RV1126 mpp交叉编译
想了解一下,如何在X86设备上编译出MPP的.SO文件.
本人尝试进入到/home/fuxi/rv1126/rv1126_rv1109_linux_release_20211022/external/mpp/build/linux/arm目录下进行编译
已安装了g+±arm-linux-gnueabihf和gcc-arm-linux-gnueabihf。cmake阶段无异常,到了make阶段出现一下报错
请问一下我该怎么处理这个报错?
[ 68%] Linking CXX shared library librockchip_mpp.so
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, CMakeFiles/rockchip_mpp.dir/mpp_info.cpp.o does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file CMakeFiles/rockchip_mpp.dir/mpp_info.cpp.o
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, CMakeFiles/rockchip_mpp.dir/mpp.cpp.o does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file CMakeFiles/rockchip_mpp.dir/mpp.cpp.o
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, CMakeFiles/rockchip_mpp.dir/mpp_impl.cpp.o does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file CMakeFiles/rockchip_mpp.dir/mpp_impl.cpp.o
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, CMakeFiles/rockchip_mpp.dir/mpi.cpp.o does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file CMakeFiles/rockchip_mpp.dir/mpi.cpp.o
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/libmpp_codec.a(mpp_enc_v2.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/libmpp_codec.a(mpp_enc_v2.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/libmpp_codec.a(enc_impl.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/libmpp_codec.a(enc_impl.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/libmpp_codec.a(mpp_dec.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/libmpp_codec.a(mpp_dec.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/libmpp_codec.a(mpp_parser.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/libmpp_codec.a(mpp_parser.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/libmpp_codec.a(mpp_enc_impl.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/libmpp_codec.a(mpp_enc_impl.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/libmpp_hal.a(mpp_enc_hal.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/libmpp_hal.a(mpp_enc_hal.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/libmpp_hal.a(hal_task.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/libmpp_hal.a(hal_task.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/libmpp_hal.a(mpp_hal.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/libmpp_hal.a(mpp_hal.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, vproc/libmpp_vproc.a(mpp_dec_vproc.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file vproc/libmpp_vproc.a(mpp_dec_vproc.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, vproc/libmpp_vproc.a(mpp_vproc_dev.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file vproc/libmpp_vproc.a(mpp_vproc_dev.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_enc_refs.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_enc_refs.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_enc_ref.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_enc_ref.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_enc_cfg.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_enc_cfg.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_dec_cfg.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_dec_cfg.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_buf_slot.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_buf_slot.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_buffer_impl.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_buffer_impl.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_buffer.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_buffer.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_packet.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_packet.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_frame.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_frame.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_callback.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_callback.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_task_impl.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_task_impl.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_task.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_task.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_meta.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_meta.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_trie.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_trie.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_bitwrite.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_bitwrite.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_bitread.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_bitread.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_bitput.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_bitput.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_cfg.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_cfg.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, base/libmpp_base.a(mpp_2str.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file base/libmpp_base.a(mpp_2str.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, vproc/iep/libvproc_iep.a(iep.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file vproc/iep/libvproc_iep.a(iep.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, vproc/iep2/libvproc_iep2.a(iep2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file vproc/iep2/libvproc_iep2.a(iep2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, vproc/iep2/libvproc_iep2.a(iep2_ff.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file vproc/iep2/libvproc_iep2.a(iep2_ff.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, vproc/iep2/libvproc_iep2.a(iep2_gmv.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file vproc/iep2/libvproc_iep2.a(iep2_gmv.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, vproc/iep2/libvproc_iep2.a(iep2_osd.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file vproc/iep2/libvproc_iep2.a(iep2_osd.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, vproc/iep2/libvproc_iep2.a(iep2_pd.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file vproc/iep2/libvproc_iep2.a(iep2_pd.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/avs/libcodec_avsd.a(avsd_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/avs/libcodec_avsd.a(avsd_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/avs/libcodec_avsd.a(avsd_parse.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/avs/libcodec_avsd.a(avsd_parse.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h263/libcodec_h263d.a(h263d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h263/libcodec_h263d.a(h263d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h263/libcodec_h263d.a(h263d_parser.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h263/libcodec_h263d.a(h263d_parser.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_parse.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_parse.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_slice.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_slice.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_sps.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_sps.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_pps.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_pps.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_scalist.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_scalist.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_sei.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_sei.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_dpb.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_dpb.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_init.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_init.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h264/libcodec_h264d.a(h264d_fill.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h264/libcodec_h264d.a(h264d_fill.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h265/libcodec_h265d.a(h265d_parser.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h265/libcodec_h265d.a(h265d_parser.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h265/libcodec_h265d.a(h265d_ps.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h265/libcodec_h265d.a(h265d_ps.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h265/libcodec_h265d.a(h265d_refs.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h265/libcodec_h265d.a(h265d_refs.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h265/libcodec_h265d.a(h265d_sei.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h265/libcodec_h265d.a(h265d_sei.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/h265/libcodec_h265d.a(h265d_parser2_syntax.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/h265/libcodec_h265d.a(h265d_parser2_syntax.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/m2v/libcodec_mpeg2d.a(m2vd_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/m2v/libcodec_mpeg2d.a(m2vd_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/m2v/libcodec_mpeg2d.a(m2vd_parser.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/m2v/libcodec_mpeg2d.a(m2vd_parser.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/mpg4/libcodec_mpeg4d.a(mpg4d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/mpg4/libcodec_mpeg4d.a(mpg4d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/mpg4/libcodec_mpeg4d.a(mpg4d_parser.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/mpg4/libcodec_mpeg4d.a(mpg4d_parser.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/vp8/libcodec_vp8d.a(vp8d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/vp8/libcodec_vp8d.a(vp8d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/vp8/libcodec_vp8d.a(vp8d_parser.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/vp8/libcodec_vp8d.a(vp8d_parser.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/vp9/libcodec_vp9d.a(vp9d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/vp9/libcodec_vp9d.a(vp9d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/vp9/libcodec_vp9d.a(vp9d_parser.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/vp9/libcodec_vp9d.a(vp9d_parser.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/vp9/libcodec_vp9d.a(vpx_rac.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/vp9/libcodec_vp9d.a(vpx_rac.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/vp9/libcodec_vp9d.a(vp9d_parser2_syntax.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/vp9/libcodec_vp9d.a(vp9d_parser2_syntax.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/jpeg/libcodec_jpegd.a(jpegd_parser.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/jpeg/libcodec_jpegd.a(jpegd_parser.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/jpeg/libcodec_jpege.a(jpege_api_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/jpeg/libcodec_jpege.a(jpege_api_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h265/libcodec_h265e.a(h265e_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h265/libcodec_h265e.a(h265e_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h265/libcodec_h265e.a(h265e_dpb.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h265/libcodec_h265e.a(h265e_dpb.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h265/libcodec_h265e.a(h265e_slice.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h265/libcodec_h265e.a(h265e_slice.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h265/libcodec_h265e.a(h265e_header_gen.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h265/libcodec_h265e.a(h265e_header_gen.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h265/libcodec_h265e.a(h265e_stream.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h265/libcodec_h265e.a(h265e_stream.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h265/libcodec_h265e.a(h265e_syntax.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h265/libcodec_h265e.a(h265e_syntax.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h265/libcodec_h265e.a(h265e_enctropy.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h265/libcodec_h265e.a(h265e_enctropy.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h265/libcodec_h265e.a(h265e_ps.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h265/libcodec_h265e.a(h265e_ps.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/vp8/libcodec_vp8e.a(vp8e_api_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/vp8/libcodec_vp8e.a(vp8e_api_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/dec/dummy/libcodec_dummy_dec.a(dummy_dec_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/dec/dummy/libcodec_dummy_dec.a(dummy_dec_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h264d/libhal_h264d.a(hal_h264d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h264d/libhal_h264d.a(hal_h264d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h264d/libhal_h264d.a(hal_h264d_vdpu34x.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h264d/libhal_h264d.a(hal_h264d_vdpu34x.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h264d/libhal_h264d.a(hal_h264d_rkv_reg.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h264d/libhal_h264d.a(hal_h264d_rkv_reg.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h264d/libhal_h264d.a(hal_h264d_vdpu2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h264d/libhal_h264d.a(hal_h264d_vdpu2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h264d/libhal_h264d.a(hal_h264d_vdpu1.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h264d/libhal_h264d.a(hal_h264d_vdpu1.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h264d/libhal_h264d.a(hal_h264d_vdpu_com.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h264d/libhal_h264d.a(hal_h264d_vdpu_com.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/avsd/libhal_avsd.a(hal_avsd_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/avsd/libhal_avsd.a(hal_avsd_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/avsd/libhal_avsd.a(hal_avsd_reg.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/avsd/libhal_avsd.a(hal_avsd_reg.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/h263d/libhal_h263d.a(hal_h263d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/h263d/libhal_h263d.a(hal_h263d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/h263d/libhal_h263d.a(hal_h263d_vdpu1.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/h263d/libhal_h263d.a(hal_h263d_vdpu1.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/h263d/libhal_h263d.a(hal_h263d_vdpu2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/h263d/libhal_h263d.a(hal_h263d_vdpu2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h265d/libhal_h265d.a(hal_h265d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h265d/libhal_h265d.a(hal_h265d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h265d/libhal_h265d.a(hal_h265d_rkv.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h265d/libhal_h265d.a(hal_h265d_rkv.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h265d/libhal_h265d.a(hal_h265d_vdpu34x.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h265d/libhal_h265d.a(hal_h265d_vdpu34x.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/h265d/libhal_h265d.a(hal_h265d_com.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/h265d/libhal_h265d.a(hal_h265d_com.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/m2vd/libhal_mpeg2d.a(hal_m2vd_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/m2vd/libhal_mpeg2d.a(hal_m2vd_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/m2vd/libhal_mpeg2d.a(hal_m2vd_vdpu1.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/m2vd/libhal_mpeg2d.a(hal_m2vd_vdpu1.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/m2vd/libhal_mpeg2d.a(hal_m2vd_vdpu2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/m2vd/libhal_mpeg2d.a(hal_m2vd_vdpu2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/mpg4d/libhal_mpeg4d.a(hal_m4vd_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/mpg4d/libhal_mpeg4d.a(hal_m4vd_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/mpg4d/libhal_mpeg4d.a(hal_m4vd_vdpu1.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/mpg4d/libhal_mpeg4d.a(hal_m4vd_vdpu1.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/mpg4d/libhal_mpeg4d.a(hal_m4vd_vdpu2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/mpg4d/libhal_mpeg4d.a(hal_m4vd_vdpu2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/mpg4d/libhal_mpeg4d.a(hal_m4vd_com.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/mpg4d/libhal_mpeg4d.a(hal_m4vd_com.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8d/libhal_vp8d.a(hal_vp8d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8d/libhal_vp8d.a(hal_vp8d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8d/libhal_vp8d.a(hal_vp8d_vdpu2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8d/libhal_vp8d.a(hal_vp8d_vdpu2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8d/libhal_vp8d.a(hal_vp8d_vdpu1.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8d/libhal_vp8d.a(hal_vp8d_vdpu1.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/vp9d/libhal_vp9d.a(hal_vp9d_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/vp9d/libhal_vp9d.a(hal_vp9d_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/vp9d/libhal_vp9d.a(hal_vp9d_rkv.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/vp9d/libhal_vp9d.a(hal_vp9d_rkv.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/vp9d/libhal_vp9d.a(hal_vp9d_vdpu34x.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/vp9d/libhal_vp9d.a(hal_vp9d_vdpu34x.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/vp9d/libhal_vp9d.a(hal_vp9d_com.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/vp9d/libhal_vp9d.a(hal_vp9d_com.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_vdpu2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_vdpu2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_vdpu1.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_vdpu1.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_rkv.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_rkv.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_common.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpegd/libhal_jpegd.a(hal_jpegd_common.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/common/h264/libhal_h264e.a(hal_h264e_api_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/common/h264/libhal_h264e.a(hal_h264e_api_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkenc/h264e/libhal_h264e_rkv.a(hal_h264e_vepu541.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkenc/h264e/libhal_h264e_rkv.a(hal_h264e_vepu541.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/h264e/libhal_h264e_vpu.a(hal_h264e_vepu2_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/h264e/libhal_h264e_vpu.a(hal_h264e_vepu2_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/h264e/libhal_h264e_vpu.a(hal_h264e_vepu1_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/h264e/libhal_h264e_vpu.a(hal_h264e_vepu1_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/h264e/libhal_h264e_vpu.a(hal_h264e_vepu_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/h264e/libhal_h264e_vpu.a(hal_h264e_vepu_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/h264e/libhal_h264e_vpu.a(hal_h264e_vpu_tbl.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/h264e/libhal_h264e_vpu.a(hal_h264e_vpu_tbl.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h264/libcodec_h264e.a(h264e_api_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h264/libcodec_h264e.a(h264e_api_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h264/libcodec_h264e.a(h264e_sps.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h264/libcodec_h264e.a(h264e_sps.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h264/libcodec_h264e.a(h264e_pps.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h264/libcodec_h264e.a(h264e_pps.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h264/libcodec_h264e.a(h264e_sei.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h264/libcodec_h264e.a(h264e_sei.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h264/libcodec_h264e.a(h264e_dpb.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h264/libcodec_h264e.a(h264e_dpb.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/enc/h264/libcodec_h264e.a(h264e_slice.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/enc/h264/libcodec_h264e.a(h264e_slice.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/rc/libenc_rc.a(rc_impl.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/rc/libenc_rc.a(rc_impl.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/rc/libenc_rc.a(rc.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/rc/libenc_rc.a(rc.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/rc/libenc_rc.a(h264e_rc.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/rc/libenc_rc.a(h264e_rc.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/rc/libenc_rc.a(h265e_rc.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/rc/libenc_rc.a(h265e_rc.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/rc/libenc_rc.a(jpege_rc.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/rc/libenc_rc.a(jpege_rc.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/rc/libenc_rc.a(vp8e_rc.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/rc/libenc_rc.a(vp8e_rc.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/rc/libenc_rc.a(rc_model_v2_smt.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/rc/libenc_rc.a(rc_model_v2_smt.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/rc/libenc_rc.a(rc_model_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/rc/libenc_rc.a(rc_model_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/rc/libenc_rc.a(rc_base.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/rc/libenc_rc.a(rc_base.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, codec/libmpp_rc.a(mpp_rc.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file codec/libmpp_rc.a(mpp_rc.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpege/libhal_jpege.a(hal_jpege_api_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpege/libhal_jpege.a(hal_jpege_api_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpege/libhal_jpege.a(hal_jpege_vepu1_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpege/libhal_jpege.a(hal_jpege_vepu1_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpege/libhal_jpege.a(hal_jpege_vepu2_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpege/libhal_jpege.a(hal_jpege_vepu2_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpege/libhal_jpege.a(hal_jpege_hdr.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpege/libhal_jpege.a(hal_jpege_hdr.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/jpege/libhal_jpege.a(hal_jpege_base.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/jpege/libhal_jpege.a(hal_jpege_base.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/common/libhal_vepu_common.a(vepu_common.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/common/libhal_vepu_common.a(vepu_common.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/common/h265/libhal_h265e.a(hal_h265e_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/common/h265/libhal_h265e.a(hal_h265e_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkenc/h265e/libhal_h265e_vepu541.a(hal_h265e_vepu541.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkenc/h265e/libhal_h265e_vepu541.a(hal_h265e_vepu541.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/h265e/libhal_h265e_vpu.a(hal_h265e_vepu22.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/h265e/libhal_h265e_vpu.a(hal_h265e_vepu22.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkenc/common/libhal_vepu541_common.a(vepu541_common.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkenc/common/libhal_vepu541_common.a(vepu541_common.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/common/libhal_common.a(hal_info.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/common/libhal_common.a(hal_info.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/common/libhal_common.a(hal_bufs.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/common/libhal_common.a(hal_bufs.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, vproc/rga/libvproc_rga.a(rga.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file vproc/rga/libvproc_rga.a(rga.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_api_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_api_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_vepu1_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_vepu1_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_vepu2_v2.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_vepu2_v2.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_base.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_base.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_putbit.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_putbit.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_table.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_table.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_entropy.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/vpu/vp8e/libhal_vp8e.a(hal_vp8e_entropy.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/dummy/libhal_dummy.a(hal_dummy_dec_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/dummy/libhal_dummy.a(hal_dummy_dec_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/dummy/libhal_dummy.a(hal_dummy_enc_api.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/dummy/libhal_dummy.a(hal_dummy_enc_api.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_soc.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_soc.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_platform.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_platform.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_allocator.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_allocator.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_thread.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_thread.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_common.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_common.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_time.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_time.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_list.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_list.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_mem.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_mem.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_env.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_env.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_log.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_log.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(os_allocator.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(os_allocator.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(os_mem.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(os_mem.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(os_env.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(os_env.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(os_log.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(os_log.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(allocator_std.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(allocator_std.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(allocator_ion.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(allocator_ion.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(allocator_ext_dma.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(allocator_ext_dma.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(allocator_drm.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(allocator_drm.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_device.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_device.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_service.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_service.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(vcodec_service.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(vcodec_service.c.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, ../osal/libosal.a(mpp_runtime.cpp.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file ../osal/libosal.a(mpp_runtime.cpp.o)
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: error: librockchip_mpp.so.0 uses VFP register arguments, hal/rkdec/libvdpu34x_com.a(vdpu34x_com.c.o) does not
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file hal/rkdec/libvdpu34x_com.a(vdpu34x_com.c.o)
collect2: error: ld returned 1 exit status
make[2]: *** [mpp/CMakeFiles/rockchip_mpp.dir/build.make:185:mpp/librockchip_mpp.so.0] 错误 1
make[1]: *** [CMakeFiles/Makefile2:2009:mpp/CMakeFiles/rockchip_mpp.dir/all] 错误 2
make: *** [Makefile:130:all] 错误 2
直接编译一遍buildroot 在输出目录 sdk/buildroot/output/xxxx/build/mpp-xx/ 就能找到交叉编译好的 so 了,在这里 make 也可以继续完成二次编译
板蓝根 发表于 2022-4-16 18:15
直接编译一遍buildroot 在输出目录 sdk/buildroot/output/xxxx/build/mpp-xx/ 就能找到交叉编译好的 so 了 …
好的,根据您的方法,问题已解决
