SDK包名称:firefly_rk3328_android10.0_git_20211215
SDK修改内容:u-boot的defconfig文件以及kernel下的dts文件
Log日志:null.txt
编译命令:
./FFTools/make.sh -d roc-rk3328-pc -j8 -l roc_rk3328_pc_32-userdebug./FFTools/mkupdate/mkupdate.sh -l roc_rk3328_pc_32-userdebug
分别修改了U-boot下的defconfig以及kernel下的dts文件,修改如下,没有发现wiki上提到的kernel/arch/arm64/boot/dts/rk3328-roc-pc-port.dtsi这个文件。
烧写img后,串口没有任何输出,img更新成功了,接上HDMI一直提示蓝牙有问题。交换串口线TX和RX也没有效果。
请问下是哪里修改的有问题吗?
chris@LAPTOP-TBE0OMGS:~/firefly/firefly_rk3328_android10.0$ git diff kernel/arch/arm64/boot/dts/rockchip/rk3328-android.dtsi
diff --git a/kernel/arch/arm64/boot/dts/rockchip/rk3328-android.dtsi b/kernel/arch/arm64/boot/dts/rockchip/rk3328-android.dtsi
index 46549a60cf..2fd8b9c025 100644
— a/kernel/arch/arm64/boot/dts/rockchip/rk3328-android.dtsi
+++ b/kernel/arch/arm64/boot/dts/rockchip/rk3328-android.dtsi
@@ -16,7 +16,7 @@
rockchip,wake-irq = <0>;
/* If enable uart uses irq instead of fiq */
rockchip,irq-mode-enable = <0>;
rockchip,baudrate = <1500000>; /* Only 115200 and 1500000 */
rockchip,baudrate = <115200>; /* Only 115200 and 1500000 */ interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_LOW>; status = "okay"; };
chris@LAPTOP-TBE0OMGS:~/firefly/firefly_rk3328_android10.0$ git diff kernel/arch/arm64/boot/dts/rockchip/roc-rk3328-pc.dtsi
diff --git a/kernel/arch/arm64/boot/dts/rockchip/roc-rk3328-pc.dtsi b/kernel/arch/arm64/boot/dts/rockchip/roc-rk3328-pc.dtsi
index af2960757f..17f2404179 100644
— a/kernel/arch/arm64/boot/dts/rockchip/roc-rk3328-pc.dtsi
+++ b/kernel/arch/arm64/boot/dts/rockchip/roc-rk3328-pc.dtsi
@@ -180,7 +180,7 @@
#if (UART2_FUNCTION == UART2_BLUETOOTH)
&fiq_debugger {
- status = “disabled”;
- status = “okay”;
&chosen {
@@ -188,7 +188,7 @@
&uart2 {
- status = “okay”;
dma-names = “!tx”,“!rx”;
#else
chris@LAPTOP-TBE0OMGS:~/firefly/firefly_rk3328_android10.0$ git diff u-boot/configs/rk3328_defconfig
diff --git a/u-boot/configs/rk3328_defconfig b/u-boot/configs/rk3328_defconfig
index 9e9b7544c1..b1c7db04b1 100644
— a/u-boot/configs/rk3328_defconfig
+++ b/u-boot/configs/rk3328_defconfig
@@ -102,7 +102,7 @@ CONFIG_SPL_RAM=y
CONFIG_TPL_RAM=y
CONFIG_ROCKCHIP_SDRAM_COMMON=y
CONFIG_DM_RESET=y
-CONFIG_BAUDRATE=1500000
+CONFIG_BAUDRATE=115200
CONFIG_DEBUG_UART_BASE=0xFF130000
CONFIG_DEBUG_UART_CLOCK=24000000
CONFIG_DEBUG_UART_SHIFT=2
null.txt (4 Bytes)
