Liuth 发表于 2022-3-31 14:19
有 https://gitlab.com/firefly-linux/prebuilts/gcc/linux-x86/aarch64
用那个 linaro-6.3.1 就可以
多谢, 用这个交叉编译成功了.
但出现了新的问题.
github上有人遇到了相似了问题,提供的解决方案是删除rga相关代码. 我想是否有更优的解决方案?
https://github.com/rockchip-linux/rknpu2/issues/12
user@firefly:~/work/rknn_yolov5_demo_Linux$ export LD_LIBRARY_PATH=./lib
user@firefly:~/work/rknn_yolov5_demo_Linux$ sudo ./rknn_yolov5_demo model/RK356X/yolov5s-640-640.rknn model/bus.jpg
Rga built version:06fc7c4
post process config: box_conf_threshold = 0.50, nms_threshold = 0.60
Read model/bus.jpg …
img width = 640, img height = 640
Loading mode…
sdk version: 1.2.0 (9db21b35d@2022-01-14T15:16:23) driver version: 0.4.2
model input num: 1, output num: 3
index=0, name=images, n_dims=4, dims=[1, 640, 640, 3], n_elems=1228800, size=1228800, fmt=NHWC, type=UINT8, qnt_type=AFFINE, zp=-128, scale=0.003922
index=0, name=output, n_dims=5, dims=[1, 3, 85, 80], n_elems=1632000, size=1632000, fmt=NCHW, type=INT8, qnt_type=AFFINE, zp=77, scale=0.080445
index=1, name=371, n_dims=5, dims=[1, 3, 85, 40], n_elems=408000, size=408000, fmt=NCHW, type=INT8, qnt_type=AFFINE, zp=56, scale=0.080794
index=2, name=390, n_dims=5, dims=[1, 3, 85, 20], n_elems=102000, size=102000, fmt=NCHW, type=INT8, qnt_type=AFFINE, zp=69, scale=0.081305
model is NHWC input fmt
model input height=640, width=640, channel=3
./rknn_yolov5_demo: symbol lookup error: ./rknn_yolov5_demo: undefined symbol: wrapbuffer_virtualaddr_t
注释掉rga相关的代码可以运行成功.运行结果如下:
Loading mode…
once run use 65.124000 ms
loadLabelName ./model/coco_80_labels_list.txt
loop count = 10 , average run 78.907700 ms
