固件文件名称:rk3588_repo_sdk_v0.1.0a.7z
固件下载地址:百度网盘-链接不存在
Log日志:log.zip
系统版本:Ubuntu22.04
描述:在网盘下载了rk3588rk3588_repo_sdk_v0.1.0a.7z,移动到虚拟机中解压后.repo/repo/repo sync -l操作,一开始使用系统自带python3环境提示:
warning: Python 3 support is currently experimental. YMMV.
Please use Python 2.6 - 2.7 instead.
/home/rk3588/Workspace/rk3588/.repo/repo/main.py:19: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module’s documentation for alternative uses
import imp
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 198, in GetBranch
b = self._branches[name]
KeyError: ‘default’
During handling of the above exception, another exception occurred:
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 188, in GetRemote
r = self._remotes[name]
KeyError: ‘origin’
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 131, in GetString
v = self._cache[_key(name)]
KeyError: ‘remote.origin.pushurl’
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_command.py”, line 231, in init
p = subprocess.Popen(command,
File “/root/anaconda3/lib/python3.9/subprocess.py”, line 951, in init
self._execute_child(args, executable, preexec_fn, close_fds,
File “/root/anaconda3/lib/python3.9/subprocess.py”, line 1821, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: ‘git’
File “/home/rk3588/Workspace/rk3588/.repo/repo/main.py”, line 531, in
_Main(sys.argv[1:])
File “/home/rk3588/Workspace/rk3588/.repo/repo/main.py”, line 507, in _Main
result = repo._Run(argv) or 0
File “/home/rk3588/Workspace/rk3588/.repo/repo/main.py”, line 158, in _Run
copts, cargs = cmd.OptionParser.parse_args(argv)
File “/home/rk3588/Workspace/rk3588/.repo/repo/command.py”, line 67, in OptionParser
self._Options(self._optparse)
File “/home/rk3588/Workspace/rk3588/.repo/repo/subcmds/sync.py”, line 189, in _Options
self.jobs = self.manifest.default.sync_j
File “/home/rk3588/Workspace/rk3588/.repo/repo/manifest_xml.py”, line 360, in default
self._Load()
File “/home/rk3588/Workspace/rk3588/.repo/repo/manifest_xml.py”, line 400, in _Load
b = m.GetBranch(m.CurrentBranch).merge
File “/home/rk3588/Workspace/rk3588/.repo/repo/project.py”, line 814, in GetBranch
return self.config.GetBranch(name)
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 200, in GetBranch
b = Branch(self, name)
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 729, in init
self.remote = self._config.GetRemote(r)
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 190, in GetRemote
r = Remote(self, name)
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 575, in init
self.pushUrl = self._Get(‘pushurl’)
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 716, in _Get
return self._config.GetString(key, all_keys = all_keys)
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 134, in GetString
return self.defaults.GetString(name, all_keys = all_keys)
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 248, in _cache
self._cache_dict = self._Read()
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 254, in _Read
d = self._ReadGit()
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 296, in _ReadGit
d = self._do(‘–null’, ‘–list’)
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 318, in _do
p = GitCommand(None,
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_command.py”, line 238, in init
raise GitError(‘%s: %s’ % (command[1], e))
error.GitError: config: [Errno 2] No such file or directory: ‘git’
遂使用anaconda3创建python2.7.17环境,未安装第三方库,提示如下:
_Main(sys.argv[1:])
self._Load()
d = self._ReadGit()
File “/home/rk3588/Workspace/rk3588/.repo/repo/git_config.py”, line 321, in _do
capture_stderr = True)
是否需要安装一些基础库?报错提示没给更多的线索,所以来求助
log.zip (2.18 KB)
