wind020 发表于 2023-7-6 15:42
我使用这个dtsi,也卡住了。定位不到是哪出的问题,有没有思路。
我的问题和你一样,你的解决了吗?
我的问题和你一样,你的解决了吗?
怎么看到的一说自己解决了就没下文了呢?
研究。研究 感谢
同样遇到这种现象,刚开始还以为是电路问题。
多重启几次,每次都卡在这里,可能还有其他问题吧。
感谢感谢。
同样卡住,不知道报啥错
[ 5.109270] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 5.109983] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.114972] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 5.115680] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 5.116531] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.117601] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 5.118009] rockchip-suspend not set sleep-mode-config for mem-lite
[ 5.118015] rockchip-suspend not set wakeup-config for mem-lite
[ 5.118022] rockchip-suspend not set sleep-mode-config for mem-ultra
[ 5.118027] rockchip-suspend not set wakeup-config for mem-ultra
[ 5.118934] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘19:25:12’, on ‘May 17 2024’.
[ 5.119298] Mali:
[ 5.119300] Mali device driver loaded
[ 5.119315] rkisp rkisp0-vir2: clear unready subdev num: 1
[ 5.119421] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.119429] cfg80211: failed to load regulatory.db
[ 5.119626] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 5.121152] rkisp rkisp1-vir0: clear unready subdev num: 1
[ 5.124348] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
v 5.124771]
[ 5.127226] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 5.127663] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
感谢分享!
感谢大神
收到谢谢
谢谢收到
看看大佬发言
3588Q能用吗
3588Q能用吗
看看
u99081582503439 发表于 2026-7-4 13:40
3588Q能用吗
可以的,参考这个demo文件改一下就行
