rkmedia_rtspget_multi_test 测试通不过,报错,请问这是什么错误啊
root@firefly:/userdata/remedia/fireflydemo# ./rkmedia_rtspget_multi_test rtsp://192.168.13.90:8554/1 rtsp://192.168.13.90:8554/1 rtsp://192.168.13.90:8554/1 rtsp://192.168.13.90:8554/1
media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rockchip-mipi-dphy-rx is null
Rga built version:1.04 +2021-04-21 08:15:44
#Display wxh: 720x1280
#Decode Mode: Hardware
#Loop Cnt: 0
##RKMEDIA Log level: 2
[RKMEDIA][SYS][Info]:text is all=2
[RKMEDIA][SYS][Info]:module is all, log_level is 2
[RKMEDIA][SYS][Info]:RK_MPI_VO_CreateChn: Enable VO[0] Start…
[RKMEDIA][SYS][Info]:suitable ids:
[RKMEDIA][SYS][Info]: connector:[RKMEDIA][SYS][Info]: 56[RKMEDIA][SYS][Info]:
[RKMEDIA][SYS][Info]: encoder:[RKMEDIA][SYS][Info]: 55[RKMEDIA][SYS][Info]:
[RKMEDIA][SYS][Info]: crtc:[RKMEDIA][SYS][Info]: 53[RKMEDIA][SYS][Info]:
[RKMEDIA][SYS][Info]: plane:[RKMEDIA][SYS][Info]: 54[RKMEDIA][SYS][Info]:
[RKMEDIA][SYS][Info]:conn id : 56, enc id: 55, crtc id: 53, plane id: 54, w/h: 1920,1080, fps: 60
[RKMEDIA][SYS][Info]:RK_MPI_VO_CreateChn: Enable VO[0] End!
[RKMEDIA][SYS][Info]:Opened DRM device /dev/dri/card0: driver rockchip version 2.0.0.
[RKMEDIA][SYS][Error]:Not support CodecType:5!
Create Vdec[0] failed! ret=-126
[RKMEDIA][SYS][Info]:OutputStreamFlow:drm_output_stream quit
rtsp流的格式是什么
