warning: GnuPG was not available during last “repo init”
warning: Cannot automatically authenticate repo.“”"
error: .repo/repo/: contains uncommitted changes
Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN.
==========Start building buildroot==========
TARGET_BUILDROOT_CONFIG=firefly_rv1126_rv1109
./build.sh: line 742: /usr/bin/time: No such file or directory
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 742:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
remote: Total 2711 (delta 1321), reused 2619 (delta 1276), pack-reused 0 | 2.41 MiB/s
Receiving objects: 100% (2711/2711), 550.63 MiB | 1.24 MiB/s, done.
Resolving deltas: 100% (1321/1321), completed with 11 local objects.
From https://gitlab.com/firefly-linux/docs
[new tag] rk3588/linux_release_v1.1.1a → rk3588/linux_release_v1.1.1a
Fetching projects: 100% (48/48), done.
info: A new version of repo is available
warning: project ‘repo’ branch ‘default’ is not signed
warning: Skipped upgrade to unverified version
Syncing work tree: 19% (9/47) error: The following untracked working tree files would be overwritten by checkout:
RK3588
Please move or remove them before you switch branches.
Aborting
Syncing work tree: 100% (47/47), done.
