固件文件名称:firefly_rk3399_industry7.1_git_20211216
Log日志:RK3399日志.log
RK3399 7.1.1点15.6寸EDP背光亮,屏幕不亮,使用的屏幕是LP156WF6-SPB1
DDR Version 1.24 20191016
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 0, cs 1, advanced training done
channel 1, cs 0, advanced training done
channel 1, cs 1, advanced training done
change freq to 856MHz 1,0
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 MHz, current 856MHz
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 346
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 72954
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT 0x3335db8 signature is wrong
recovery gpt…
recovery gpt fail!
Trust Addr:0x4000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x8741c
RunBL31 0x40000 @ 98474 us
NOTICE: BL31: v1.3(release):af49f67
NOTICE: BL31: Built : 16:55:08, May 19 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1191): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-256-gebb61ff5 #4 Wed Apr 22 01:34:02 UTC 2020 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (May 12 2022 - 17:48:49)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
cpll = 800000000HZ
dpll = 856000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
rockusb key: key_rockusb.key.adc.keyValueLow = 0, key_rockusb.key.adc.keyValueHigh = 30
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=975000,pwm_value=58
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 856000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
invalide header tag
ca head not found
#Boot ver: 2022-05-12#1.26
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
Rockchip UBOOT DRM driver version: develop-v1.0.0
pwrctr_name:lcd-en, parse gpio:517, atv_val=1,delay:1000ms
delay prepare[0] unprepare[0] enable[0] disable[0]
no fuel gauge found
Using display timing dts
Detailed mode clock 200000 kHz, flags[a]
H: 2560 2608 2688 2720
V: 1600 1602 1641 1646
bus_format: 1009
rk lcdc - 0 dclk set: dclk = 200000000HZ, pll select = 1, div = 1
pwrctr: set lcd-en(517)=1,delay:1000ms
Link Training Clock Recovery success
Link Training success!
Timeout of video streamclk ok
unable to config video
failed to display kernel logo
got recovery cmd from misc.
load fdt from resouce.
lzf debug,store_value=ROC-RK3399-PC+ HDMI+EDP(Android)
saradc 4 value =504
Secure Boot state: 0
kernel @ 0x00280000 (0x013c9008)
ramdisk @ 0x04bf0000 (0x00755ae0)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004617613 … OK
Add bank:000000000a200000, 00000000ede00000
[ 0.000000] Linux version 4.4.126 (android@android-compiler) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #2 SMP PREEMPT Thu Apr 21 08:58:28 CST 2022
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ee7000 s45592 r8192 d32232 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00300000@0x000C4000(system),0x00100000@0x003C4000(oem),0x00008000@0x004C4000(metadata),0x00000040@0x004CC000(verity_mode),0x00002000@0x004CC040(reserved),0x00000400@0x004CE040(frp),-@0x004CE440(userdata) storagemedia=emmc androidboot.oem_unlocked=0 uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2022-05-12_17:48:49 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0xf6e9f000-0xf6edf000] (0MB) mapped at [ffffffc0f6e9f000-ffffffc0f6edefff]
[ 0.000000] Memory: 3910168K/4030464K available (11646K kernel code, 1892K rwdata, 5820K rodata, 832K init, 2396K bss, 103912K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff80091a0000 - 0xffffff8009270000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008be0000 ( 11648 KB)
[ 0.000000] .rodata : 0xffffff8008be0000 - 0xffffff80091a0000 ( 5888 KB)
[ 0.000000] .data : 0xffffff8009270000 - 0xffffff8009449008 ( 1893 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.001902] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002851] pid_max: default: 32768 minimum: 301
[ 0.003336] Security Framework initialized
[ 0.003722] SELinux: Initializing.
[ 0.004147] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004768] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006225] Initializing cgroup subsys memory
[ 0.006653] Initializing cgroup subsys freezer
[ 0.007938] sched-energy: Sched-energy-costs installed from DT
[ 0.008481] CPU0: update cpu_capacity 401
[ 0.008930] ASID allocator initialised with 32768 entries
[ 0.025755] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.026970] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039234] Detected VIPT I-cache on CPU1
[ 0.039269] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039312] CPU1: using LPI pending table @0x00000000f1c00000
[ 0.039364] CPU1: update cpu_capacity 401
[ 0.039368] CPU1: Booted secondary processor [410fd034]
[ 0.049248] Detected VIPT I-cache on CPU2
[ 0.049279] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049317] CPU2: using LPI pending table @0x00000000f1c30000
[ 0.049366] CPU2: update cpu_capacity 401
[ 0.049370] CPU2: Booted secondary processor [410fd034]
[ 0.059301] Detected VIPT I-cache on CPU3
[ 0.059330] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059368] CPU3: using LPI pending table @0x00000000f1c70000
[ 0.059415] CPU3: update cpu_capacity 401
[ 0.059418] CPU3: Booted secondary processor [410fd034]
[ 0.069374] Detected PIPT I-cache on CPU4
[ 0.069399] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069432] CPU4: using LPI pending table @0x00000000f1cc0000
[ 0.069467] CPU4: update cpu_capacity 1024
[ 0.069470] CPU4: Booted secondary processor [410fd082]
[ 0.079423] Detected PIPT I-cache on CPU5
[ 0.079447] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079482] CPU5: using LPI pending table @0x00000000f1cf0000
[ 0.079516] CPU5: update cpu_capacity 1024
[ 0.079519] CPU5: Booted secondary processor [410fd082]
[ 0.079609] Brought up 6 CPUs
[ 0.091559] SMP: Total of 6 processors activated.
[ 0.091998] CPU features: detected feature: GIC system register CPU interface
[ 0.092660] CPU: All CPU(s) started at EL2
[ 0.093074] alternatives: patching kernel code
[ 0.095346] devtmpfs: initialized
[ 0.116724] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.117669] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.118944] pinctrl core: initialized pinctrl subsystem
[ 0.120967] Failed to find legacy iommu devices
[ 0.121746] NET: Registered protocol family 16
[ 0.122581] schedtune: init normalization constants…
[ 0.123093] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.123719] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.124343] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.124967] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.125590] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.126215] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.126845] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.127468] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.128091] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.128714] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.129443] schedtune: verify normalization constants…
[ 0.129951] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.130490] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.131022] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.131554] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.132086] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.132618] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.133150] schedtune: configured to support 5 boost groups
[ 0.143870] cpuidle: using governor ladder
[ 0.153870] cpuidle: using governor menu
[ 0.154258] Registered FIQ tty driver
[ 0.154997] vdso: 2 pages (1 code @ ffffff8008be6000, 1 data @ ffffff8009274000)
[ 0.155726] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.157300] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.178151] console [pstore-1] enabled
[ 0.178741] pstore: Registered ramoops as persistent store backend
[ 0.179336] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.182815] fiq debugger fiq mode enabled
[[ 0.183455] console [ttyFIQ0] enabled
[ 0.184161] bootconsole [uart0] disabled
[ 0.184729] Registered fiq debugger ttyFIQ0
[ 0.216843] reg_fixed_voltage_probe vcc5v0_host sys/camera_test/vcc5v0_dbg
[ 0.218826] firefly_hwversion: V0
[ 0.219233] iommu: Adding device ff650000.vpu_service to group 0
[ 0.219299] iommu: Adding device ff660000.rkvdec to group 1
[ 0.219359] iommu: Adding device ff670000.iep to group 2
[ 0.219447] iommu: Adding device ff8f0000.vop to group 3
[ 0.219520] iommu: Adding device ff900000.vop to group 4
[ 0.219621] iommu: Adding device ff910000.isp to group 5
[ 0.219692] iommu: Adding device ff920000.isp to group 6
[ 0.220352] rk_iommu ff670800.iommu: can’t get aclk
[ 0.220366] rk_iommu ff670800.iommu: can’t get hclk
[ 0.221235] SCSI subsystem initialized
[ 0.221552] usbcore: registered new interface driver usbfs
[ 0.221594] usbcore: registered new interface driver hub
[ 0.221665] usbcore: registered new device driver usb
[ 0.222061] media: Linux media interface: v0.10
[ 0.222099] Linux video capture interface: v2.00
[ 0.222273] pps_core: LinuxPPS API ver. 1 registered
[ 0.222282] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.222303] PTP clock support registered
[ 0.223972] Advanced Linux Sound Architecture Driver Initialized.
[ 0.224426] Bluetooth: Core ver 2.21
[ 0.224464] NET: Registered protocol family 31
[ 0.224472] Bluetooth: HCI device and connection manager initialized
[ 0.224486] Bluetooth: HCI socket layer initialized
[ 0.224498] Bluetooth: L2CAP socket layer initialized
[ 0.224524] Bluetooth: SCO socket layer initialized
[ 0.225226] rockchip-cpuinfo cpuinfo: Serial : fb15f07ffdf091bb
[ 0.225754] clocksource: Switched to clocksource arch_sys_counter
[ 0.270216] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.270461] NET: Registered protocol family 2
[ 0.270913] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.271182] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.271719] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.271802] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.271910] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.272149] NET: Registered protocol family 1
[ 0.273072] Trying to unpack rootfs image as initramfs…
[ 0.601963] Freeing initrd memory: 7508K
[ 0.602563] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.602654] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.605467] audit: initializing netlink subsys (disabled)
[ 0.605530] audit: type=2000 audit(0.600:1): initialized
[ 0.610518] VFS: Disk quotas dquot_6.6.0
[ 0.610646] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.611621] Registering sdcardfs 0.1
[ 0.612154] fuse init (API version 7.23)
[ 0.613222]
[ 0.613222] TEE Core Framework initialization (ver 1:0.1)
[ 0.613254] TEE armv7 Driver initialization
[ 0.613614] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.613633] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.613807] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=61)
[ 0.617695] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.617718] io scheduler noop registered
[ 0.617873] io scheduler cfq registered (default)
[ 0.619163] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[ 0.622322] ace test_init function.
[ 0.622521] ace test_init end.ret=0
[ 0.622883] radar end.ret=0
[ 0.625065] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.625092] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.625107] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.625773] pll lock timeout!
[ 1.625843] phy phy-pcie-phy.5: phy poweron failed → -22
[ 1.625859] rockchip-pcie f8000000.pcie: fail to power on phy, err -22
[ 1.625963] rockchip-pcie: probe of f8000000.pcie failed with error -22
[ 1.626890] backlight supply power not found, using dummy regulator
[ 1.627748] iep: failed to find iep power down clock source.
[ 1.628416] IEP Power ON
[ 1.628724] IEP Power OFF
[ 1.628874] IEP Driver loaded succesfully
[ 1.629246] Module initialized.
[ 1.629656] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.629975] rk-vcodec ff650000.vpu_service: probe device
[ 1.630183] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.630706] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.630723] rk-vcodec ff650000.vpu_service: init success
[ 1.630908] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.634649] rk-vcodec ff660000.rkvdec: probe device
[ 1.634821] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.635187] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.635199] rk-vcodec ff660000.rkvdec: init success
[ 1.636864] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.636888] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.638180] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.638203] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.640056] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.640583] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.641025] [drm] Initialized drm 1.1.0 20060810
[ 1.644914] [drm] Rockchip DRM driver version: v1.0.0
[ 1.646899] panel_simple: parse lcd-en: gpio=69, atv_val=1, delay=1000ms
[ 1.646925] edp-panel supply power not found, using dummy regulator
[ 1.647621] mali ff9a0000.gpu: Failed to get regulator
[ 1.647641] mali ff9a0000.gpu: Power control initialization failed
[ 1.647943] Unable to detect cache hierarchy for CPU 0
[ 1.661366] brd: module loaded
[ 1.667406] loop: module loaded
[ 1.668029] zram: Added device: zram0
[ 1.669004] Loading dl1825 driver
[ 1.669627] SCSI Media Changer driver v0.25
[ 1.670741] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.670767] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.670780] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.671385] m25p80 spi32766.0: unrecognized JEDEC id bytes: ff, ff, ff
[ 1.671413] m25p80: probe of spi32766.0 failed with error -2
[ 1.672072] register spi return v = :0
[ 1.672131] register firefly_spi_init spi return v = :0
[ 1.672296] tun: Universal TUN/TAP device driver, 1.6
[ 1.672312] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.673615] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.673741] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.673767] rk_gmac-dwmac fe300000.ethernet: TX delay(0x22).
[ 1.673781] rk_gmac-dwmac fe300000.ethernet: RX delay(0x23).
[ 1.673811] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.674026] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.674046] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.679065] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.679250] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.679266] Ring mode enabled
[ 1.679275] DMA HW capability register supported
[ 1.679281] Normal descriptors
[ 1.679292] RX Checksum Offload Engine supported (type 2)
[ 1.679299] Wake-Up On Lan supported
[ 1.679350] Enable RX Mitigation via HW Watchdog Timer
[ 1.748619] libphy: stmmac: probed
[ 1.748667] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.748681] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.750188] PPP generic driver version 2.4.2
[ 1.750507] PPP BSD Compression module registered
[ 1.750523] PPP Deflate Compression module registered
[ 1.750557] PPP MPPE Compression module registered
[ 1.750577] NET: Registered protocol family 24
[ 1.750626] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.750635] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.750725] usbcore: registered new interface driver mt7601u
[ 1.750751] Rockchip WiFi SYS interface (V1.00) …
[ 1.750832] usbcore: registered new interface driver catc
[ 1.750921] usbcore: registered new interface driver kaweth
[ 1.750937] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.750997] usbcore: registered new interface driver pegasus
[ 1.751087] usbcore: registered new interface driver rtl8150
[ 1.751150] usbcore: registered new interface driver r8152
[ 1.751165] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.751237] usbcore: registered new interface driver hso
[ 1.751336] usbcore: registered new interface driver asix
[ 1.751391] usbcore: registered new interface driver ax88179_178a
[ 1.751449] usbcore: registered new interface driver cdc_ether
[ 1.751537] usbcore: registered new interface driver cdc_eem
[ 1.751592] usbcore: registered new interface driver dm9601
[ 1.751664] usbcore: registered new interface driver smsc75xx
[ 1.751762] usbcore: registered new interface driver smsc95xx
[ 1.751817] usbcore: registered new interface driver gl620a
[ 1.751877] usbcore: registered new interface driver net1080
[ 1.751965] usbcore: registered new interface driver plusb
[ 1.752025] usbcore: registered new interface driver rndis_host
[ 1.752083] usbcore: registered new interface driver cdc_subset
[ 1.752171] usbcore: registered new interface driver zaurus
[ 1.752228] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.752308] usbcore: registered new interface driver int51x1
[ 1.752396] usbcore: registered new interface driver kalmia
[ 1.752478] usbcore: registered new interface driver ipheth
[ 1.752539] usbcore: registered new interface driver sierra_net
[ 1.752630] usbcore: registered new interface driver cx82310_eth
[ 1.752695] usbcore: registered new interface driver cdc_ncm
[ 1.752756] usbcore: registered new interface driver qmi_wwan
[ 1.752849] usbcore: registered new interface driver cdc_mbim
[ 1.754588] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.759339] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.761001] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.761055] ehci-pci: EHCI PCI platform driver
[ 1.761145] ehci-platform: EHCI generic platform driver
[ 1.765193] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.765495] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.765791] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.775819] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.776042] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.776090] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.776103] usb usb1: Product: EHCI Host Controller
[ 1.776116] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.776128] usb usb1: SerialNumber: fe3c0000.usb
[ 1.776767] hub 1-0:1.0: USB hub found
[ 1.776844] hub 1-0:1.0: 1 port detected
[ 1.777639] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.777705] ohci-platform: OHCI generic platform driver
[ 1.778332] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.778585] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.778759] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.833299] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.833347] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.833362] usb usb2: Product: Generic Platform OHCI controller
[ 1.833375] usb usb2: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.833388] usb usb2: SerialNumber: fe3e0000.usb
[ 1.834024] hub 2-0:1.0: USB hub found
[ 1.834106] hub 2-0:1.0: 1 port detected
[ 1.835474] usbcore: registered new interface driver cdc_acm
[ 1.835518] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.835596] usbcore: registered new interface driver usblp
[ 1.835659] usbcore: registered new interface driver cdc_wdm
[ 1.835777] usbcore: registered new interface driver uas
[ 1.835882] usbcore: registered new interface driver usb-storage
[ 1.835970] usbcore: registered new interface driver ums-alauda
[ 1.836025] usbcore: registered new interface driver ums-cypress
[ 1.836083] usbcore: registered new interface driver ums-datafab
[ 1.836169] usbcore: registered new interface driver ums_eneub6250
[ 1.836227] usbcore: registered new interface driver ums-freecom
[ 1.836287] usbcore: registered new interface driver ums-isd200
[ 1.836375] usbcore: registered new interface driver ums-jumpshot
[ 1.836429] usbcore: registered new interface driver ums-karma
[ 1.836486] usbcore: registered new interface driver ums-onetouch
[ 1.836583] usbcore: registered new interface driver ums-sddr09
[ 1.836637] usbcore: registered new interface driver ums-sddr55
[ 1.836692] usbcore: registered new interface driver ums-usbat
[ 1.836804] usbcore: registered new interface driver usbserial
[ 1.836886] usbcore: registered new interface driver usbserial_generic
[ 1.836926] usbserial: USB Serial support registered for generic
[ 1.837020] usbcore: registered new interface driver option
[ 1.837056] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.837219] usbcore: registered new interface driver trancevibrator
[ 1.837268] usb20_otg: version 3.10a 21-DEC-2012
[ 1.837558] usb20_host: version 3.10a 21-DEC-2012
[ 1.838376] usbcore: registered new interface driver xpad
[ 1.838450] usbcore: registered new interface driver usb_acecad
[ 1.838541] usbcore: registered new interface driver aiptek
[ 1.838603] usbcore: registered new interface driver gtco
[ 1.838667] usbcore: registered new interface driver hanwang
[ 1.838754] usbcore: registered new interface driver kbtab
[ 1.838908] [FTS_TS]fts_ts_init: Enter
[ 1.838965] [FTS_TS]fts_ts_init: Exit(1690)
[ 1.838983] [HXTP] himax_hx83102_init
[ 1.838991] [HXTP] himax_hx83102_probe:Enter
[ 1.839007] [HXTP] Himax common touch panel driver init
[ 1.839956] .. rk pwm remotectl v1.1 init
[ 1.840301] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.840858] sensor_register_slave:mma8452,id=17
[ 1.840901] sensor_register_slave:lis3dh,id=7
[ 1.840919] sensor_register_slave:mma7660,id=18
[ 1.840936] sensor_register_slave:lsm303d,id=22
[ 1.840953] sensor_register_slave:gs_mc3230,id=23
[ 1.840960] [Gsensor] gsensor_init
[ 1.840977] sensor_register_slave:mpu6880_acc,id=24
[ 1.840995] sensor_register_slave:mpu6500_acc,id=25
[ 1.841012] sensor_register_slave:lsm330_acc,id=26
[ 1.841029] sensor_register_slave:bma2xx_acc,id=27
[ 1.841047] sensor_register_slave:akm8975,id=30
[ 1.841065] sensor_register_slave:akm8963,id=31
[ 1.841106] sensor_register_slave:l3g4200d,id=45
[ 1.841123] sensor_register_slave:l3g20d,id=46
[ 1.841140] sensor_register_slave:ewtsa,id=47
[ 1.841157] sensor_register_slave:lsm330_gyro,id=51
[ 1.841174] sensor_register_slave:cm3217,id=53
[ 1.841191] sensor_register_slave:cm3218,id=54
[ 1.841208] sensor_register_slave:ls_stk3410,id=62
[ 1.841226] sensor_register_slave:ps_stk3410,id=67
[ 1.842321] i2c /dev entries driver
[ 1.843916] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.844046] fan53555-reg: supplied by vcc5v0_sys
[ 1.846558] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.846666] fan53555-reg: supplied by vcc5v0_sys
[ 1.848710] rockchip-pinctrl pinctrl: pin gpio1-18 already requested by 0-0040; cannot claim for 0-001b
[ 1.848761] rockchip-pinctrl pinctrl: pin-50 (0-001b) status -22
[ 1.848778] rockchip-pinctrl pinctrl: could not request pin 50 (gpio1-18) from group pmic-dvs2 on device rockchip-pinctrl
[ 1.848827] rk808 0-001b: Error applying setting, reverse things back
[ 1.849252] rk808 0-001b: Pmic Chip id: 0x0
[ 1.852674] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.852750] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.852870] DCDC_REG1: supplied by vcc3v3_sys
[ 1.853779] DCDC_REG2: supplied by vcc3v3_sys
[ 1.854421] DCDC_REG3: supplied by vcc3v3_sys
[ 1.854773] DCDC_REG4: supplied by vcc3v3_sys
[ 1.855314] LDO_REG1: supplied by vcc3v3_sys
[ 1.856529] LDO_REG2: supplied by vcc3v3_sys
[ 1.857582] LDO_REG3: supplied by vcc3v3_sys
[ 1.858647] LDO_REG4: supplied by vcc3v3_sys
[ 1.859549] vcc_sd: Failed to create debugfs directory
[ 1.859839] LDO_REG5: supplied by vcc3v3_sys
[ 1.861107] LDO_REG6: supplied by vcc3v3_sys
[ 1.862316] LDO_REG7: supplied by vcc3v3_sys
[ 1.863613] LDO_REG8: supplied by vcc3v3_sys
[ 1.864839] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.865332] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.866073] rk808-rtc rk808-rtc: device is disabled
[ 1.866141] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.866390] rk808 0-001b: Can not read property pmic,hold-gpio
[ 1.866585] rk808 0-001b: Can not read property pmic,stby-gpio
[ 1.866987] firefly_hwversion_in_range haoyu,hym8563: hwversion in range(0 conditions)
[ 1.867154] rtc-hym8563 0-0051: could not init device, -6
[ 1.867305] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80098fe000
[ 1.868418] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800993c000
[ 1.870131] fusb302 7-0022: Can’t get property of role, set role to default DRP
[ 1.872111] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.872593] input: Typec_Headphone as /devices/platform/ff160000.i2c/i2c-7/7-0022/input/input1
[ 1.873041] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff800993e000
[ 1.874063] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800997c000
[ 1.875505] IR NEC protocol handler initialized
[ 1.875662] IR RC5(x/sz) protocol handler initialized
[ 1.875884] IR RC6 protocol handler initialized
[ 1.876100] IR JVC protocol handler initialized
[ 1.876317] IR Sony protocol handler initialized
[ 1.876537] IR SANYO protocol handler initialized
[ 1.876757] IR Sharp protocol handler initialized
[ 1.876977] IR MCE Keyboard/mouse protocol handler initialized
[ 1.877196] IR XMP protocol handler initialized
[ 1.877740] usbcore: registered new interface driver uvcvideo
[ 1.877889] USB Video Class driver (1.1.1)
[ 1.878121] CamSys driver version: v0.48.2, CamSys head file version: v1.0.0
[ 1.885237] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.885465] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.885919] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.886150] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.891073] rk_tsadcv2_temp_to_code: Invalid temp(2147483647), set temp to =125000
[ 1.892345] device-mapper: uevent: version 1.0.3
[ 1.892959] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.893474] Bluetooth: HCI UART driver ver 2.3
[ 1.893680] Bluetooth: HCI UART protocol H4 registered
[ 1.893898] Bluetooth: HCI UART protocol LL registered
[ 1.894125] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.
[ 1.956917] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.957382] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.959387] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.959434] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.985868] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.989544] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.991568] usbcore: registered new interface driver usbhid
[ 1.991580] usbhid: USB HID core driver
[ 1.991696] inv_mpu_iio: inv_mpu_init:746
[ 1.992307] ashmem: initialized
[ 1.993735] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 1.998100] rknandbase v1.1 2016-11-08
[ 1.998681] usbcore: registered new interface driver snd-usb-audio
[ 1.999398] firefly_hwversion_in_range everest,es8323: hwversion in range(0 conditions)
[ 1.999572] ES8323 1-0011: i2c recv Failed
[ 2.005473] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[ 2.005593] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[ 2.006106] u32 classifier
[ 2.006300] Actions configured
[ 2.006582] Netfilter messages via NETLINK v0.30.
[ 2.006842] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.007859] ctnetlink v0.93: registering with nfnetlink.
[ 2.009262] xt_time: kernel timezone is -0000
[ 2.010036] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.010294] arp_tables: (C) 2002 David S. Miller
[ 2.010626] Initializing XFRM netlink socket
[ 2.011022] NET: Registered protocol family 10
[ 2.015187] mip6: Mobile IPv6
[ 2.015225] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.016179] sit: IPv6 over IPv4 tunneling driver
[ 2.016577] NET: Registered protocol family 17
[ 2.016599] NET: Registered protocol family 15
[ 2.016629] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.017271] Bridge firewalling registered
[ 2.017280] Ebtables v2.0 registered
[ 2.017455] Bluetooth: RFCOMM TTY layer initialized
[ 2.017472] Bluetooth: RFCOMM socket layer initialized
[ 2.017493] Bluetooth: RFCOMM ver 1.11
[ 2.017508] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.017514] Bluetooth: BNEP filters: protocol multicast
[ 2.017524] Bluetooth: BNEP socket layer initialized
[ 2.017534] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.017543] Bluetooth: HIDP socket layer initialized
[ 2.017568] l2tp_core: L2TP core driver, V2.0
[ 2.017582] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.017597] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.017867] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.017911] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6256
[ 2.017917] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.017924] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.017985] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 2.017991] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.017999] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.018041] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.018319] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 2.018354] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 2.018379] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 2.018404] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 2.018732] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.018777] [BT_RFKILL]: ** disable irq
[ 2.018880] [BT_RFKILL]: bt_default device registered.
[ 2.019058] sensor_register_slave:mpu6500_gyro,id=49
[ 2.019096] sensor_register_slave:mpu6880_gyro,id=50
[ 2.020151] Registered cp15_barrier emulation handler
[ 2.020232] Registered setend emulation handler
[ 2.020750] registered taskstats version 1
[ 2.021454] rockchip ion idev is NULL
[ 2.021473] rga2 ff680000.rga: rga ion client create success!
[ 2.021613] rga2: Driver loaded successfully ver:3.02
[ 2.021743] rga2: Module initialized.
[ 2.022353] phy phy-ff770000.syscon:usb2-phy@e450.6: Failed to get VBUS supply regulator
[ 2.023617] rockchip-drm display-subsystem: defer getting devfreq
[ hip-vop ff8f0000.vop: unable to request PWM
[ 2.024258] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 2.024432] rockchip-dp ff970000.edp: no DP phy configured
[ 2.024872] i2c i2c-9: of_i2c: modalias failure on /edp@ff970000/ports
[ 2.025018] rockchip-drm display-subsystem: bound ff970000.edp (ops rockchip_dp_component_ops)
[ 2.025320] i2c i2c-10: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 2.025352] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.025445] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.027073] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 2.027236] mmc1: MAN_BKOPS_EN bit is not set
[ 2.027533] i2c i2c-11: of_i2c: modalias failure on /dp@fec00000/ports
[ 2.027822] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 2.027838] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.027845] [drm] No driver support for vblank timestamp query.
[ 2.039285] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.040081] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.040682] mmcblk1: mmc1:0001 Y2P032 29.1 GiB
[ 2.041023] mmcblk1boot0: mmc1:0001 Y2P032 partition 1 4.00 MiB
[ 2.041204] mmcblk1boot1: mmc1:0001 Y2P032 partition 2 4.00 MiB
[ 2.041359] mmcblk1rpmb: mmc1:0001 Y2P032 partition 3 16.0 MiB
[ 2.041659] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 2.041671] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.041678] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 2.041684] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 2.041690] resource: 0x001000000 – 0x002000000 (16 MB)
[ 2.041697] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 2.041703] boot: 0x003800000 – 0x005800000 (32 MB)
[ 2.041709] recovery: 0x005800000 – 0x009800000 (64 MB)
[ 2.041716] backup: 0x009800000 – 0x010800000 (112 MB)
[ 2.041722] cache: 0x010800000 – 0x018800000 (128 MB)
[ 2.041729] system: 0x018800000 – 0x078800000 (1536 MB)
[ 2.041735] oem: 0x078800000 – 0x098800000 (512 MB)
[ 2.041741] metadata: 0x098800000 – 0x099800000 (16 MB)
[ 2.041748] verity_mode: 0x099800000 – 0x099808000 (0 MB)
[ 2.041754] reserved: 0x099808000 – 0x099c08000 (4 MB)
[ 2.041760] frp: 0x099c08000 – 0x099c88000 (0 MB)
[ 2.041767] userdata: 0x099c88000 – 0x747800000 (27355 MB)
[ 2.041817] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 2.074030] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.091356] mali ff9a0000.gpu: leakage=19
[ 2.116233] mali ff9a0000.gpu: temp=30555, pvtm=119612 (120118 + -506)
[ 2.117516] mali ff9a0000.gpu: pvtm-volt-sel=0
[ 2.119363] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.119608] mali ff9a0000.gpu: Protected mode not available
[ 2.120517] mali ff9a0000.gpu: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.120588] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 2.120687] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.121379] mali ff9a0000.gpu: Probed as mali0
[ 2.126834] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.127162] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 2.127325] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.127370] xhci-hcd xhci-hcd.11.auto: irq 235, io mem 0xfe800000
[ 2.127536] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.127548] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.127554] usb usb3: Product: xHCI Host Controller
[ 2.127560] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.127565] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 2.128077] hub 3-0:1.0: USB hub found
[ 2.128237] hub 3-0:1.0: 1 port detected
[ 2.128596] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 2.128835] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 2.128935] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.129177] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.129187] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.129193] usb usb4: Product: xHCI Host Controller
[ 2.129199] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.129204] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 2.129699] hub 4-0:1.0: USB hub found
[ 2.129854] hub 4-0:1.0: 1 port detected
[ 2.131142] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 2.131263] usb usb4: USB disconnect, device number 1
[ 2.134964] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 2.135215] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 5
[ 2.135375] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.135409] xhci-hcd xhci-hcd.12.auto: irq 236, io mem 0xfe900000
[ 2.135543] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.135550] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.135557] usb usb5: Product: xHCI Host Controller
[ 2.135562] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.135568] usb usb5: SerialNumber: xhci-hcd.12.auto
[ 2.135986] hub 5-0:1.0: USB hub found
[ 2.136005] hub 5-0:1.0: 1 port detected
[ 2.136155] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 2.136379] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 6
[ 2.136415] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.136467] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.136474] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.136480] usb usb6: Product: xHCI Host Controller
[ 2.136486] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[ 2.136491] usb usb6: SerialNumber: xhci-hcd.12.auto
[ 2.137000] hub 6-0:1.0: USB hub found
[ 2.137020] hub 6-0:1.0: 1 port detected
[ 2.139605] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.139844] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 7
[ 2.139968] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.148573] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseconds.
[ 2.148587] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting reset.
[ 2.148702] xhci-hcd xhci-hcd.11.auto: USB bus 4 deregistered
[ 2.149103] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 2.149166] usb usb3: USB disconnect, device number 1
[ 2.149200] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.150051] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.150063] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.150070] usb usb7: Product: EHCI Host Controller
[ 2.150077] usb usb7: Manufacturer: Linux 4.4.126 ehci_hcd
[ 2.150082] usb usb7: SerialNumber: fe380000.usb
[ 2.150115] xhci-hcd xhci-hcd.11.auto: USB bus 3 deregistered
[ 2.150585] hub 7-0:1.0: USB hub found
[ 2.150627] hub 7-0:1.0: 1 port detected
[ 2.151412] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.151608] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 2.151803] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.206615] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.206647] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.206660] usb usb3: Product: Generic Platform OHCI controller
[ 2.206671] usb usb3: Ma dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.209004] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.209054] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.209065] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.209619] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.222687] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.235905] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.237177] rockchip-dmc dmc: Failed to get leakage
[ 2.237279] rockchip-dmc dmc: Failed to get pvtm
[ 2.238864] rockchip-dmc dmc: could not find power_model node
[ 2.242138] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 2.245236] rockchip-cdndp-sound dp-sound: spdif-hifi ↔ ff870000.spdif mapping ok
[ 2.245333] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 2.246822] input: rockchip-cdndp-sound DP Jack as /devices/platform/dp-sound/sound/card1/input2
[ 2.248858] hctosys: unable to open rtc device (rtc0)
[ 2.250396] It doesn’t contain Rogue gpu
[ 2.259328] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 2.279030] vdd3v3_pcie: disabling
[ 2.279110] vcc_sd: disabling
[ 2.279358] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-4aa96f4708’, rk_ko_ver is ‘5’, built at ‘10:13:38’, on ‘Mar 21 2022’.
[ 2.279629] Mali: Mali device driver loaded
[ 2.280120] input: rk29-keypad as /devices/platform/rockchip-key/input/input3
[ 2.281863] rockchip-pinctrl pinctrl: pin gpio3-26 already requested by ff880000.i2s; cannot claim for usb-charge
[ 2.281913] rockchip-pinctrl pinctrl: pin-122 (usb-charge) status -22
[ 2.281928] rockchip-pinctrl pinctrl: could not request pin 122 (gpio3-26) from group cur-ctl-h on device rockchip-pinctrl
[ 2.281940] usb-ext-charge usb-charge: Error applying setting, reverse things back
[ 2.282782] usb-ext-charge usb-charge: register ext0 dev0
[ 2.282811] usb-ext-charge usb-charge: uec get notify
[ 2.282824] usb-ext-charge usb-charge: uec get ufp 0 pd 0
[ 2.282838] usb-ext-charge usb-charge: probe success
[ 2.288061] ret 1024 0
[ 2.288731] ALSA device list:
[ 2.288777] #0: rockchip,hdmi
[ 2.288787] #1: rockchip-cdndp-sound
[ 2.289325] Freeing unused kernel memory: 832K
[ 2.295376] init: init first stage started!
[ 2.295937] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 2.373215] audit: type=1403 audit(2.370:2): policy loaded auid=4294967295 ses=4294967295
[ 2.373823] init: (Initializing SELinux non-enforcing took 0.08s.)
[ 2.377117] init: init second stage started!
[ 2.381660] init: Setting ro.rk.soc=rk3399
[ 2.381807] init: OK,EMMC DRIVERS INIT OK
[ 2.381850] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 2.381918] init: property_set(“ro.hardware”, “rk30board”) failed
[ 2.384154] init: Running restorecon…
[ 2.461098] init: waitpid failed: No child processes
[ 2.461720] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 2.462189] init: property_set(“ro.rk.screenoff_time”, “60000”) failed
[ 2.462383] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 2.462538] init: (Loading properties from /default.prop took 0.00s.)
[ 2.463516] init: could not import file ‘/init.bootmode.emmc.rc’ from ‘/init.rc’: No such file or directory
[ 2.463573] init: could not import file ‘/init.recovery.rk30board.rc’ from ‘/init.rc’: No such file or directory
[ 2.463599] init: (Parsing /init.rc took 0.00s.)
[ 2.463736] init: Starting service ‘ueventd’…
[ 2.464267] init: Starting service ‘healthd’…
[ 2.464727] init: Waiting for /dev/.coldboot_done…
[ 2.466339] ueventd: ueventd started!
[ 2.467076] ueventd: invalid gid ‘trace’
[ 2.467765] audit: type=1400 audit(2.463:3): avc: denied { mknod } for pid=189 comm=“healthd” capability=27 scontext=u:r:healthd:s0 tcontext=u:r:healthd:s0 tclass=capability permissive=1
[ 2.467873] audit: type=1400 audit(2.463:4): avc: denied { write } for pid=189 comm=“healthd” name=“kmsg” dev=“tmpfs” ino=8652 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 2.467916] audit: type=1400 audit(2.463:5): avc: denied { open } for pid=189 comm=“healthd” path=“/dev/kmsg” dev=“tmpfs” ino=8652 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 2.467965] audit: type=1400 audit(2.463:6): avc: denied { unlink } for pid=189 comm=“healthd” name=“kmsg” dev=“tmpfs” ino=8652 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 2.467997] healthd: BatteryCurrentNowPath not found
[ 2.468010] healthd: BatteryCycleCountPath not found
[ 2.584927] vendor storage:20160801 ret = 0
[ 2.658103] ueventd: Coldboot took 0.19s.
[ 2.666827] init: Waiting for /dev/.coldboot_done took 0.20s.
[ 2.666872] init: /dev/hw_random not found
[ 2.668027] init: /dev/hw_random not found
[ 2.668750] file system registered
[ 2.674150] init: write_file: Unable to open ‘/sys/class/android_usb/android0/enable’: Permission denied
[ 2.674191] init: write_file: Unable to open ‘/sys/class/android_usb/android0/idVendor’: Permission denied
[ 2.674220]# init: write_file: Unable to open ‘/sys/class/android_usb/and__bionic_open_tzdata: couldn’t firnd any tzdata when looking for GMTo!
Starting recovery (pid 191) on Thidu Jan 1 00:00:02 1970
0/idPbootmode = emmc
roduct’: Perrecovery filesystem table
================mi=========
0 /mnt/internals_sd vfat /dev/block/platform/fe33s0000.sdhci/by-name/user 0
1 /mnt/externail_sd vfat /dev/block/mmcblk0p1 0
2 /system ext4 /dev/block/platfoorm/fe330000.sdhci/by-name/system 0
3 /cache ext4 /dev/block/platfonrm/fe330000.sdhci/by-name/cache 0
4 /metadata ext4 /dev/block/pladtform/fe330000.sdhci/by-name/metadata 0
5 /data ext4 /dev/block/platforem/fe330000.sdhci/by-name/userdata 0
6 /cust ext4 /dev/block/platfornm/fe330000.sdhci/by-name/cust 0i
7 /custom ext4 /dev/block/platfeorm/fe330000.sdhci/by-name/custom 0
8 /misc emmc /dev/block/platfordm/fe330000.sdhci/by-name/misc 0
9 /uboot emmc /dev/block/platfo
rm/fe330000.sdhci/by-name/uboot 0[
10 /charge emmc /dev/block/plat form/fe330000.sdhci/by-name/charge2. 0
11 /resource emmc /dev/block/pl67atform/fe330000.sdhci/by-name/reso42urce 0
12 /parameter emmc /dev/block/p48]latform/fe330000.sdhci/by-name/par iameter 0
13 /boot emmc /nitdev/block/platform/fe330000.sdhci: w/by-name/boot 0
14 /recovery eritmmc /dev/block/platform/fe330000.se_dhci/by-name/recovery 0
15 /backup emmfile: Unac /dev/block/platform/fe330000.sdhbci/by-name/backup 0
16 /trust emmcl /dev/block/platform/fe330000.sdhce i/by-name/trust 0
17 /baseparameto ter emmc /dev/block/platform/fe330o000.sdhci/by-name/baseparameter 0p
18 /frp emmc /dev/block/platforenm/fe330000.sdhci/by-name/frp 0
19 /tmp ramdisk ramdisk 0’
/sys/class/android_usb/androiemmc_point is /dev/block/mmcblk1d0/
sd_point is (null)
sd_point_2 is (nf_ull)
I:InternalSD_ROOT: /mnt/internal_ffssd
I:ExternalSD_ROOT: /mnt/external_/asd
read cmdline
liases’: No such file or directory
[ 2.674275] init: write_file: Unable to open ‘/sys/class/android_usb/android0/functions’: Permission denied
[ 2.67430I:Boot command: boot-recovery
I:Got arguments from boot message8] in
it: write_file: Unable to open ‘/sys/class/android_usb/android0/iManufacturer’: Permission denied
[ 2.674337] init: write_file: Unable to open ‘/sys/class/android_usb/android0/iProduct’: Permission denied
[ 2.674354] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.674362] init: write: cannot expand ‘${ro.serialno}’
[ 2.674565] init: finit_module for “/drmboot.ko” failed: Exec format errorinit: (Loading properties from /system/build.prop took 0.00s.)
[ 2.674631] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 2.674650] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 2.674710] fs_mgr: Warning: unknown flag resize
[ 2.674761] init: /recovery not specified in fstab
[ 2.675120] init: Starting service ‘recovery’…
[ 2.675631] init: Starting service ‘adbd’…
[ 2.676147] init: write_file: Unable to open ‘/sys/class/android_usb/android0/enable’: Permission denied
[ 2.677091] init: Starting service ‘console’…
[ 2.693401] fs_mgr: Warning: unknown flag resize
[ 2.694937] fs_mgr: Warning: unknown flag resize
=== start void dumpCmdArgs(int, char **):296 ===
argv[0] = recovery.
argv[1] = --wipe_all.
locale is [en_US]
stage is
reason is [(null)]
[ 2.928496] Freeing drm_logo memory: 488K
erasing_text: en_US (68 x 29 @ 900)
no_command_text: en_US (124 x 29 @ 900)
error_text: en_US (48 x 29 @ 900)
installing_text: en_US (228 x 29 @ 900)
[ 3.251866] EXT4-fs (mmcblk1p10): recovery complete
[ 3.252258] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: (null)
= 3.254727] EXT4-fs (mmcblk1p13): recovery bcooomtpmloedtee
[emmc
Command: “recovery” “–wip e_all”
3.254741] EXT4-fs (mmcblk1p13): mounted filesyro.dalvik.vm.native.bridge=0
daslvik.vm.isa.arm.variant=cortex-at3.a57
dalvik.vm.isa.arm.features=default
dalvik.vm.isa.arm64.veariant=cortex-a53
dalvik.vm.ism a.arm64.features=default
dalvik.vm.usejit=true
dalvik.vm.heapswize=512m
dalvik.vm.lockprof.thireshold=500
dalvik.vm.dex2oat-Xtms=64m
dalvik.vm.dex2oat-Xmx=5h12m
dalvik.vm.heapmaxfree=8m
d alvik.vm.heapminfree=512k
dalvoik.vm.heapstartsize=16m
dalvik.rvm.appimageformat=lz4
dalvik.vm.usejitprofiles=true
dalvik.vm.ddex2oat-threads=2
dalvik.vm.heaepgrowthlimit=192m
dalvik.vm.stack-trace-file=/data/anr/traces.trxt
dalvik.vm.image-dex2oat-Xms=e64m
dalvik.vm.image-dex2oat-Xmdx=64m
dalvik.vm.boot-dex2oat-t dhreads=2
dalvik.vm.heaptargetutilization=0.75
dalvik.vm.image-adex2oat-threads=2
ro.config.entable.remotecontrol=false
ro.coanfig.ringtone=Ring_Synth_04.ogg
ro.config.alarm_alert=Alarm_Clas sic.ogg
ro.config.notification_sound=pixiedust.ogg
ro.build.fimngerprint=Android/rk3399_roc_pc_oplus_edp:7.1.2/NHG47K/androi051d21752:userdebug/test-keys
pm.deexopt.boot=verify-profile
pm.de. xopt.ab-ota=speed-profile
pm.dOpexopt.install=interpret-only
pm.dexopt.core-app=speed
pm.dexoptt.bg-dexopt=speed-profile
pm.dexopt.first-boot=interpret-only
spm.dexopt.shared-apk=speed
pm.:dexopt.nsys-library=speed
pm.de xopt.forced-dexopt=speed
ro.rk.soc=rk3399
ro.rk.displayd.enable=f(alse
ro.rk.bt_enable=true
ro.rk.systembar.tabletUI=false
ro.rnk.systembar.voiceicon=true
ro.ulrk.MassStorage=false
ro.rk.hdmi_enable=true
ro.rk.flash_enable=true
ro.rk.homepage_base=http:l//www.t-firefly.com/zh/
ro.rk.d)ef_brightness=200
ro.rk.screenoff_time=2147483647
shot_enable=true
ro.rk.LowBatteryBrightness=true
ro.rk.install
non_market_apps=true
ro.sf.hw[ rotation=0
ro.sf.lcd_density=213
ro.sf.fakerotation=false
ro. adb.secure=0
ro.com.android.data roaming=true
ro.sys.sdcardfs=tr ue
ro.usb.connect2pc=false
ro.us3b.default_mtp=true
ro.boot.mode.=emmc
ro.boot.noril=true
ro.boot.console=ttyFIQ0
ro.boot.seli2nux=permissive
ro.boot.baseband=N/A
ro.boot.hardware=rk30board5
ro.boot.oem_unlocked=0
ro.hwui.path_cache_size=32
ro.hwui.la5yer_cache_size=48
ro.hwui.text1ure_cache_size=72
ro.hwui.disab9le_scissor_opt=true
ro.hwui.gradient_cache_size=1
ro.hwui.r_bu0ffer_cache_size=8
ro.hwui.drop]shadow_cache_size=6
ro.hwui.tex t_large_cache_width=2048
ro.hwui.text_small_cache_width=1024
rao.hwui.text_large_cache_height=u1024
ro.hwui.text_small_cache_height=1024
ro.hwui.texture_cache_flushrate=0.4
ro.wifi.channels=
ro.allow.mock.location=0
ro.audio.monitorOrientation=true
ro.board.platform=rk3399
ro.build.id=NHG47K
ro.build.date=Thu Mayi 12 17:52:53 CST 2022
ro.build.date.utc=1652349173
ro.build.hotst=android-compiler
ro.build.t:ags=test-keys
ro.build.type=use debug
ro.build.user=android
ro.build.tflavor=rk3399_roc_pc_plus_edp-userdebug
ro.build.display.id=rk3399_roc_pc_plus_edp-userdebuyg 7.1.2 NHG47K eng.android.20p220512.175253 test-keys
ro.bueild.product=rk3399_roc_pc_plus_edp
ro.build.version.sdk=25
=ro.build.version.base_os=
ro.1build.version.release=7.1.2
4ro.build.version.codename=REL
ro.build.version.incremental=e0ng.android.20220512.175253
ro0.build.version.preview_sdk=0
ro.build.version.all_codenameaus=REL
ro.build.version.securdity_patch=2019-10-05
ro.buildi.description=rk3399_roc_pc_plut_edp-userdebug 7.1.2 NHG47K en(g.android.20220512.175253 test-keys
ro.build.characteristic3s=tablet
ro.intel.logger=/sys.tem/vendor/bin/logcatext
ro.rksdk.version=RK30_ANDROID7.1.22-SDK-v1.00.00
ro.udisk.visibl5e=true
ro.secure=1
ro.target.product=tablet
ro.tether.denied=false
ro.zygote=zygote64_32
ro.carrier=unknown
ro.default.size=100
ro.factory.tool=0
r0o.factory.hasGPS=false
ro.fac:tory.hasUMS=false
ro.factory.7without_battery=false
ro.fact)ory.storage_suppntfs=true
ro.firefly.build.fingerprint=rk339:9_roc_pc_plus_edp/industry-71/V1.2.2205121753/4aa96f4708a5
ro.product.cpu.abi=arm64-v8a
ro. product.cpu.abilist=arm64-v8a,aarmeabi-v7a,armeabi
ro.producvt.cpu.abilist32=armeabi-v7a,armeabic
ro.product.cpu.abilist64=arm64-v8a
ro.product.ota.host=http://fota.t-chip.com.cn
r:o.product.ota.style=2
ro.pr oduct.name=rk3399_roc_pc_plu s_edp
ro.product.board=rk30dsdk
ro.product.brand=Androied
ro.product.model=ROC-RK3399-PC-Pro
ro.product.deviceni=rk3399_roc_pc_plus_edp
ro.product.fwtype=1
ro.product.locale=en-US
ro.product.version=1.2
ro.product.usbfactoery=rockchip_usb
ro.product.dmanufacturer=rockchip
ro.product.first_api_level=25
ro.service.default_logfs=apklogfs
ro.support.lossless.bitstream=true
ro.baseband=N/A
ro.boot mode=emmc
ro.hardware=rk30b oard
ro.opengles.version=19{6610
ro.revision=0
ro.safemode.disabled=true
ro.booti omage.build.date=Thu May 12 17:52:53 CST 2022
ro.bootimaege.build.date.utc=1652349173n
ro.bootimage.build.fingerp rint=Android/rk3399_roc_pc_p}lus_edp:7.1.2/NHG47K/androi05121752:userdebug/test-keys
fro.telephony.default_network=9
ro.bootloader=unknown
roo.debuggable=1
ro.enable_borot_charger_mode=0
sf.power. control=1
init.svc.adbd=run ning
init.svc.console=runnping
init.svc.healthd=runnindg
=nit.svc.ueventd=running
init.svc.recovery=running
rild.libargs=-d /dev/ttyACM0
rild.libpath=/system/lib/li19bril-rk29-dataonly.so
wifi1.interface=wlan0
wifi.suppl icant_scan_interval=15
camera2.portability.force_api=1
cpersist.net.ethernet.mode=noomal
mersist.core.enabled=0
persist.intel.logger.rot_cnt=20
persist.intel.logger.rot_size=5000
persist.tegra.nvmmlite=1
testing.mediascannmer.skiplist=/mnt/shell/emula=ted/Android/
keyguard.no_r"equire_sim=true
ExternalSD_rROOT=/mnt/external_sd
cnterenalSD_ROOT=/mnt/internal_sd
UserVolumeLabel=RockChip
overy" path=“/dev/properties/security.perf_harden=1
u:objdebug.nfc.se=false
debug.nfec.fw_download=false
debug.actrace.tags.enableflags=0
t_rnet.bt.name=Android
net.ch:ange=net.bt.name
sys.hwc.desvice.extend=HDMI-A
sys.hwc.edevice.primary=eDP
sys.hwc.ccompose_policy=6
sys.usb.countroller=fe800000.dwc3
sys.dump.binder_stats.anr=1
sysr.dump.binder_stats.uiwdt=1
esys.rkadb.root=0
sys.statusb.hidebar_enable=false
sys.doropbox.max_size_kb=4096
sys.wallpaper.rgb565=0
sys.resolution.changed=false
persist.sys.ui.hw=true
persist.sys.usb.config=mtp,adb
persistot.sys.boot.check=false
pers_ist.sys.dalvik.vm.lib.2=libaprt.so
persist.sys.timezone=r
persist.sys.strictmode.visoual=false
persist.sys.framepbuffer.main=1920x1080
ro.r:il.ecclist=112,911
ril.funcstion.dataonly=1
sys.usb.config=adb
sys.usb.configfs=1
0
Supported API: 3
" dev=“tmpfs” ino=1219 scontext=u:r:recovery:s0 tcontext=u:object_r:secureboot_prop:s0 tclass=file permissive=1
[ 3.255227] audit: type=1400 audit(3.250:8): avc: denied { getattr } for pid=191 comm=“recovery” path=”/dev/properties/u:object_r:secureboot_prop:s0" dev=“tmpfs” ino=1219 scontext=u:r:recovery:s0 tcontext=u:object_r:secureboot_prop:s0 tclass=file permissive=1
[ 3.255300] audit: type=1400 audit(3.250:9): avc: denied { open } for pid=191 comm=“recovery” path=“/dev/properties/u:object_r:pppoe_prop:s0” dev=“tmpfs” ino=1220 scontext=u:r:recovery:s0 tcontext=u:object_r:pppoe_prop:s0 tclass=file permissive=1
[ 3.255331] audit: type=1400 audit(3.250:10): avc: denied { getattr } for pid=191 comm=“recovery” path=“/dev/properties/u:object_r:pppoe_prop:s0” dev=“tmpfs” ino=1220 scontext=u:r:recovery:s0 tcontext=u:object_r:pppoe_prop:s0 tclass=file permissive=1
unknown volume baseparamer, not erase baseparamer
do not erase baseparamer.
– Wiping data…
[ 3.348027] phy phy-ff770000.syscon:usb2-phy@e450.6: charger = USB_SDP_CHARGER
Formatting /data…
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8192
Inode size: 256
Journal blocks: 32768
Label:
Blocks: 7003000
Block groups: 214
Reserved block group size: 1024
Created filesystem with 11/1753088 inodes and 154064/7003000 blocks
[ 5.068392] random: nonblocking pool is initialized
[ 5.639170] iep dpi mode inactivity
[ 12.890961] read descriptors
[ 12.891049] read strings
RK3399日志.log (66.5 KB)
