/dev/console is Ok
starting version 237
[ 1.930630] phy phy-fe8a0000.usb2-phy.1: charger = USB_DCP_CHARGER
[ 2.567397] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x3
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Running /scripts/local-premount … done.
Warning: fsck not present, so skipping root file system
mount: mounting dev/nfs on /root failed: No such file or directory
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … IP-Config: eth0 hardware address f2:74:4c:53:9e:98 mtu 1500
[ 3.300657] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 3.300723] Generic PHY stmmac-1:00: [phy_probe-1992] led_status_value = 0x2f60
[ 3.301626] Generic PHY stmmac-1:00: phy_rtl8211f_led_fixup
[ 3.322773] Generic PHY stmmac-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-1:00, irq=POLL )
[ 3.334636] dwmac4: Master AXI performs any burst length
[ 3.334679] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[ 3.334701] rk_IP-Config: eth0 guessed broadcast address 192.168.154.255
gmac-dwmac fe010000.ethernet eth0: IEEE 1IP-Config: eth0 complete:
address: 192.168.154.10 broadcast: 192.168.154.255 netmas5k: 255.255.255.0
gatewa8y: 192.168.154.1 dns0 8: 0.0.0.0 dns1 : -0.0.0.0
rootserver2: 192.168.154.134 rootpath: 0
filename :
08 Advanced Timestamp supported
[ 3.335001] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[ 3.335453] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.335482] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 3.335646] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
no search or nameservers found in /run/net-eth0.conf /run/net-eth0.conf /run/net6-*.conf
mount: mounting /dev on /root/dev failed: No such file or directory
Warning: Something odd, no /lib/modules/4.19.219 in initramfs.
done.
mount: mounting /run on /root/run failed: No such file or directory
run-init: current directory on the same filesystem as the root: error 0
Target filesystem doesn’t have requested /sbin/init.
