开发板ROC-RK3568-PC的rtc(hym8563ts)设备用不了?
固件文件名称:ROC-RK3568-PC-BUILDROOT-GPT-20220222-1538
Log日志:rk3568-rtc.txt
1、启动报错:
[ 1.375490] rk808-rtc rk808-rtc: device is disabled
[ 1.375533] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.376991] fusb302 0-0022: Can’t get property of role, set role to default DRP
[ 1.386500] fusb302 0-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.386769] input: Typec_Headphone as /devices/platform/fdd40000.i2c/i2c-0/0-0022/input/input2
[ 1.388626] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 1.388736] pca953x 1-0021: Linked as a consumer to regulator.0
[ 1.388944] pca953x 1-0021: failed reading register
[ 1.389029] pca953x 1-0021: Dropping the link to regulator.0
[ 1.391312] rtc-hym8563 5-0051: could not init device, -6
2、dev下没有rtc设备
rk3568-rtc.txt (62.7 KB)
用 i2cdetect 查看 i2c5 0x51 位置有没有设备
可能是 rtc 坏了
