固件文件名称:U-Boot 2017.09(u-boot commit id: c1bd6ed8bb49333e0
固件下载地址:百度网盘
Log日志:YOLOv5-RK3399Pro-master.zip
按照 1. 编译 Linux 固件 — Firefly Wiki 中说的进行编译,出现如下错误
load addr is 0x200000!
pack input u-boot.bin
pack file size: 1007664(984 KB)
crc = 0x2faf6aac
uboot version: U-Boot 2017.09-g278b1a832c (Nov 24 2021 - 01:45:41)
pack uboot.img success!
pack uboot okay! Input: u-boot.bin
usage: boot_merger pack [-h] [–version] [–chip CHIP]
[–loader_ver LOADER_VER]
[–entry_471 ENTRY_471 [ENTRY_471 …]]
[–entry_472 ENTRY_472 [ENTRY_472 …]]
[–entry_loader ENTRY_LOADER [ENTRY_LOADER …]]
[–create_head] [–rc4_off] [–rc4_471_off]
[–keep_cert] [–hash_type {sha256,sha512}]
[–output OUTPUT]
boot_merger pack: error: unrecognized arguments: --replace tools/rk_tools/ ./ /root/rk3399pro_linux_release_v2.5.1_20210304/rkbin/RKBOOT/RK3399PROMINIALL.ini
====Build uboot failed!====
YOLOv5-RK3399Pro-master.zip (398 KB)
895816513 发表于 2022-5-16 15:03
你用试试用这个命令同步一下
.repo/repo/repo sync -cn
我在刚解压完源码就已经同步过了,然后刚才又同步过一遍,问题没有解决,
我测试是可以的,你确认这几个仓库的版本号对不对的上,还有看看仓库是否干净
u-boot:
278b1a832c659e6604bec49dca8d9a7fd972d27f - huangjc 2020-08-06 : firefly: Solve debug-serial input problems
rkbin:
2e3e6bb1f2bf7a30d392bec1b113f7f318228686 - huangjc 2020-12-03 : Revert "rk3399pro: bl32: update version to 2.00"
tools:
3625ca56cf9217dc1b1b863546d9fb8868831a3a - huangjf 2021-10-11 : firefly: mkrawimg.sh: enable set bootable partition
device/rockchip:
7d7dc389b60562de88ce034f93b26a0213ee1b67 - lvsx 2022-02-17 : oem_ipc_firefly: use ircutSwitch
kernel:
42dfe93869b78f2d102fc808d583748a681089f7 - dengkx 2022-01-05 : Merge remote-tracking branch 'rk/stable-4.4-rk3399pro-linux' into rk_debug
我现在使用的manifest.xml是
realpath .repo/manifest.xml
.repo/manifests/rk3399pro/rk3399pro_linux_release_20220304_v1.4.2a.xml
无论解决没有都及时回复我一下,我的邮箱地址:
hjc@t-chip.com.cn
多次尝试同步更新后,已经可以正常编译了,非常感谢!!
请问一下仓库版本对不上该怎么更新呢?看了一下官网的SDK包是210304的,请问下有没有你这个220304版本的SDK呢?
