板子: 3128
编译步骤是参考的 http://wiki.t-firefly.com/index.php/FirePrime/Build_kernel
步骤
git clone https://bitbucket.org/T-Firefly/fireprime-kernel.git
cd fireprime-kernel
export ARCH=arm
export CROSS_COMPILE=/opt/arm-linux-androideabi-4.6/bin/arm-linux-androideabi-
make fireprime-linux_defconfig
make rk3128-fireprime.img
git clone -b fireprime https://github.com/TeeFirefly/initrd.git
make -C initrd
truncate -s “%4” initrd.img
mkbootimg --kernel arch/arm/boot/zImage --ramdisk initrd.img -o linux-boot.img
3128这个板子之前固件为:FirePrime_Ubuntu15.04_201508071519.img
能够正常启动和使用
但烧写分区映像 把前述步骤编译的linux-boot.img烧写到uboot分区(boot分区的地址已修改为0x0000E000)之后,内核出错
错误信息:
rk312x_pie_init: failed to load section -12
请帮忙看看是哪里出了问题,谢谢。
完整的内核启动信息
DDR Version 2.04 20150121
1A1A2A2B 0
1A1A2929 3
LPDDR2
292A292A F
Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Die Bus-Width=32 Size=1024MB
mach:14
Boot1 Release Time: 2015-05-25, version: 2.25
ChipType = a 1373
No.1 FLASH ID:ad de 14 a7 42 4a
ECC:60
*V?k%???0 20
StorageInit ok = 614470
theL?H?H???с2014.10-RK3128-10 (Jun 12 2015 - 09:11:25)
CPU: rk3128
CPU’s clock information:
arm pll = 300000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks:1
128 MiB
rk dma?.?K???init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk312x!
Unknow param: MACHINE_ID:007!
power key: bank-3 pin-23
can’t find dts node for act8846
can’t find dts node for rk808
++++ LDO3 write 0x03 to regular
cpu_det GPIO pull up
pmic:rk818
can’t find dts node for ADC
#Boot ver: 2015-06-12#2.25
empty serial no.
checkKey
vbus = 1
use dc chg rk818_charger_setting iset1:0x79 chgiset:0x75 current 1
read logo_on switch from dts [1]
failed to find part:logo
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x62000000 (0x006e7888)
ramdisk @ 0x65bf0000 (0x00299aa8)
bootrk: do_bootm_linux…
Loading Device Tree to 65600000, end 65616309 … OK
Add bank:0000000060000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (root@vmu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Aug 31 19:50:29 CST 2015 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128 [ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@9dc00000, offset:0 [ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@9dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(0) size(800000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 8 MiB at 9d400000 [ 0.000000] ion_reserve: cma reserved base 9d400000 size 8388608 [ 0.000000] cma: CMA: reserved 16 MiB at 7f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c16d3000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261120 [ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0,115200 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00010000@0x0000E000(boot),0x00020000@0x0001E000(backup),-@0x0003E000(linuxroot) storagemedia=nand uboot_logo=0x02000000@0x9dc00000 loader.timestamp=2015-06-12_09:11:25 [ 0.000000] rockchip jtag enabled [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 962480k/962480k available, 86096k reserved, 483328K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0bc5760 (12022 kB) [ 0.000000] .init : 0xc0bc6000 - 0xc0c2d6c0 ( 414 kB) [ 0.000000] .data : 0xc0c2e000 - 0xc0ce5338 ( 733 kB) [ 0.000000] .bss : 0xc0d88424 - 0xc0eaa4fc (1161 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 25 [ 0.000000] rkclk_init_clks: cnt_rate = 17 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:30 [ 0.000000] target-temp:85 [ 0.000000] channel:0, lkg:30 [ 0.000000] target-temp:85 [ 0.000000] channel:0, lkg:30 [ 0.000000] target-temp:85 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.000000] Console: colour dummy device 80x30 [ 0.586640] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.586668] pid_max: default: 32768 minimum: 301 [ 0.586873] Security Framework initialized [ 0.586907] SELinux: Initializing. [ 0.587047] Mount-cache hash table entries: 512 [ 0.588313] Initializing cgroup subsys debug [ 0.588342] Initializing cgroup subsys memory [ 0.588395] Initializing cgroup subsys freezer [ 0.588457] CPU: Testing write buffer coherency: ok [ 0.589030] /cpus/cpu@0 missing clock-frequency property [ 0.589061] /cpus/cpu@1 missing clock-frequency property [ 0.589080] /cpus/cpu@2 missing clock-frequency property [ 0.589099] /cpus/cpu@3 missing clock-frequency property [ 0.589176] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [ 0.589257] Setting up static identity map for 0xc08b4f28 - 0xc08b4f80 [ 0.591354] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1626 (version 3.0) [ 0.664458] CPU1: Booted secondary processor [ 0.664519] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [ 0.684168] CPU2: Booted secondary processor [ 0.684218] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [ 0.703926] CPU3: Booted secondary processor [ 0.703974] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [ 0.704171] Brought up 4 CPUs [ 0.704226] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.704242] CPU: All CPU(s) started in SVC mode. [ 0.705749] devtmpfs: initialized [ 0.715465] pinctrl core: initialized pinctrl subsystem [ 0.715996] regulator-dummy: no parameters [ 0.717584] NET: Registered protocol family 16 [ 0.720863] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.721581] ion_snapshot: 0x7e998000 map to 0xe0907000 and copy to 0xc0e85a84 (version 0.1) [ 0.721818] Registered FIQ tty driver [ 0.724256] console [ttyFIQ0] enabled [ 0.724692] Registered fiq debugger ttyFIQ0 [ 0.726151] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000 start=0x2007c000,end=0x2007c0ff [ 0.726294] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000 start=0x20080000,end=0x200800ff [ 0.726381] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000 start=0x20084000,end=0x200840ff [ 0.726461] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000 start=0x20088000,end=0x200880ff [ 0.726553] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000 start=0x20086000,end=0x200860ff [ 0.726629] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5 [ 0.726661] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7 [ 0.726691] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3 [ 0.726720] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137 [ 0.726749] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103 [ 0.729550] rockchip_pinctrl_probe:init ok [ 0.737337] rk_iommu 1010e300.vop_mmu: (vop) Enter [ 0.737398] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq [ 0.737515] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.737544] rk_iommu 1010e300.vop_mmu: (vop) Initialized [ 0.737835] rk_iommu 10104440.hevc_mmu: (hevc) Enter [ 0.737985] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.738017] rk_iommu 10104440.hevc_mmu: (hevc) Initialized [ 0.738286] rk_iommu 10106800.vpu_mmu: (vpu) Enter [ 0.738418] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.738449] rk_iommu 10106800.vpu_mmu: (vpu) Initialized [ 0.738716] rk_iommu 10108800.iep_mmu: (iep) Enter [ 0.738846] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.738877] rk_iommu 10108800.iep_mmu: (iep) Initialized [ 0.740604] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.740635] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.740713] rk312x_pie_init: failed to load section -12 [ 0.740929] DDR DEBUG: version 1.02 20140828 [ 0.740962] Unable to handle kernel NULL pointer dereference at virtual address 00000008 [ 1.433458] pgd = c0004000 [ 1.436129] [00000008] *pgd=00000000 [ 1.439672] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 1.444900] Modules linked in: [ 1.447929] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #1 [ 1.453758] task: de880000 ti: de866000 task.ti: de866000 [ 1.459082] PC is at __kern_to_pie+0x4/0x28 [ 1.463209] LR is at ddr_init.constprop.26+0x50/0x2a8 [ 1.468188] pc : [] lr : [] psr: 60000113 [ 1.468188] sp : de867f08 ip : 00000000 fp : c0c287e0 [ 1.479482] r10: 00000002 r9 : fed10fff r8 : 000001fc [ 1.484628] r7 : c0d8c12c r6 : c0d8a134 r5 : c0d8a040 r4 : c0008280 [ 1.491052] r3 : 0060d478 r2 : c0d348c8 r1 : c0cd5f8c r0 : 00000000 [ 1.497478] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 1.504671] Control: 10c5387d Table: 6000406a DAC: 00000015 [ 1.510325] [ 1.510325] PC: 0xc02a8834: [ 1.514535] 8834 e59f0070 e0040000 e3500000 0a000008 e2401001 e2633001 e1c10000 e0832002 [ 1.522690] 8854 e1a003a0 e16f0f10 e2600020 e08201c0 e8bd80f0 e3550003 e2822004 9a000006 [ 1.530843] 8874 e2455004 e0827006 e1a0c000 e4974000 e35c0000 0affffe6 e8bd80f0 e0633002 [ 1.538995] 8894 e1530001 22810001 e8bd80f0 e1a0000c e8bd80f0 fefefeff 80808080 e59f301c [ 1.547148] 88b4 e5902008 e79f3003 e0633001 e1530002 35900004 23a00000 30830000 e12fff1e [ 1.555301] 88d4 0060d478 e92d4010 e1a04000 e8900007 ebffdc1f e1a00004 e8bd4010 eaf98e59 [ 1.563453] 88f4 e5900000 eaffdbb7 e3a00000 e12fff1e e3a00000 e12fff1e e92d4ff0 e1a09003 [ 1.571607] 8914 e59f4178 e24dd024 e59f3174 e1a06002 e08f4004 e58d0014 e58d101c e3a00000 [ 1.579761] [ 1.579761] LR: 0xc0894eb0: [ 1.583971] 4eb0 e0834004 e0841001 e0812002 e1a0221c e082001c e8bd8030 e0800001 e0802002 [ 1.592125] 4ed0 e3a00001 e1a00210 e8bd8030 fed10fff e92d47f3 e59f0240 e59f4240 e08f0000 [ 1.600278] 4ef0 e59f923c eb000ab9 e59f3238 e08f4004 e59f6234 e519ae33 e7945003 e08f6006 [ 1.608431] 4f10 e59f3228 e7e0a5da e59f7224 e28aa001 e5950000 e7941003 e08f7007 ebe84e5f [ 1.616584] 4f30 e59f3210 e58600a0 e5950000 e7941003 ebe84e5a e59f3200 e587069c e5950000 [ 1.624737] 4f50 e7948003 e3c81001 e2088001 ebe84e53 e59f31e8 e1808008 e5950000 e58680a4 [ 1.632889] 4f70 e3a08000 e7941003 ebe84e4c e59f31d0 e7943003 e5830000 e59630a0 e5192e33 [ 1.641043] 4f90 e7e226d2 e58320a0 e3a02015 e58320a4 e597369c e5838000 e59f31a8 e5950000 [ 1.649197] [ 1.649197] SP: 0xde867e88: [ 1.653407] 7e88 00000020 c003ba94 00000000 00000000 00000000 00000000 c0da9cc4 00000020 [ 1.661558] 7ea8 00000000 c02a88b4 60000113 ffffffff de867ef4 c000d758 00000000 c0cd5f8c [ 1.669711] 7ec8 c0d348c8 0060d478 c0008280 c0d8a040 c0d8a134 c0d8c12c 000001fc fed10fff [ 1.677863] 7ee8 00000002 c0c287e0 00000000 de867f08 c0894f30 c02a88b4 60000113 ffffffff [ 1.686015] 7f08 c0bcf354 c0d8a018 c0d8905c c0bcf354 de866000 00000000 000001fc c0d89000 [ 1.694166] 7f28 c0b6fef8 c0bcf3dc 00000000 c0008704 c0bcf354 c0c00da8 c0c287ec c0d8905c [ 1.702319] 7f48 00000003 c0c203c0 c0c203a0 c0bc6c68 00000003 00000003 c0bc664c 00200200 [ 1.710470] 7f68 c0cf7d78 c0bc664c 00000000 c0c286dc c0c286dc 00000000 00000000 00000000 [ 1.718623] [ 1.718623] FP: 0xc0c28760: [ 1.722833] 8760 c0c02224 c0c03838 c0bcade8 c0bdbca0 c0bf0d5c c0bf1590 c0bf15ec c0bf1a60 [ 1.730987] 8780 c0bf211c c0bf2a88 c0bf326c c0bf49c4 c0bf4b4c c0bf51cc c0bf6214 c0bf8ba0 [ 1.739140] 87a0 c0bfe14c c0bfe20c c0bd0b70 c0bc8818 c0bc8f78 c0bca88c c0bcb0b4 c0bceaf4 [ 1.747293] 87c0 c0bcf1c4 c0bcf6d8 c0bcfca4 c0bd03c4 c0bf212c c0bf214c c0c00da8 c0bcf354 [ 1.755446] 87e0 c0bcf80c c0bcfdd8 c0bd04f4 c0bc8c8c c0bd37f8 c0bd5a58 c0bdbd00 c0bdf440 [ 1.763599] 8800 c0be11c4 c0be1414 c0bed200 c0bed2f8 c0bee558 c0bee5b4 c0bee5f4 c0bee68c [ 1.771752] 8820 c0bee780 c0bf15b4 c0bf181c c0bf1994 c0bf1eb8 c0bf1f74 c0bf2660 c03050b0 [ 1.779905] 8840 c0bf2a58 c0bf3cd0 c0bf4a0c c034b6a8 c0bf5200 c0bf5314 c0bf63e0 c0bf75b4 [ 1.788061] [ 1.788061] R1: 0xc0cd5f0c: [ 1.792270] 5f0c e59f30c0 e08f3003 e593105c e5932060 e2411001 e381143f e2422001 e381180f [ 1.800424] 5f2c e1812402 e5842010 e5933064 e2432001 e1a030a3 e382257f e2433001 e382283f [ 1.808577] 5f4c e38336ff e5842014 e383380f e5843018 ebfffef8 e3a03602 e584301c f57ff04f [ 1.816730] 5f6c e3a00000 e8bd8038 e5153d7b e3130020 1a000002 ebfffeef e2544001 1afffff9 [ 1.824882] 5f8c e59f3038 e3a02807 e58320c8 e59f2038 e5832050 f57ff04f e3a00000 e8bd8038 [ 1.833035] 5fac 000006a4 00000690 0000067c 00000668 0000065c 00000648 fed10fff ffffe840 [ 1.841186] 5fcc fed00000 00200020 000005d0 00300010 eaffff8e e92d40f0 e1a04000 e24dd05c [ 1.849337] 5fec e59f51d8 ebfffc20 e59f71d4 ebfffebc e1a00004 e3a01001 ebfffff4 e79f5005 [ 1.857492] [ 1.857492] R2: 0xc0d34848: [ 1.861702] 4848 00000000 00000000 00000000 00000001 00000000 00000000 ffffffe0 c0d34864 [ 1.869852] 4868 c0d34864 c002d5d4 00000000 74737461 00000000 c0e2a402 c0053110 c0d34860 [ 1.878004] 4888 ffffffff 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1.886152] 48a8 00000000 00000000 00000000 00000000 00000000 00000000 c0cf7470 00000000 [ 1.894302] 48c8 c0d348c8 c0d348c8 c0c2a6fc c0cf81d8 c0cfa994 c004061c c0041114 00000000 [ 1.902454] 48e8 00000000 00000000 00000000 00000000 00000000 00000000 c0a75eaf c0a7848a [ 1.910604] 4908 c0c364d0 00000004 000001a4 00000000 c0043ed0 00000000 00000000 00000000 [ 1.918754] 4928 c0a76040 c0c3f684 00000004 000001a4 00000000 c00727fc 00000000 c0c3f1f4 [ 1.926907] [ 1.926907] R4: 0xc0008200: [ 1.931117] 8200 e1330c06 1a22252d e5876004 ea0000f0 c0008210 c0c1fa9c c0c1ff7c c0c3e384 [ 1.939270] 8220 e3120003 1a00000b e5925000 e59f602c e1550006 0a000006 e3550005 13550002 [ 1.947423] 8240 1a000004 e5925004 e59f6014 e1550006 1a000000 e1a0f00e e3a02000 e1a0f00e [ 1.955576] 8260 edfe0dd0 54410001 e320f000 e320f000 e320f000 e320f000 e320f000 e320f000 [ 1.963728] 8280 ea0018a7 e92d40f0 e1a05000 e5903040 e24dd08c e590603c e203201f e3520013 [ 1.971882] 82a0 05964000 0a000018 e3130020 e1a0200d e3c23d7f e1a00006 e3c3303f e5931008 [ 1.980035] 82c0 e2411001 0a00000c eb0a131d e3500000 1a000030 e6ff4072 e3540b3a 3a00000a [ 1.988188] 82e0 e2860002 eb0a1316 e3500000 06ff2072 01824804 0a000004 ea000026 eb0a1318 [ 1.996342] [ 1.996342] R5: 0xc0d89fc0: [ 2.000551] 9fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.008700] 9fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.016848] a000 00000000 00000000 00000000 02000000 9dc00000 00000001 c001f888 c001f868 [ 2.024999] a020 c0021420 c001f8b8 c002032c c001efe4 c001ff48 00000000 00001c00 00000000 [ 2.033150] a040 00000000 de9d4d00 31260001 00000000 00000000 00000000 00000000 00000000 [ 2.041299] a060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.049447] a080 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.057596] a0a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.065745] [ 2.065745] R6: 0xc0d8a0b4: [ 2.069955] a0b4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.078103] a0d4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.086252] a0f4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.094400] a114 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.102549] a134 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.110697] a154 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.118846] a174 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.126994] a194 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.135145] [ 2.135145] R7: 0xc0d8c0ac: [ 2.139355] c0ac 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.147504] c0cc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.155652] c0ec 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.163801] c10c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.171950] c12c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.180098] c14c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.188247] c16c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.196395] c18c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.204545] [ 2.204545] R9: 0xfed10f7f: [ 2.208755] 0f7c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.216905] 0f9c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.225055] 0fbc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.233204] 0fdc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.241353] 0ffc 00000000 ******** ******** ******** ******** ******** ******** ******** [ 2.249505] 101c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.257654] 103c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.265804] 105c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.273953] 107c ******** ******** ******** ******** ******** ******** ******** ******** [ 2.282107] Process swapper/0 (pid: 1, stack limit = 0xde866238) [ 2.288020] Stack: (0xde867f08 to 0xde868000) [ 2.292319] 7f00: c0bcf354 c0d8a018 c0d8905c c0bcf354 de866000 00000000 [ 2.300374] 7f20: 000001fc c0d89000 c0b6fef8 c0bcf3dc 00000000 c0008704 c0bcf354 c0c00da8 [ 2.308427] 7f40: c0c287ec c0d8905c 00000003 c0c203c0 c0c203a0 c0bc6c68 00000003 00000003 [ 2.316481] 7f60: c0bc664c 00200200 c0cf7d78 c0bc664c 00000000 c0c286dc c0c286dc 00000000 [ 2.324533] 7f80: 00000000 00000000 00000000 00000000 00000000 c0bc6d58 de866000 00000000 [ 2.332585] 7fa0: c0890ab4 c0890abc 00000000 c000dc58 00000000 00000000 00000000 00000000 [ 2.340635] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.348686] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000 eb7a583a 9c6b7baa [ 2.356756] [] (__kern_to_pie+0x4/0x28) from [] (ddr_init.constprop.26+0x50/0x2a8) [ 2.365928] [] (ddr_init.constprop.26+0x50/0x2a8) from [] (rk312x_ddr_init+0x88/0xbc) [ 2.375354] [] (rk312x_ddr_init+0x88/0xbc) from [] (do_one_initcall+0x38/0xf8) [ 2.384183] [] (do_one_initcall+0x38/0xf8) from [] (do_initcalls+0xa0/0xd8) [ 2.392753] [] (do_initcalls+0xa0/0xd8) from [] (kernel_init_freeable+0xb4/0x170) [ 2.401838] [] (kernel_init_freeable+0xb4/0x170) from [] (kernel_init+0x8/0x110) [ 2.410838] [] (kernel_init+0x8/0x110) from [] (ret_from_fork+0x14/0x3c) [ 2.419147] Code: e8bd80f0 fefefeff 80808080 e59f301c (e5902008) [ 2.425222] ---[ end trace 1b75b31a2719ed1c ]--- [ 2.429831] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b [ 2.429831] [ 2.438830] CPU3: stopping [ 2.441509] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 3.10.0 #1 [ 2.448297] [] (unwind_backtrace+0x0/0xe8) from [] (show_stack+0x10/0x14) [ 2.456698] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x170/0x2f8) [ 2.464840] [] (handle_IPI+0x170/0x2f8) from [] (gic_handle_irq+0x5c/0x68) [ 2.473324] [] (gic_handle_irq+0x5c/0x68) from [] (__irq_svc+0x40/0x70) [ 2.481540] Exception stack(0xde8b5f70 to 0xde8b5fb8) [ 2.486518] 5f60: ffffffed ffff8ae0 00000000 00000000 [ 2.494572] 5f80: de8b4000 00000015 10c0387d c0ce1ed9 6000406a 410fc075 00000000 00bb7c4c [ 2.502623] 5fa0: 00000003 de8b5fb8 c000e9c4 c000e9c8 60000113 ffffffff [ 2.509147] [] (__irq_svc+0x40/0x70) from [] (arch_cpu_idle+0x34/0x3c) [ 2.517291] [] (arch_cpu_idle+0x34/0x3c) from [] (cpu_idle_loop+0x1c4/0x230) [ 2.525947] [] (cpu_idle_loop+0x1c4/0x230) from [] (freezing_slow_path+0x0/0x74) [ 2.534933] [] (freezing_slow_path+0x0/0x74) from [<600081bc>] (0x600081bc) [ 2.542638] CPU1: stopping [ 2.545317] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 3.10.0 #1 [ 2.552101] [] (unwind_backtrace+0x0/0xe8) from [] (show_stack+0x10/0x14) [ 2.560500] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x170/0x2f8) [ 2.568642] [] (handle_IPI+0x170/0x2f8) from [] (gic_handle_irq+0x5c/0x68) [ 2.577125] [] (gic_handle_irq+0x5c/0x68) from [] (__irq_svc+0x40/0x70) [ 2.585341] Exception stack(0xde8b1f70 to 0xde8b1fb8) [ 2.590319] 1f60: ffffffed ffff8ae0 00000000 00000000 [ 2.598372] 1f80: de8b0000 00000015 10c0387d c0ce1ed9 6000406a 410fc075 00000000 00bb7c4c [ 2.606424] 1fa0: 00000001 de8b1fb8 c000e9c4 c000e9c8 60000113 ffffffff [ 2.612947] [] (__irq_svc+0x40/0x70) from [] (arch_cpu_idle+0x34/0x3c) [ 2.621091] [] (arch_cpu_idle+0x34/0x3c) from [] (cpu_idle_loop+0x1c4/0x230) [ 2.629746] [] (cpu_idle_loop+0x1c4/0x230) from [] (freezing_slow_path+0x0/0x74) [ 2.638738] [] (freezing_slow_path+0x0/0x74) from [<600081bc>] (0x600081bc) [ 2.646443] CPU2: stopping [ 2.649121] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 3.10.0 #1 [ 2.655905] [] (unwind_backtrace+0x0/0xe8) from [] (show_stack+0x10/0x14) [ 2.664304] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x170/0x2f8) [ 2.672446] [] (handle_IPI+0x170/0x2f8) from [] (gic_handle_irq+0x5c/0x68) [ 2.680930] [] (gic_handle_irq+0x5c/0x68) from [] (__irq_svc+0x40/0x70) [ 2.689146] Exception stack(0xde8b3f70 to 0xde8b3fb8) [ 2.694124] 3f60: ffffffed ffff8ae0 00000000 00000000 [ 2.702178] 3f80: de8b2000 00000015 10c0387d c0ce1ed9 6000406a 410fc075 00000000 00bb7c4c [ 2.710229] 3fa0: 00000002 de8b3fb8 c000e9c4 c000e9c8 60000113 ffffffff [ 2.716752] [] (__irq_svc+0x40/0x70) from [] (arch_cpu_idle+0x34/0x3c) [ 2.724896] [] (arch_cpu_idle+0x34/0x3c) from [] (cpu_idle_loop+0x1c4/0x230) [ 2.733551] [] (cpu_idle_loop+0x1c4/0x230) from [] (freezing_slow_path+0x0/0x74) [ 2.742544] [] (freezing_slow_path+0x0/0x74) from [<600081bc>] (0x600081bc) [ 2.750249] CRU: [ 2.752075] 00000000: 0000304b 00001441 00000000 00000000 [ 2.757395] 00000010: 0000304b 00001441 00000001 00000000 [ 2.762715] 00000020: 000020c8 00001446 00000000 00000000 [ 2.768035] 00000030: 00002063 00001442 00000000 00000000 [ 2.773355] 00000040: 00001111 00004000 00003113 00008307 [ 2.778676] 00000050: 0000401f 00000083 00008003 0000421f [ 2.783997] 00000060: 0bb8ea60 0bb8ea60 0000401f 0000a100 [ 2.789317] 00000070: 000080bd 0000bd97 0000521f 0000021f [ 2.794638] 00000080: 0000021f 00000200 0bb8ea60 0bb8ea60 [ 2.799958] 00000090: 0bb8ea60 0bb8ea60 00000000 00000000 [ 2.805278] 000000a0: 00000102 00001700 0000011f 00000000 [ 2.810598] 000000b0: 00000701 00000300 00000526 00008100 [ 2.815917] 000000c0: 00004040 00004040 00000000 00002221 [ 2.821236] 000000d0: 00000000 00000000 00000000 00000000 [ 2.826555] 000000e0: 00000000 00000000 00000000 00000000 [ 2.831874] 000000f0: 00000000 00000000 00000000 00000000 [ 2.837192] 00000100: 00000000 00000000 00000000 00000000 [ 2.842511] 00000110: 00000000 00000000 00000000 00000000 [ 2.847830] 00000120: 00000000 00000000 00000000 00000000 [ 2.853149] 00000130: 00000000 00000000 00000000 00000000 [ 2.858468] 00000140: 3a981064 00000000 00000000 00000000 [ 2.863787] 00000150: 00000002 00000000 00000000 00000000 [ 2.869106] 00000160: 00000000 00000000 00000000 00000000 [ 2.874425] 00000170: 00000000 00000000 00000000 00000000 [ 2.879743] 00000180: 00000000 00000000 00000000 00000000 [ 2.885062] 00000190: 00000000 00000000 00000000 00000000 [ 2.890381] 000001a0: 00000000 00000000 00000000 00000000 [ 2.895700] 000001b0: 00000000 00000000 00000000 00000000 [ 2.901019] 000001c0: 00000004 00000000 00000004 00000000 [ 2.906337] 000001d0: 00000000 00000000 00000004 00000000 [ 2.911656] 000001e0: 00000000 00000000 00000000 00000000 [ 2.916975] 000001f0: 00005a5a 00000000 00000000 00000000 [ 2.922296] 00000200: 0000304b 00001441 00000000 00000000 [ 2.927615] 00000210: 0000304b 00001441 00000001 00000000 [ 2.932931] Rebooting in 5 seconds..
