RK3308b系统启动后卡死
RK3308自研的板子,开机后死机,下面是开机的打印信息,用同一个固件刷到firefly的板子却没有问题,各位大神帮忙看看呗
下面这部分是自研板的打印信息:
[ 0.135725] fiq debugger fiq mode enabled
[[ 0.136567] console [ttyFIQ0] enabled
[ 0.137268] bootconsole [uart0] disabled
[ 0.137907] Registered fiq debugger ttyFIQ0
[ 0.190882] raid6: int64x1 gen() 222 MB/s
[ 0.208072] raid6: int64x1 xor() 189 MB/s
[ 0.225290] raid6: int64x2 gen() 328 MB/s
[ 0.242327] raid6: int64x2 xor() 240 MB/s
[ 0.259472] raid6: int64x4 gen() 445 MB/s
[ 0.276684] raid6: int64x4 xor() 289 MB/s
[ 0.293883] raid6: int64x8 gen() 355 MB/s
[ 0.310918] raid6: int64x8 xor() 250 MB/s
[ 0.328122] raid6: neonx1 gen() 394 MB/s
[ 0.345251] raid6: neonx1 xor() 330 MB/s
[ 0.362382] raid6: neonx2 gen() 546 MB/s
[ 0.379584] raid6: neonx2 xor() 406 MB/s
[ 0.396685] raid6: neonx4 gen() 679 MB/s
[ 0.413849] raid6: neonx4 xor() 464 MB/s
[ 0.431044] raid6: neonx8 gen() 699 MB/s
[ 0.448172] raid6: neonx8 xor() 478 MB/s
[ 0.448194] raidWARNING: suspend_mode_handler: Not support call: 0x4
6: using algorithm neonx8 gen() 699 MB/s
[ 0.448205] raid6: … xor() 478 MB/s, rmw enabled
[ 0.448216] raid6: using intx1 recovery algorithm
[ 0.450944] vcc_1v8: regulator get failed, ret=-517
[ 0.451934] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.452883] vcc_1v8: supplied by vcc_io
[ 0.453002] vcc_1v8_codec: supplied by vcc_io
[ 0.455645] SCSI subsystem initialized
[ 0.455976] usbcore: registered new interface driver usbfs
[ 0.456057] usbcore: registered new interface driver hub
[ 0.456201] usbcore: registered new device driver usb
[ 0.456314] media: Linux media interface: v0.10
[ 0.456376] Linux video capture interface: v2.00
[ 0.456524] pps_core: LinuxPPS API ver. 1 registered
[ 0.456537] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.456572] PTP clock support registered
[ 0.457888] Advanced Linux Sound Architecture Driver Initialized.
[ 0.458633] Bluetooth: Core ver 2.21
[ 0.458708] NET: Registered protocol family 31
[ 0.458720] Bluetooth: HCI device and connection manager initialized
[ 0.458742] Bluetooth: HCI socket layer initialized
[ 0.458758] Bluetooth: L2CAP socket layer initialized
[ 0.458798] Bluetooth: SCO socket layer initialized
[ 0.460071] rockchip-cpuinfo cpuinfo: Serial : 1b4efac6bb81c5de
[ 0.460881] clocksource: Switched to clocksource arch_sys_counter
[ 0.473498] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.473848] NET: Registered protocol family 2
[ 0.474566] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.474616] TCP bind hash table entries: 1024 (order: 2, 16384 bytes)
[ 0.474650] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.474739] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.474778] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.475052] NET: Registered protocol family 1
[ 0.475374] Unpacking initramfs…
[ 1.162303] Freeing initrd memory: 8512K
[ 1.163160] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.177124] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.177478] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.177765] SGI XFS with security attributes, no debug enabled
[ 1.182754] io scheduler noop registered (default)
[ 1.184084] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 1.189030] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.189085] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.191491] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.191536] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.191957] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 1.192138] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 1.193673] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.196382] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 12, base_baud = 5078125) is a 16550A
[ 1.198523] [drm] Initialized drm 1.1.0 20060810
[ 1.198677] random: nonblocking pool is initialized
[ 1.201223] Unable to detect cache hierarchy for CPU 0
[ 1.208746] loop: module loaded
[ 1.209045] SCSI Media Changer driver v0.25
[ 1.209723] register spi return v = :0
[ 1.209785] lora1276 register spi return v = :0
[ 1.209840] CAN device driver interface
[ 1.211247] rk_gmac-dwmac ff4e0000.ethernet: clock input or output? (output).
[ 1.211293] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: tx_delay.
[ 1.211311] rk_gmac-dwmac ff4e0000.ethernet: set tx_delay to 0x30
[ 1.211333] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: rx_delay.
[ 1.211348] rk_gmac-dwmac ff4e0000.ethernet: set rx_delay to 0x10
[ 1.211373] rk_gmac-dwmac ff4e0000.ethernet: integrated PHY? (no).
[ 1.216687] rk_gmac-dwmac ff4e0000.ethernet: init for RMII
[ 1.216838] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.216856] Ring mode enabled
[ 1.216883] DMA HW capability register supported
[ 1.216893] Normal descriptors
[ 1.216905] RX Checksum Offload Engine supported (type 2)
[ 1.216915] TX Checksum insertion supported
[ 1.216924] Wake-Up On Lan supported
[ 1.216989] Enable RX Mitigation via HW Watchdog Timer
[ 1.281538] libphy: stmmac: probed
[ 1.281561] eth%d: No PHY found
[ 1.282436] Rockchip WiFi SYS interface (V1.00) …
[ 1.282604] usbcore: registered new interface driver r8152
[ 1.282688] usbcore: registered new interface driver asix
[ 1.282768] usbcore: registered new interface driver ax88179_178a
[ 1.282829] usbcore: registered new interface driver cdc_ether
[ 1.282919] usbcore: registered new interface driver net1080
[ 1.282998] usbcore: registered new interface driver cdc_subset
[ 1.283060] usbcore: registered new interface driver zaurus
[ 1.283181] usbcore: registered new interface driver cdc_ncm
[ 1.283253] usbcore: registered new interface driver qmi_wwan
[ 1.283665] ff400000.usb supply vusb_d not found, using dummy regulator
[ 1.283768] ff400000.usb supply vusb_a not found, using dummy regulator
[ 1.396950] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 1.398540] dwc2 ff400000.usb: DWC OTG Controller
[ 1.398593] dwc2 ff400000.usb: new USB bus registered, assigned bus number 1
[ 1.398648] dwc2 ff400000.usb: irq 19, io mem 0xff400000
[ 1.399619] hub 1-0:1.0: USB hub found
[ 1.399675] hub 1-0:1.0: 1 port detected
[ 1.623374] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 1.623635] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.623658] ehci-platform: EHCI generic platform driver
[ 1.627526] ehci-platform ff440000.usb: EHCI Host Controller
[ 1.627583] ehci-platform ff440000.usb: new USB bus registered, assigned bus number 2
[ 1.627747] ehci-platform ff440000.usb: irq 20, io mem 0xff440000
[ 1.632905] ehci-platform ff440000.usb: USB 2.0 started, EHCI 1.00
[ 1.633844] hub 2-0:1.0: USB hub found
[ 1.633939] hub 2-0:1.0: 1 port detected
[ 1.634560] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.634642] ohci-platform: OHCI generic platform driver
[ 1.635110] ohci-platform ff450000.usb: Generic Platform OHCI controller
[ 1.635160] ohci-platform ff450000.usb: new USB bus registered, assigned bus number 3
[ 1.635323] ohci-platform ff450000.usb: irq 21, io mem 0xff450000
[ 1.690828] hub 3-0:1.0: USB hub found
[ 1.690932] hub 3-0:1.0: 1 port detected
[ 1.691590] usbcore: registered new interface driver cdc_wdm
[ 1.691679] usbcore: registered new interface driver uas
[ 1.691818] usbcore: registered new interface driver usb-storage
[ 1.691913] usbcore: registered new interface driver ums-alauda
[ 1.691975] usbcore: registered new interface driver ums-cypress
[ 1.692037] usbcore: registered new interface driver ums-datafab
[ 1.692102] usbcore: registered new interface driver ums_eneub6250
[ 1.692171] usbcore: registered new interface driver ums-freecom
[ 1.692233] usbcore: registered new interface driver ums-isd200
[ 1.692299] usbcore: registered new interface driver ums-jumpshot
[ 1.692360] usbcore: registered new interface driver ums-karma
[ 1.692421] usbcore: registered new interface driver ums-onetouch
[ 1.692482] usbcore: registered new interface driver ums-sddr09
[ 1.692558] usbcore: registered new interface driver ums-sddr55
[ 1.692620] usbcore: registered new interface driver ums-usbat
[ 1.692756] usbcore: registered new interface driver usbserial
[ 1.692826] usbcore: registered new interface driver option
[ 1.692897] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.695204] i2c /dev entries driver
[ 1.696522] rk3x-i2c ff050000.i2c: Initialized RK3xxx I2C bus at ffffff8008d6e000
[ 1.697800] IR NEC protocol handler initialized
[ 1.697829] IR RC5(x/sz) protocol handler initialized
[ 1.697846] IR RC6 protocol handler initialized
[ 1.697881] IR JVC protocol handler initialized
[ 1.697898] IR Sony protocol handler initialized
[ 1.697914] IR SANYO protocol handler initialized
[ 1.697932] IR Sharp protocol handler initialized
[ 1.697950] IR MCE Keyboard/mouse protocol handler initialized
[ 1.697966] IR XMP protocol handler initialized
[ 1.698417] usbcore: registered new interface driver uvcvideo
[ 1.698432] USB Video Class driver (1.1.1)
[ 1.699015] rockchip-iodomain ff000000.grf:io-domains: vccio0 supplied by 3300000 uV
[ 1.699201] rockchip-iodomain ff000000.grf:io-domains: vccio1 supplied by 3300000 uV
[ 1.699317] rockchip-iodomain ff000000.grf:io-domains: vccio2 supplied by 3300000 uV
[ 1.699427] rockchip-iodomain ff000000.grf:io-domains: vccio3 supplied by 1800000 uV
[ 1.699571] rockchip-iodomain ff000000.grf:io-domains: vccio4 supplied by 3300000 uV
[ 1.699677] rockchip-iodomain ff000000.grf:io-domains: vccio5 supplied by 3300000 uV
[ 1.701562] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 1.702144] Bluetooth: HCI UART driver ver 2.3
[ 1.702173] Bluetooth: HCI UART protocol H4 registered
[ 1.702185] Bluetooth: HCI UART protocol LL registered
[ 1.702530] cpu cpu0: leakage=8
[ 1.702837] cpu cpu0: Failed to get pvtm
[ 1.704315] cpu cpu0: l=0 h=55000 hyst=5000 l_limit=1008000000 h_limit=1008000000
[ 1.705150] Synopsys Designware Multimedia Card Interface Driver
[ 1.707058] dwmmc_rockchip ff480000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 1.707219] dwmmc_rockchip ff480000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.707276] dwmmc_rockchip ff480000.dwmmc: Using internal DMA controller.
[ 1.707300] dwmmc_rockchip ff480000.dwmmc: Version ID is 270a
[ 1.707385] dwmmc_rockchip ff480000.dwmmc: DW MMC controller at irq 22,32 bit host data width,256 deep fifo
[ 1.718926] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.729963] set vqmmc to 3.3v, ret=0
[ 1.739926] dwmmc_rockchip ff480000.dwmmc: 1 slots initialized
[ 1.740163] dwmmc_rockchip ff490000.dwmmc: No default pinctrl state
[ 1.740186] dwmmc_rockchip ff490000.dwmmc: No off pinctrl state
[ 1.740313] dwmmc_rockchip ff490000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.740357] dwmmc_rockchip ff490000.dwmmc: Using internal DMA controller.
[ 1.740380] dwmmc_rockchip ff490000.dwmmc: Version ID is 270a
[ 1.740453] dwmmc_rockchip ff490000.dwmmc: DW MMC controller at irq 23,32 bit host data width,256 deep fifo
[ 1.740520] dwmmc_rockchip ff490000.dwmmc: No vmmc regulator found
[ 1.740536] dwmmc_rockchip ff490000.dwmmc: No vqmmc regulator found
[ 1.750947] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.761930] dwmmc_rockchip ff490000.dwmmc: 1 slots initialized
[ 1.762643] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 1.862950] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 1.963952] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 2.064959] is31fl32xx_init_regs, write to shutdown register failed
[ 2.065040] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 2.076568] mmc1: MAN_BKOPS_EN bit is not set
[ 2.079929] mmc_host mmc1: Bus speed (slot 0) = 147456000Hz (slot req 150000000Hz, actual 147456000HZ div = 0)
[ 2.166068] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 2.267039] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 2.334419] dwmmc_rockchip ff490000.dwmmc: Successfully tuned phase to 300
[ 2.334567] mmc1: new HS200 MMC card at address 0001
[ 2.335793] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[ 2.336311] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[ 2.336789] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[ 2.337313] mmcblk1rpmb: mmc1:0001 8GTF4R partition 3 512 KiB
[ 2.338742] mmcblk1: retrying because a re-tune was needed
[ 2.368585] usbcore: registered new interface driver usbkbd
[ 2.368748] usbcore: registered new interface driver usbmouse
[ 2.369060] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 2.369566] rockchip-dmc dmc: Failed to get leakage
[ 2.369776] rockchip-dmc dmc: Failed to get pvtm
[ 2.370427] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 2.370480] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 2.370512] rockchip-dmc dmc: don’t add devfreq feature
[ 2.374152] rknandc_base v1.1 2017-01-11
[ 2.374582] rksfc_base v1.1 2016-01-08
[ 2.381081] usbcore: registered new interface driver snd-usb-audio
[ 2.382282] dummy_codec dummy-codec: Unable to get mclk
[ 2.383619] rk3308-acodec ff560000.acodec: Don’t need pa-drv gpio
[ 2.383669] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 2.383966] The acodec version is: c
[ 2.385062] 1-001a supply AVDD not found, using dummy regulator
[ 2.385216] 1-001a supply DVDD not found, using dummy regulator
[ 2.385334] 1-001a supply PVDD_A not found, using dummy regulator
[ 2.385455] 1-001a supply PVDD_B not found, using dummy regulator
[ 2.385557] 1-001a supply PVDD_C not found, using dummy regulator
[ 2.385685] 1-001a supply PVDD_D not found, using dummy regulator
[ 2.386156] tas571x 1-001a: error requesting pdn_gpio: -16
[ 2.386750] tas571x: probe of 1-001a failed with error -16
[ 2.391027] nf_conntrack version 0.5.0 (880 buckets, 3520 max)
[ 2.392256] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.393376] NET: Registered protocol family 10
[ 2.394842] NET: Registered protocol family 17
[ 2.394991] NET: Registered protocol family 15
[ 2.395115] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.395149] can: controller area network core (rev 20120528 abi 9)
[ 2.395401] NET: Registered protocol family 29
[ 2.395438] can: raw protocol (rev 20120528)
[ 2.395464] can: broadcast manager protocol (rev 20120528 t)
[ 2.395496] can: netlink gateway (rev 20130117) max_hops=1
[ 2.395826] Bluetooth: RFCOMM TTY layer initialized
[ 2.395899] Bluetooth: RFCOMM socket layer initialized
[ 2.395952] Bluetooth: RFCOMM ver 1.11
[ 2.395990] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.396017] Bluetooth: HIDP socket layer initialized
[ 2.396053] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.396423] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.396452] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 2.396471] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8188eu
[ 2.396491] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.396506] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.396602] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.396618] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.396637] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.396727] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.397275] flash vendor_init_thread!
[ 2.397307] flash vendor storage:20170308 ret = -1
[ 2.401905] Btrfs loaded
[ 2.403111] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 2.403898]
[ 2.403937] =======================================================
[ 2.403950] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.403963] =======================================================
[ 2.403979] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 2.403995] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.404012] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 2.404027] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.404042] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.404057] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: wifi OOB pin isn’t defined.
[ 2.404251] usbcore: registered new interface driver rtl8188eu
[ 2.404611] hctosys: unable to open rtc device (rtc0)
[ 2.423811] vcc_sd: disabling
[ 2.423898] vccio_sd: disabling
[ 2.723555] dwmmc_rockchip ff490000.dwmmc: Successfully tuned phase to 310
[ 2.728536] mmcblk1: p1 p2 p3 p4 p5 p6
ú 2.739802]
[ 2.749307] vendor storage:20160801 ret = 0
下面这部分是firefly官方板子的打印信息,能正常起来,用的同一个固件:
[ 0.000000] Linux version 4.4.143 (linsq@linsq-virtual-machine) (kernel commit id: 73ef8ac37f22b376c0dde54c518a6397bdc532e4) (sdk version: rk3308_linux_release_20220304_v1.5.0a.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP PREEMPT Wed Jun 1 13:56:49 CST 2022
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff0c0000 (options ‘’)
[ 0.000000] On node 0 totalpages: 130560
[ 0.000000] DMA zone: 2040 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 130560 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 19 pages/cpu @ffffffc01ff41000 s40280 r8192 d29352 u77824
[ 0.000000] pcpu-alloc: s40280 r8192 d29352 u77824 alloc=19*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 128520
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 rw rootwait earlycon=uart8250,mmio32,0xff0c0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 snd_aloop.index=7
[ 0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] software IO TLB [mem 0x1fe3d000-0x1fe7d000] (0MB) mapped at [ffffffc01fe3d000-ffffffc01fe7cfff]
[ 0.000000] Memory: 490584K/522240K available (8254K kernel code, 762K rwdata, 2864K rodata, 384K init, 578K bss, 31656K reserved, 0K cma-reserved)
modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
.init : 0xffffff8008b60000 - 0xffffff8008bc0000 ( 384 KB)
.text : 0xffffff8008080000 - 0xffffff8008890000 ( 8256 KB)
.rodata : 0xffffff8008890000 - 0xffffff8008b60000 ( 2880 KB)
.data : 0xffffff8008bc0000 - 0xffffff8008c7e808 ( 763 KB)
fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
memory : 0xffffffc000200000 - 0xffffffc020000000 ( 510 MB)
[ 0.000000] rockchip_mmc_get_phase: invalid clk rate
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.002055] Console: colour dummy device 80x25
[ 0.002491] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003446] pid_max: default: 32768 minimum: 301
[ 0.004007] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.004629] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.006018] Initializing cgroup subsys devices
[ 0.006446] Initializing cgroup subsys freezer
[ 0.007173] sched-energy: CPU device node has no sched-energy-costs
[ 0.007754] Invalid sched_group_energy for CPU0
[ 0.008196] CPU0: update cpu_capacity 1024
[ 0.008624] ASID allocator initialised with 65536 entries
[ 0.018457] Detected VIPT I-cache on CPU1
[ 0.018518] Invalid sched_group_energy for CPU1
[ 0.018523] CPU1: update cpu_capacity 1024
[ 0.018527] CPU1: Booted secondary processor [410fd042]
[ 0.021480] Detected VIPT I-cache on CPU2
[ 0.021522] Invalid sched_group_energy for CPU2
[ 0.021526] CPU2: update cpu_capacity 1024
[ 0.021530] CPU2: Booted secondary processor [410fd042]
[ 0.024525] Detected VIPT I-cache on CPU3
[ 0.024564] Invalid sched_group_energy for CPU3
[ 0.024568] CPU3: update cpu_capacity 1024
[ 0.024572] CPU3: Booted secondary processor [410fd042]
[ 0.024651] Brought up 4 CPUs
[ 0.029870] SMP: Total of 4 processors activated.
[ 0.030309] CPU: All CPU(s) started at EL2
[ 0.030831] Invalid sched_group_energy for CPU3
[ 0.031254] Invalid sched_group_energy for Cluster3
[ 0.031717] Invalid sched_group_energy for CPU2
[ 0.032134] Invalid sched_group_energy for Cluster2
[ 0.032583] Invalid sched_group_energy for CPU1
[ 0.033010] Invalid sched_group_energy for Cluster1
[ 0.033458] Invalid sched_group_energy for CPU0
[ 0.033875] Invalid sched_group_energy for Cluster0
[ 0.034964] devtmpfs: initialized
[ 0.057473] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.058418] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.059469] xor: measuring software checksum speed
[ 0.069496] 8regs : 1144.000 MB/sec
[ 0.079569] 8regs_prefetch: 972.000 MB/sec
[ 0.089641] 32regs : 1292.000 MB/sec
[ 0.099711] 32regs_prefetch: 1120.000 MB/sec
[ 0.100139] xor: using function: 32regs (1292.000 MB/sec)
[ 0.100655] pinctrl core: initialized pinctrl subsystem
[ 0.102389] NET: Registered protocol family 16
[ 0.107252] cpuidle: using governor menu
[ 0.107651] Registered FIQ tty driver
[ 0.108464] vdso: 2 pages (1 code @ ffffff8008896000, 1 data @ ffffff8008bc4000)
[ 0.109171] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.110032] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.114381] console [pstore-1] enabled
[ 0.114732] pstore: Registered ramoops as persistent store backend
[ 0.115317] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.123507] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[ 0.123645] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[ 0.123764] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[ 0.123877] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[ 0.123993] gpiochip_add_data: registered GPIOs 128 to 159 on device: gpio4
[ 0.136908] fiq debugger fiq mode enabled
[ 0.137759] console [ttyFIQ0] enabled
[ 0.138435] bootconsole [uart0] disabled
[ 0.139101] Registered fiq debugger ttyFIQ0
[ 0.192434] raid6: int64x1 gen() 222 MB/s
[ 0.209598] raid6: int64x1 xor() 189 MB/s
[ 0.226851] raid6: int64x2 gen() 328 MB/s
[ 0.243877] raid6: int64x2 xor() 240 MB/s
[ 0.261033] raid6: int64x4 gen() 445 MB/s
[ 0.278255] raid6: int64x4 xor() 289 MB/s
[ 0.295445] raid6: int64x8 gen() 355 MB/s
[ 0.312487] raid6: int64x8 xor() 250 MB/s
[ 0.329677] raid6: neonx1 gen() 394 MB/s
[ 0.346814] raid6: neonx1 xor() 330 MB/s
[ 0.363946] raid6: neonx2 gen() 546 MB/s
[ 0.381160] raid6: neonx2 xor() 406 MB/s
[ 0.398256] raid6: neonx4 gen() 679 MB/s
[ 0.415414] raid6: neonx4 xor() 464 MB/s
[ 0.432600] raid6: neonx8 gen() 699 MB/s
[ 0.449754] raid6: neonx8 xor() 478 MB/s
[ 0.449773] raid6: using algorithm neonx8 gen() 699 MB/s
[ 0.449786] raid6: … xor() 478 MB/s, rmw enabled
[ 0.449796] raid6: using intx1 recovery algorithm
[ 0.451235] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vdd-log[0]’
[ 0.451631] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vdd-1v0[0]’
[ 0.451958] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc-1v8[0]’
[ 0.452524] vcc_1v8: regulator get failed, ret=-517
[ 0.452700] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vcc-sd[0]’ - status (0)
[ 0.453207] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc-1v8-codec[0]’
[ 0.453512] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.453683] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc-ddr[0]’
[ 0.454135] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc-io[0]’
[ 0.454470] vcc_1v8: supplied by vcc_io
[ 0.454599] vcc_1v8_codec: supplied by vcc_io
[ 0.454749] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vccio-flash[0]’
[ 0.455161] of_get_named_gpiod_flags: can’t parse ‘gpio’ property of node ‘/vcc-phy-regulator[0]’
[ 0.455718] of_get_named_gpiod_flags: parsed ‘gpio’ property of node ‘/vbus-host-regulator[0]’ - status (0)
[ 0.456393] of_get_named_gpiod_flags: can’t parse ‘enable-gpio’ property of node ‘/vccio-sd[0]’
[ 0.456456] of_get_named_gpiod_flags: parsed ‘gpios’ property of node ‘/vccio-sd[0]’ - status (0)
[ 0.457311] SCSI subsystem initialized
[ 0.457645] usbcore: registered new interface driver usbfs
[ 0.457727] usbcore: registered new interface driver hub
[ 0.457875] usbcore: registered new device driver usb
[ 0.458029] media: Linux media interface: v0.10
[ 0.458103] Linux video capture interface: v2.00
[ 0.458206] pps_core: LinuxPPS API ver. 1 registered
[ 0.458218] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.458261] PTP clock support registered
[ 0.459626] Advanced Linux Sound Architecture Driver Initialized.
[ 0.460400] Bluetooth: Core ver 2.21
[ 0.460476] NET: Registered protocol family 31
[ 0.460488] Bluetooth: HCI device and connection manager initialized
[ 0.460511] Bluetooth: HCI socket layer initialized
[ 0.460528] Bluetooth: L2CAP socket layer initialized
[ 0.460563] Bluetooth: SCO socket layer initialized
[ 0.461787] rockchip-cpuinfo cpuinfo: Serial : 28dac63c0af834ab
[ 0.462658] clocksource: Switched to clocksource arch_sys_counter
[ 0.475385] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.475790] NET: Registered protocol family 2
[ 0.476513] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.476601] TCP bind hash table entries: 4096 (order: 4, 65536 bytes)
[ 0.476741] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.476854] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.476893] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.477129] NET: Registered protocol family 1
[ 0.477441] Unpacking initramfs…
[ 1.097224] Freeing initrd memory: 8652K
[ 1.098119] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.112099] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.112431] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.112747] SGI XFS with security attributes, no debug enabled
[ 1.117804] io scheduler noop registered (default)
[ 1.119133] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 1.124139] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.124194] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.126745] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.126788] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.127170] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 1.127337] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 1.127990] pwm-regulator vdd-core: GPIO lookup for consumer enable
[ 1.128009] pwm-regulator vdd-core: using device tree for GPIO lookup
[ 1.128026] of_get_named_gpiod_flags: can’t parse ‘enable-gpios’ property of node ‘/vdd-core[0]’
[ 1.128041] of_get_named_gpiod_flags: can’t parse ‘enable-gpio’ property of node ‘/vdd-core[0]’
[ 1.128054] pwm-regulator vdd-core: using lookup tables for GPIO lookup
[ 1.128071] pwm-regulator vdd-core: lookup for GPIO enable failed
[ 1.128890] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.131514] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 12, base_baud = 5078125) is a 16550A
[ 1.133626] [drm] Initialized drm 1.1.0 20060810
[ 1.133789] random: nonblocking pool is initialized
[ 1.136308] Unable to detect cache hierarchy for CPU 0
[ 1.144126] loop: module loaded
[ 1.144400] SCSI Media Changer driver v0.25
[ 1.145135] register spi return v = :0
[ 1.145199] lora1276 register spi return v = :0
[ 1.145254] CAN device driver interface
[ 1.146605] rk_gmac-dwmac ff4e0000.ethernet: clock input or output? (output).
[ 1.146679] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: tx_delay.
[ 1.146697] rk_gmac-dwmac ff4e0000.ethernet: set tx_delay to 0x30
[ 1.146721] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: rx_delay.
[ 1.146735] rk_gmac-dwmac ff4e0000.ethernet: set rx_delay to 0x10
[ 1.146761] rk_gmac-dwmac ff4e0000.ethernet: integrated PHY? (no).
[ 1.152093] rk_gmac-dwmac ff4e0000.ethernet: init for RMII
[ 1.152250] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.152268] Ring mode enabled
[ 1.152279] DMA HW capability register supported
[ 1.152288] Normal descriptors
[ 1.152300] RX Checksum Offload Engine supported (type 2)
[ 1.152311] TX Checksum insertion supported
[ 1.152319] Wake-Up On Lan supported
[ 1.152383] Enable RX Mitigation via HW Watchdog Timer
[ 1.152584] of_get_named_gpiod_flags: parsed ‘snps,reset-gpio’ property of node ‘/ethernet@ff4e0000[0]’ - status (0)
[ 1.356532] libphy: stmmac: probed
[ 1.356575] eth%d: PHY ID 0000ffff at 0 IRQ POLL (stmmac-0:00) active
[ 1.356592] eth%d: PHY ID 0000ffff at 1 IRQ POLL (stmmac-0:01)
[ 1.356610] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 1.356625] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 1.356638] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 1.356685] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 1.356700] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 1.356713] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 1.356726] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 1.356739] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 1.356752] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 1.356765] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 1.356779] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 1.356791] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 1.356813] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 1.356826] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 1.356839] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 1.356852] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 1.356865] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 1.356878] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 1.356891] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 1.356903] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 1.356917] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 1.356930] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 1.356943] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 1.356956] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 1.356969] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 1.356982] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 1.356995] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 1.357008] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 1.357033] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 1.357047] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 1.358264] Rockchip WiFi SYS interface (V1.00) …
[ 1.358429] usbcore: registered new interface driver r8152
[ 1.358514] usbcore: registered new interface driver asix
[ 1.358592] usbcore: registered new interface driver ax88179_178a
[ 1.358685] usbcore: registered new interface driver cdc_ether
[ 1.358751] usbcore: registered new interface driver net1080
[ 1.358820] usbcore: registered new interface driver cdc_subset
[ 1.358894] usbcore: registered new interface driver zaurus
[ 1.359015] usbcore: registered new interface driver cdc_ncm
[ 1.359087] usbcore: registered new interface driver qmi_wwan
[ 1.359543] ff400000.usb supply vusb_d not found, using dummy regulator
[ 1.359664] ff400000.usb supply vusb_a not found, using dummy regulator
[ 1.472733] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 1.473338] dwc2 ff400000.usb: DWC OTG Controller
[ 1.473387] dwc2 ff400000.usb: new USB bus registered, assigned bus number 1
[ 1.473438] dwc2 ff400000.usb: irq 19, io mem 0xff400000
[ 1.474417] hub 1-0:1.0: USB hub found
[ 1.474473] hub 1-0:1.0: 1 port detected
[ 1.698141] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 1.698410] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.698434] ehci-platform: EHCI generic platform driver
[ 1.702316] ehci-platform ff440000.usb: EHCI Host Controller
[ 1.702371] ehci-platform ff440000.usb: new USB bus registered, assigned bus number 2
[ 1.702533] ehci-platform ff440000.usb: irq 20, io mem 0xff440000
[ 1.707689] ehci-platform ff440000.usb: USB 2.0 started, EHCI 1.00
[ 1.708686] hub 2-0:1.0: USB hub found
[ 1.708749] hub 2-0:1.0: 1 port detected
[ 1.709384] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.709448] ohci-platform: OHCI generic platform driver
[ 1.709929] ohci-platform ff450000.usb: Generic Platform OHCI controller
[ 1.709990] ohci-platform ff450000.usb: new USB bus registered, assigned bus number 3
[ 1.710143] ohci-platform ff450000.usb: irq 21, io mem 0xff450000
[ 1.765627] hub 3-0:1.0: USB hub found
[ 1.765712] hub 3-0:1.0: 1 port detected
[ 1.766373] usbcore: registered new interface driver cdc_wdm
[ 1.766461] usbcore: registered new interface driver uas
[ 1.766601] usbcore: registered new interface driver usb-storage
[ 1.766696] usbcore: registered new interface driver ums-alauda
[ 1.766758] usbcore: registered new interface driver ums-cypress
[ 1.766820] usbcore: registered new interface driver ums-datafab
[ 1.766886] usbcore: registered new interface driver ums_eneub6250
[ 1.766963] usbcore: registered new interface driver ums-freecom
[ 1.767030] usbcore: registered new interface driver ums-isd200
[ 1.767097] usbcore: registered new interface driver ums-jumpshot
[ 1.767161] usbcore: registered new interface driver ums-karma
[ 1.767222] usbcore: registered new interface driver ums-onetouch
[ 1.767283] usbcore: registered new interface driver ums-sddr09
[ 1.767351] usbcore: registered new interface driver ums-sddr55
[ 1.767413] usbcore: registered new interface driver ums-usbat
[ 1.767552] usbcore: registered new interface driver usbserial
[ 1.767623] usbcore: registered new interface driver option
[ 1.767693] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.769042] i2c /dev entries driver
[ 1.770362] rk3x-i2c ff050000.i2c: Initialized RK3xxx I2C bus at ffffff8008d6e000
[ 1.771636] IR NEC protocol handler initialized
[ 1.771681] IR RC5(x/sz) protocol handler initialized
[ 1.771697] IR RC6 protocol handler initialized
[ 1.771712] IR JVC protocol handler initialized
[ 1.771728] IR Sony protocol handler initialized
[ 1.771745] IR SANYO protocol handler initialized
[ 1.771762] IR Sharp protocol handler initialized
[ 1.771781] IR MCE Keyboard/mouse protocol handler initialized
[ 1.771796] IR XMP protocol handler initialized
[ 1.772256] usbcore: registered new interface driver uvcvideo
[ 1.772277] USB Video Class driver (1.1.1)
[ 1.772848] rockchip-iodomain ff000000.grf:io-domains: vccio0 supplied by 3300000 uV
[ 1.773072] rockchip-iodomain ff000000.grf:io-domains: vccio1 supplied by 3300000 uV
[ 1.773204] rockchip-iodomain ff000000.grf:io-domains: vccio2 supplied by 3300000 uV
[ 1.773317] rockchip-iodomain ff000000.grf:io-domains: vccio3 supplied by 1800000 uV
[ 1.773414] rockchip-iodomain ff000000.grf:io-domains: vccio4 supplied by 3300000 uV
[ 1.773533] rockchip-iodomain ff000000.grf:io-domains: vccio5 supplied by 3300000 uV
[ 1.775244] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 1.775502] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 1.776068] Bluetooth: HCI UART driver ver 2.3
[ 1.776094] Bluetooth: HCI UART protocol H4 registered
[ 1.776106] Bluetooth: HCI UART protocol LL registered
[ 1.776379] cpu cpu0: leakage=18
[ 1.776709] cpu cpu0: Failed to get pvtm
[ 1.778215] cpu cpu0: l=0 h=55000 hyst=5000 l_limit=1200000000 h_limit=1008000000
[ 1.779738] Synopsys Designware Multimedia Card Interface Driver
[ 1.781636] dwmmc_rockchip ff480000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 1.781866] dwmmc_rockchip ff480000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.781924] dwmmc_rockchip ff480000.dwmmc: Using internal DMA controller.
[ 1.781949] dwmmc_rockchip ff480000.dwmmc: Version ID is 270a
[ 1.782024] dwmmc_rockchip ff480000.dwmmc: DW MMC controller at irq 22,32 bit host data width,256 deep fifo
[ 1.782411] dwmmc_rockchip ff480000.dwmmc: GPIO lookup for consumer cd
[ 1.782430] dwmmc_rockchip ff480000.dwmmc: using device tree for GPIO lookup
[ 1.782446] of_get_named_gpiod_flags: can’t parse ‘cd-gpios’ property of node ‘/dwmmc@ff480000[0]’
[ 1.782462] of_get_named_gpiod_flags: can’t parse ‘cd-gpio’ property of node ‘/dwmmc@ff480000[0]’
[ 1.782477] dwmmc_rockchip ff480000.dwmmc: using lookup tables for GPIO lookup
[ 1.782493] dwmmc_rockchip ff480000.dwmmc: lookup for GPIO cd failed
[ 1.782509] dwmmc_rockchip ff480000.dwmmc: GPIO lookup for consumer wp
[ 1.782523] dwmmc_rockchip ff480000.dwmmc: using device tree for GPIO lookup
[ 1.782538] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@ff480000[0]’
[ 1.782553] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@ff480000[0]’
[ 1.782566] dwmmc_rockchip ff480000.dwmmc: using lookup tables for GPIO lookup
[ 1.782581] dwmmc_rockchip ff480000.dwmmc: lookup for GPIO wp failed
[ 1.793719] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.804750] set vqmmc to 3.3v, ret=0
[ 1.814703] dwmmc_rockchip ff480000.dwmmc: 1 slots initialized
[ 1.814954] dwmmc_rockchip ff490000.dwmmc: No default pinctrl state
[ 1.814975] dwmmc_rockchip ff490000.dwmmc: No off pinctrl state
[ 1.815119] dwmmc_rockchip ff490000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.815166] dwmmc_rockchip ff490000.dwmmc: Using internal DMA controller.
[ 1.815190] dwmmc_rockchip ff490000.dwmmc: Version ID is 270a
[ 1.815278] dwmmc_rockchip ff490000.dwmmc: DW MMC controller at irq 23,32 bit host data width,256 deep fifo
[ 1.815353] dwmmc_rockchip ff490000.dwmmc: No vmmc regulator found
[ 1.815368] dwmmc_rockchip ff490000.dwmmc: No vqmmc regulator found
[ 1.815395] dwmmc_rockchip ff490000.dwmmc: GPIO lookup for consumer wp
[ 1.815409] dwmmc_rockchip ff490000.dwmmc: using device tree for GPIO lookup
[ 1.815424] of_get_named_gpiod_flags: can’t parse ‘wp-gpios’ property of node ‘/dwmmc@ff490000[0]’
[ 1.815438] of_get_named_gpiod_flags: can’t parse ‘wp-gpio’ property of node ‘/dwmmc@ff490000[0]’
[ 1.815453] dwmmc_rockchip ff490000.dwmmc: using lookup tables for GPIO lookup
[ 1.815469] dwmmc_rockchip ff490000.dwmmc: lookup for GPIO wp failed
[ 1.826718] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.837743] dwmmc_rockchip ff490000.dwmmc: 1 slots initialized
[ 1.838219] is31fl32xx 1-003c: GPIO lookup for consumer reset
[ 1.838234] is31fl32xx 1-003c: using device tree for GPIO lookup
[ 1.838313] of_get_named_gpiod_flags: parsed ‘reset-gpios’ property of node ‘/i2c@ff050000/led-controller@3c[0]’ - status (0)
[ 1.838474] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 1.938824] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 2.010720] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 2.039829] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 2.126316] hub 2-1:1.0: USB hub found
[ 2.126448] hub 2-1:1.0: 4 ports detected
[ 2.140943] is31fl32xx_init_regs, write to shutdown register failed
[ 2.141077] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 2.152719] mmc1: MAN_BKOPS_EN bit is not set
[ 2.156385] mmc_host mmc1: Bus speed (slot 0) = 147456000Hz (slot req 150000000Hz, actual 147456000HZ div = 0)
[ 2.242089] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 2.342942] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 2.391829] usb 2-1.3: new high-speed USB device number 3 using ehci-platform
[ 2.444636] usbcore: registered new interface driver usbkbd
[ 2.444886] usbcore: registered new interface driver usbmouse
[ 2.445169] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 2.445748] rockchip-dmc dmc: Failed to get leakage
[ 2.445965] rockchip-dmc dmc: Failed to get pvtm
[ 2.446564] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 2.446613] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 2.446691] rockchip-dmc dmc: don’t add devfreq feature
[ 2.450310] rknandc_base v1.1 2017-01-11
[ 2.450794] rksfc_base v1.1 2016-01-08
[ 2.457462] usbcore: registered new interface driver snd-usb-audio
[ 2.458829] dummy_codec dummy-codec: Unable to get mclk
[ 2.459622] rk3308-acodec ff560000.acodec: GPIO lookup for consumer hp-ctl
[ 2.459711] rk3308-acodec ff560000.acodec: using device tree for GPIO lookup
[ 2.459782] of_get_named_gpiod_flags: parsed ‘hp-ctl-gpios’ property of node ‘/acodec@ff560000[0]’ - status (0)
[ 2.459880] rk3308-acodec ff560000.acodec: GPIO lookup for consumer spk-ctl
[ 2.459909] rk3308-acodec ff560000.acodec: using device tree for GPIO lookup
[ 2.459960] of_get_named_gpiod_flags: parsed ‘spk-ctl-gpios’ property of node ‘/acodec@ff560000[0]’ - status (0)
[ 2.460020] rk3308-acodec ff560000.acodec: GPIO lookup for consumer pa-drv
[ 2.460048] rk3308-acodec ff560000.acodec: using device tree for GPIO lookup
[ 2.460078] of_get_named_gpiod_flags: can’t parse ‘pa-drv-gpios’ property of node ‘/acodec@ff560000[0]’
[ 2.460107] of_get_named_gpiod_flags: can’t parse ‘pa-drv-gpio’ property of node ‘/acodec@ff560000[0]’
[ 2.460134] rk3308-acodec ff560000.acodec: using lookup tables for GPIO lookup
[ 2.460165] rk3308-acodec ff560000.acodec: lookup for GPIO pa-drv failed
[ 2.460192] rk3308-acodec ff560000.acodec: Don’t need pa-drv gpio
[ 2.460241] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 2.460501] The acodec version is: b
[ 2.461786] 1-001a supply AVDD not found, using dummy regulator
[ 2.461946] 1-001a supply DVDD not found, using dummy regulator
[ 2.462079] 1-001a supply PVDD_A not found, using dummy regulator
[ 2.462193] 1-001a supply PVDD_B not found, using dummy regulator
[ 2.462298] 1-001a supply PVDD_C not found, using dummy regulator
[ 2.462409] 1-001a supply PVDD_D not found, using dummy regulator
[ 2.462738] tas571x 1-001a: GPIO lookup for consumer pdn
[ 2.462768] tas571x 1-001a: using device tree for GPIO lookup
[ 2.462840] of_get_named_gpiod_flags: parsed ‘pdn-gpios’ property of node ‘/i2c@ff050000/tas5731@1a[0]’ - status (0)
[ 2.462867] gpio-5 (spk-ctl): gpiod_request: status -16
[ 2.462896] tas571x 1-001a: error requesting pdn_gpio: -16
[ 2.463494] tas571x: probe of 1-001a failed with error -16
[ 2.465895] nf_conntrack version 0.5.0 (3900 buckets, 15600 max)
[ 2.467401] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.468587] NET: Registered protocol family 10
[ 2.470996] NET: Registered protocol family 17
[ 2.471081] NET: Registered protocol family 15
[ 2.471147] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.471163] can: controller area network core (rev 20120528 abi 9)
[ 2.471358] NET: Registered protocol family 29
[ 2.471382] can: raw protocol (rev 20120528)
[ 2.471399] can: broadcast manager protocol (rev 20120528 t)
[ 2.471419] can: netlink gateway (rev 20130117) max_hops=1
[ 2.471748] Bluetooth: RFCOMM TTY layer initialized
[ 2.471774] Bluetooth: RFCOMM socket layer initialized
[ 2.471811] Bluetooth: RFCOMM ver 1.11
[ 2.471834] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.471851] Bluetooth: HIDP socket layer initialized
[ 2.471867] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.472168] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.472187] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 2.472199] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8188eu
[ 2.472208] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.472218] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.472230] of_get_named_gpiod_flags: can’t parse ‘WIFI,poweren_gpio’ property of node ‘/wireless-wlan[0]’
[ 2.472241] of_get_named_gpiod_flags: can’t parse ‘WIFI,vbat_gpio’ property of node ‘/wireless-wlan[0]’
[ 2.472252] of_get_named_gpiod_flags: can’t parse ‘WIFI,reset_gpio’ property of node ‘/wireless-wlan[0]’
[ 2.472262] of_get_named_gpiod_flags: can’t parse ‘WIFI,host_wake_irq’ property of node ‘/wireless-wlan[0]’
[ 2.472279] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 2.472287] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.472300] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.472359] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.472999] flash vendor_init_thread!
[ 2.473026] flash vendor storage:20170308 ret = -1
[ 2.476408] Btrfs loaded
[ 2.477351] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 2.478047] =======================================================
[ 2.478056] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.478063] =======================================================
[ 2.478072] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 2.478083] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.478093] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 2.478103] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.478113] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.478121] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: wifi OOB pin isn’t defined.
[ 2.482697] bFWReady == _FALSE call reset 8051…
[ 2.511020] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.530849] usb 2-1.4: new high-speed USB device number 4 using ehci-platform
[ 2.538638] dwmmc_rockchip ff490000.dwmmc: Successfully tuned phase to 25
[ 2.538990] mmc1: new HS200 MMC card at address 0001
[ 2.540407] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[ 2.541278] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[ 2.542152] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[ 2.543964] mmcblk1rpmb: mmc1:0001 8GTF4R partition 3 512 KiB
[ 2.550152] mmcblk1: p1 p2 p3 p4 p5 p6
[ 2.674896] usb 2-1.4: reset high-speed USB device number 4 using ehci-platform
[ 2.779626] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[ 2.779830] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): Create an ether addr [28:da:a:f8:34:ab] from system serial number
[ 2.817204] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): Random ether addr 28:da:0a:f8:34:ab
[ 2.818804] r8152 2-1.4:1.0 eth1: v2.12.0 (2019/04/29)
[ 2.996073] vendor storage:20160801 ret = 0
[ 3.011734] [WLAN_RFKILL]: get_wifi_addr_vendor: rk_vendor_read wifi mac address failed (-1)
[ 3.020525] usbcore: registered new interface driver rtl8188eu
[ 3.021253] hctosys: unable to open rtc device (rtc0)
[ 3.043185] vcc_sd: disabling
[ 3.043302] vccio_sd: disabling
[ 3.050052] ret 1024
[ 3.050845] ALSA device list:
[ 3.050900] #7: Loopback 1
[ 3.051627] Freeing unused kernel memory: 384K
[ 5.750184] EXT4-fs (mmcblk1p6): recovery complete
[ 5.751107] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null)
[ 6.054033] systemd[1]: System time before build time, advancing clock.
[ 6.063929] systemd[1]: Failed to insert module ‘autofs4’: No such file or directory
[ 6.068713] cgroup: cgroup2: unknown option “nsdelegate”
[ 6.083300] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.084844] systemd[1]: Detected architecture arm64.
[ 6.092544] systemd[1]: Set hostname to .
[ 6.306351] systemd[1]: File /lib/systemd/system/systemd-udevd.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.306454] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.409390] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.410476] systemd[1]: Reached target Remote File Systems.
[ 6.411917] systemd[1]: Created slice System Slice.
[ 6.412984] systemd[1]: Listening on udev Kernel Socket.
[ 6.414035] systemd[1]: Listening on Syslog Socket.
[ 6.414925] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.416444] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.424051] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.425132] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.426066] systemd[1]: Reached target Paths.
[ 6.426567] systemd[1]: Reached target Swap.
[ 6.427011] systemd[1]: Reached target Local Encrypted Volumes.
[ 6.428185] systemd[1]: Listening on udev Control Socket.
[ 6.429387] systemd[1]: Listening on Journal Socket.
[ 6.433205] systemd[1]: Mounting Kernel Debug File System…
[ 6.437759] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 6.442945] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.451415] systemd[1]: Starting Load Kernel Modules…
[ 6.457640] systemd[1]: Starting Journal Service…
[ 6.468738] systemd[1]: Starting udev Coldplug all Devices…
[ 6.480829] systemd[1]: Starting Set the console keyboard layout…
[ 6.485640] systemd[1]: Created slice User and Session Slice.
[ 6.486910] systemd[1]: Reached target Slices.
[ 6.495056] systemd[1]: Mounted Kernel Debug File System.
[ 6.498133] systemd[1]: Started Create Static Device Nodes in /dev.
[ 6.510974] systemd[1]: Started Remount Root and Kernel File Systems.
[ 6.514065] systemd[1]: Started Load Kernel Modules.
[ 6.521128] systemd[1]: Starting Apply Kernel Variables…
[ 6.526337] systemd[1]: Mounting Kernel Configuration File System…
[ 6.536227] systemd[1]: Starting Load/Save Random Seed…
[ 6.542307] systemd[1]: Starting udev Kernel Device Manager…
[ 6.561501] systemd[1]: Mounted Kernel Configuration File System.
[ 6.581451] systemd[1]: Started Load/Save Random Seed.
[ 6.600131] systemd[1]: Started Apply Kernel Variables.
[ 6.665525] systemd[1]: Started udev Kernel Device Manager.
[ 6.677261] systemd[1]: Started Journal Service.
[ 6.739222] systemd-journald[398]: Received request to flush runtime journal from PID 1
[ 6.749994] systemd-journald[398]: File /var/log/journal/80c82fe76a454de3bb49847d1cff70de/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 7.041202] cfg80211: World regulatory domain updated:
[ 7.041231] cfg80211: DFS Master region: unset
[ 7.041239] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.041252] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.041261] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.041270] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.041280] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.041290] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.041300] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.041309] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.041317] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.628616] file system registered
[ 7.688909] read descriptors
[ 7.688956] read strings
[ 7.803475] stmmac_hw_setup: DMA engine initialization failed
[ 7.803528] stmmac_open: Hw setup failed
[ 8.362576] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.463787] stmmac_hw_setup: DMA engine initialization failed
[ 8.463824] stmmac_open: Hw setup failed
[ 8.494720] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 8.522605] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 8.545236] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[ 8.674693] dwc2 ff400000.usb: bound driver configfs-gadget
[ 8.833080] dwc2 ff400000.usb: new device is high-speed
[ 8.866362] dwc2 ff400000.usb: new address 27
[ 8.879499] android_work: sent uevent USB_STATE=CONNECTED
[ 8.891006] configfs-gadget gadget: high-speed config #1: b
[ 8.891377] android_work: sent uevent USB_STATE=CONFIGURED
[ 9.223039] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[ 9.244562] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.245174] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.348570] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.491485] stmmac_hw_setup: DMA engine initialization failed
[ 9.491530] stmmac_open: Hw setup failed
[ 9.505304] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.685784] stmmac_hw_setup: DMA engine initialization failed
[ 9.685823] stmmac_open: Hw setup failed
[ 9.707871] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.757086] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.799532] tty_port_close_start: tty->count = 1 port count = 2.
[ 9.881393] stmmac_hw_setup: DMA engine initialization failed
[ 9.881431] stmmac_open: Hw setup failed
[ 9.894764] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.911356] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[ 10.031992] stmmac_hw_setup: DMA engine initialization failed
[ 10.032031] stmmac_open: Hw setup failed
[ 10.043959] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.382531] adbd (638): /proc/638/oom_adj is deprecated, please use /proc/638/oom_score_adj instead.
[ 114.234446] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 114.235747] r8152 2-1.4:1.0 eth1: carrier on
abcxyztt 发表于 2022-6-23 14:44
用官方的SDK编译固件出来试试
我用瑞芯微的SDK编译出来没问题,但firefly的就不行
我这板子也卡死在同一个地方,请问你找到原因了吗?
解决了,有段时间忘记具体是什么原因了和解决方案了,印象中有出来过两个状况,一种是通过降低emmc的速率解决,还有一个是rk3308和rk3308bs两款是用的不同的SDK,更换了SDK解决
soldier 发表于 2023-5-13 22:29
解决了,有段时间忘记具体是什么原因了和解决方案了,印象中有出来过两个状况,一种是通过降低emmc的速率 …
降低emmc速率后程序仍然卡死,请问你最终用的SDK是原厂的还是firefly的?用的是哪个版本?
原厂的SDK,内核4.4版本的,后面换5.10也没出现问题
我用原厂的5.10的SDK,照着文档一步步来,历尽千辛万苦最后终于全编译成功,但是最后得到的完整固件update.img才65M,用RKDevTool.exe工具加载升级固件,提示:固件概要检查失败,加载固件失败。firefly的文件 系统是一个ubuntu的镜像文件有几百M,而5.10的SDK文件系统类型是squashfs,是否原厂的SDK直接编译出来的固件是不能烧录的?需要进行修改才行?在最开始编译选择板载文件时,文档上是.mk,如下所示:
./build.sh lunch
You’re building on Linux
Lunch menu…pick a combo:
0. default BoardConfig.mk
  1. BoardConfig.mk
  2. BoardConfig_32bit.mk
  3. BoardConfig_rk3308b_32bit.mk
  4. BoardConfig_rk3308b_64bit.mk
  5. BoardConfig_rk3308bs_32bit.mk
  6. BoardConfig_rk3308bs_64bit.mk
  7. BoardConfig_rk3308h_32bit.mk
  8. BoardConfig_rk3308hs_32bit.mk
  9. BoardConfig_robot32.mk
而我这里却是defconfig。
./build.sh lunch
Pick a defconfig:
1. rockchip_defconfig
2. rockchip_32bit_defconfig
3. rockchip_rk3308b_32bit_defconfig
4. rockchip_rk3308b_64bit_defconfig
5. rockchip_rk3308bs_32bit_defconfig
6. rockchip_rk3308bs_64bit_defconfig
7. rockchip_rk3308h_32bit_defconfig
8. rockchip_rk3308hs_32bit_defconfig
Which would you like? [1]:
像类似这样的情况,你以前在开发的时候也遇到过吗?后来是如何解决的呢?为方便沟通能否加Q731793898,谢谢你的指导!
1、./build.sh <配置文件>
2、./build.sh 全编译
配置文件是device/rocket里面吧,具体路径忘了,大概是这里,应该都是和你以前编译的一样
你好,能加个微信吗?也是遇到相同的问题。
楼上几位有解决么?大概是什么方向呢?我这边换了4G EMMC,也是卡死在这个地方,也是用firefly 开发板提供的SDK编译的
