固件文件名称:rk3328_linux_release_v2.5.1_20210301_split_dir
Log日志:UART_PC_LOG.zip
采用 ROC-RK3328-PC 源码的地址,下载了 rk3328_linux_release_v2.5.1_20210301_split_dir ubuntu18.04源码包;
按维基的教程,更改了ROOTFS.IMG的路径,用下面的两套指令编译,用ROC-RK3328-CC-UBUNTU.MK的可以开机(但是没有WIFI模块);
用 ROC-RK3328-PC-UBUNTU.MK 的不能开机,开机第一画面正常,卡在第二画面并黑屏。UART LOG 日志卡在 Starting kernel … 这里。
编译 CC 固件,可以开机,但没有WIFI模块,有线可以用。
./build.sh roc-rk3328-cc-ubuntu.mk
./build.sh
编译 PC 固件,不能开机。
./build.sh roc-rk3328-pc-ubuntu.mk
./build.sh
请大家帮忙指导下,新手刚学习中,谢谢了!
UART LOG:
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 231
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=29820MB
FwPartOffset=2000 , 2000
SdmmcInit=0 NOT PRESENT
StorageInit ok = 179410
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x600000
GPT part: 7, name: userdata, start:0x65a000, size:0x33e3fdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd1a30
RunBL31 0x40000
INFO: Preloader serial: 2
NOTICE: BL31: v1.3(release):3be52e9
NOTICE: BL31: Built : 14:51:38, Nov 3 2020
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #3 Mon Aug 17 09:29:38 UTC 2020 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc56bc3a030-dirty #h (Apr 28 2022 - 15:37:52 +0800)
Model: Firefly ROC-RK3328-CC
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbf5000, fdt: 7bdea578
rksdmmc@ff500000: 1, rksdmmc@ff520000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(s): OK
Android header version 0
use default hdmi phy table
Warn: can’t find connect driver
In: serial
Out: serial
Err: serial
Model: Firefly ROC-RK3328-PC
xfer: num: 2, addr: 0x50
Monitor has basic audio support
mode:1920x1080
Detailed mode clock 148500 kHz, flags[5]
H: 1920 2008 2052 2200
V: 1080 1084 1089 1125
bus_format: 100a
CEA mode used vic=16
final pixclk = 148500000 tmdsclk = 148500000
start Inno HDMI PHY Power On
tmdsclock = 148500000; chipversion = 2
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500
CLK: (sync kernel. arm: enter 600000 KHz, init 600000 KHz, kernel 0N/A)
apll 400000 KHz
dpll 664000 KHz
cpll 1200000 KHz
gpll 491009 KHz
npll 600000 KHz
armclk 600000 KHz
aclk_bus 150000 KHz
hclk_bus 75000 KHz
pclk_bus 75000 KHz
aclk_peri 150000 KHz
hclk_peri 75000 KHz
pclk_peri 75000 KHz
Net:
Warning: ethernet@ff540000 (eth0) using random MAC address - 82:ba:f6:7c:4b:11
eth0: ethernet@ff540000
Hit key to stop autoboot(‘CTRL+C’): 3 2 1 0
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 21393 KiB
RAM disk load addr 0x0a200000 size 8762 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 … OK
Using Device Tree in place at 0000000008300000, end 00000000083157e6
No file: logo_kernel.bmp
Total: 4387.375 ms
UART_PC_LOG.zip (2.16 KB)
