RK3568
SDK包名称:rk356x_linux_release_20211019
SDK更新到哪个COMMIT:2022-02-17 16:01:00
SDK修改内容:rockchip,baudrate = <115200>; /* Only 115200 and 1500000 */
Log日志:print.txt
./build.sh roc-rk3568-pc-ubuntu.mk 编译后,在开发板上可以启动,在我们自己参考开发板做的板子上不能启动,打印信息如下:
0.154287] console [ttyFIQ0] enabled
[ 0.162001] bootconsole [uart8250] disabled
[ 0.166868] Registered fiq debugger ttyFIQ0
[ 0.167920] vcc3v3_sys: supplied by dc_12v
[ 0.168406] vcc5v0_sys: supplied by dc_12v
[ 0.170173] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.170657] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.171139] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.171627] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.175497] rk_iommu fde4b000.iommu: version = 2
[ 0.176190] rk_iommu fdea0800.iommu: version = 2
[ 0.176740] rk_iommu fded0480.iommu: version = 2
[ 0.177297] rk_iommu fdee0800.iommu: version = 2
[ 0.177776] rk_iommu fdef0800.iommu: version = 2
[ 0.178231] rk_iommu fdf40f00.iommu: version = 2
[ 0.178781] rk_iommu fdf80800.iommu: version = 2
[ 0.179271] rk_iommu fdff1a00.iommu: version = 2
[ 0.179735] rk_iommu fe043e00.iommu: version = 2
[ 0.180829] SCSI subsystem initialized
[ 0.181201] usbcore: registered new interface driver usbfs
[ 0.181297] usbcore: registered new interface driver hub
[ 0.181374] usbcore: registered new device driver usb
[ 0.181505] media: Linux media interface: v0.10
[ 0.181572] videodev: Linux video capture interface: v2.00
[ 0.181695] pps_core: LinuxPPS API ver. 1 registered
[ 0.181720] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.181763] PTP clock support registered
[ 0.182168] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 0.185236] Advanced Linux Sound Architecture Driver Initialized.
[ 0.185867] Bluetooth: Core ver 2.22
[ 0.185942] NET: Registered protocol family 31
[ 0.185966] Bluetooth: HCI device and connection manager initialized
[ 0.185997] Bluetooth: HCI socket layer initialized
[ 0.186024] Bluetooth: L2CAP socket layer initialized
[ 0.186101] Bluetooth: SCO socket layer initialized
[ 0.186674] rockchip-cpuinfo cpuinfo: SoC : 35681000
[ 0.186706] rockchip-cpuinfo cpuinfo: Serial : bb2164b5a710f20d
[ 0.188416] clocksource: Switched to clocksource arch_sys_counter
[ 0.290398] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.290821] NET: Registered protocol family 2
[ 0.291043] IP idents hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.292536] tcp_listen_portaddr_hash hash table entries: 1024 (order: 3, 40960 bytes)
[ 0.292615] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.292798] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.293319] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.293534] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.293673] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.294026] NET: Registered protocol family 1
[ 0.294798] RPC: Registered named UNIX socket transport module.
[ 0.294816] RPC: Registered udp transport module.
[ 0.294839] RPC: Registered tcp transport module.
[ 0.294860] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.296831] Trying to unpack rootfs image as initramfs…
[ 0.690022] Freeing initrd memory: 6792K
[ 0.691880] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.694776] Initialise system trusted keyrings
[ 0.695034] workingset: timestamp_bits=61 max_order=19 bucket_order=0
[ 0.703658] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.704704] NFS: Registering the id_resolver key type
[ 0.704762] Key type id_resolver registered
[ 0.704790] Key type id_legacy registered
[ 0.704849] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.705210] fuse init (API version 7.27)
[ 0.705826] SGI XFS with security attributes, no debug enabled
[ 0.709362] NET: Registered protocol family 38
[ 0.709417] Key type asymmetric registered
[ 0.709442] Asymmetric key parser ‘x509’ registered
[ 0.709510] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.709537] io scheduler noop registered
[ 0.709558] io scheduler deadline registered
[ 0.709729] io scheduler cfq registered (default)
[ 0.709757] io scheduler mq-deadline registered
[ 0.709779] io scheduler kyber registered
[ 0.711200] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.711416] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.715038] phy phy-fe8b0000.usb2-phy.0: Linked as a consumer to regulator.4
[ 0.715461] phy phy-fe8b0000.usb2-phy.1: Linked as a consumer to regulator.4
[ 0.715638] phy phy-fe8b0000.usb2-phy.1: No vbus specified for otg port
[ 0.726279] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.15
[ 0.726924] mpp_service mpp-srv: unknown mpp version for missing VCS info
[ 0.726959] mpp_service mpp-srv: probe start
[ 0.728143] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.728200] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.728530] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.729175] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.729204] rkvenc_init:1199: failed to add venc devfreq
[ 0.729643] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 0.731089] iommu: Adding device fdea0400.vdpu to group 1
[ 0.731147] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.731373] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.732193] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.732961] iommu: Adding device fdee0000.vepu to group 3
[ 0.733018] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.733279] mpp_vepu2 fdee0000.vepu: probe device
[ 0.734045] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.734831] iommu: Adding device fdef0000.iep to group 4
[ 0.734886] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.735143] mpp-iep2 fdef0000.iep: probe device
[ 0.735806] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.736046] mpp-iep2 fdef0000.iep: probing finish
[ 0.736744] iommu: Adding device fded0000.jpegd to group 2
[ 0.736801] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.737005] mpp_jpgdec fded0000.jpegd: probe device
[ 0.737760] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.738535] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.738578] rk-pcie 3c0800000.pcie: Missing config reg space
[ 0.738588] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.738610] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.738639] rk-pcie 3c0800000.pcie: err 0x380000000..0x3807fffff → 0x80000000
[ 0.738679] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.738686] rk-pcie 3c0800000.pcie: IO 0x380800000..0x3808fffff → 0x80800000
[ 0.738703] rk-pcie 3c0800000.pcie: MEM 0x380900000..0x3bfffffff → 0x80900000
[ 0.739026] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.739302] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.739787] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.739808] rkvdec2_init:661: No niu aclk reset resource define
[ 0.739839] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.739862] rkvdec2_init:664: No niu hclk reset resource define
[ 0.740123] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.740153] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.740178] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.740203] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 0.740226] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.740309] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 0.740416] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.740905] mpp_service mpp-srv: probe success
[ 0.748821] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.748868] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.752184] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.752224] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.754070] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.755516] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.756673] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 66, base_baud = 1500000) is a 16550A
[ 0.757561] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 67, base_baud = 1500000) is a 16550A
[ 0.758477] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 68, base_baud = 1500000) is a 16550A
[ 0.762172] random: fast init done
[ 0.762519] random: crng init done
[ 0.762957] iommu: Adding device fe040000.vop to group 8
[ 0.763018] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.769656] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.771409] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.774240] rockchip-drm display-subsystem: dmc is disabled
[ 0.774615] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4
[ 0.774658] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1
[ 0.774693] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.774995] [drm] unsupported AFBC format[3432564e]
[ 0.775162] [drm] failed to init overlay plane Cluster0-win1
[ 0.775262] [drm] failed to init overlay plane Cluster1-win1
[ 0.775415] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008fba698)
[ 0.775681] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.776458] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.777256] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008fbe1b8)
[ 0.777291] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.777314] [drm] No driver support for vblank timestamp query.
[ 0.777625] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 0.777717] rockchip-drm display-subsystem: can’t not find any loader display
[ 0.777751] rockchip-drm display-subsystem: failed to show loader logo
[ 0.777806] [drm] Cannot find any crtc or sizes
[ 0.778940] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.786533] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 0.786649] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.786708] mali fde60000.gpu: Device initialization Deferred
[ 0.787669] brd: module loaded
[ 0.797224] loop: module loaded
[ 0.797877] zram: Added device: zram0
[ 0.798042] lkdtm: No crash points registered, enable through debugfs
[ 0.799902] ahci fc800000.sata: forcing port_map 0x0 → 0x1
[ 0.799985] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 0.800008] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 0.800050] ahci fc800000.sata: port 0 is not capable of FBS
[ 0.801435] scsi host0: ahci
[ 0.801989] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 11
[ 0.804568] libphy: Fixed MDIO Bus: probed
[ 0.804646] CAN device driver interface
[ 0.809261] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 0.809304] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 0.809332] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[ 0.809355] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26).
[ 0.809388] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 0.809472] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 0.814512] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 0.814864] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.814897] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 0.814926] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 0.814949] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 0.814963] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 0.814983] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 0.815044] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 0.815111] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.815141] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 0.948457] libphy: stmmac: probed
[ 0.954090] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 0.954134] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 0.954163] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c).
[ 0.954186] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f).
[ 0.954214] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 0.954296] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 0.959336] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 0.959677] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.959709] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 0.959734] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 0.959757] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 0.959779] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 0.959799] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 0.959857] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 0.959882] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.959909] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 1.091789] libphy: stmmac: probed
[ 1.096738] usbcore: registered new interface driver rndis_wlan
[ 1.096825] usbcore: registered new interface driver rtl8150
[ 1.096908] usbcore: registered new interface driver r8152
[ 1.096986] usbcore: registered new interface driver asix
[ 1.097056] usbcore: registered new interface driver ax88179_178a
[ 1.097135] usbcore: registered new interface driver cdc_ether
[ 1.097211] usbcore: registered new interface driver rndis_host
[ 1.097290] usbcore: registered new interface driver cdc_ncm
[ 1.097379] usbcore: registered new interface driver qmi_wwan_q
[ 1.097455] usbcore: registered new interface driver qmi_wwan
[ 1.097520] usbcore: registered new interface driver cdc_mbim
[ 1.099144] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.100898] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.104030] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.104077] ehci-pci: EHCI PCI platform driver
[ 1.104186] ehci-platform: EHCI generic platform driver
[ 1.106545] ehci-platform fd800000.usb: EHCI Host Controller
[ 1.106818] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 1.107384] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[ 1.115111] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.118446] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 1.118809] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.118840] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.118871] usb usb1: Product: EHCI Host Controller
[ 1.118896] usb usb1: Manufacturer: Linux 4.19.219 ehci_hcd
[ 1.118917] usb usb1: SerialNumber: fd800000.usb
[ 1.119599] hub 1-0:1.0: USB hub found
[ 1.119677] hub 1-0:1.0: 1 port detected
[ 1.122503] ehci-platform fd880000.usb: EHCI Host Controller
[ 1.122790] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 1.123498] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000
[ 1.135115] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 1.135452] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.135485] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.135511] usb usb2: Product: EHCI Host Controller
[ 1.135535] usb usb2: Manufacturer: Linux 4.19.219 ehci_hcd
[ 1.135556] usb usb2: SerialNumber: fd880000.usb
[ 1.136200] hub 2-0:1.0: USB hub found
[ 1.136278] hub 2-0:1.0: 1 port detected
[ 1.137389] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.137438] ohci-platform: OHCI generic platform driver
[ 1.137775] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 1.138046] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 1.138512] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000
[ 1.199381] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.199415] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.199441] usb usb3: Product: Generic Platform OHCI controller
[ 1.199463] usb usb3: Manufacturer: Linux 4.19.219 ohci_hcd
[ 1.199485] usb usb3: SerialNumber: fd840000.usb
[ 1.200130] hub 3-0:1.0: USB hub found
[ 1.200205] hub 3-0:1.0: 1 port detected
[ 1.200951] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 1.201226] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 1.201650] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[ 1.259395] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.259428] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.259454] usb usb4: Product: Generic Platform OHCI controller
[ 1.259479] usb usb4: Manufacturer: Linux 4.19.219 ohci_hcd
[ 1.259500] usb usb4: SerialNumber: fd8c0000.usb
[ 1.260134] hub 4-0:1.0: USB hub found
[ 1.260214] hub 4-0:1.0: 1 port detected
[ 1.262501] usbcore: registered new interface driver cdc_acm
[ 1.262534] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.262622] usbcore: registered new interface driver cdc_wdm
[ 1.262969] usbcore: registered new interface driver uas
[ 1.263145] usbcore: registered new interface driver usb-storage
[ 1.263299] usbcore: registered new interface driver usbserial_generic
[ 1.263346] usbserial: USB Serial support registered for generic
[ 1.263439] usbcore: registered new interface driver cp210x
[ 1.263494] usbserial: USB Serial support registered for cp210x
[ 1.263622] usbcore: registered new interface driver ftdi_sio
[ 1.263678] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.263938] usbcore: registered new interface driver keyspan
[ 1.263994] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.264035] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.264089] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.264140] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.264239] usbcore: registered new interface driver option
[ 1.264298] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.264643] usbcore: registered new interface driver oti6858
[ 1.264698] usbserial: USB Serial support registered for oti6858
[ 1.264770] usbcore: registered new interface driver pl2303
[ 1.264829] usbserial: USB Serial support registered for pl2303
[ 1.264928] usbcore: registered new interface driver qcserial
[ 1.264972] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.265127] usbcore: registered new interface driver sierra
[ 1.265194] usbserial: USB Serial support registered for Sierra USB modem
[ 1.266898] usbcore: registered new interface driver usbtouchscreen
[ 1.266971] ============ himax_hx83102_init 1742 jjlook ==========
[ 1.266995] ============ himax_hx83102_probe 1725 jjlook ==========
[ 1.267092] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 1.267120] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 1.267567] .. rk pwm remotectl v2.0 init
[ 1.267944] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 1.268497] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[ 1.268541] remotectl-pwm fe6e0030.pwm: cannot find PWR IRQ
[ 1.268574] remotectl-pwm fe6e0030.pwm: pwm sip wakeup config error!!
[ 1.268596] remotectl-pwm fe6e0030.pwm: Donot support ATF Wakeup
[ 1.269519] i2c /dev entries driver
[ 1.272004] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 1.273869] vdd_cpu: supplied by vcc5v0_sys
[ 1.279119] rk808 0-0020: chip id: 0x8090
[ 1.279204] rk808 0-0020: No cache defaults, reading back from HW
[ 1.302981] rk808 0-0020: source: on=0x40, off=0x00
[ 1.303020] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 1.303050] rk808 0-0020: support pmic reset mode:0,0
[ 1.309534] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.309605] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.310107] vdd_logic: supplied by vcc3v3_sys
[ 1.311010] vdd_gpu: supplied by vcc3v3_sys
[ 1.311491] vcc_ddr: supplied by vcc3v3_sys
[ 1.311993] vdd_npu: supplied by vcc3v3_sys
[ 1.312840] vcc_1v8: supplied by vcc3v3_sys
[ 1.313298] vdda0v9_image: supplied by vcc3v3_sys
[ 1.314120] vdda_0v9: supplied by vcc3v3_sys
[ 1.314588] vdda0v9_pmu: supplied by vcc3v3_sys
[ 1.315049] vccio_acodec: supplied by vcc3v3_sys
[ 1.315908] vccio_sd: supplied by vcc3v3_sys
[ 1.316384] vcc3v3_pmu: supplied by vcc3v3_sys
[ 1.317217] vcca_1v8: supplied by vcc3v3_sys
[ 1.317694] vcca1v8_pmu: supplied by vcc3v3_sys
[ 1.318164] vcca1v8_image: supplied by vcc3v3_sys
[ 1.319012] vcc_3v3: supplied by vcc3v3_sys
[ 1.319821] vcc3v3_sd: supplied by vcc3v3_sys
[ 1.320430] rk817-battery rk817-battery: Failed to find matching dt id
[ 1.320771] rk817-charger rk817-charger: Failed to find matching dt id
[ 1.324157] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 1.324768] rk808-rtc rk808-rtc: device is disabled
[ 1.324810] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.326345] fusb302 0-0022: Can’t get property of role, set role to default DRP
[ 1.335762] fusb302 0-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.335990] input: Typec_Headphone as /devices/platform/fdd40000.i2c/i2c-0/0-0022/input/input2
[ 1.337877] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 1.338017] pca953x 1-0021: Linked as a consumer to regulator.0
[ 1.338220] pca953x 1-0021: failed reading register
[ 1.338316] pca953x 1-0021: Dropping the link to regulator.0
[ 1.348069] rtc-hym8563 5-0051: rtc core: registered hym8563 as rtc0
[ 1.349162] rtc-hym8563 5-0051: setting system clock to 2017-01-02 13:42:17 UTC (1483364537)
[ 1.350836] gsensor_mc3230 5-004c: sensor_register_device: gs_mc3230, id = 27
[ 1.350873] i2c i2c-5: sensor_probe: gs_mc3230,000000007ddb1698
[ 1.350943] gsensor_mc3230 5-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x000000007eae501e
[ 1.388627] [Gsensor] init_3230_ctl_data 457 : error: -6
[ 1.388660] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor
[ 1.388684] gsensor_mc3230 5-004c: sensor_chip_init:fail to init sensor
[ 1.388708] i2c i2c-5: sensor_probe failed -2
[ 1.388708]
[ 1.392556] iommu: Adding device fdff0000.rkisp to group 7
[ 1.392617] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[ 1.392891] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 1.392925] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 1.392973] rkisp_hw fdff0000.rkisp: can’t request region for resource [mem 0xfdff0000-0xfdffffff]
[ 1.394208] rkisp rkisp-vir0: rkisp driver version: v01.07.00
[ 1.394601] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 1.394645] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 1.397337] usbcore: registered new interface driver uvcvideo
[ 1.397370] USB Video Class driver (1.1.1)
[ 1.397766] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.27
[ 1.397832] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 1.397995] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 1.398146] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.25
[ 1.398206] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 1.398469] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.26
[ 1.398532] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 1.398694] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.21
[ 1.398754] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 1.398895] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.31
[ 1.398955] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 1.399109] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 1.399296] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 1.403692] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 1.405378] Bluetooth: HCI UART driver ver 2.3
[ 1.405414] Bluetooth: HCI UART protocol H4 registered
[ 1.405436] Bluetooth: HCI UART protocol ATH3K registered
[ 1.405729] Bluetooth: HCI UART protocol Broadcom registered
[ 1.405841] usbcore: registered new interface driver bfusb
[ 1.405948] usbcore: registered new interface driver btusb
[ 1.406339] cpu cpu0: leakage=39
[ 1.407034] cpu cpu0: Linked as a consumer to regulator.16
[ 1.434046] cpu cpu0: temp=36666, pvtm=91777 (91881 + -104)
[ 1.437250] cpu cpu0: Dropping the link to regulator.16
[ 1.437318] cpu cpu0: pvtm-volt-sel=1
[ 1.438278] cpu cpu0: Linked as a consumer to regulator.16
[ 1.438357] cpu cpu0: Dropping the link to regulator.16
[ 1.439136] cpu cpu0: Linked as a consumer to regulator.16
[ 1.440239] cpu cpu0: avs=0
[ 1.440340] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[ 1.440671] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.444366] cpu cpu0: failed to find power_model node
[ 1.446373] sdhci: Secure Digital Host Controller Interface driver
[ 1.446399] sdhci: Copyright(c) Pierre Ossman
[ 1.446414] Synopsys Designware Multimedia Card Interface Driver
[ 1.447507] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.447797] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 1.447824] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 1.447892] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 1.448068] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 1.448093] mmc_host mmc3: card is non-removable.
[ 1.565666] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.579303] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.580171] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 1.580200] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 1.580282] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 50,32 bit host data width,256 deep fifo
[ 1.580468] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.32
[ 1.580578] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.26
[ 1.589265] mmc3 mmc_send_io_op_cond err: -110
[ 1.596058] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.609011] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.610159] mmc0: Unknown controller version (5). You may experience problems.
[ 1.641214] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 1.643039] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.643462] usbcore: registered new interface driver usbhid
[ 1.643482] usbhid: USB HID core driver
[ 1.643834] rockchip,bus bus-npu: Linked as a consumer to regulator.17
[ 1.643862] rockchip,bus bus-npu: Failed to get leakage
[ 1.643925] rockchip,bus bus-npu: pvtm = 91777, form pvtm_value
[ 1.643942] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 1.644196] rockchip,bus bus-npu: avs=0
[ 1.646310] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.28
[ 1.647011] rksfc_base v1.1 2016-01-08
[ 1.647677] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 1.647741] rkflash_dev_init enter
[ 1.647764] sfc nor id: ff ff ff
[ 1.647777] rkflash[1] is invalid
[ 1.647779] rkflash_dev_init enter
[ 1.647801] sfc_nand id: ff ff ff
[ 1.647812] rkflash[2] is invalid
[ 1.648690] usbcore: registered new interface driver snd-usb-audio
[ 1.650926] rk817-codec rk817-codec: DMA mask not set
[ 1.651636] rk817_codec_parse_dt_property: rk809 hp adc effective value of detection 976~1024
[ 1.651665] invalid rk817->hp_det_gpio: -2
[ 1.651684] invalid gpio: -2
[ 1.656635] Initializing XFRM netlink socket
[ 1.656970] NET: Registered protocol family 10
[ 1.657662] Segment Routing with IPv6
[ 1.657734] NET: Registered protocol family 17
[ 1.657755] NET: Registered protocol family 15
[ 1.657778] can: controller area network core (rev 20170425 abi 9)
[ 1.657879] NET: Registered protocol family 29
[ 1.657911] can: raw protocol (rev 20170425)
[ 1.657923] can: broadcast manager protocol (rev 20170425 t)
[ 1.657940] can: netlink gateway (rev 20170425) max_hops=1
[ 1.658114] Bluetooth: RFCOMM socket layer initialized
[ 1.658152] Bluetooth: RFCOMM ver 1.11
[ 1.658169] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.658183] Bluetooth: HIDP socket layer initialized
[ 1.658219] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.658230] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.658759] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.658799] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 1.658810] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.658820] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.658862] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 1.658877] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.658887] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.658898] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 1.658908] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.659410] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 1.659437] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96.
[ 1.659455] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 97.
[ 1.659472] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 98.
[ 1.659528] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.659605] [BT_RFKILL]: ** disable irq
[ 1.659710] [BT_RFKILL]: bt_default device registered.
[ 1.659824] Key type dns_resolver registered
[ 1.660123] flash vendor_init_thread!
[ 1.660137] flash vendor storage:20170308 ret = -1
[ 1.661668] Loading compiled-in X.509 certificates
[ 1.662233] pstore: Using compression: deflate
[ 1.663081] rga2: Driver loaded successfully ver:3.2.63318
[ 1.663403] rga2: Module initialized.
[ 1.674088] mmc0: new HS200 MMC card at address 0001
[ 1.675330] mmcblk0: mmc0:0001 SPeMMC 29.0 GiB
[ 1.676205] mmcblk0boot0: mmc0:0001 SPeMMC partition 1 4.00 MiB
[ 1.677132] mmcblk0boot1: mmc0:0001 SPeMMC partition 2 4.00 MiB
[ 1.677410] mmcblk0rpmb: mmc0:0001 SPeMMC partition 3 4.00 MiB, chardev (239:0)
[ 1.685727] phy phy-fe8a0000.usb2-phy.6: Linked as a consumer to regulator.4
[ 1.685955] phy phy-fe8a0000.usb2-phy.7: No vbus specified for otg port
[ 1.687644] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 1.687661] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.687816] mali fde60000.gpu: Linked as a consumer to regulator.18
[ 1.687949] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 1.688038] mali fde60000.gpu: leakage=11
[ 1.688438] mali fde60000.gpu: avs=0
[ 1.688459] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 1.688797] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 1.688879] mali fde60000.gpu: No priority control manager is configured
[ 1.688889] mali fde60000.gpu: No memory group manager is configured
[ 1.689356] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.689969] mali fde60000.gpu: Probed as mali0
[ 1.692844] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.696814] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.696967] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[ 1.697431] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 1.697485] xhci-hcd xhci-hcd.4.auto: irq 82, io mem 0xfd000000
[ 1.697709] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.697721] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.697731] usb usb5: Product: xHCI Host Controller
[ 1.697740] usb usb5: Manufacturer: Linux 4.19.219 xhci-hcd
[ 1.697748] usb usb5: SerialNumber: xhci-hcd.4.auto
[ 1.698047] hub 5-0:1.0: USB hub found
[ 1.698079] hub 5-0:1.0: 1 port detected
[ 1.698284] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.698420] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 6
[ 1.698441] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 1.698502] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.698585] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.698597] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.698607] usb usb6: Product: xHCI Host Controller
[ 1.698612] usb usb6: Manufacturer: Linux 4.19.219 xhci-hcd
[ 1.698621] usb usb6: SerialNumber: xhci-hcd.4.auto
[ 1.698937] hub 6-0:1.0: USB hub found
[ 1.698967] hub 6-0:1.0: 1 port detected
[ 1.699542] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 1.700523] asoc-simple-card hdmi-sound: i2s-hifi ↔ fe400000.i2s mapping ok
[ 1.705770] asoc-simple-card rk809-sound: rk817-hifi ↔ fe410000.i2s mapping ok
[ 1.705796] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 1.705808] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.705818] asoc-simple-card rk809-sound: ASoC: no source widget found for Mic Jack
[ 1.705827] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.705836] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 1.705843] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 1.705852] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 1.705860] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 1.707794] register spi return v = :0
[ 1.707816] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 1.707826] ======== dhd_wlan_init_plat_data ========
[ 1.707835] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.707884] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=111, oob_irq_flags=0x414
[ 1.707894] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 1.707899] dhd_wifi_platform_load: Enter
[ 1.707908] Power-up adapter ‘DHD generic adapter’
[ 1.707935] wifi_platform_set_power = 1, delay: 200 msec
[ 1.707945] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.707954] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.707961] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 1.707969] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 1.765125] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 1.792468] devfreq fde60000.gpu: Couldn’t update frequency transition information.
[ 1.808049] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 1.828893] mmc3 mmc_send_io_op_cond err: -110
[ 1.971500] mmc3 mmc_send_io_op_cond err: -110
[ 2.011801] wifi_platform_bus_enumerate device present 1
[ 2.011814] ======== Card detection to detect SDIO card! ========
[ 2.011822] mmc3:mmc host rescan start!
[ 2.114384] dwmmc_rockchip fe2b0000.dwmmc: Busy; trying anyway
[ 2.114840] mmc3 mmc_send_io_op_cond err: -110
[ 2.614400] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 2.628282] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 2.641420] vendor storage:20190527 ret = 0
[ 2.642905] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 2.778479] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 2.936783] phy phy-fe8a0000.usb2-phy.7: charger = USB_SDP_CHARGER
[ 3.144215] dwmmc_rockchip fe2b0000.dwmmc: Busy; trying anyway
[ 3.644233] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 3.644269] usb 4-1: new full-speed USB device number 2 using ohci-platform
[ 3.791788] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 4.111784] failed to power up DHD generic adapter, 0 retry left
[ 4.127876] wifi_platform_set_power = 0, delay: 0 msec
[ 4.127889] ======== PULL WL_REG_ON(-1) LOW! ========
[ 4.127895] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 4.127906] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 4.127912] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 4.127917] wifi_platform_bus_enumerate device present 0
[ 4.127922] ======== Card detection to remove SDIO card! ========
[ 4.127926] mmc3:mmc host rescan start!
[ 4.127935] failed to power up DHD generic adapter, max retry reached**
[ 4.127944] unregister wifi platform drivers
[ 4.127954] wifi_platform_bus_enumerate device present 0
[ 4.127962] ======== Card detection to remove SDIO card! ========
[ 4.127969] mmc3:mmc host rescan start!
[ 4.127977] ======== dhd_wlan_deinit_plat_data ========
[ 4.127987] dhd_module_init: Failed to load the driver, try cnt 0
[ 4.128039] dhd_module_init: Failed to load driver max retry reached**
[ 4.128049] dhd_module_init: Exit err=-19
[ 4.128440] ==gsl_ts_init==
[ 4.128502] ret=0
[ 4.129259] iommu: Adding device fde40000.npu to group 0
[ 4.129291] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 4.129700] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 4.129816] RKNPU fde40000.npu: Linked as a consumer to regulator.20
[ 4.129840] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
[ 4.130282] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[ 4.130535] RKNPU fde40000.npu: leakage=6
[ 4.130948] RKNPU fde40000.npu: avs=0
[ 4.131525] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5
print.txt (39.5 KB)
我也遇到了和你一样的情况,朋友,你后来解决了吗?可不可以加个wx一起研究
