linux 在dts中添加子节点,编译通过 log中找不到节点信息
SDK包名称:rk356x_linux_release_v1.2.0_20211012.xml
SDK修改内容:i2c1下添加了子节点
Log日志:log.zip
对应的dts文件下在ic1下添加了rk628d子节点,编译通过后,烧录固件,打印出来的log中找不到添加的rk628节点信息。
dts修改如下:
&i2c1{
clock-frequency = <400000>;
status = “okay”;
rk628: rk628@50{
    reg = <0x50>;
    interrupt-parent = <&gpio3>;
    interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>;
    reset-gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_LOW>;
    status = "okay";
#include <arm/rk628.dtsi>
&rk628_combtxphy{
status = “okay”;
&rk628_combrxphy{
status = “okay”;
&rk628_csi {
status = “okay”;
/** If the hpd output level is inverted on the circuit, * the following configuration needs to be enabled. /
hpd-output-inverted; */
//plugin-det-gpios = <&gpio4 RK_PB4 GPIO_ACTIVE_LOW>; //
plugin-det-gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; //
//plugin-det-gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>;
//power-gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
rockchip,camera-module-index = <0>;
rockchip,camera-module-facing = "back";
rockchip,camera-module-name = "RK628-CSI";
rockchip,camera-module-lens-name = "NC";
port {
    hdmiin_out0: endpoint {
        remote-endpoint = <&mipi_in>;
        data-lanes = <1 2 3 4>;
&csi2_dphy_hw {
status = “okay”;
&csi2_dphy0 {
status = “okay”;
ports {
    #address-cells = <1>;
    #size-cells = <0>;
    port@0 {
        reg = <0>;
        #size-cells = <0>;
        mipi_in: endpoint@0 {
            reg = <0>;
            remote-endpoint = <&hdmiin_out0>;
    port@1 {
        reg = <1>;
        #size-cells = <0>;
        csidphy0_out: endpoint@0 {
            reg = <0>;
            remote-endpoint = <&isp0_in>;
&rkisp {
status = “okay”;
&rkisp_mmu {
status = “okay”;
&rkisp_vir0 {
status = “okay”;
port {
    #size-cells = <0>;
    isp0_in: endpoint@0 {
        reg = <0>;
        remote-endpoint = <&csidphy0_out>;
log.zip (25.1 KB)
编译打包过程如下:
litong@ubuntu:~/linux/rk356x_linux_release_20211019$ ./build.sh
processing option: allff
TARGET_ARCH=arm64
TARGET_PLATFORM=rk356x
TARGET_UBOOT_CONFIG=firefly-rk3568
TARGET_SPL_CONFIG=
TARGET_KERNEL_CONFIG=firefly_linux_defconfig
TARGET_KERNEL_DTS=rk3568-firefly-aioj
TARGET_TOOLCHAIN_CONFIG=
TARGET_BUILDROOT_CONFIG=
TARGET_RECOVERY_CONFIG=
TARGET_PCBA_CONFIG=
TARGET_RAMBOOT_CONFIG=
============Start building uboot============
## make firefly-rk3568_defconfig -j4
CHK include/config.h
GEN include/autoconf.mk.dep
CFG u-boot.cfg
CFG tpl/u-boot.cfg
CFG spl/u-boot.cfg
GEN spl/include/autoconf.mk
GEN tpl/include/autoconf.mk
CHK include/config/uboot.release
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
CHK include/generated/version_autogenerated.h
CHK include/generated/asm-offsets.h
CHK include/generated/generic-asm-offsets.h
CFG u-boot.cfg
HOSTCC tools/mkenvimage.o
HOSTCC tools/image-host.o
HOSTCC tools/fit_image.o
HOSTCC tools/dumpimage.o
HOSTCC tools/mkimage.o
HOSTCC tools/rockchip/boot_merger.o
HOSTCC tools/rockchip/loaderimage.o
HOSTLD tools/loaderimage
HOSTLD tools/mkenvimage
HOSTLD tools/dumpimage
HOSTLD tools/mkimage
HOSTLD tools/boot_merger
CC arch/arm/cpu/armv8/fwcall.o
LD arch/arm/cpu/armv8/built-in.o
CC cmd/version.o
CC common/main.o
LD cmd/built-in.o
LD common/built-in.o
CC drivers/usb/gadget/f_fastboot.o
CC lib/display_options.o
LD drivers/usb/gadget/built-in.o
LD lib/built-in.o
LD u-boot
OBJCOPY u-boot.srec
OBJCOPY u-boot-nodtb.bin
make[2]: ‘arch/arm/dts/rk3568-firefly.dtb’ is up to date.
SYM u-boot.sym
start=$(/home/litong/linux/rk356x_linux_release_20211019/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ’ '); end=$(/home/litong/linux/rk356x_linux_release_20211019/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ’ '); tools/relocate-rela u-boot-nodtb.bin 0x00a00000 $start $end
COPY u-boot.dtb
CAT u-boot-dtb.bin
MKIMAGE u-boot.img
MKIMAGE u-boot-dtb.img
COPY u-boot.bin
ALIGN u-boot.bin
CC spl/arch/arm/cpu/armv8/fwcall.o
CC tpl/arch/arm/mach-rockchip/tpl.o
CC tpl/arch/arm/cpu/armv8/fwcall.o
LD spl/arch/arm/cpu/armv8/built-in.o
LD tpl/arch/arm/cpu/armv8/built-in.o
LD tpl/arch/arm/mach-rockchip/built-in.o
CC spl/common/spl/spl.o
LD tpl/u-boot-tpl
LD spl/common/spl/built-in.o
OBJCOPY tpl/u-boot-tpl-nodtb.bin
COPY tpl/u-boot-tpl.bin
COPY spl/u-boot-spl.dtb
CC spl/lib/display_options.o
LD spl/lib/built-in.o
LD spl/u-boot-spl
OBJCOPY spl/u-boot-spl-nodtb.bin
CAT spl/u-boot-spl-dtb.bin
COPY spl/u-boot-spl.bin
CFGCHK u-boot.cfg
SEC=1
pack u-boot.itb okay! Input: /home/litong/linux/rk356x_linux_release_20211019/rkbin/RKTRUST/RK3568TRUST.ini
FIT description: FIT Image with ATF/OP-TEE/U-Boot/MCU
Created: Mon May 16 00:23:50 2022
Image 0 (uboot)
Description: U-Boot
Type: Standalone Program
Compression: uncompressed
Data Size: 1210656 Bytes = 1182.28 KiB = 1.15 MiB
Architecture: AArch64
Load Address: 0x00a00000
Entry Point: unavailable
Hash algo: sha256
Hash value: 5febe2d56ca5740b3333366f74bd6e228434dd82cea7f1eebdef61d2a04da190
Image 1 (atf-1)
Description: ARM Trusted Firmware
Type: Firmware
Data Size: 155648 Bytes = 152.00 KiB = 0.15 MiB
Load Address: 0x00040000
Hash algo: sha256
Hash value: fe4f274c0624c2d7e7b9aa0d5b40a3331801664bf625367702d2116dbe452466
Image 2 (atf-2)
Type: Firmware
Data Size: 19531 Bytes = 19.07 KiB = 0.02 MiB
Load Address: 0x00068000
Hash algo: sha256
Hash value: 8d440360954c39a1d9a1eb604c0642e7201f4a47679272a9885cfd46205aa418
Image 3 (atf-3)
Type: Firmware
Data Size: 8192 Bytes = 8.00 KiB = 0.01 MiB
Load Address: 0xfdcd0000
Hash algo: sha256
Hash value: e410275b51692587b5d09c794ae13f2dcd4d187bd6ab1eb2998bf18d44750876
Image 4 (atf-4)
Type: Firmware
Load Address: 0xfdcc9000
Hash algo: sha256
Hash value: 990c53fc0167a7bcd877235f09a3ac6911841c978a4e270d89f6259ec1d36144
Image 5 (atf-5)
Type: Firmware
Data Size: 7668 Bytes = 7.49 KiB = 0.01 MiB
Load Address: 0x00066000
Hash algo: sha256
Hash value: 315a4195a9f6536f971c695a79fcab4870363fc7fc97f355bd091d8d7092261a
Image 6 (optee)
Description: OP-TEE
Type: Firmware
Data Size: 457112 Bytes = 446.40 KiB = 0.44 MiB
Load Address: 0x08400000
Hash algo: sha256
Hash value: f3f0302d4cf61565726829783ee08321117a2e409b8933199ce36b3f0ea60677
Image 7 (fdt)
Description: U-Boot dtb
Type: Flat Device Tree
Data Size: 15115 Bytes = 14.76 KiB = 0.01 MiB
Hash algo: sha256
Hash value: 30938731debb4198eb74f983facf8e81a2a52dfccdbac4a0a35ddeccaba3402a
Default Configuration: ‘conf’
Configuration 0 (conf)
Description: rk3568-firefly
Kernel: unavailable
Firmware: atf-1
FDT: fdt
Loadables: uboot
atf-2
atf-3
atf-4
atf-5
optee
pack loader ok.(rk356x_spl_loader_v1.11.112.bin)(0.02)
pack loader(SPL) okay! Input: /home/litong/linux/rk356x_linux_release_20211019/rkbin/RKBOOT/RK3568MINIALL.ini
/home/litong/linux/rk356x_linux_release_20211019/u-boot
pack loader with new: spl/u-boot-spl.bin
Image(no-signed, version=0): uboot.img (FIT with uboot, trust…) is ready
Image(no-signed): rk356x_spl_loader_v1.11.112.bin (with spl, ddr, usbplug) is ready
pack uboot.img okay! Input: /home/litong/linux/rk356x_linux_release_20211019/rkbin/RKTRUST/RK3568TRUST.ini
Platform RK3568 is build OK, with new .config(make firefly-rk3568_defconfig -j4)
Mon May 16 00:23:50 PDT 2022
Image Type: Rockchip RK35 boot image
Init Data Size: 59392 bytes
Boot Data Size: 241664 bytes
Input:
/home/litong/linux/rk356x_linux_release_20211019/rkbin/bin/rk35/rk3568_ddr_1560MHz_v1.11.bin
/home/litong/linux/rk356x_linux_release_20211019/rkbin/bin/rk35/rk356x_spl_v1.12.bin
Pack rk3568 idblock.bin okay!
Running build_uboot succeeded.
Skipping build_loader for missing configs: RK_LOADER_BUILD_TARGET.
============Start building kernel============
TARGET_ARCH =arm64
TARGET_KERNEL_CONFIG =firefly_linux_defconfig
TARGET_KERNEL_DTS =rk3568-firefly-aioj
TARGET_KERNEL_CONFIG_FRAGMENT =
scripts/kconfig/conf --syncconfig Kconfig
DTC arch/arm64/boot/dts/rockchip/rk3568-firefly-aioj.dtb
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
GZIP kernel/config_data.gz
Image: kernel.img is ready
Building modules, stage 2.
MODPOST 0 modules
found ./arch/arm64/boot/dts/rockchip/.rk3568-firefly-aioj.dtb.dts.tmp
Image: resource.img (with rk3568-firefly-aioj.dtb logo.bmp logo_kernel.bmp) is ready
Image: boot.img (with Image ramdisk.img resource.img) is ready
Image: zboot.img (with Image.lz4 ramdisk.img resource.img) is ready
fdt {
kernel {
ramdisk {
resource {
FIT description: U-Boot FIT source file for arm
Created: Mon May 16 00:24:11 2022
Image 0 (fdt)
Description: unavailable
Data Size: 141421 Bytes = 138.11 KiB = 0.13 MiB
Load Address: 0xffffff00
Hash algo: sha256
Hash value: db6ea2523a521ca322006d378709b4e874b9d8d59160e7262ce5780e160654cc
Image 1 (kernel)
Type: Kernel Image
Data Size: 24252424 Bytes = 23684.01 KiB = 23.13 MiB
OS: Linux
Load Address: 0xffffff01
Entry Point: 0xffffff01
Hash algo: sha256
Hash value: d5a1f03c8b4bdca57b51dc8a58352643ec3c444cccd8dd8fd0237763c12bd53d
Image 2 (ramdisk)
Type: RAMDisk Image
Data Size: 8860887 Bytes = 8653.21 KiB = 8.45 MiB
OS: Linux
Load Address: 0xffffff02
Hash algo: sha256
Hash value: 252b580d48d2afa60baba78b73045c9ccc36e894535d5683b9d1d2f4158db7e1
Image 3 (resource)
Type: Multi-File Image
Data Size: 399872 Bytes = 390.50 KiB = 0.38 MiB
Hash algo: sha256
Hash value: 44ce1d1d11f206617d1c788d05ddf77377f3621e69ac1e54c4099203f3c80278
Kernel: kernel
Init Ramdisk: ramdisk
FDT: fdt
Running build_kernel succeeded.
Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN.
Skipping build_buildroot for missing configs: RK_CFG_BUILDROOT.
buildroot/output//images/rootfs.ext4 not generated?
Running build_rootfs succeeded.
==========Start building recovery==========
config is
use prebuilt rk356x-recovery-arm64.cpio.gz for CPIO image
found kernel image
pack recovery.img…fdt {
kernel {
ramdisk {
resource {
Image 0 (fdt)
Hash algo: sha256
Image 1 (kernel)
Type: Kernel Image
OS: Linux
Hash algo: sha256
Image 2 (ramdisk)
Type: RAMDisk Image
Data Size: 6956263 Bytes = 6793.23 KiB = 6.63 MiB
OS: Linux
Hash algo: sha256
Hash value: 848757f81587ca00f60eeb52788b237c9cde5bb2b94663176b2393ad70038702
Image 3 (resource)
Hash algo: sha256
Kernel: kernel
FDT: fdt
done.
you take 0:00.86 to build recovery
====Build recovery ok!====
Running build_recovery succeeded.
Skipping build_ramboot for missing configs: RK_CFG_RAMBOOT.
Running build_all succeeded.
/usr/bin/fakeroot
create rootfs.img…done.
create parameter…done.
/home/litong/linux/rk356x_linux_release_20211019/device/rockchip/rk356x/parameter-ubuntu-fit.txt
0x00002000@0x00004000(uboot),0x00002000@0x00006000(misc),0x00020000@0x00008000(boot),0x00020000@0x00028000(recovery),0x00010000@0x00048000(backup),0x00c00000@0x00058000(rootfs),-@0x00c58000(userdata:grow)
create misc.img…done.
warning: not found!
create uboot.img…done.
create idblock.bin…done.
uboot fotmat type is fit, so ignore trust.img…
create loader…done.
create boot.img…done.
mkupdate.sh will resize the rootfs partition.
Image: image in rockdev is ready
Make image ok!
File name is AIO-3568J-UBUNTU20.04-GPT
Rename the file? [N|y]n
Make update.img
start to make update.img…
Resize rootfs partition size
dumpe2fs 1.44.1 (24-Mar-2018)
Android Firmware Package Tool v1.66
------ PACKAGE ------
Add file: ./package-file
Add file: ./package-file done,offset=0x800,size=0x11a,userspace=0x1
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/MiniLoaderAll.bin done,offset=0x1000,size=0x701c0,userspace=0xe1
Add file: ./Image/parameter.txt
Add file: ./Image/parameter.txt done,offset=0x71800,size=0x1d5,userspace=0x1
Add file: ./Image/uboot.img
Add file: ./Image/uboot.img done,offset=0x72000,size=0x400000,userspace=0x800
Add file: ./Image/misc.img
Add file: ./Image/misc.img done,offset=0x472000,size=0xc000,userspace=0x18
Add file: ./Image/boot.img
Add file: ./Image/boot.img done,offset=0x47e000,size=0x2019800,userspace=0x4033
Add file: ./Image/recovery.img
Add file: ./Image/recovery.img done,offset=0x2497800,size=0x1e48800,userspace=0x3c91
Add file: ./Image/rootfs.img
Add file: ./Image/rootfs.img done,offset=0x42e0000,size=0xa744fc00,userspace=0x14e8a0
Add CRC…
Make firmware OK!
------ OK ------
RKImageMaker ver 1.66
Generating new image, please wait…
Writing head info…
Writing boot file…
Writing firmware…
Generating MD5 data…
MD5 data generated successfully!
New image generated successfully!
Making ./Image/update.img OK.
Make update image ok!
/home/litong/linux/rk356x_linux_release_20211019/rockdev/pack/AIO-3568J-UBUNTU20.04-GPT-20220516-0024.img
Running build_updateimg succeeded.
之前的问题解决了,是添加模块的问题,现在又遇到了新的问题。
i2c找不到模块信息
Android调通了,可以对比一下linux相关的差异。内核差别应该不大
贵厂的rk628d什么时候上线呢,你们是适配了那些soc呢
目前还没具体日期、主要适配RK356x、RK3399
您好,我现在遇到了如下问题,之前我用原厂提供的for all版本的代码,修改drivers/media/i2c/Makefile,添加rk628的编译,在i2c1下添加节点,报找不到模块信息。
dts修改如下:
&i2c1 {
status = “okay”;
rk628_csi_v4l2: rk628_csi_v4l2@51 {
reg = <0x50>;
compatible = “rockchip,rk628-csi-v4l2”;
        reset-gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>;
        /* hpd-output-inverted; */
        //plugin-det-gpios = <&gpio0 13 GPIO_ACTIVE_HIGH>;
        //hdcp-enable = <1>;
        status = "okay";
log为:
之后我发现linux内核里面带有628d的驱动信息,直接用3568内核里面的驱动。(之前安卓平台验证该方案可行)
dts修改为:
&i2c1{
status = “okay”;
rk628: rk628@50{
    reg = <0x50>;
    status = "okay";
&rk628_combtxphy{
status = “okay”;
&rk628_combrxphy{
status = “okay”;
&rk628_csi {
status = “okay”;
port {
&csi2_dphy_hw {
status = “okay”;
&csi2_dphy0 {
status = “okay”;
ports {
    #size-cells = <0>;
    port@0 {
        reg = <0>;
        #size-cells = <0>;
            reg = <0>;
    port@1 {
        reg = <1>;
        #size-cells = <0>;
            reg = <0>;
&rkisp {
status = “okay”;
&rkisp_mmu {
status = “okay”;
&rkisp_vir0 {
status = “okay”;
port {
    #size-cells = <0>;
        reg = <0>;
kernel config 打开如下配置:
CONFIG_MFD_RK628=Y
CONFIG_VIDEO_RK628_CSI=Y
log中找不到rk628的节点信息,即无法调用rk628d驱动
现在怀疑是i2c节点中子节点添加失败,导致以上错误,请问如何检验或者如何解决。
使用固件版本:roc-rk3568-pc-ubuntu
非常感谢。
添加的节点中根本没有compatible属性,肯定是匹配不上驱动的啊
你不是安卓调通了吗,dts节点照搬过来应该就可以的吧,安卓和linux的dts基本一致的
你不是安卓调通了吗,dts节点照搬过来应该 …
compatible信息在3568自带的rk628.dtsi里,不需要在dts里面定义。
之前安卓dts就是这么写的
kernel config 打开 rk628 之后有没有保存到 firefly_linux_defconfig ?
有的。所以就很奇怪
你把 include <arm/rk628.dtsi> 移到 dts 最开头试试
Liuth 发表于 2022-5-27 15:58
你把 include 移到 dts 最开头试试
我之前考虑过这个情况,会报找不到节点,原因是i2c1里面已经定义了rk628d节点,但是#include 放到最前面会导致rk628.dts引用rk628节点找不到定义
log提示说 Y 对 MFD_RK628 无效
把大写Y改成小写y
把大写Y改成小写y
ok了,确实是没注意
把大写Y改成小写y
您好,现在我遇到了设备EBUSY这个问题,检查后发现配置的引脚没有被其它模块申请,
总共用到了两个引脚,分别作为中断和复位。
修改的dts为rk3568-firefly-aioj.dts
也尝试过更换其他的配置文件,并对相应的dts进行更改,log报错相同,总共尝试了
aio-3568j-ubuntu.mk
firefly-rk3568-ubuntu.mk
roc-rk3568-pc-ubuntu.mk
给这两个脚设置一下pinctrl,如果有问题,开机打印会有详细说明
我已经找到问题了
我在rk628_csi中添加了检测hdmi插入的引脚,这个引脚应该是固定的,我看内核里面其他的驱动检测hdmi都用的这个节点
但是我发现,在rk568-firefly-core.dtsi中该引脚已经被使用了
请问vcc5v0_host这个gpio能换别别的引脚吗?
你是自己做的底板吗?
官方底板上它已经作为 USB3.0 的电源脚了,不能换
