SDK包名称:Firefly-RK356X_Android11.0_git_20210824
SDK修改内容:无
Log日志:make_log.txt
复现步骤:
1、source build/envsetup.sh
2、lunch rk3568_firefly_roc_pc-userdebug
3、make installclean
4、make -j24
lrs@lrs-YangTianM4000e-08:/mnt/data/lrs_share/RK356X_Android11.0$ make -j24
19:22:06 ************************************************************
19:22:06 You are building on a machine with 15.6GB of RAM
19:22:06
19:22:06 The minimum required amount of free memory is around 16GB,
19:22:06 and even with that, some configurations may not work.
19:22:06
19:22:06 If you run into segfaults or other errors, try reducing your
19:22:06 -j value.
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=11
TARGET_PRODUCT=rk3568_firefly_roc_pc
TARGET_BUILD_VARIANT=userdebug
TARGET_BUILD_TYPE=release
TARGET_ARCH=arm64
TARGET_ARCH_VARIANT=armv8-a
TARGET_CPU_VARIANT=cortex-a55
TARGET_2ND_ARCH=arm
TARGET_2ND_ARCH_VARIANT=armv8-2a
TARGET_2ND_CPU_VARIANT=cortex-a55
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-5.13.0-35-generic-x86_64-Ubuntu-20.04.4-LTS
HOST_CROSS_OS=windows
HOST_CROSS_ARCH=x86
HOST_CROSS_2ND_ARCH=x86_64
HOST_BUILD_TYPE=release
BUILD_ID=RQ3A.210705.001
OUT_DIR=out
wildcard(out/target/product/rk3568_firefly_roc_pc/clean_steps.mk) was changed, regenerating…
$(shell date +%y%m%d%H%M) was changed, regenerating…
[100% 24087/24087] initializing build system …
device/rockchip/common/prebuild.mk:2: warning: Generating manifest snapshot at out/commit_id.xml…
device/rockchip/common/prebuild.mk:3: warning: You can disable this by removing this and setting BOARD_RECORD_COMMIT_ID := false in BoardConfig.mk
[ 98% 24092/24369] including build/make/target/board/Android.mk …
build fstab file with device/rockchip/common/scripts/fstab_tools/fstab.in…
rebuilding dtbo image with device/rockchip/rk356x/rk3568_firefly_roc_pc/dt-overlay.in…
build parameter.txt with device/rockchip/common/scripts/parameter_tools/parameter.in…
[ 99% 24149/24369] including external/rk_tee_user/v2/Android.mk …
‘building rk_tee_user v2’
[ 99% 24210/24369] including hardware/rockchip/camera_engine_rkisp/Android.mk …
TARGET_BOARD_PLATFORM=rk356x
[ 99% 24217/24369] including hardware/rockchip/libhwjpeg/Android.mk …
[ 99% 24220/24369] including hardware/rockchip/librga/Android.mk …
RGA is compiling with Android.mk Generated version.h
[ 99% 24222/24369] including hardware/rockchip/omx_il/Android.mk …
date: Unknown option ‘R’ (see “date --help”)
cp: .git/hooks/pre-commit: No such file or directory
tools/hooks .git/hooks
[ 99% 24368/24369] finishing build rules …
packages/apps/Camera2/Android.mk: warning: “Camera2 (app:platform) should not link against libjni_jpegutil (native:ndk:libc++:static)”
FAILED: ninja: ‘kernel/arch/arm64/boot/Image’, needed by ‘out/target/product/rk3568_firefly_roc_pc/kernel’, missing and no known rule to make it
19:23:44 ninja failed with: exit status 1
#### failed to build some targets (01:39 (mm:ss)) ####
make_log.txt (2.99 KB)
