFIG_ARM64_ERRATUM_826319 is not set
# CONFIG_ARM64_ERRATUM_827319 is not set
# CONFIG_ARM64_ERRATUM_824069 is not set
@@ -89,6 +89,7 @@ CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
+CONFIG_CPU_FREQ_GOV_SCHED=y
CONFIG_CPUFREQ_DT=y
CONFIG_ARM_ROCKCHIP_CPUFREQ=y
CONFIG_NET=y
@@ -354,6 +355,7 @@ CONFIG_USB_SIERRA_NET=y
# CONFIG_RTL_CARDS is not set
CONFIG_WL_ROCKCHIP=y
CONFIG_WIFI_BUILD_MODULE=y
+CONFIG_WIFI_LOAD_DRIVER_WHEN_KERNEL_BOOTUP=n
CONFIG_AP6XXX=m
CONFIG_RTL8188EU=m
CONFIG_RTL8188FU=m
# CONFIG_LOCALVERSION_AUTO is not set
# CONFIG_USELIB is not set
CONFIG_AUDIT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_LOG_BUF_SHIFT=19
CONFIG_CGROUPS=y
CONFIG_CGROUP_DEBUG=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CPUSETS=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_SCHEDTUNE=y
CONFIG_CGROUP_SCHED=y
CONFIG_RT_GROUP_SCHED=y
CONFIG_NAMESPACES=y
# CONFIG_UTS_NS is not set
# CONFIG_PID_NS is not set
CONFIG_SCHED_TUNE=y
CONFIG_DEFAULT_USE_ENERGY_AWARE=y
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
# CONFIG_RD_BZIP2 is not set
# CONFIG_RD_LZMA is not set
# CONFIG_RD_XZ is not set
# CONFIG_RD_LZO is not set
# CONFIG_RD_LZ4 is not set
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_KALLSYMS_ALL=y
# CONFIG_AIO is not set
CONFIG_EMBEDDED=y
# CONFIG_VM_EVENT_COUNTERS is not set
# CONFIG_SLUB_DEBUG is not set
CONFIG_PROFILING=y
CONFIG_JUMP_LABEL=y
CONFIG_CC_STACKPROTECTOR_STRONG=y
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_PARTITION_ADVANCED=y
CONFIG_CMDLINE_PARTITION=y
# CONFIG_IOSCHED_DEADLINE is not set
CONFIG_ARCH_ROCKCHIP=y
CONFIG_PCI=y
CONFIG_PCI_MSI=y
# CONFIG_ARM64_ERRATUM_819472 is not set
# CONFIG_ARM64_ERRATUM_832075 is not set
# CONFIG_CAVIUM_ERRATUM_22375 is not set
# CONFIG_CAVIUM_ERRATUM_23154 is not set
# CONFIG_CAVIUM_ERRATUM_27456 is not set
CONFIG_SCHED_MC=y
CONFIG_NR_CPUS=8
CONFIG_PREEMPT=y
CONFIG_HZ_300=y
CONFIG_KSM=y
CONFIG_CMA=y
CONFIG_ZSMALLOC=y
CONFIG_SECCOMP=y
CONFIG_ARMV8_DEPRECATED=y
CONFIG_SWP_EMULATION=y
CONFIG_CP15_BARRIER_EMULATION=y
CONFIG_SETEND_EMULATION=y
CONFIG_ARM64_SW_TTBR0_PAN=y
# CONFIG_EFI is not set
# CONFIG_COREDUMP is not set
CONFIG_COMPAT=y
CONFIG_PM_AUTOSLEEP=y
CONFIG_PM_WAKELOCKS=y
CONFIG_PM_WAKELOCKS_LIMIT=0
# CONFIG_PM_WAKELOCKS_GC is not set
CONFIG_PM_DEBUG=y
CONFIG_PM_ADVANCED_DEBUG=y
CONFIG_WQ_POWER_EFFICIENT_DEFAULT=y
CONFIG_CPU_IDLE=y
CONFIG_ARM_CPUIDLE=y
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_DEFAULT_GOV_INTERACTIVE=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPUFREQ_DT=y
CONFIG_NET=y
CONFIG_PACKET=y
CONFIG_UNIX=y
CONFIG_XFRM_USER=y
CONFIG_NET_KEY=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_SYN_COOKIES=y
CONFIG_INET_AH=y
CONFIG_INET_ESP=y
CONFIG_INET_IPCOMP=y
# CONFIG_INET_LRO is not set
CONFIG_INET_DIAG_DESTROY=y
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_IPV6_ROUTE_INFO=y
CONFIG_IPV6_OPTIMISTIC_DAD=y
CONFIG_INET6_AH=y
CONFIG_INET6_ESP=y
CONFIG_INET6_IPCOMP=y
CONFIG_IPV6_MIP6=y
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_IPV6_SUBTREES=y
CONFIG_NETFILTER=y
CONFIG_BRIDGE_NETFILTER=y
CONFIG_NF_CONNTRACK=y
CONFIG_NF_CONNTRACK_SECMARK=y
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_CT_PROTO_DCCP=y
CONFIG_NF_CT_PROTO_SCTP=y
CONFIG_NF_CT_PROTO_UDPLITE=y
CONFIG_NF_CONNTRACK_AMANDA=y
CONFIG_NF_CONNTRACK_FTP=y
CONFIG_NF_CONNTRACK_H323=y
CONFIG_NF_CONNTRACK_IRC=y
CONFIG_NF_CONNTRACK_NETBIOS_NS=y
CONFIG_NF_CONNTRACK_PPTP=y
CONFIG_NF_CONNTRACK_SANE=y
CONFIG_NF_CONNTRACK_TFTP=y
CONFIG_NF_CT_NETLINK=y
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=y
CONFIG_NETFILTER_XT_TARGET_CONNMARK=y
CONFIG_NETFILTER_XT_TARGET_CONNSECMARK=y
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=y
CONFIG_NETFILTER_XT_TARGET_LOG=y
CONFIG_NETFILTER_XT_TARGET_MARK=y
CONFIG_NETFILTER_XT_TARGET_NFLOG=y
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=y
CONFIG_NETFILTER_XT_TARGET_TPROXY=y
CONFIG_NETFILTER_XT_TARGET_TRACE=y
CONFIG_NETFILTER_XT_TARGET_SECMARK=y
CONFIG_NETFILTER_XT_TARGET_TCPMSS=y
CONFIG_NETFILTER_XT_MATCH_COMMENT=y
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=y
CONFIG_NETFILTER_XT_MATCH_CONNMARK=y
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=y
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=y
CONFIG_NETFILTER_XT_MATCH_HELPER=y
CONFIG_NETFILTER_XT_MATCH_IPRANGE=y
CONFIG_NETFILTER_XT_MATCH_LENGTH=y
CONFIG_NETFILTER_XT_MATCH_LIMIT=y
CONFIG_NETFILTER_XT_MATCH_MAC=y
CONFIG_NETFILTER_XT_MATCH_MARK=y
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=y
CONFIG_NETFILTER_XT_MATCH_POLICY=y
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=y
CONFIG_NETFILTER_XT_MATCH_QTAGUID=y
CONFIG_NETFILTER_XT_MATCH_QUOTA=y
CONFIG_NETFILTER_XT_MATCH_QUOTA2=y
CONFIG_NETFILTER_XT_MATCH_QUOTA2_LOG=y
CONFIG_NETFILTER_XT_MATCH_SOCKET=y
CONFIG_NETFILTER_XT_MATCH_STATE=y
CONFIG_NETFILTER_XT_MATCH_STATISTIC=y
CONFIG_NETFILTER_XT_MATCH_STRING=y
CONFIG_NETFILTER_XT_MATCH_TIME=y
CONFIG_NETFILTER_XT_MATCH_U32=y
CONFIG_NF_CONNTRACK_IPV4=y
CONFIG_IP_NF_IPTABLES=y
CONFIG_IP_NF_MATCH_AH=y
CONFIG_IP_NF_MATCH_ECN=y
CONFIG_IP_NF_MATCH_RPFILTER=y
CONFIG_IP_NF_MATCH_TTL=y
CONFIG_IP_NF_FILTER=y
CONFIG_IP_NF_TARGET_REJECT=y
CONFIG_IP_NF_NAT=y
CONFIG_IP_NF_TARGET_MASQUERADE=y
CONFIG_IP_NF_TARGET_NETMAP=y
CONFIG_IP_NF_TARGET_REDIRECT=y
CONFIG_IP_NF_MANGLE=y
CONFIG_IP_NF_RAW=y
CONFIG_IP_NF_SECURITY=y
CONFIG_IP_NF_ARPTABLES=y
CONFIG_IP_NF_ARPFILTER=y
CONFIG_IP_NF_ARP_MANGLE=y
CONFIG_NF_CONNTRACK_IPV6=y
CONFIG_IP6_NF_IPTABLES=y
CONFIG_IP6_NF_MATCH_RPFILTER=y
CONFIG_IP6_NF_FILTER=y
CONFIG_IP6_NF_TARGET_REJECT=y
CONFIG_IP6_NF_MANGLE=y
CONFIG_IP6_NF_RAW=y
CONFIG_IP6_NF_NAT=y
CONFIG_IP6_NF_TARGET_MASQUERADE=y
CONFIG_BRIDGE_NF_EBTABLES=y
CONFIG_BRIDGE_EBT_BROUTE=y
CONFIG_L2TP=y
CONFIG_BRIDGE=y
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_HTB=y
CONFIG_NET_SCH_PRIO=y
CONFIG_NET_CLS_FW=y
CONFIG_NET_CLS_U32=y
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_FLOW=y
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_CMP=y
CONFIG_NET_EMATCH_NBYTE=y
CONFIG_NET_EMATCH_U32=y
CONFIG_NET_EMATCH_META=y
CONFIG_NET_EMATCH_TEXT=y
CONFIG_NET_CLS_ACT=y
CONFIG_BT=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=y
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=y
CONFIG_BT_RTKBTUSB=y
CONFIG_BT_HCIUART=y
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_LL=y
CONFIG_RFKILL=y
CONFIG_DEVTMPFS=y
CONFIG_FW_LOADER_USER_HELPER_FALLBACK=y
CONFIG_DMA_CMA=y
CONFIG_ZRAM=y
CONFIG_ZRAM_LZ4_COMPRESS=y
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_SIZE=8192
CONFIG_BLK_DEV_NVME=y
CONFIG_ROCKCHIP_SCR=y
CONFIG_SRAM=y
CONFIG_UID_SYS_STATS=y
CONFIG_USB_CAM_GPIO=y
CONFIG_BLK_DEV_SD=y
CONFIG_CHR_DEV_SG=y
CONFIG_CHR_DEV_SCH=y
CONFIG_SCSI_CONSTANTS=y
CONFIG_SCSI_LOGGING=y
CONFIG_SCSI_SCAN_ASYNC=y
CONFIG_ATA=y
CONFIG_SATA_AHCI=y
CONFIG_SATA_AHCI_PLATFORM=y
CONFIG_AHCI_CEVA=y
CONFIG_ATA_GENERIC=y
CONFIG_MD=y
CONFIG_BLK_DEV_DM=y
CONFIG_DM_CRYPT=y
CONFIG_DM_UEVENT=y
CONFIG_DM_VERITY=y
CONFIG_DM_VERITY_FEC=y
CONFIG_NETDEVICES=y
CONFIG_TUN=y
# CONFIG_NET_VENDOR_3COM is not set
# CONFIG_NET_VENDOR_ADAPTEC is not set
# CONFIG_NET_VENDOR_AGERE is not set
# CONFIG_NET_VENDOR_ALTEON is not set
# CONFIG_NET_VENDOR_AMD is not set
# CONFIG_NET_VENDOR_ARC is not set
# CONFIG_NET_VENDOR_ATHEROS is not set
# CONFIG_NET_CADENCE is not set
# CONFIG_NET_VENDOR_BROADCOM is not set
# CONFIG_NET_VENDOR_BROCADE is not set
# CONFIG_NET_VENDOR_CAVIUM is not set
# CONFIG_NET_VENDOR_CHELSIO is not set
# CONFIG_NET_VENDOR_CISCO is not set
# CONFIG_NET_VENDOR_DEC is not set
# CONFIG_NET_VENDOR_DLINK is not set
# CONFIG_NET_VENDOR_EMULEX is not set
# CONFIG_NET_VENDOR_EZCHIP is not set
# CONFIG_NET_VENDOR_EXAR is not set
# CONFIG_NET_VENDOR_HISILICON is not set
# CONFIG_NET_VENDOR_HP is not set
# CONFIG_NET_VENDOR_INTEL is not set
# CONFIG_NET_VENDOR_MARVELL is not set
# CONFIG_NET_VENDOR_MELLANOX is not set
# CONFIG_NET_VENDOR_MICREL is not set
# CONFIG_NET_VENDOR_MICROCHIP is not set
# CONFIG_NET_VENDOR_MYRI is not set
# CONFIG_NET_VENDOR_NATSEMI is not set
# CONFIG_NET_VENDOR_NVIDIA is not set
# CONFIG_NET_VENDOR_OKI is not set
# CONFIG_NET_PACKET_ENGINE is not set
# CONFIG_NET_VENDOR_QLOGIC is not set
# CONFIG_NET_VENDOR_QUALCOMM is not set
# CONFIG_NET_VENDOR_REALTEK is not set
# CONFIG_NET_VENDOR_RENESAS is not set
# CONFIG_NET_VENDOR_RDC is not set
# CONFIG_NET_VENDOR_ROCKER is not set
# CONFIG_NET_VENDOR_SAMSUNG is not set
# CONFIG_NET_VENDOR_SEEQ is not set
# CONFIG_NET_VENDOR_SILAN is not set
# CONFIG_NET_VENDOR_SIS is not set
# CONFIG_NET_VENDOR_SMSC is not set
CONFIG_STMMAC_ETH=y
# CONFIG_DWMAC_GENERIC is not set
# CONFIG_NET_VENDOR_SUN is not set
# CONFIG_NET_VENDOR_SYNOPSYS is not set
# CONFIG_NET_VENDOR_TEHUTI is not set
# CONFIG_NET_VENDOR_TI is not set
# CONFIG_NET_VENDOR_VIA is not set
# CONFIG_NET_VENDOR_WIZNET is not set
CONFIG_ROCKCHIP_PHY=y
CONFIG_PPP=y
CONFIG_PPP_BSDCOMP=y
CONFIG_PPP_DEFLATE=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=y
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOE=y
CONFIG_PPPOL2TP=y
CONFIG_PPPOLAC=y
CONFIG_PPPOPNS=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
CONFIG_SLIP=y
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_MODE_SLIP6=y
CONFIG_USB_CATC=y
CONFIG_USB_KAWETH=y
CONFIG_USB_PEGASUS=y
CONFIG_USB_RTL8150=y
CONFIG_USB_RTL8152=y
CONFIG_USB_USBNET=y
CONFIG_USB_NET_CDC_EEM=y
CONFIG_USB_NET_CDC_MBIM=y
CONFIG_USB_NET_DM9601=y
CONFIG_USB_NET_SMSC75XX=y
CONFIG_USB_NET_SMSC95XX=y
CONFIG_USB_NET_GL620A=y
CONFIG_USB_NET_PLUSB=y
CONFIG_USB_NET_MCS7830=y
CONFIG_USB_NET_RNDIS_HOST=y
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_KC2190=y
CONFIG_USB_NET_CX82310_ETH=y
CONFIG_USB_NET_KALMIA=y
CONFIG_USB_NET_QMI_WWAN=y
CONFIG_USB_HSO=y
CONFIG_USB_NET_INT51X1=y
CONFIG_USB_IPHETH=y
CONFIG_AP6XXX=m
CONFIG_RTL8188EU=m
CONFIG_RTL8188FU=m
CONFIG_RTL8189ES=m
CONFIG_RTL8189FS=m
CONFIG_RTL8723BS=m
CONFIG_RTL8723BU=m
CONFIG_RTL8723CS=m
CONFIG_RTL8723DS=m
CONFIG_RTL8822BE=m
# CONFIG_INPUT_MOUSEDEV is not set
CONFIG_INPUT_EVDEV=y
CONFIG_INPUT_KEYRESET=y
# CONFIG_KEYBOARD_ATKBD is not set
CONFIG_KEYBOARD_ROCKCHIP=y
# CONFIG_INPUT_MOUSE is not set
CONFIG_INPUT_JOYSTICK=y
CONFIG_JOYSTICK_XPAD=y
CONFIG_JOYSTICK_XPAD_FF=y
CONFIG_JOYSTICK_XPAD_LEDS=y
CONFIG_INPUT_TABLET=y
CONFIG_TABLET_USB_ACECAD=y
CONFIG_TABLET_USB_AIPTEK=y
CONFIG_TABLET_USB_GTCO=y
CONFIG_TABLET_USB_HANWANG=y
CONFIG_TABLET_USB_KBTAB=y
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_GSLX680_VR=y
CONFIG_TOUCHSCREEN_GSL3673=y
CONFIG_TOUCHSCREEN_GT9XX=y
CONFIG_ROCKCHIP_REMOTECTL=y
CONFIG_ROCKCHIP_REMOTECTL_PWM=y
CONFIG_RK_IR_NO_DEEP_SLEEP=y
CONFIG_SENSOR_DEVICE=y
CONFIG_GSENSOR_DEVICE=y
CONFIG_GS_MC3230=y
CONFIG_HALL_DEVICE=y
CONFIG_HS_MH248=y
CONFIG_INPUT_MISC=y
CONFIG_INPUT_KEYCHORD=y
CONFIG_INPUT_UINPUT=y
CONFIG_INPUT_GPIO=y
# CONFIG_SERIO is not set
# CONFIG_VT is not set
# CONFIG_LEGACY_PTYS is not set
CONFIG_SERIAL_8250=y
# CONFIG_SERIAL_8250_DEPRECATED_OPTIONS is not set
CONFIG_SERIAL_8250_CONSOLE=y
# CONFIG_SERIAL_8250_PCI is not set
CONFIG_SERIAL_8250_NR_UARTS=5
CONFIG_SERIAL_8250_RUNTIME_UARTS=5
CONFIG_SERIAL_8250_DW=y
# CONFIG_HW_RANDOM is not set
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_GPIO=y
CONFIG_I2C_RK3X=y
CONFIG_SPI=y
CONFIG_SPI_ROCKCHIP=y
CONFIG_SPI_SPIDEV=y
CONFIG_SPI_WK2XXX=y
CONFIG_DEBUG_GPIO=y
CONFIG_GPIO_SYSFS=y
CONFIG_TEST_POWER=y
CONFIG_CHARGER_BQ25700=y
CONFIG_BATTERY_EC=y
CONFIG_BATTERY_CW2015=y
CONFIG_BATTERY_RK818=y
CONFIG_CHARGER_RK818=y
CONFIG_POWER_RESET_GPIO=y
CONFIG_SYSCON_REBOOT_MODE=y
CONFIG_POWER_AVS=y
CONFIG_ROCKCHIP_IODOMAIN=y
CONFIG_THERMAL=y
CONFIG_THERMAL_WRITABLE_TRIPS=y
CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR=y
CONFIG_THERMAL_GOV_FAIR_SHARE=y
CONFIG_THERMAL_GOV_STEP_WISE=y
CONFIG_THERMAL_GOV_USER_SPACE=y
CONFIG_CPU_THERMAL=y
CONFIG_DEVFREQ_THERMAL=y
CONFIG_ROCKCHIP_THERMAL=y
CONFIG_RK3368_THERMAL=y
CONFIG_WATCHDOG=y
CONFIG_DW_WATCHDOG=y
CONFIG_MFD_RK808=y
CONFIG_FUSB_30X=y
CONFIG_REGULATOR=y
CONFIG_REGULATOR_FIXED_VOLTAGE=y
CONFIG_REGULATOR_ACT8865=y
CONFIG_REGULATOR_FAN53555=y
CONFIG_REGULATOR_LP8752=y
CONFIG_REGULATOR_MP8865=y
CONFIG_REGULATOR_PWM=y
CONFIG_REGULATOR_RK808=y
CONFIG_REGULATOR_RK818=y
CONFIG_REGULATOR_XZ3216=y
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_RC_SUPPORT=y
CONFIG_MEDIA_CONTROLLER=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_MEDIA_USB_SUPPORT=y
CONFIG_USB_VIDEO_CLASS=y
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_CAMSYS_DRV=y
CONFIG_FLASHLIGHT=y
CONFIG_LEDS_RT8547=y
CONFIG_CAMSYS_MRV=y
CONFIG_ROCK_CHIP_SOC_CAMERA=y
CONFIG_ROCKCHIP_CAMERA_SENSOR_INTERFACE=y
CONFIG_RK30_CAMERA_ONEFRAME=y
# CONFIG_VGA_ARB is not set
CONFIG_DRM=y
CONFIG_DRM_LOAD_EDID_FIRMWARE=y
CONFIG_DRM_ROCKCHIP=y
CONFIG_ROCKCHIP_CDN_DP=y
CONFIG_ROCKCHIP_DW_HDMI=y
CONFIG_ROCKCHIP_DW_MIPI_DSI=y
CONFIG_ROCKCHIP_ANALOGIX_DP=y
CONFIG_ROCKCHIP_INNO_HDMI=y
CONFIG_ROCKCHIP_LVDS=y
CONFIG_ROCKCHIP_DRM_TVE=y
CONFIG_DRM_PANEL_SIMPLE=y
CONFIG_DRM_DW_HDMI_I2S_AUDIO=y
CONFIG_DRM_RK1000=y
CONFIG_MALI400=y
CONFIG_MALI450=y
# CONFIG_MALI400_PROFILING is not set
CONFIG_MALI_SHARED_INTERRUPTS=y
CONFIG_MALI_DT=y
CONFIG_MALI_DEVFREQ=y
CONFIG_MALI_MIDGARD=y
CONFIG_MALI_EXPERT=y
CONFIG_MALI_PLATFORM_THIRDPARTY=y
CONFIG_MALI_PLATFORM_THIRDPARTY_NAME="rk"
CONFIG_MALI_DEBUG=y
CONFIG_BACKLIGHT_LCD_SUPPORT=y
# CONFIG_LCD_CLASS_DEVICE is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
# CONFIG_BACKLIGHT_GENERIC is not set
CONFIG_BACKLIGHT_PWM=y
CONFIG_FB_ROCKCHIP=y
CONFIG_LCDC_RK3368=y
CONFIG_LCDC_RK322X=y
CONFIG_LCDC_LITE_RK3X=y
CONFIG_LCD_MIPI=y
CONFIG_RK_TRSM=y
CONFIG_RK32_DP=y
# CONFIG_RK_VGA is not set
CONFIG_MIPI_DSI=y
CONFIG_RK32_MIPI_DSI=y
CONFIG_RK_HDMI=y
CONFIG_ROCKCHIP_RGA2=y
CONFIG_RK_VCODEC=y
CONFIG_IEP=y
CONFIG_ROCKCHIP_DP=y
CONFIG_LOGO=y
# CONFIG_LOGO_LINUX_MONO is not set
# CONFIG_LOGO_LINUX_VGA16 is not set
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_DYNAMIC_MINORS=y
# CONFIG_SND_SUPPORT_OLD_API is not set
CONFIG_SND_VERBOSE_PRINTK=y
# CONFIG_SND_DRIVERS is not set
# CONFIG_SND_PCI is not set
# CONFIG_SND_SPI is not set
CONFIG_SND_USB_AUDIO=y
CONFIG_SND_SOC=y
CONFIG_SND_SOC_ROCKCHIP=y
CONFIG_SND_SOC_ROCKCHIP_SPDIF=y
CONFIG_SND_SOC_ROCKCHIP_HDMI_ANALOG=y
CONFIG_SND_SOC_ROCKCHIP_HDMI_DP=y
CONFIG_SND_SOC_ROCKCHIP_RT5651_TC358749=y
CONFIG_SND_SOC_ROCKCHIP_CDNDP=y
CONFIG_SND_SOC_CX2072X=y
CONFIG_SND_SOC_DW_HDMI_AUDIO=y
CONFIG_SND_SOC_BT_SCO=y
CONFIG_SND_SOC_ES8316=y
CONFIG_SND_SOC_RK3328=y
CONFIG_SND_SOC_SPDIF=y
CONFIG_SND_SIMPLE_CARD=y
CONFIG_HIDRAW=y
CONFIG_UHID=y
CONFIG_HID_A4TECH=y
CONFIG_HID_ACRUX=y
CONFIG_HID_ACRUX_FF=y
CONFIG_HID_APPLE=y
CONFIG_HID_APPLEIR=y
CONFIG_HID_AUREAL=y
CONFIG_HID_BELKIN=y
CONFIG_HID_CHERRY=y
CONFIG_HID_CHICONY=y
CONFIG_HID_PRODIKEYS=y
CONFIG_HID_CYPRESS=y
CONFIG_HID_DRAGONRISE=y
CONFIG_DRAGONRISE_FF=y
CONFIG_HID_EMS_FF=y
CONFIG_HID_ELECOM=y
CONFIG_HID_EZKEY=y
CONFIG_HID_HOLTEK=y
CONFIG_HID_KEYTOUCH=y
CONFIG_HID_KYE=y
CONFIG_HID_UCLOGIC=y
CONFIG_HID_WALTOP=y
CONFIG_HID_GYRATION=y
CONFIG_HID_ICADE=y
CONFIG_HID_TWINHAN=y
CONFIG_HID_KENSINGTON=y
CONFIG_HID_LCPOWER=y
CONFIG_HID_LENOVO=y
CONFIG_HID_LOGITECH=y
CONFIG_HID_LOGITECH_DJ=y
CONFIG_LOGITECH_FF=y
CONFIG_LOGIRUMBLEPAD2_FF=y
CONFIG_LOGIG940_FF=y
CONFIG_HID_MAGICMOUSE=y
CONFIG_HID_MICROSOFT=y
CONFIG_HID_MONTEREY=y
CONFIG_HID_MULTITOUCH=y
CONFIG_HID_NTRIG=y
CONFIG_HID_ORTEK=y
CONFIG_HID_PANTHERLORD=y
CONFIG_PANTHERLORD_FF=y
CONFIG_HID_PETALYNX=y
CONFIG_HID_PICOLCD=y
CONFIG_HID_PRIMAX=y
CONFIG_HID_ROCCAT=y
CONFIG_HID_SAITEK=y
CONFIG_HID_SAMSUNG=y
CONFIG_HID_SONY=y
CONFIG_HID_SPEEDLINK=y
CONFIG_HID_STEELSERIES=y
CONFIG_HID_SUNPLUS=y
CONFIG_HID_GREENASIA=y
CONFIG_GREENASIA_FF=y
CONFIG_HID_SMARTJOYPLUS=y
CONFIG_SMARTJOYPLUS_FF=y
CONFIG_HID_TIVO=y
CONFIG_HID_TOPSEED=y
CONFIG_HID_THINGM=y
CONFIG_HID_THRUSTMASTER=y
CONFIG_HID_WACOM=y
CONFIG_HID_WIIMOTE=y
CONFIG_HID_ZEROPLUS=y
CONFIG_HID_ZYDACRON=y
CONFIG_HID_RKVR=y
CONFIG_HID_ALPS=y
CONFIG_USB_HIDDEV=y
CONFIG_I2C_HID=y
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
CONFIG_USB_XHCI_HCD=y
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_HCD_PLATFORM=y
CONFIG_USB_OHCI_HCD=y
# CONFIG_USB_OHCI_HCD_PCI is not set
CONFIG_USB_OHCI_HCD_PLATFORM=y
CONFIG_USB_ACM=y
CONFIG_USB_PRINTER=y
CONFIG_USB_STORAGE=y
CONFIG_USB_STORAGE_DATAFAB=y
CONFIG_USB_STORAGE_FREECOM=y
CONFIG_USB_STORAGE_ISD200=y
CONFIG_USB_STORAGE_USBAT=y
CONFIG_USB_STORAGE_SDDR09=y
CONFIG_USB_STORAGE_SDDR55=y
CONFIG_USB_STORAGE_JUMPSHOT=y
CONFIG_USB_STORAGE_ALAUDA=y
CONFIG_USB_STORAGE_ONETOUCH=y
CONFIG_USB_STORAGE_KARMA=y
CONFIG_USB_STORAGE_CYPRESS_ATACB=y
CONFIG_USB_STORAGE_ENE_UB6250=y
CONFIG_USB_UAS=y
CONFIG_USB_DWC3=y
# CONFIG_USB_DWC3_PCI is not set
CONFIG_USB_SERIAL=y
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_CH341=y
CONFIG_USB_SERIAL_CP210X=y
CONFIG_USB_SERIAL_PL2303=y
CONFIG_USB_SERIAL_OPTION=y
CONFIG_USB_TRANCEVIBRATOR=y
CONFIG_USB_OTG_WAKELOCK=y
CONFIG_USB_GADGET=y
CONFIG_USB_GADGET_DEBUG_FILES=y
CONFIG_USB_GADGET_VBUS_DRAW=500
CONFIG_USB_CONFIGFS=y
CONFIG_USB_CONFIGFS_ACM=y
CONFIG_USB_CONFIGFS_RNDIS=y
CONFIG_USB_CONFIGFS_MASS_STORAGE=y
CONFIG_USB_CONFIGFS_F_FS=y
CONFIG_USB_CONFIGFS_F_MTP=y
CONFIG_USB_CONFIGFS_F_PTP=y
CONFIG_USB_CONFIGFS_F_ACC=y
CONFIG_USB_CONFIGFS_F_AUDIO_SRC=y
CONFIG_USB_CONFIGFS_UEVENT=y
CONFIG_USB_CONFIGFS_F_MIDI=y
CONFIG_USB20_HOST=y
CONFIG_USB20_OTG=y
CONFIG_MMC=y
CONFIG_MMC_BLOCK_MINORS=32
# CONFIG_MMC_BLOCK_BOUNCE is not set
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_OF_ARASAN=y
CONFIG_MMC_DW=y
CONFIG_MMC_DW_ROCKCHIP=y
CONFIG_LEDS_GPIO=y
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_BACKLIGHT=y
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
CONFIG_SWITCH=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_DRV_RK808=y
CONFIG_DMADEVICES=y
CONFIG_PL330_DMA=y
CONFIG_STAGING=y
CONFIG_INV_MPU_IIO=y
CONFIG_ASHMEM=y
CONFIG_ANDROID_TIMED_GPIO=y
CONFIG_ANDROID_LOW_MEMORY_KILLER=y
CONFIG_SYNC=y
CONFIG_SW_SYNC=y
CONFIG_SW_SYNC_USER=y
CONFIG_ION=y
CONFIG_ION_ROCKCHIP=y
CONFIG_FIQ_DEBUGGER=y
CONFIG_FIQ_DEBUGGER_NO_SLEEP=y
CONFIG_FIQ_DEBUGGER_CONSOLE=y
CONFIG_FIQ_DEBUGGER_CONSOLE_DEFAULT_ENABLE=y
CONFIG_FIQ_DEBUGGER_TRUST_ZONE=y
CONFIG_RK_CONSOLE_THREAD=y
CONFIG_POWERVR_ROGUE_N=y
CONFIG_COMMON_CLK_RK808=y
# CONFIG_COMMON_CLK_XGENE is not set
CONFIG_COMMON_CLK_PWM=y
CONFIG_MAILBOX=y
CONFIG_RK3368_MBOX=y
CONFIG_RK3368_SCPI_PROTOCOL=y
CONFIG_ROCKCHIP_IOMMU=y
CONFIG_RK_IOMMU=y
CONFIG_RK_IOVMM=y
CONFIG_ROCKCHIP_PM_DOMAINS=y
CONFIG_ROCKCHIP_PVTM=y
CONFIG_ROCKCHIP_SUSPEND_MODE=y
CONFIG_PM_DEVFREQ=y
CONFIG_DEVFREQ_GOV_PERFORMANCE=y
CONFIG_DEVFREQ_GOV_POWERSAVE=y
CONFIG_DEVFREQ_GOV_USERSPACE=y
CONFIG_ARM_ROCKCHIP_DMC_DEVFREQ=y
CONFIG_PM_DEVFREQ_EVENT=y
CONFIG_IIO=y
CONFIG_IIO_BUFFER=y
CONFIG_IIO_BUFFER_CB=y
CONFIG_IIO_KFIFO_BUF=y
CONFIG_IIO_TRIGGER=y
CONFIG_ROCKCHIP_SARADC=y
CONFIG_PWM=y
CONFIG_PWM_ROCKCHIP=y
CONFIG_PHY_ROCKCHIP_USB=y
CONFIG_PHY_ROCKCHIP_INNO_USB2=y
CONFIG_PHY_ROCKCHIP_EMMC=y
CONFIG_PHY_ROCKCHIP_DP=y
CONFIG_PHY_ROCKCHIP_INNO_MIPI_DPHY=y
CONFIG_PHY_ROCKCHIP_INNO_HDMI_PHY=y
CONFIG_PHY_ROCKCHIP_TYPEC=y
CONFIG_PHY_ROCKCHIP_PCIE=y
CONFIG_ANDROID=y
CONFIG_ANDROID_BINDER_IPC=y
CONFIG_NVMEM=y
CONFIG_ROCKCHIP_EFUSE=y
CONFIG_RK_NAND=y
CONFIG_RK_HEADSET=y
CONFIG_ROCKCHIP_SIP=y
# CONFIG_ACPI is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_FS_SECURITY=y
CONFIG_F2FS_FS=y
# CONFIG_F2FS_FS_POSIX_ACL is not set
CONFIG_F2FS_FS_SECURITY=y
CONFIG_QUOTA=y
CONFIG_QUOTA_NETLINK_INTERFACE=y
CONFIG_QFMT_V2=y
CONFIG_FUSE_FS=y
CONFIG_ISO9660_FS=y
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_UDF_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_PSTORE=y
CONFIG_PSTORE_CONSOLE=y
CONFIG_PSTORE_PMSG=y
CONFIG_PSTORE_RAM=y
CONFIG_CIFS=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
# CONFIG_CIFS_DEBUG is not set
CONFIG_NLS_CODEPAGE_437=y
CONFIG_NLS_ASCII=y
CONFIG_NLS_ISO8859_1=y
CONFIG_NLS_UTF8=y
CONFIG_PRINTK_TIME=y
CONFIG_DEBUG_INFO=y
CONFIG_MAGIC_SYSRQ=y
CONFIG_LOCKUP_DETECTOR=y
CONFIG_DEFAULT_HUNG_TASK_TIMEOUT=10
CONFIG_PANIC_TIMEOUT=5
CONFIG_SCHEDSTATS=y
CONFIG_TIMER_STATS=y
# CONFIG_DEBUG_PREEMPT is not set
CONFIG_ENABLE_DEFAULT_TRACERS=y
CONFIG_KEYS=y
CONFIG_SECURITY_PERF_EVENTS_RESTRICT=y
CONFIG_SECURITY=y
CONFIG_SECURITY_NETWORK=y
CONFIG_LSM_MMAP_MIN_ADDR=4096
CONFIG_HARDENED_USERCOPY=y
CONFIG_SECURITY_SELINUX=y
CONFIG_TEE_SUPPORT=y
CONFIG_CRYPTO_ECHAINIV=y
CONFIG_CRYPTO_SHA512=y
CONFIG_CRYPTO_TWOFISH=y
CONFIG_CRYPTO_ANSI_CPRNG=y
CONFIG_ARM64_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM64_CE=y
CONFIG_CRYPTO_SHA2_ARM64_CE=y
CONFIG_CRYPTO_GHASH_ARM64_CE=y
CONFIG_CRYPTO_AES_ARM64_CE_CCM=y
CONFIG_CRYPTO_AES_ARM64_CE_BLK=y
然后设备adb进去后也存在system/lib/modules/bcmdhd.ko文件:
rk3399_firefly_aioc_lvds_box:/system/lib/modules $ ls
8188eu.ko 8189fs.ko 8723cs.ko bcmdhd.ko rk29-ipp.ko.3.0.101+
8188fu.ko 8723bs.ko 8723ds.ko readme.txt rk29-ipp.ko.3.0.36+
8189es.ko 8723bu.ko 8822be.ko rk29-ipp.ko
du -sch bcmdhd.ko
15M bcmdhd.ko
15M total
md5sum bcmdhd.ko
1f8a3f75c5e464766864a1790411a849 bcmdhd.ko
