roc-rk3566-pc openwrt不能操作wifi进行扫描和创建热点
root@OpenWrt:/#
root@OpenWrt:/# ff_wifi down
[ 506.476663] [dhd-wlan0] wl_iw_event : Link Down with 08:e9:f6:38:af:18, reason=4
[ 506.476721] [dhd-wlan0] wl_ext_iapsta_event : [A] Link down, reason=4
[ 506.477757] [wlan0] tx queue stopped
[ 506.477791] dhd_stop: Enter wlan0
[ 506.477804] dhd_stop: ######### dhd_stop called for ifidx=0 #########
[ 506.477820] dhd_stop: making dhdpub up FALSE
[ 506.479175] [dhd] CFGP2P-ERROR) wl_cfgp2p_disable_discovery : do nothing, not initialized
[ 506.479223] dhd_tcpack_suppress_set 382: already set to 0
[ 506.479249] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=1, on_failure=1
[ 506.480567] dhd_dbg_detach_pkt_monitor, 2100
[ 506.480592] dhd_bus_devreset: == Power OFF ==
[ 506.480813] dhd_bus_stop: making DHD_BUS_DOWN
[ 506.480868] bcmsdh_oob_intr_unregister: Enter
[ 506.480903] dhd_bus_devreset: making dhdpub up FALSE
[ 506.480922] dhd_txglom_enable: enable 0
[ 506.480935] dhd_bus_devreset: making DHD_BUS_DOWN
[ 506.480948] dhd_bus_devreset: WLAN OFF DONE
[ 506.481015] wifi_platform_set_power = 0, delay: 0 msec
[ 506.481035] ======== PULL WL_REG_ON(-1) LOW! ========
[ 506.481047] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 506.481072] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 506.481085] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 506.481096] [dhd-wlan0] wl_android_wifi_off : out
[ 506.523901] dhd_stop: Exit wlan0
[ 506.524291] br-lan: port 1(wlan0) entered disabled state
[ 506.526125] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
root@OpenWrt:/# [ 506.550697] device wlan0 left promiscuous mode
[ 506.550819] br-lan: port 1(wlan0) entered disabled state
[ 506.585180] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 506.585654] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
root@OpenWrt:/# ff_wifi set sta TP_3ECE 111222333
root@OpenWrt:/#
root@OpenWrt:/# ff_wifi set sta on
root@OpenWrt:/# ff_wifi up
[ 567.172686] dhd_open: Enter wlan0
[ 567.172742] dhd_open : no mutex held. set lock
[ 567.172758]
[ 567.172758] Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 567.172779] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 567.172788] wifi_platform_set_power = 1, delay: 200 msec
[ 567.172799] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 567.172820] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 567.172829] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 567.172842] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 567.477196] sdio_reset_comm():
[ 567.492867] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 567.509807] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 100000Hz, actual 93750HZ div = 2)
[ 567.562031] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 567.568606] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 567.575319] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 567.587108] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 567.600877] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 567.958611] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 567.958801] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 567.959030] sdioh_start: set sd_f2_blocksize 256
[ 567.959690]
[ 567.959690]
[ 567.959690] dhd_bus_devreset: == Power ON ==
[ 567.959958] F1 signature read @0x18000000=0x1541a9a6
[ 567.965183] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 567.966231] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 567.966384] dhd_bus_devreset: making DHD_BUS_DOWN
[ 567.966448] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 567.966699] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 567.966726] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43438a1.bin
[ 567.966739] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram.txt
[ 567.966750] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43438a1.blob
[ 567.966757] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 567.967639] dhd_os_open_image1: /vendor/etc/firmware/fw_bcm43438a1.bin (414579 bytes) open success
[ 568.026095] dhd_os_open_image1: /vendor/etc/firmware/nvram.txt (2840 bytes) open success
[ 568.026147] NVRAM version: AP6356S_NVRAM_V1.2_20170331
[ 568.027008] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 568.145067] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 568.145179] bcmsdh_oob_intr_register: HW_OOB irq=102 flags=0x4
[ 568.146278] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 568.146295] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 568.146643] dhd_tcpack_suppress_set 382: already set to 0
[ 568.147436] dhd_apply_default_clm: Ignore clm file /vendor/etc/firmware/clm_bcm43438a1.blob
[ 568.150786] Firmware up: op_mode=0x0005, MAC=08:e9:f6:38:af:18
[ 568.151565] Disable tdls_auto_op failed. -1
[ 568.154752] dhd_preinit_ioctls Set scancache failed -23
[ 568.155788] dhd_preinit_ioctls: event_log_max_sets: 26 ret: -23
[ 568.169915] Driver: 100.10.545.9 (r826445-20200316-8)
[ 568.169915] Firmware: wl0: Jun 13 2018 13:18:38 version 7.45.96.24 (7ffe8b7@shgit) (r) FWID 01-40f9deb0 es7.c5.n4.a3
[ 568.169915] CLM: 7.11.15 (2014-05-26 10:53:55)
[ 568.170847] dhd_preinit_ioctls wlc_ver failed -23
[ 568.171167] dhd_txglom_enable: enable 1
[ 568.171176] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy
[ 568.171183] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0
[ 568.171189] [dhd] dhd_conf_set_txglom_params : txinrx_thres=-1, dhd_txminmax=1
[ 568.171195] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300
[ 568.171210] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-1
[ 568.172626] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[ 568.174769] dhd_pno_init: Support Android Location Service
[ 568.211125] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[ 568.211165] dhd_rtt_init : FTM is not supported
[ 568.212242] dhd_rtt_ftm_config : failed to set config
[ 568.215073] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[ 568.215111] failed to get wnm_bsstrans_resp
[ 568.216135] failed to set WNM capabilities
[ 568.246064] dhd_preinit_ioctls: Failed to get preserve log # !
[ 568.246568] [dhd] dhd_conf_set_country : set country CN, revision 0
[ 568.251005] [dhd] dhd_conf_set_country : Country code: CN (CN/0)
[ 568.257821] [dhd] CONFIG-ERROR) dhd_conf_set_intiovar : ampdu_mpdu setting failed -29
[ 568.257858] [dhd-wlan0] wl_android_wifi_on : Success
[ 568.296357] [dhd] CFG80211-ERROR) __wl_update_wiphybands : error reading vhtmode (-23)
[ 568.312248] dhd_open : the lock is released.
[ 568.312292] dhd_open: Exit wlan0 ret=0
[ 568.312310] [wlan0] tx queue started
root@OpenWrt:/# [ 568.414951] [wlan0] tx queue stopped
[ 568.414987] dhd_stop: Enter wlan0
[ 568.414995] dhd_stop: ######### dhd_stop called for ifidx=0 #########
[ 568.415003] dhd_stop: making dhdpub up FALSE
[ 568.417561] [dhd] CFGP2P-ERROR) wl_cfgp2p_disable_discovery : do nothing, not initialized
[ 568.417792] dhd_tcpack_suppress_set 382: already set to 0
[ 568.417814] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=1, on_failure=1
[ 568.419171] dhd_dbg_detach_pkt_monitor, 2100
[ 568.419188] dhd_bus_devreset: == Power OFF ==
[ 568.419368] dhd_bus_stop: making DHD_BUS_DOWN
[ 568.419410] bcmsdh_oob_intr_unregister: Enter
[ 568.419444] dhd_bus_devreset: making dhdpub up FALSE
[ 568.419459] dhd_txglom_enable: enable 0
[ 568.419469] dhd_bus_devreset: making DHD_BUS_DOWN
[ 568.419480] dhd_bus_devreset: WLAN OFF DONE
[ 568.419532] wifi_platform_set_power = 0, delay: 0 msec
[ 568.419547] ======== PULL WL_REG_ON(-1) LOW! ========
[ 568.419558] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 568.419578] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 568.419589] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 568.419598] [dhd-wlan0] wl_android_wifi_off : out
[ 568.457156] dhd_stop: Exit wlan0
[ 568.580700] [dhd] CFG80211-ERROR) wl_cfg80211_add_virtual_iface : device is not ready
[ 568.608637] dhd_open: Enter wlan0
[ 568.608694] dhd_open : no mutex held. set lock
[ 568.608710]
[ 568.608710] Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 568.608732] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 568.608741] wifi_platform_set_power = 1, delay: 200 msec
[ 568.608752] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 568.608759] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 568.608768] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 568.608776] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 568.914116] sdio_reset_comm():
[ 568.929593] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 568.946802] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 100000Hz, actual 93750HZ div = 2)
[ 569.002184] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 569.008924] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 569.015664] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 569.027856] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 569.043694] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 569.417271] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 569.417465] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 569.417689] sdioh_start: set sd_f2_blocksize 256
[ 569.418346]
[ 569.418346]
[ 569.418346] dhd_bus_devreset: == Power ON ==
[ 569.418614] F1 signature read @0x18000000=0x1541a9a6
[ 569.424196] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 569.426192] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 569.426505] dhd_bus_devreset: making DHD_BUS_DOWN
[ 569.426655] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 569.427174] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 569.427256] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43438a1.bin
[ 569.427285] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram.txt
[ 569.427345] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43438a1.blob
[ 569.427397] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 569.428999] dhd_os_open_image1: /vendor/etc/firmware/fw_bcm43438a1.bin (414579 bytes) open success
[ 569.507093] dhd_os_open_image1: /vendor/etc/firmware/nvram.txt (2840 bytes) open success
[ 569.507228] NVRAM version: AP6356S_NVRAM_V1.2_20170331
[ 569.509258] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 569.628470] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 569.628897] bcmsdh_oob_intr_register: HW_OOB irq=102 flags=0x4
[ 569.629335] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 569.629405] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 569.631861] dhd_tcpack_suppress_set 382: already set to 0
[ 569.633427] dhd_apply_default_clm: Ignore clm file /vendor/etc/firmware/clm_bcm43438a1.blob
[ 569.638805] Firmware up: op_mode=0x0005, MAC=08:e9:f6:38:af:18
[ 569.639990] Disable tdls_auto_op failed. -1
[ 569.645473] dhd_preinit_ioctls Set scancache failed -23
[ 569.646998] dhd_preinit_ioctls: event_log_max_sets: 26 ret: -23
[ 569.669761] Driver: 100.10.545.9 (r826445-20200316-8)
[ 569.669761] Firmware: wl0: Jun 13 2018 13:18:38 version 7.45.96.24 (7ffe8b7@shgit) (r) FWID 01-40f9deb0 es7.c5.n4.a3
[ 569.669761] CLM: 7.11.15 (2014-05-26 10:53:55)
[ 569.671174] dhd_preinit_ioctls wlc_ver failed -23
[ 569.671952] dhd_txglom_enable: enable 1
[ 569.672010] [dhd] dhd_conf_set_txglom_params : txglom_mode=copy
[ 569.672054] [dhd] dhd_conf_set_txglom_params : txglomsize=36, deferred_tx_len=0
[ 569.672092] [dhd] dhd_conf_set_txglom_params : txinrx_thres=-1, dhd_txminmax=1
[ 569.672131] [dhd] dhd_conf_set_txglom_params : tx_max_offset=0, txctl_tmo_fix=300
[ 569.672178] [dhd] dhd_conf_get_disable_proptx : fw_proptx=1, disable_proptx=-1
[ 569.674775] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[ 569.678653] dhd_pno_init: Support Android Location Service
[ 569.715401] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[ 569.715478] dhd_rtt_init : FTM is not supported
[ 569.716881] dhd_rtt_ftm_config : failed to set config
[ 569.720737] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[ 569.720811] failed to get wnm_bsstrans_resp
[ 569.722149] failed to set WNM capabilities
[ 569.760166] dhd_preinit_ioctls: Failed to get preserve log # !
[ 569.760985] [dhd] dhd_conf_set_country : set country CN, revision 0
[ 569.766083] [dhd] dhd_conf_set_country : Country code: CN (CN/0)
[ 569.775118] [dhd] CONFIG-ERROR) dhd_conf_set_intiovar : ampdu_mpdu setting failed -29
[ 569.775187] [dhd-wlan0] wl_android_wifi_on : Success
[ 569.814701] [dhd] CFG80211-ERROR) __wl_update_wiphybands : error reading vhtmode (-23)
[ 569.830157] dhd_open : the lock is released.
[ 569.830178] dhd_open: Exit wlan0 ret=0
[ 569.830185] [wlan0] tx queue started
root@OpenWrt:/# ifconfig[ 580.121537] [dhd] CFG80211-ERROR) wl_set_tx_power : dBm=0, txpwrqdbm=0x0
[ 580.141332] [dhd] CFG80211-ERROR) wl_cfg80211_add_if : Interface name wlan0 exists!
br-lan Link encap:Ethernet HWaddr 00:00:00:00:00:00
inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fd54:9d0b:acb::1/60 Scope:Global
inet6 addr: fe80::ae9:f6ff:fe38:af18/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:1594 (1.5 KiB)
eth0 Link encap:Ethernet HWaddr 4A:7B:B3:03:8F:67
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:37
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:392 errors:0 dropped:0 overruns:0 frame:0
TX packets:392 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:30504 (29.7 KiB) TX bytes:30504 (29.7 KiB)
wlan0 Link encap:Ethernet HWaddr 08:E9:F6:38:AF:18
TX packets:95 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:18948 (18.5 KiB)
root@OpenWrt:/# iwlist wlan0 scanning
wlan0 Interface doesn’t[ s u5p9p1o.r16t8 4s5c7a]n n[idnhgd -:w lResource busy
rn0] AEXT-ERROR) wl_ext_check_scan : cfg80211 scanning…
oot@OpenWrt:/#
