SDK包名称:Firefly-RK3399_Android10.0_git_20211222
SDK更新到哪个COMMIT:2021-12-22 15:23:00
SDK修改内容:无修改
Log日志:22-03-23-07-36-48.rar
贵司释放的固件 :AIO-3399J_Android10_HDMI_210331 烧录后,有节点dev/ttysWK0 dev/ttysWK1 dev/ttysWK2 dev/ttysWK3
我自行编译的固件,找不到这几个节点
尝试rk3399-firefly-aio.dts 文件
添加
&spi_wk2xxx {
status = “okay”;
&uart4 {
status = “disabled”;
没有效果
编译命令:
./FFTools/make.sh -j24 -d rk3399-firefly-aio -l rk3399_firefly_aio-userdebug./FFTools/mkupdate/mkupdate.sh -l rk3399_firefly_aio-userdebug请帮忙分析一下,哪里的问题,谢谢!
22-03-23-07-36-48.rar (148 KB)
lisd
2
kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-aio.dtsi
发下dts看下
lisd
4
03-23 07:34:48.997 0 0 W 11wk2xxx_probe: setup mode 0, 0 bits/w, 0 Hz max
03-23 07:34:48.997 0 0 W : wk2xxx_probe() Can not read property power-gpio
03-23 07:34:48.997 0 0 W wk2xxxspi: probe of spi0.0 failed with error -2
03-23 07:34:48.997 0 0 F : register spi return v = :0
log中没有解析到power-gpio,
楼上的dts没有问题,把编译生成的kernel/arch/arm64/boot/dts/rockchip/.rk3399-firefly-aio.dtb.dts.tmp发出来看下
lisd
6
5楼和3楼的dts对应不上
编译后的应该有这一段
spi_wk2xxx {
power_gpios: power-gpios {
rockchip,pins = <2 4 0 &pcfg_pull_none>;
reset_gpios: reset-gpios {
rockchip,pins = <1 17 0 &pcfg_pull_none>;
irq_gpios: irq-gpios {
rockchip,pins = <1 2 0 &pcfg_pull_none>;
cs_gpios: cs-gpios {
rockchip,pins = <1 10 0 &pcfg_pull_none>;
但是5楼的没有,重新编译内核确认下是不是没有编译到
lisd
8
看起来没问题,我这里验证是正常的,升级下附件的boot.img试下
lisd
9
单独下载 boot 后,开不了机了,直接进入maskrom 模式了!(C:\Users\chenpeng\Desktop\下载boot 失败图片.jpg)
图片见附件
另外从log上看
03-24 11:31:59.988 0 0 W rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
03-24 11:31:59.988 0 0 W rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
03-24 11:31:59.988 0 0 W rockchip-spi ff1d0000.spi: no high_speed pinctrl state
03-24 11:31:59.989 0 0 F : register firefly_spi_init spi return v = :0
03-24 11:31:59.989 0 0 W 11wk2xxx_probe: setup mode 0, 0 bits/w, 0 Hz max
03-24 11:31:59.989 0 0 W : wk2xxx_probe() Can not read property power-gpio
03-24 11:31:59.989 0 0 W wk2xxxspi: probe of spi0.0 failed with error -2
03-24 11:31:59.989 0 0 F : register spi return v = :0
是不是用WK2XXX 时,要把rockchip_spi 去掉啊?还是power gpio 脚被占用了?
单独烧录,开不了机问题已解决,并确定,您这边给的boot 开机后,是有ttysWK0 ttysWK1 ttysWK2 ttysWK3 节点的, 帮忙看一下,我下载的代码却没有(完全按照wiki 文档一步步操作,编译出来的软件)
帮忙看一下,是不是这个文件有问题?
spi-wk2xxx.rar (74.1 KB)
代码里面对应得SPi_wk2xxx 文件,见附件
android 7.1的节点ttysWK1-4是ok的,但是android10.0无这些节点,经检查发现,android7.1用的spi-wk2xxx驱动被打成了包,将其替换掉android10.0中,编译报错,最终的解决办法找一份spi-wk2xxx.c和spi-wk2xxx.h移植到android10.0上,且删除原来spi-wk2xxx的引用
