固件文件名称:FIREFLY-RK3568-AIOJ_RTLINUX_MINIMALUBUNTU-GPT-2021
Log日志:log.zip
root@firefly:~# media-ctl -p -d /dev/media0
Media controller API version 4.19.193
Media device information
driver rkisp-vir0
model rkisp0
serial
bus info
hw revision 0x0
driver version 4.19.193
Device topology
- entity 1: rkisp-isp-subdev (4 pads, 7 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
[fmt:SBGGR10_1X10/800x600 field:none
crop.bounds:(0,0)/800x600
crop:(0,0)/800x600]
<- "rkisp-csi-subdev":1 [ENABLED]
<- "rkisp_rawrd0_m":0 []
<- "rkisp_rawrd2_s":0 []
pad1: Sink
<- "rkisp-input-params":0 [ENABLED]
pad2: Source
[fmt:YUYV8_2X8/800x600 field:none colorspace:smpte170m quantization:full-range
crop:(0,0)/800x600]
-> "rkisp_mainpath":0 [ENABLED]
-> "rkisp_selfpath":0 [ENABLED]
pad3: Source
-> "rkisp-statistics":0 [ENABLED]
- entity 6: rkisp-csi-subdev (6 pads, 5 links)
device node name /dev/v4l-subdev1
pad0: Sink
<- "rockchip-csi2-dphy0":1 [ENABLED]
pad1: Source
-> "rkisp-isp-subdev":0 [ENABLED]
pad2: Source
-> "rkisp_rawwr0":0 [ENABLED]
pad3: Source
pad4: Source
-> "rkisp_rawwr2":0 [ENABLED]
pad5: Source
-> "rkisp_rawwr3":0 [ENABLED]
- entity 13: rkisp_mainpath (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "rkisp-isp-subdev":2 [ENABLED]
- entity 19: rkisp_selfpath (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
- entity 25: rkisp_rawwr0 (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
<- "rkisp-csi-subdev":2 [ENABLED]
- entity 31: rkisp_rawwr2 (1 pad, 1 link)
device node name /dev/video3
pad0: Sink
<- "rkisp-csi-subdev":4 [ENABLED]
- entity 37: rkisp_rawwr3 (1 pad, 1 link)
device node name /dev/video4
pad0: Sink
<- "rkisp-csi-subdev":5 [ENABLED]
- entity 43: rkisp_rawrd0_m (1 pad, 1 link)
device node name /dev/video5
pad0: Source
-> "rkisp-isp-subdev":0 []
- entity 49: rkisp_rawrd2_s (1 pad, 1 link)
device node name /dev/video6
pad0: Source
- entity 55: rkisp-statistics (1 pad, 1 link)
device node name /dev/video7
pad0: Sink
<- "rkisp-isp-subdev":3 [ENABLED]
- entity 61: rkisp-input-params (1 pad, 1 link)
device node name /dev/video8
pad0: Source
-> "rkisp-isp-subdev":1 [ENABLED]
- entity 67: rockchip-csi2-dphy0 (2 pads, 1 link)
device node name /dev/v4l-subdev2
pad0: Sink
pad1: Source
-> "rkisp-csi-subdev":0 [ENABLED]
root@firefly:~# v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat='NV12' --stream-mmap=4 --set-selection=target=crop,flags=0,top=0,left=ght=1080 --stream-to=./out.yuv
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture Multiplanar:
Width/Height : 800/600
Pixel Format : 'NV12'
Field : None
Number of planes : 1
Flags :
Colorspace : Default
Transfer Function : Default
YCbCr Encoding : Default
Quantizatio[ 16.770205] rkisp-vir0: update sensor info failed -19
n : Full Range
Plane 0 :
Bytes per Line : 800
Size Image : 720000
VIDIOC_G_SELECTION: ok
VIDIOC_S_SELECTION: ok
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: failed: No such device
如上记录,media-ctl和v4l2-ctl使用情况,附件为开机log。
同样的开发板和摄像头,烧录ubuntu20,ubuntu18的固件可以使用。
猜测与rtlinux专用固件相关,但是还不确定。
请各位工程师朋友积极提供解决思路,谢谢!
log.zip (20.2 KB)
