现在需要要输出为1920*1200P60的显示输出,在哪个地方可以调节呢。给个思路,在源码的哪个地方可以调节这个参数。理论4K都能显示,向下应该是没有问题的
我刚找到了一个朋友与我有相同的需求,只是他的需求是1366*768
http://developer.t-firefly.com/forum.php?mod=viewthread&tid=942&highlight=�ֱ���
他解决的办法是添加一个配置信息:
我已经解决了这个问题,在lcd-box.dtsi里面添加, timing1: timing1 {
screen-type = <SCREEN_LVDS>;
lvds-format = <LVDS_8BIT_2>;
out-face = <OUT_D888_P666>;
clock-frequency = <85500000>;
hactive = <1366>;
vactive = <768>;
hback-porch = <213>;
hfront-porch = <70>;
vback-porch = <24>;
vfront-porch = <3>;
hsync-len = <143>;
vsync-len = <3>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <1>;
pixelclk-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
问题是我如果添加1920*1200P60需要怎么给参数呢?
我也找到本机的配置信息,如下,
disp_power_ctr: power_ctr {
/* rockchip,debug = <0>;
lcd_en:lcd_en {
rockchip,power_type = ;
gpios = <&gpio0 GPIO_B0 GPIO_ACTIVE_HIGH>;
rockchip,delay = <10>;
bl_en:bl_en {
rockchip,power_type = <GPIO>;
gpios = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
bl_ctr:bl_ctr {
gpios = <&gpio3 GPIO_D6 GPIO_ACTIVE_HIGH>;
lcd_rst:lcd_rst {
rockchip,power_type = <REGULATOR>;
rockchip,delay = <5>;
native-mode = <&timing1>;
timing0: timing0 {
screen-type = <SCREEN_RGB>;
out-face = <OUT_P888>;
clock-frequency = <74250000>;
hactive = <1280>;
vactive = <720>;
hback-porch = <220>;
hfront-porch = <110>;
vback-porch = <20>;
vfront-porch = <5>;
hsync-len = <40>;
vsync-len = <5>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
timing1: timing1 {
clock-frequency = <148500000>;
hactive = <1920>;
vactive = <1080>;
hback-porch = <148>;
hfront-porch = <88>;
vback-porch = <36>;
vfront-porch = <4>;
hsync-len = <44>;
vsync-len = <5>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
timing2: timing2 {
clock-frequency = <297000000>;
hactive = <3840>;
vactive = <2160>;
hback-porch = <296>;
hfront-porch = <176>;
vback-porch = <72>;
vfront-porch = <8>;
hsync-len = <88>;
vsync-len = <10>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
我是不是应该加这个参数:
timing3: timing3 {
clock-frequency = <??????>;
hactive = <1920>;
vactive = <1200>;
hback-porch = <???>;
hfront-porch = <??>;
vback-porch = <??>;
vfront-porch = <?>;
hsync-len = <??>;
vsync-len = <?>;
hsync-active = <?>;
vsync-active = <?>;
de-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
这些参数有什么定义规则?或帮我填一下,谢谢
你是什么版本? 输出到什么显示?屏?VGA ?HDMI?
是4.4.2版本,输出显示为HDMI。
配置信息为:/firefly-rk3288/kernel/arch/arm/boot/dts下的lcd-box.dtsi配置文件
/ rockchip,debug = <0>;
lcd_en:lcd_en {
bl_en:bl_en {
bl_ctr:bl_ctr {
lcd_rst:lcd_rst {
timing0: timing0 {
hactive = <1280>;
vactive = <720>;
vback-porch = <20>;
vfront-porch = <5>;
hsync-len = <40>;
vsync-len = <5>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
timing1: timing1 {
hactive = <1920>;
vactive = <1080>;
vback-porch = <36>;
vfront-porch = <4>;
hsync-len = <44>;
vsync-len = <5>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
timing2: timing2 {
clock-frequency = <154000000>;
hactive = <1920>;
vactive = <1200>;
hback-porch = <80>;
hfront-porch = <48>;
vback-porch = <26>;
vfront-porch = <3>;
hsync-len = <32>;
vsync-len = <6>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
timing3: timing3 {
hactive = <3840>;
vactive = <2160>;
vback-porch = <72>;
vfront-porch = <8>;
hsync-len = <88>;
vsync-len = <10>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
以上红色是我加的与修改的地方。
但编译完烧写进去,还是没有1920*1200P60显示项
1、请问这个修改项对吗
2、还要不要改别的地方的配置
请指教
你是说设置里面的HDMI 选项?那个你看下kernel里面的rk_hdmi_lcdc.c 以及上层Setting里面hdmi mode部分。
修改dts里面,只是默认直,并不增加HDMI输出选项
isle 发表于 2015-8-27 15:12
你是说设置里面的HDMI 选项?那个你看下kernel里面的rk_hdmi_lcdc.c 以及上层Setting里面hdmi mode部分 …
请问您说的上层是哪个目录,为什么找不到 以及上层Setting里面hdmi mode部分 …
packages/app/settings
先把驱动调成功再调上层吧,上层要学过APP的才好改,如果不会添加的,就把一项的字符串给改了。驱动相应的改
carlinluo 发表于 2015-8-28 12:19
先把驱动调成功再调上层吧,上层要学过APP的才好改,如果不会添加的,就把一项的字符串给改了。驱动相应的 …
看上去好难啊,对编程没有基础
suky8 发表于 2015-8-31 09:36
看上去好难啊,对编程没有基础
楼主,你那个1920*1200的HDMI显示调出来了吗?
static const struct hdmi_video_timing hdmi_mode = {
/* name refresh xres yres pixclock h_bp h_fp v_bp v_fp h_pw v_pw polariry PorI flag vic 2ndvic pixelrepeat interface */
{ { "720x480i@60Hz", 60, 720, 480, 27000000, 57, 19, 15, 4, 62, 3, 0, 1, 0 }, 6, HDMI_720X480I_60HZ_16_9, 2, OUT_P888},
{ { "720x576i@50Hz", 50, 720, 576, 27000000, 69, 12, 19, 2, 63, 3, 0, 1, 0 }, 21, HDMI_720X576I_50HZ_16_9, 2, OUT_P888},
{ { "720x480p@60Hz", 60, 720, 480, 27000000, 60, 16, 30, 9, 62, 6, 0, 0, 0 }, 2, HDMI_720X480P_60HZ_16_9, 1, OUT_P888},
{ { "720x576p@50Hz", 50, 720, 576, 27000000, 68, 12, 39, 5, 64, 5, 0, 0, 0 }, 17, HDMI_720X576P_50HZ_16_9, 1, OUT_P888},
{ { "1280x720p@24Hz", 24, 1280, 720, 59400000, 220, 1760, 20, 5, 40, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 60, HDMI_1280X720P_24HZ_4_3, 1, OUT_P888},
{ { "1280x720p@25Hz", 25, 1280, 720, 74250000, 220, 2420, 20, 5, 40, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 61, HDMI_1280X720P_25HZ_4_3, 1, OUT_P888},
{ { "1280x720p@30Hz", 30, 1280, 720, 74250000, 220, 1760, 20, 5, 40, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 62, HDMI_1280X720P_30HZ_4_3, 1, OUT_P888},
{ { "1280x720p@50Hz", 50, 1280, 720, 74250000, 220, 440, 20, 5, 40, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 19, HDMI_1280X720P_50HZ_4_3, 1, OUT_P888},
{ { "1280x720p@60Hz", 60, 1280, 720, 74250000, 220, 110, 20, 5, 40, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 4, HDMI_1280X720P_60HZ_4_3, 1, OUT_P888},
{ { "1920x1080i@50Hz", 50, 1920, 1080, 74250000, 148, 528, 15, 2, 44, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 1, 0 }, 20, 0, 1, OUT_P888},
{ { "1920x1080i@60Hz", 60, 1920, 1080, 74250000, 148, 88, 15, 2, 44, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 1, 0 }, 5, 0, 1, OUT_P888},
{ { "1920x1080p@24Hz", 24, 1920, 1080, 74250000, 148, 638, 36, 4, 44, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 32, HDMI_1920X1080P_24HZ_4_3, 1, OUT_P888},
{ { "1920x1080p@25Hz", 25, 1920, 1080, 74250000, 148, 528, 36, 4, 44, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 33, HDMI_1920X1080P_25HZ_4_3, 1, OUT_P888},
{ { "1920x1080p@30Hz", 30, 1920, 1080, 74250000, 148, 88, 36, 4, 44, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 34, HDMI_1920X1080P_30HZ_4_3, 1, OUT_P888},
// { { “1920x1080p@50Hz”, 60, 1920, 1200, 193250000, 336, 136, 36, 3, 200, 6, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 31, HDMI_1920X1080P_50HZ_4_3, 1, OUT_P888},
{ { “1920x1080p@50Hz”, 50, 1920, 1080, 148500000, 148, 528, 36, 4, 44, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 31, HDMI_1920X1080P_50HZ_4_3, 1, OUT_P888},
{ { “1920x1080p@60Hz”, 60, 1920, 1080, 148500000, 148, 88, 36, 4, 44, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 16, HDMI_1920X1080P_60HZ_4_3, 1, OUT_P888},
// { { “1920x1080p@60Hz”, 60, 1920, 1080, 148500000, 148, 88, 36, 4, 44, 5, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 16, HDMI_1920X1080P_60HZ_4_3, 1, OUT_P888},
{ { “3840x2160p@24Hz”, 24, 3840, 2160, 297000000, 296, 1276, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 93, HDMI_3840X2160P_24HZ_4_3, 1, OUT_P888},
{ { “3840x2160p@25Hz”, 25, 3840, 2160, 297000000, 296, 1056, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 94, HDMI_3840X2160P_25HZ_4_3, 1, OUT_P888},
{ { “3840x2160p@30Hz”, 30, 3840, 2160, 297000000, 296, 176, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 95, HDMI_3840X2160P_30HZ_4_3, 1, OUT_P888},
{ { “4096x2160p@24Hz”, 24, 4096, 2160, 297000000, 296, 1020, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 98, 0, 1, OUT_P888},
{ { “4096x2160p@25Hz”, 25, 4096, 2160, 297000000, 128, 968, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 99, 0, 1, OUT_P888},
{ { “4096x2160p@30Hz”, 30, 4096, 2160, 297000000, 128, 88, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 100, 0, 1, OUT_P888},
{ { “3840x2160p@50Hz”, 50, 3840, 2160, 594000000, 296, 1056, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 96, HDMI_3840X2160P_50HZ_4_3, 1, OUT_P888},
{ { “3840x2160p@60Hz”, 60, 3840, 2160, 594000000, 296, 176, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 97, HDMI_3840X2160P_60HZ_4_3, 1, OUT_P888},
{ { “4096x2160p@50Hz”, 50, 4096, 2160, 594000000, 128, 968, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 101, 0, 1, OUT_P888},
{ { “4096x2160p@60Hz”, 60, 4096, 2160, 594000000, 128, 88, 72, 8, 88, 10, FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, 0, 0 }, 102, 0, 1, OUT_P888},
有这么多mode,但是android系统里的HDMI选项哪里并没这多选项。
RK那颗芯片可以做3D投影方案
