固件文件名称:ITX-3588J_Ubuntu20.04-Gnome-r211_v0.1.0a_220424.im
固件下载地址:官网链接
Log日志:rk3588 解码功能异常问题.zip
git clonehttps://github.com/rockchip-linux/mpp.git
cd build/linux/aarch64
cmake ../../../
make
准备好Tennis1080p.h264文件,
执行 :
sudo ./mpi_dec_test-i Tennis1080p.h264 -o 1080P_n.yuv -w1920 -h 1080 -t 7 -d 0 -x 0
【输出问题】:没打印信息,没有输出文件:然后dmesg输出如下:
rk_vcodec:mpp_task_attach_fd:1679: can’t import dma-buf 1
[ 1904.064617]rk_vcodec: mpp_translate_reg_address:1735: reg[128]: 0x00000001 fd 1 failed
[ 1904.064624]rk_vcodec: mpp_task_dump_mem_region:1909: — dump mem region —
[ 1904.064634]mpp_rkvdec2 fdc38100.rkvdec-core: no memory region mapped
[ 1904.064642]rk_vcodec: mpp_process_task_default:566: alloc_task failed.
[ 1904.064684]rk_vcodec: mpp_wait_result_default:826: session 000000004d9d2db2 pending listis empty!
[ 1904.064699]rk_vcodec: mpp_msgs_wait:1531: session 7 wait result ret -5
[ 1904.564840]mpp_dma_import_fd:197: dma_buf_get fd 1 failed
[ 1904.564873]rk_vcodec: mpp_task_attach_fd:1679: can’t import dma-buf 1
[ 1904.564882]rk_vcodec: mpp_translate_reg_address:1735: reg[128]: 0x00000001 fd 1 failed
[ 1904.564889]rk_vcodec: mpp_task_dump_mem_region:1909: — dump mem region —
[ 1904.564901]mpp_rkvdec2 fdc38100.rkvdec-core: no memory region mapped
[ 1904.564910]rk_vcodec: mpp_process_task_default:566: alloc_task failed.
[ 1904.564953]rk_vcodec: mpp_wait_result_default:826: session 000000004d9d2db2 pending list
第二个问题:使用系统默认解码脚本
cd /usr/local/bin
./h264dec.sh
mpp[6646]: mpp_info: mpp version: 8a85dc5d author: HermanChen 2022-03-14 [mpp_enc]: Fix stuck onreset async mode encoder
mpp[6646]: mpp_rt: NOT found ion allocator
mpp[6646]: mpp_rt: found drm allocator
Setting pipeline to PAUSED …
ERROR: Pipeline doesn’t want to pause.
ERROR: from element/GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Could not initialise Xvoutput
Additional debug info:
xvimagesink.c(1996): gst_xv_image_sink_open ():/GstPipeline:pipeline0/GstXvImageSink:xvimagesink0:
Could not open display (null)
Setting pipeline to NULL …
Freeing pipeline …
firefly@firefly:/usr/local/bin$
请问如果验证32路1080P解码能力,如果进行解码,系统是否有问题?
rk3588 解码功能异常问题.zip (11.8 KB)
