按照文档的说明编译了内核,文件系统,和uboot,最后使用编译产生的相应文件对Firefly-3288升级,但是出现如下错误,屏幕卡在Firefly log图像,启动不了android系统。
我用现成的镜像是可以启动的,自己编译出来的东西就不可以
打印信息如下所示,有没有同僚遇到类似问题的,求解…… ,
4.210686] Init: Power Port (0)
[ 4.296749] Display is GTF capable
[ 4.296768] vga-ddc: read and parse vga edid success.
[ 4.296776] vga-ddc: max mode 1440x900@59[pixclock-106507 KHZ]
[ 4.296790] vga-ddc: best mode 1440x900@60[pixclock-9 KHZ]
[ 4.296796] VGA Devie connected 7
[ 4.296801] firefly_vga_set_mode 203
[ 4.296807] firefly_vga_set_mode 219 1440 900 60 106500000
[ 4.296813] firefly_vga_enable 130 start
[ 4.296818] firefly_switch_fb 55
[ 4.296825]
[ 4.296825] rk_fb_switch_screen lcdc_id 0 type 1 enable 1
[ 4.296835] fb0 win id 1 state 1
[ 4.296877] rk3288-lcdc lcdc0: lcdc0: dclk:118800000>>fps:67
[ 4.296900] fb1 win id 0 state 0
[ 4.296906] fb2 win id 2 state 0
[ 4.296910] fb3 win id 3 state 0
[ 4.296915] fb4 win id 4 state 0
[ 4.296921]
[ 4.296921] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done
[ 4.296921]
[ 4.417280] Indeed it is in host mode hprt0 = 00021501
[ 4.604223] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 4.604302] Indeed it is in host mode hprt0 = 00001101
[ 4.801230] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 4.801244] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.801252] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 4.801581] hub 3-1:1.0: USB hub found
[ 4.801628] hub 3-1:1.0: 4 ports detected
[ 5.020974] init: /dev/hw_random not found
[ 5.021546] android_usb: already disabled
[ 5.021623] android_usb: Cannot enable ‘adb’ (-22)init: property ‘ro.serialn’
[ 5.021689] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/clas’
[ 5.912931] iep dpi mode inactivity
[ 9.394074] init: /sbin/e2fsck terminated by exit(8)
[ 9.394099] init: Operational error while checking volume ‘/dev/block/platfo’
[ 9.394191] init: Failed to mount /dev/block/platform/emmc/by-name/cache, fow
[ 9.396040] init: /dev/hw_random not found
[ 9.396095] init: Unable to open persistent property directory /data/propert2
[ 9.397004] init: service ‘recovery’ requires console
[ 9.397024] init: service ‘console’ requires console
[ 9.397084] android_usb: already disabled
[ 9.397188] android_usb: Cannot enable ‘adb’ (-22)pcd_pullup, is_on 1
[ 9.397240] init: using deprecated syntax for specifying property 'ro.producd
[ 9.397291] init: using deprecated syntax for specifying property 'ro.producd
[ 9.397336] init: using deprecated syntax for specifying property 'ro.seriald
[ 9.397350] init: property ‘ro.serialno’ doesn’t exist while expanding ‘$ro.’
[ 9.397361] init: cannot expand ‘$ro.serialno’ while writing to ‘/sys/class/’
[ 10.882188] es8323_mic_state_ctrl read:
[ 10.882216] mic_state_switch 0
[ 10.882224] hp_det = 0,insert hp
[ 10.882230] hp mic use intern
[ 17.848852] vbus detect**
[ 18.028103] Using Buffer DMA mode
[ 18.028120] Periodic Transfer Interrupt Enhancement - disabled
[ 18.028128] Multiprocessor Interrupt Enhancement - disabled
[ 18.028137] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 18.028145] ^^^^^^^^^^^^^^^^^Device Mode
[ 18.028188] soft connect!!!
[ 18.399322] USB RESET
[ 18.470077] android_work: sent uevent USB_STATE=CONNECTED
[ 18.473922] USB RESET
[ 18.564482] USB RESET
[ 18.639223] USB RESET
[ 18.729814] USB RESET
[ 18.824758] USB RESET
