运行firefly_rkmedia_demo下的例程ffrtsp_demo_test
#ffrtsp_demo_test rtsp://admin:admin@192.168.1.88:554/11
rtsp://192.168.1.100:8554/H264_stream_0
然后使用VLC打开:rtsp://192.168.1.100:8554/H264_stream_0
VLC提示打开失败。
备注:
1.摄像头、电脑、RV1126开发板在同一个局域网,互相ping是通的;
2.电脑使用VLC打开摄像头rtsp://admin:admin@192.168.1.88:554/11,播放正常;
执行时,屏幕没有打印字符串“FFRTSP_Send start”,估计ffrtsp_get的回调函数FFRTSP_Send()没有执行。
demo代码如下:
#include <pthread.h>
#include <getopt.h>
#include <math.h>
#include <signal.h>
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include "ffrtsp/ffrtsp.hh"
#define RTSP_PORT 8554
//#define SAVE_FILE
struct RTSP_PUSH_INFO ffrtsp_push[MAXFFRTSPChn];
int FFRTSP_Send(u_int8_t* framebuff,unsigned framesize,bool * quit,int cur_chn)
printf("FFRTSP_Send start\n");
if (ffrtsp_push[cur_chn].fp == NULL)
return -1;
#ifdef SAVE_FILE
char save_file_path[30] = "test_rtsp_";
char str[10] = {0};
sprintf(str, "%d", cur_chn);
strcat(save_file_path,str);
FILE *fp = fopen(save_file_path, "a+b");
fwrite(framebuff, framesize, 1, fp);
fclose(fp);
fp = NULL;
#else
fwrite(framebuff,framesize, 1, ffrtsp_push[cur_chn].fp);
#endif
static void *rtspgetbuff(void *data) {
ffrtspGet(*(struct FFRTSPGet *)data);
static void *rtsppushbuff(void *data) {
ffrtsph264Push((struct RTSP_PUSH_INFO *)data); //h265 需要用 ffrtsph265Push
int main(int argc, char **argv){
struct FFRTSPGet ffrtsp_get;
ffrtsp_get.count = argc - 1;
ffrtsp_get.callback = FFRTSP_Send;
pthread_t rtsppush_thread[MAXFFRTSPChn];
int i = 0;
for(i = 0; i < argc - 1; i++) {
ffrtsp_get.ffrtsp_get_info[i].url = argv[i + 1];
ffrtsp_push[i].idex = i;
ffrtsp_push[i].port = RTSP_PORT + i;
pthread_create(&rtsppush_thread[i], NULL, rtsppushbuff, (void *)&ffrtsp_push[i]);
pthread_t rtspget_thread;
pthread_create(&rtspget_thread, NULL, rtspgetbuff, (void *)&ffrtsp_get);
while (1) {
usleep(3000 * 1000);
return 0;
