屏蔽掉mipi后,整体编译显示u-boot/trust.img not fount! 请问这样正常吗,哪个是结果
固件文件名称:firefly_rk3588_android12.0_git_20220311
Log日志:log.txt
2022-03-24 18:36:58 - build_super_image.py - INFO : Done writing image out/target/product/rk3588_firefly_itx_3588j/super.img
#### build completed successfully (11:44 (mm:ss)) ####
Build android ok!
====== make and copy android images
./mkimage.sh
TARGET_PRODUCT=rk3588_firefly_itx_3588j
TARGET_BASE_PARAMETER_IMAGE==device/rockchip/common/baseparameter/8k_4k_baseparameter.img
HIGH_RELIABLE_RECOVERY_OTA=
BOARD_AVB_ENABLE=false
system filesysystem is ext4
create dtbo.img…
done.
create rockdev/Image-rk3588_firefly_itx_3588j/resource.img…
done.
create rockdev/Image-rk3588_firefly_itx_3588j/boot.img…
done.
create rockdev/Image-rk3588_firefly_itx_3588j/boot-debug.img…
done.
skip copy images: /home/stone/FireFly/Sources/RK3588_Android12.0/out/target/product/rk3588_firefly_itx_3588j/vendor_boot.img
skip copy images: /home/stone/FireFly/Sources/RK3588_Android12.0/out/target/product/rk3588_firefly_itx_3588j/vendor_boot-debug.img
create rockdev/Image-rk3588_firefly_itx_3588j/recovery.img…
done.
create rockdev/Image-rk3588_firefly_itx_3588j/super.img…
done.
skip copy images: /home/stone/FireFly/Sources/RK3588_Android12.0/out/target/product/rk3588_firefly_itx_3588j/userdata.img
create vbmeta.img…
BOARD_AVB_ENABLE is false, use default vbmeta.img
create misc.img… done.
create uboot.img…
make oem images…
u-boot/trust.img not fount! Please make it from u-boot first!
create loader…
create config.cfg…
create baseparameter…done.
Make image ok!
log.txt (12.1 KB)
该编译是正常,没有问题,现在trust.img文件没有用到。
