你好,题目上的这个编译器不在sdk包里,导致编译时提示出错。
root@cecb05d9d823:/home/pubd0/rockchip/rk3588_firefly# ./build.sh all
processing option: all
TARGET_ARCH=arm64
TARGET_PLATFORM=rk3588
TARGET_UBOOT_CONFIG=rk3588
TARGET_SPL_CONFIG=
TARGET_KERNEL_CONFIG=rockchip_linux_defconfig
TARGET_KERNEL_DTS=rk3588-firefly-itx-3588j
TARGET_TOOLCHAIN_CONFIG=
TARGET_BUILDROOT_CONFIG=rockchip_rk3588
TARGET_RECOVERY_CONFIG=
TARGET_PCBA_CONFIG=rockchip_rk3588_pcba
TARGET_RAMBOOT_CONFIG=
============Start building uboot============
Using .config as base
Merging ./arch/../configs/firefly-linux.config
Value of CONFIG_ROCKCHIP_EARLY_DISTRO_DTB is redefined by fragment ./arch/../configs/firefly-linux.config:
Previous value: # CONFIG_ROCKCHIP_EARLY_DISTRO_DTB is not set
New value: CONFIG_ROCKCHIP_EARLY_DISTRO_DTB=y
Value of CONFIG_SPL_GPIO_SUPPORT is redefined by fragment ./arch/../configs/firefly-linux.config:
Previous value: CONFIG_SPL_GPIO_SUPPORT=y
New value: CONFIG_SPL_GPIO_SUPPORT=n
Value of CONFIG_DM_PCA953X is redefined by fragment ./arch/../configs/firefly-linux.config:
Previous value: # CONFIG_DM_PCA953X is not set
New value: CONFIG_DM_PCA953X=y
# merged configuration written to .config (needs make)
scripts/kconfig/conf --oldconfig Kconfig
./make.sh: line 270: cd: ../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin: No such file or directory
ERROR: No find /home/pubd0/rockchip/rk3588_firefly/u-boot/aarch64-linux-gnu-gcc
ERROR: Running build_uboot failed!
ERROR: exit code 1 from line 543:
./make.sh $UBOOT_COMPILE_COMMANDS
