Px30音频无法播放
SDK包名称:px30_linux_release_20210304
SDK修改内容:无修改
Log日志:命令提示符 - adb shell.txt
官网下载px30_linux_release_20210304,同步命令,编译之后使用 aplay 672f48fd5c318.wav 内核会有异常打印,一点声音都没有。设备树没有改动。
[root@px30_64:/]# dmesg | grep -iE ‘rk809|sound|rockchip,rk809-codec’
[ 0.388634] Advanced Linux Sound Architecture Driver Initialized.
[ 2.510196] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,hp-det-gpio’ property of node ‘/rk809-sound[0]’
[ 2.510216] of_get_named_gpiod_flags: can’t parse ‘simple-audio-card,mic-det-gpio’ property of node ‘/rk809-sound[0]’
[ 2.516214] asoc-simple-card rk809-sound: rk817-hifi ↔ ff070000.i2s mapping ok
[ 2.516923] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 2.517633] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 2.518492] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 2.519174] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 2.519973] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 2.520649] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 2.521533] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 2.522260] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 3.612226] #0: rockchip,rk809-codec
[root@px30_64:/]#
内核 COMMITID: a24d398f774fcfaf0f722006aa13e9fce3322a64
不知道是否是更新步骤有问题,更新代码步骤如下:
hsychips02@hsy:~/linjunqin/px30_linux_release_20210304/px30_linux_release_20210304$ .repo/repo/repo sync -l
warning: Python 3 support is currently experimental. YMMV.
Please use Python 2.6 - 2.7 instead.
/home/hsychips02/linjunqin/px30_linux_release_20210304/px30_linux_release_20210304/.repo/repo/main.py:19: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module’s documentation for alternative uses
import imp
hsychips02@hsy:~/linjunqin/px30_linux_release_20210304/px30_linux_release_20210304$ .repo/repo/repo sync -c --no-tags
import imp
Fetching project docs-soc_internal
Fetching project external/chromium
Fetching project kernel
Fetching project buildroot-dl
Fetching project external/libmali
Fetching project external/bluetooth_bsa
Fetching project tools
Fetching project device/rockchip
Fetching project external/app
Fetching project external/common_algorithm
Fetching project prebuilts/gcc/linux-x86/aarch64/gcc-buildroot-9.3.0-2020.03-x86_64_aarch64-rockchip-linux-gnu
Fetching project external/libglCompositor
Fetching project prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf
Fetching project external/minilogger
Fetching project external/tensorflow
Fetching project u-boot
Fetching project external/wifiAutoSetup
Fetching project external/rkupdate
Fetching project external/security/bin
Fetching project external/rkwifibt
Fetching project external/minigui_desktop
Fetching project rkbin
Fetching project external/security/rk_tee_user
Fetching project external/linux-rga
Fetching project external/mpp
Fetching project app/qcamera
Fetching project external/eq_drc_process
Fetching project prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu
Fetching project external/update_engine
Fetching project external/broadcom_bsa
Fetching project app/multivideoplayer
Fetching project external/deviceio_release
Fetching project app/QLauncher
Fetching project app/aiserver
Fetching project external/camera_engine_rkisp
Fetching project external/uac_app
Fetching project external/gstreamer-rockchip
Fetching project external/rktoolkit
Fetching project external/recovery
Fetching project external/quectel-cm
Fetching project external/pcba_adb_test
Fetching project external/rtc_demo
Fetching project app/qplayer
Fetching project external/rk_pcba_test
Fetching project external/alsa-config
Fetching project app/qfm
Fetching project external/avb
Fetching project app/qsetting
Fetching project external/rkscript
Fetching project external/bluez-alsa
Fetching project external/softapDemo
info: A new version of repo is available
warning: project ‘repo’ branch ‘stable’ is not signed
warning: Skipped upgrade to unverified version
hsychips02@hsy:~/linjunqin/px30_linux_release_20210304/px30_linux_release_20210304$ .repo/repo/repo start firefly --all
import imp
命令提示符 - adb shell.txt (74.5 KB)
