Rv1126 运行算法提示打开设备失败
固件文件名称:rv1126_rv1109_linux_20210904.xml
固件下载地址:买的时候自带的
Log日志:0110.log
启动算法后报错,打开设备失败,昨天开始出现的。
Load stream: rtsp://192.168.0.85:554/stream1
–>loading model
loading model done
→ Init runtime environment
librknn_runtime version 1.7.1 (97198ce build: 2021-11-24 09:34:01 base: 1131)
[ 1] Failed to open device: No such file or directory, Try again…
[ 2] Failed to open device: No such file or directory, Try again…
[ 3] Failed to open device: No such file or directory, Try again…
[ 4] Failed to open device: No such file or directory, Try again…
[ 5] _OpenDevice(1091): FATAL: Failed to open device, errno=No such file or directory.
0110.log (67.7 KB)
算法是基于yolo5的
刷机了,依然报这个错
root 用户再跑一下试试看
板子上跑 rknn_server 程序了吗?
