log报错: DMA mask not set
SDK包名称:Firefly-RK356X_Android11.0_git_20210824
SDK修改内容:增加rk628d的相关驱动。
Log日志:log.zip
问题:DMA mask not set
网上也没找到相关的解决方法,小白求助。
核心板:core-3568j
行业版:aio-3568j
所驱动芯片:瑞芯微rk628d
dts代码如下:其中部分代码参考子rk官方提供的节点配置以及安卓内核中部分其他主板的rk628驱动dts
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
  • Copyright (c) 2020 Rockchip Electronics Co., Ltd.
#include “rk3568-firefly-aioj.dtsi”
  •                           Select one of the three
  • using single camera xc7160 ----> rk3568-firefly-aioj-cam-8ms1m.dtsi
  • using dual camera gc2053/gc2093 ----> rk3568-firefly-aioj-cam-2ms2m.dtsi
  • using hdmi-in module rk628d ----> rk3568-firefly-aioj-tf-hdmi-mipi-rk628.dtsi
    #include “rk3568-firefly-aioj-cam-8ms1m.dtsi”
    //#include “rk3568-firefly-aioj-cam-2ms2m.dtsi”
    //#include “rk3568-firefly-aioj-tf-hdmi-mipi-rk628.dtsi”
model = “AIO-3568J HDMI (Android)”;
compatible = “rockchip,rk3568-firefly-aioj”, “rockchip,rk3568”;
&route_hdmi {
status = “okay”;
connect = <&vp0_out_hdmi>;
&i2c4{
clock-frequency = <400000>;
status = “okay”;
rk628: rk628@50{
    reg = <0x50>;
    interrupt-parent = <&gpio3>;
    interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>;
    reset-gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_LOW>;
    status = "okay";
#include <arm/rk628.dtsi>
&rk628_combtxphy{
status = “okay”;
&rk628_combrxphy{
status = “okay”;
&rk628_csi {
status = “okay”;
/** If the hpd output level is inverted on the circuit, * the following configuration needs to be enabled. /
hpd-output-inverted; */
plugin-det-gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>; //
//power-gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
rockchip,camera-module-index = <0>;
rockchip,camera-module-facing = “back”;
rockchip,camera-module-name = “RK628-CSI”;
rockchip,camera-module-lens-name = “NC”;
port {
    hdmiin_out0: endpoint {
        remote-endpoint = <&mipi_in>;
        data-lanes = <1 2 3 4>;
&csi2_dphy_hw {
status = “okay”;
&csi2_dphy0 {
status = “okay”;
ports {
    #address-cells = <1>;
    #size-cells = <0>;
    port@0 {
        reg = <0>;
        #size-cells = <0>;
        mipi_in: endpoint@0 {
            reg = <0>;
            remote-endpoint = <&hdmiin_out0>;
    port@1 {
        reg = <1>;
        #size-cells = <0>;
        csidphy0_out: endpoint@0 {
            reg = <0>;
            remote-endpoint = <&isp0_in>;
&rkisp {
status = “okay”;
&rkisp_mmu {
status = “okay”;
&rkisp_vir0 {
status = “okay”;
port {
    #size-cells = <0>;
    isp0_in: endpoint@0 {
        reg = <0>;
        remote-endpoint = <&csidphy0_out>;
log.zip (28 KB)
好像是这个的问题,有人知道这个是怎么回事码
配置的引脚是否被复用或其它模块申请了?
zyk 发表于 2022-4-26 14:30
配置的引脚是否被复用或其它模块申请了?
确实,问题已经解决了,应该是i2c先挂在了其他模块了
