固件文件名称:rv1126_rv1109_linux_release_20220324_v2.2.5b.xml
Log日志:build_err.txt
从官方百度云盘下载固件,按如下步骤操作
#本压缩包内包含一个.repo目录,解压之后,在当前目录下执行以下操作.repo/repo/repo sync -l.repo/repo/repo sync -c --no-tags.repo/repo/repo start firefly --all
编译u-boot出现错误,错误日志已上传
build_err.txt (5.2 KB)
使用vm16虚拟机,ubuntu-16.04.6-desktop-i386.iso系统
ufofhb@ubuntu:/home/fire_fly/sdk$ ./build.sh device/rockchip/rv1126_rv1109/aio-rv1126-jd4-BE-45.mk
processing board option: device/rockchip/rv1126_rv1109/aio-rv1126-jd4-BE-45.mk
processing option: device/rockchip/rv1126_rv1109/aio-rv1126-jd4-BE-45.mk
ufofhb@ubuntu:/home/fire_fly/sdk$ ./build.sh uboot
processing board option: uboot
processing option: uboot
============Start building uboot============
TARGET_UBOOT_CONFIG=rv1126
## make rv1126_defconfig -j8
/home/fire_fly/sdk/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc
/home/fire_fly/sdk/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: 1: /home/fire_fly/sdk/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: ELF: not found
/home/fire_fly/sdk/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: 1: /home/fire_fly/sdk/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: Syntax error: Unterminated quoted string
dirname: missing operand
Try ‘dirname --help’ for more information.
./scripts/binutils-version.sh: line 18: /home/fire_fly/sdk/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-as: cannot execute binary file: Exec format error
CHK include/config.h
GEN include/autoconf.mk.dep
CFG u-boot.cfg
CFG tpl/u-boot.cfg
CFG spl/u-boot.cfg
scripts/Makefile.autoconf:50: recipe for target ‘include/autoconf.mk.dep’ failed
make[1]: *** [include/autoconf.mk.dep] Error 1
make[1]: *** Waiting for unfinished jobs…
scripts/Makefile.autoconf:79: recipe for target ‘u-boot.cfg’ failed
make[1]: *** [u-boot.cfg] Error 1
scripts/Makefile.autoconf:86: recipe for target ‘tpl/u-boot.cfg’ failed
make[1]: *** [tpl/u-boot.cfg] Error 1
scripts/Makefile.autoconf:82: recipe for target ‘spl/u-boot.cfg’ failed
make[1]: *** [spl/u-boot.cfg] Error 1
make: *** No rule to make target ‘include/config/auto.conf’, needed by ‘include/config/uboot.release’. Stop.
ERROR: Running build_uboot failed!
ERROR: exit code 2 from line 523:
./make.sh $RK_UBOOT_DEFCONFIG $UBOOT_COMPILE_COMMANDS
使用vm16虚拟机,系统是ubuntu-16.04.6-desktop-i386.iso系统 是32位的系统
