固件文件名称:rv1126_rv1109_linux_release_20211022
Log日志:aio-rv1126-debian.mk.log
我使用的是RV1126-JD4的核心板+底板
文件系统debain10
根据https://dev.t-firefly.com/thread-118473-1-1.html的回复
选用aio-rv1126-debian.mk编译内核
发现串口232及串口485不可用,
会报类似下列错误(内核启动打印见附件):
set divisor fail, quot:13 != dll,dlh:0
使用官网aio-rv1126-jd4-BE-45.mk 编译的kernel,串口232及串口485可用
请问我使用的板子是否应使用aio-rv1126-debian.mk,或该配置需做哪些调整
才能正确配置串口。
期待回复,多谢!
aio-rv1126-debian.mk.log (65.5 KB)
尝试了三组波特率,打印如下:
root@firefly:~# busybox stty -F /dev/ttyS1 ispeed 4000000 ospeed 4000000 cs8
[ 2252.578798] ttyS1 set divisor fail, quot:1 != dll,dlh:0
[ 2252.579009] sclk_uart1_fracdiv p_rate(480000000) is low than rate(64000000)*20, use integer or half-div
[ 2252.579051] sclk_uart1_fracdiv p_rate(480000000) is lorwo ot@firefly:~# han rate(64000000)*20, use integer or half-div
[ 2252.579129] sclk_uart1_fracdiv p_rate(1188000000) is low than rate(65280000)*20, use integer or half-div
[ 2252.579167] dw-apb-uart ff410000.serial: set rate:64000000, but get rate:62526316
[ 2252.579197] ttyS1 set divisor fail, quot:1 != dll,dlh:0
root@firefly:~# busybox stty -F /dev/ttyS1 ispeed 1500000 ospeed 1500000 cs8
[ 2289.215985] sclk_uart1_fracdiv p_rate(1188000000) is low than rate(64000000)*20, use integer or half-div
[ 2289.216029] sclk_uart1_fracdiv p_rate(1188000000)root@firefly:~# is low than rate(65280000)*20, use integer or half-div
[ 2289.216044] dw-apb-uart ff410000.serial: set rate:64000000, but get rate:62526316
[ 2289.216061] ttyS1 set divisor fail, quot:1 != dll,dlh:0
[ 2289.216182] ttyS1 set divisor fail, quot:1 != dll,dlh:0
root@firefly:~# busybox stty -F /dev/ttyS1 ispeed 115200 ospeed 115200 cs8
[ 2318.945134] ttyS1 set divisor fail, quot:1 != dll,dlh:0
[ 2318.945310] ttyS1 set divisor fail, quot:13 != dll,dlh:0
请问是否是驱动不匹配导致?合适的驱动哪里获得
捋了一遍驱动代码,虽然有告警打印,但不影响基本的收发使用。
