RK3288 编译android 没有生成system.img
如题,make的时候没有生成system.img,也没有报错试了多次都一样。
Note: Recompile with -Xlint:unchecked for details.
100 warnings
Preparing output jar [/home/zhsun/proj/firefly-rk3288/out/target/common/obj/APPS/Mms_intermediates/proguard.classes.jar]
Copying resources from program jar [/home/zhsun/proj/firefly-rk3288/out/target/common/obj/APPS/Mms_intermediates/classes.jar]
patch 0 is 207 bytes (of 6307850)
patch 1 is 2935154 bytes (of 1183764)
patch 2 is 186 bytes (of 12258)
chunk 0: normal ( 0, 6307850) 207
chunk 1: deflate ( 6307850, 4263826) 2935154 (null)
chunk 2: normal ( 10571676, 12388) 186
zhsun@ubuntu64:~/proj/firefly-rk3288$ ls /home/zhsun/proj/firefly-rk3288/out/target/product/rk3288/system/
app build.prop fonts lib media tts vendor
bin etc framework manifest.xml priv-app usr xbin
zhsun@ubuntu64:~/proj/firefly-rk3288$ sudo ./mkimage.sh
TARGET_PRODUCT=rk3288
TARGET_HARDWARE=rk30board
system filesysystem is ext4
create boot.img without kernel… done.
create recovery.img with kernel and with out resource… done.
create misc.img… done.
create system.img… ls: cannot access /home/zhsun/proj/firefly-rk3288/out/target/product/rk3288/system.img: No such file or directory
./mkimage.sh: line 91: [: -gt: unary operator expected
Please make first!!!
编译完成后应该是有一个system.img的,mkimage.sh 是打包命令。先检查一下make之后编译后有没有system.img
就是编译之后没有system.img
zhsun@ubuntu64:~/proj/firefly-rk3288/rockdev/Image-rk3288$ ls
boot.img misc.img pcba_small_misc.img pcba_whole_misc.img recovery.img
不用make clean,再make一次,看看编译到最后的有无提示生成system.img
rm -rf out后,不用root权限重新编译后试试看
第三次 make之后system.img竟然神奇的出现了
我也遇到了这个问题,反复编译没有生成system.img,怎么破。
你好,你这个问题解决了吗
