rk3399 linux掉电开关机,概率出现系统无法启动的问题
开机log
Model: Rockchip RK3399 EVB IND LPDDR4 Board edp (Linux)
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Not AVB images, AVB skip
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 16989 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
rktest emmc 报错:
=> rktest emmc
switch to partitions #0, OK
MMC0 RW sectors on userdata 0x0020c000 - 0x0021c000(size: 32 MiB) for 4 round
Sysmem Error: “storage_w” (0x00000002 - 0x02000002) alloc is overlap with existence “KERNEL” (0x0027f800 - 0x01317204)
sysmem_dump_all:
memory.rgn[0].addr = 0x00200000 - 0x08400000 (size: 0x08200000)
memory.rgn[1].addr = 0x0a200000 - 0x80000000 (size: 0x75e00000)
memory.total = 0x7e000000 (2016 MiB. 0 KiB)
allocated.rgn[0].name = "UBOOT"
.addr = 0x7bdbd340 - 0x80000000 (size: 0x04242cc0)
allocated.rgn[1].name = "STACK"
.addr = 0x7bbbd340 - 0x7bdbd340 (size: 0x00200000)
allocated.rgn[2].name = "FDT"
.addr = 0x08300000 - 0x0831d404 (size: 0x0001d404)
allocated.rgn[3].name = "KERNEL"
.addr = 0x0027f800 - 0x01317204 (size: 0x01097a04)
kmem-resv.rgn[0].name = "ramoops@110000"
.addr = 0x00110000 - 0x00200000 (size: 0x000f0000)
framework malloc_r = 32 MiB
framework malloc_f = 16 KiB
allocated.total = 0x055e7ac8 (85 MiB. 926 KiB)
LMB.allocated[0].addr = 0x0027f800 - 0x01317204 (size: 0x01097a04)
LMB.allocated[1].addr = 0x08300000 - 0x0831d404 (size: 0x0001d404)
LMB.allocated[2].addr = 0x7bbbd340 - 0x80000000 (size: 0x04442cc0)
reserved.core.total = 0x054f7ac8 (84 MiB. 990 KiB)
[UT-ERROR]: MMC0: no sysmem for w_buf
### [emmc] test done, result: ..
exit not allowed from main input shell.
sysmem_dump:
=> sysmem_dump
sysmem_dump_all:
