Rk3588-rt-v1.1
Type: Self-Compiled Firmware
SDK Package Name: Buildroot Linux SDK
Modification Content: make menuconfig
Log: log.zip
I have setup full sdk on our ubuntu18 system. I able to compile provided standard buildroot config. When I am trying to customise buildroot config via /buildroot/make menuconfig
Than saving config and executing ./build.sh
to create custom buildroot I constantly getting errors below:
# merged configuration written to /workspace/proj/rk3588_sdk/
firefly_rk3588_SDK/buildroot/output/firefly_rk3588/.config.in (needs make)
BR2_DEFCONFIG=‘’ KCONFIG_AUTOCONFIG=/workspace/
proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/build/buildroot-config/tristate.config BR2_CONFIG=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/.config HOST_GCC_VERSION=“7” BASE_DIR=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588 SKIP_LEGACY= CUSTOM_KERNEL_VERSION=“5.10” BR2_DEFCONFIG=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/configs/firefly_rk3588_defconfig /workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/build/buildroot-config/conf --defconfig=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/.config.in Config.in
# configuration written to /workspace/proj/rk3588_sdk/
make: Leaving directory '/workspace/proj/rk3588_sdk/
firefly_rk3588_SDK/buildroot’
450c450
< BR2_TARGET_GENERIC_ISSUE="
[i]Welcome to test RK3588 Buildroot"
BR2_TARGET_GENERIC_ISSUE="[/i]Welcome to RK3588 Buildroot"
467c467
< BR2_TARGET_GENERIC_ROOT_
[i]PASSWD=“root”
BR2_TARGET_GENERIC_ROOT_[/i]PASSWD=“firefly”
Found old config, override it? (y/n):Command exited with non-zero status 142
you take 0:11.35 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 142 from line 1378:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $RK_CFG_BUILDROOT $DST_DIR
root@57bea03ddf96:/workspace/
proj/rk3588_sdk/firefly_rk3588_SDK#
log.zip (539 Bytes)
