按官方执行 .repo/repo/repo sync -c --no-tags 报错
固件文件名称:ITX-3588J_Buildroot_v1.1.1e_231031
固件下载地址:ITX-3588J_Buildroot_v1.1.1e_231031
Log日志:fireflyerr.rar
按照官方步骤进行解压、导出数据以及同步数,步骤如下:
步骤记录
#解压
cat rk3588_linux_release_20230114_v1.0.6c_0* | tar -xv
#导出数据
.repo/repo/repo sync -l
# 进入 SDK 根目录
cd rk3588_sdk
# 同步
.repo/repo/repo start firefly --all
在执行上述“同步”步骤: .repo/repo/repo sync -c --no-tags,会提示出错,具体信息如下:
Fetching project yocto/meta-browser
Fetching project external/camera_engine_rkaiq
Fetching project external/rkwifibt
Fetching project external/mpp
Fetching project external/linux-rga
Fetching project external/gstreamer-rockchip
Fetching project docs-soc_internal-en
Fetching project external/dpdk
Fetching project external/security/librkcrypto
Fetching project tools
Fetching project external/drm-cursor
Fetching project external/uac_app
Fetching project device/rockchip
Fetching project app/rkadk
Fetching project app/multivideoplayer
Fetching project prebuilts/gcc/linux-x86/arm/gcc-arm-10.3-2021.07-x86_64-arm-none-linux-gnueabihf
Fetching project external/rkscript
警告:重定向到 https://gitlab.com/firefly-linux/device/rockchip.git/
Fetching projects: 100% (55/55), done.
info: A new version of repo is available
warning: project ‘repo’ branch ‘default’ is not signed
warning: Skipped upgrade to unverified version
error: Cannot remove project “docs/.Socs”: uncommitted changes are present
commit changes, then run sync again
请问各位大伽,如何解决上述错误,感谢。
fireflyerr.rar (899 Bytes)
补充一下
1、多次执行 .repo/repo/repo sync -c --no-tags,依然提示相同错误;
2、执行同步前,没有修改源文件;
arvin_fresh 发表于 2024-10-18 10:57
补充一下
2、执行同步前,没有修改 …
删除docs/.Socs 目录看看
dengkx 发表于 2024-10-18 16:28
删除docs/.Socs 目录看看
原先的错误过了,但出现新的错误(如下),请问这是什么问题,怎么让其正常执行成功
警告:重定向到 h …
出现该警告信息后,去查看buildroot目录,发现其文件目录大小仅不到200M,且在<rk3588_sdk_root_dir>目录下执行./build.sh buildroot会提示错误
make: Leaving directory ‘/home/work/3358/sdk/rk3588_firefly/buildroot’
Done in 0s (error code: 1)
Failed to build /home/work/3358/sdk/rk3588_firefly/buildroot/output/firefly_rk3588/.config:
2024-10-21T14:21:10 can’t find package Expect
2024-10-21T14:21:10 while executing
2024-10-21T14:21:10 “package require Expect”
2024-10-21T14:21:10 (file “/usr/bin/unbuffer” line 6)
Please check details in /home/work/3358/sdk/rk3588_firefly/.buildroot/br.log
you take 0:04.57 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 1376:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $RK_CFG_BUILDROOT $DST_DIR
