→ Config model
→ Loading onnx model
I Start importing onnx…
W Detect Input node:1325 is dynamic input, the shape info is [0]
W Use the follow command to see more detail and try to fix the dynamic dim
W python -m rknn.bin.freeze_inshape_for_onnx_model -h
E Loading dynamic inputs model is not support, please fix it first
E Catch exception when loading onnx model: E:\examples\onnx\nano\nanodet_sim.onnx!
E Traceback (most recent call last):
E File “rknn\base\RKNNlib\RK_nn.py”, line 141, in rknn.base.RKNNlib.RK_nn.RKnn.load_onnx
E File “rknn\base\RKNNlib\app\importer\import_onnx.py”, line 118, in rknn.base.RKNNlib.app.importer.import_onnx.Importonnx.run
E File “rknn\base\RKNNlib\converter\convert_onnx.py”, line 68, in rknn.base.RKNNlib.converter.convert_onnx.convert_onnx.init
E File “rknn\base\RKNNlib\converter\convert_onnx.py”, line 73, in rknn.base.RKNNlib.converter.convert_onnx.convert_onnx.init
E File “rknn\api\rknn_log.py”, line 323, in rknn.api.rknn_log.RKNNLog.e
E ValueError: Loading dynamic inputs model is not support, please fix it first
E Please feedback the detailed log file <RKNN_toolkit.log> to the RKNN Toolkit development team.
E You can also check github issues: Issues · rockchip-linux/rknn-toolkit · GitHub
→ Load onnx model failed!
