固件文件名称:rk356x_linux_release_20211019
固件下载地址:百度网盘
Log日志:New.zip
我在官方SDK下编译,得到自己编译出来的两个包
linux-headers-4.19.219_4.19.219-12_arm64.deb
linux-image-4.19.219_4.19.219-12_arm64.deb
然后再开发板上安装,按照这个步骤安装
2.3.2. 安装以下以 ROC-RK3568-PC 安装为例:
将得到的 deb 包放入设备中,然后安装,对于 headers,安装后还需要进行编译处理:
对于使用了 extboot 的板卡,安装后重启即可完成内核更新,之后再进行编译 headers
# 安装sudo dpkg -i linux-headers-4.19.172_4.19.172-189_arm64.debsudo dpkg -i linux-image-4.19.172_4.19.172-189_arm64.deb# 编译cd /usr/src/linux-headers-4.19.172make headers_checkmake headers_install# make scripts 可能会出错,如果出错在 tools,可以直接忽略,安装完成make scripts
root@firefly:/home/firefly# ls
Desktop New.c linux-headers-4.19.219_4.19.219-12_arm64.deb linux-image-4.19.219_4.19.219-12_arm64.deb
root@firefly:/home/firefly# dpkg -i linux-headers-4.19.219_4.19.219-12_arm64.deb
(Reading database … 81711 files and directories currently installed.)
Preparing to unpack linux-headers-4.19.219_4.19.219-12_arm64.deb …
Unpacking linux-headers-4.19.219 (4.19.219-12) over (4.19.219-12) …
Setting up linux-headers-4.19.219 (4.19.219-12) …
root@firefly:/home/firefly# dpkg -i linux-image-4.19.219_4.19.219-12_arm64.deb
Preparing to unpack linux-image-4.19.219_4.19.219-12_arm64.deb …
Unpacking linux-image-4.19.219 (4.19.219-12) over (4.19.219-12) …
Setting up linux-image-4.19.219 (4.19.219-12) …
update-initramfs: Generating /boot/initrd.img-4.19.219
root@firefly:/home/firefly# cd /usr/src/linux-headers-4.19.219/
这里显示,没有这个文本,可如何是好呢?
root@firefly:/usr/src/linux-headers-4.19.219# make headers_check
/usr/bin/env: ‘python’: No such file or directory
HOSTCC scripts/basic/fixdep
/bin/sh: 1: gcc: not found
scripts/Makefile.host:90: recipe for target ‘scripts/basic/fixdep’ failed
make[1]: *** [scripts/basic/fixdep] Error 127
Makefile:509: recipe for target ‘scripts_basic’ failed
make: *** [scripts_basic] Error 2
然后我还考虑到可能是linuxSDK版本不对无法使用,我就cat一下
root@firefly:~# cat /proc/version
Linux version 4.19.219 (zjt@zjt-virtual-machine) (firefly: 72491ed436765c35dddc56ce27b537a4d3703107) (sdk version: rk356x_linux_release_20220311_v1.2.3a.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #12 SMP Mon May 23 10:33:38 CST 2022
SDK这里版本显示是V.1.2.3a,是不是因为它低于1.2.4a,所以就导致linux-headers和linux-image无法使用呢?
New.zip (598 Bytes)
