EC20 4G模块在官方ubuntu18.04系统下无法配置联网
固件文件名称:AIO-3568J-UBUNTU18.04-GPT-20211201-1505
Log日志:kernel_userlog.zip
基于UBUNTU18.04,AIO-3568J开发板上接入配套购买的EC20模块。
  1. 通过UBUNTU右上方的网络设置发现模块无法联网。
  2. 直接输入AT命令,检测SIM卡的IMSI信息,没问题。SIM卡为电信卡,如下信息:
    firefly@firefly:~$ busybox microcom /dev/ttyUSB2
    at+cimi
    460115304260332
OK
  1. 通过命令quectel-CM 配置,wwan0会被down, LOG如下。 其SIM卡状态也是ready的
firefly@firefly:~$ sudo quectel-CM -s ctlte
[04-20_02:37:44:221] QConnectManager_Linux_V1.6.1
[04-20_02:37:44:226] Find /sys/bus/usb/devices/5-1.3 idVendor=0x2c7c idProduct=0x125, bus=0x005, dev=0x003
[04-20_02:37:44:227] Auto find qmichannel = /dev/cdc-wdm0
[04-20_02:37:44:228] Auto find usbnet_adapter = wwan0
[04-20_02:37:44:228] netcard driver = qmi_wwan_q, driver version = 22-Aug-2005
[04-20_02:37:44:229] Modem works in QMI mode
[04-20_02:37:44:243] /proc/992/fd/7 → /dev/cdc-wdm0
[04-20_02:37:44:243] /proc/992/exe → /usr/local/bin/quectel-CM
[04-20_02:37:46:261] cdc_wdm_fd = 7
[04-20_02:37:46:363] Get clientWDS = 4
[04-20_02:37:46:395] Get clientDMS = 1
[04-20_02:37:46:427] Get clientNAS = 4
[04-20_02:37:46:459] Get clientUIM = 1
[04-20_02:37:46:491] Get clientWDA = 1
[04-20_02:37:46:523] requestBaseBandVersion EC20CEFRGR06A04M4G
[04-20_02:37:46:651] requestGetSIMStatus SIMStatus: SIM_READY
[04-20_02:37:46:685] requestGetProfile[1] ctlte///0/IPV4
[04-20_02:37:46:686] requestSetProfile[1] ctlte///0/IPV4
[04-20_02:37:46:686] no need to set skip the rest
[04-20_02:37:46:716] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[04-20_02:37:46:747] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[04-20_02:37:46:747] ifconfig wwan0 0.0.0.0
[04-20_02:37:46:766] ifconfig wwan0 down
[04-20_02:43:56:829] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
附件:
kernel dmesg信息,特别注意1134行以后。
求助,谢谢大家!
kernel_userlog.zip (22.6 KB)
运行quectel-CM -s cmnet呢?
都试过的,用cmnet, 或不加 apn都尝试过。结果都是一样的,wwan0 会被down。
这个固件我们验证过的。加装天线试试。
Firefly_Javier 发表于 2022-4-21 14:45
这个固件我们验证过的。加装天线试试。
厉害,就是这个原因,装了3根天线,搞定了
感谢
感谢分享
