SDK包名称:rk356x_linux_release_v1.2.0_20211019
SDK修改内容:无
Log日志:dmesg.zip
问题描述:没有WLAN0节点
[root@RK356X:/sys/class/rkwifi]# ifconfig -a
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:16 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:60
can1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
Interrupt:61
eth0 Link encap:Ethernet HWaddr 1A:4C:FE:EF:41:61
inet addr:192.168.1.230 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::a550:1df6:424d:5786/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:29412 errors:0 dropped:0 overruns:0 frame:0
TX packets:714 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2421240 (2.3 MiB) TX bytes:48059 (46.9 KiB)
Interrupt:38
eth1 Link encap:Ethernet HWaddr 16:4C:FE:EF:41:61
UP BROADCAST MULTICAST MTU:1500 Metric:1
Interrupt:48
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:36 errors:0 dropped:0 overruns:0 frame:0
TX packets:36 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2608 (2.5 KiB) TX bytes:2608 (2.5 KiB)
DMESG:
[root@RK356X:/sys/class/rkwifi]# dmesg
[ 0.000000] Linux version 4.19.219 (colorlight@k8s-master) (firefly: 72491ed436765c35dddc56ce27b537a4d3703107) (sdk version: rk356x_linux_release_20220311_v1.2.3a.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #34 SMP Mon May 23 08:13:26 UTC 2022
[ 0.000000] Machine model: Firefly RK3568-ROC-PC HDMI (Linux)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options ‘’)
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] On node 0 totalpages: 519680
[ 0.000000] DMA32 zone: 8184 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 519680 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 23 pages/cpu s54184 r8192 d31832 u94208
[ 0.000000] pcpu-alloc: s54184 r8192 d31832 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 511496
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=sdhci@fe310000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] Memory: 1990044K/2078720K available (14782K kernel code, 2004K rwdata, 5236K rodata, 1600K init, 592K bss, 72292K reserved, 16384K cma-reserved)
[ 0.000000] ftrace: allocating 53356 entries in 209 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @7e500000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @7e510000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007e520000
[ 0.000000] CPU0: using LPI pending table @0x000000007e530000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x510 with crng_init=0
[ 0.002221] Console: colour dummy device 80x25
[ 0.002679] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003627] pid_max: default: 32768 minimum: 301
[ 0.004233] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004871] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.007317] ASID allocator initialised with 32768 entries
[ 0.007994] rcu: Hierarchical SRCU implementation.
[ 0.011328] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.012501] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.014107] smp: Bringing up secondary CPUs …
[ 0.016020] Detected VIPT I-cache on CPU1
[ 0.016061] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.016114] CPU1: using LPI pending table @0x000000007e6b0000
[ 0.016168] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.017770] Detected VIPT I-cache on CPU2
[ 0.017805] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.017858] CPU2: using LPI pending table @0x000000007e710000
[ 0.017902] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.019456] Detected VIPT I-cache on CPU3
[ 0.019489] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.019543] CPU3: using LPI pending table @0x000000007e730000
[ 0.019586] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.019723] smp: Brought up 1 node, 4 CPUs
[ 0.026656] SMP: Total of 4 processors activated.
[ 0.027097] CPU features: detected: GIC system register CPU interface
[ 0.027692] CPU features: detected: Privileged Access Never
[ 0.028206] CPU features: detected: LSE atomic instructions
[ 0.028724] CPU features: detected: User Access Override
[ 0.029215] CPU features: detected: 32-bit EL0 Support
[ 0.029690] CPU features: detected: RAS Extension Support
[ 0.030393] CPU: All CPU(s) started at EL2
[ 0.030804] alternatives: patching kernel code
[ 0.038125] devtmpfs: initialized
[ 0.068849] Registered cp15_barrier emulation handler
[ 0.069342] Registered setend emulation handler
[ 0.070096] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.071064] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.072409] pinctrl core: initialized pinctrl subsystem
[ 0.073228] regulator-dummy: no parameters
[ 0.073990] NET: Registered protocol family 16
[ 0.079476] cpuidle: using governor menu
[ 0.079880] Registered FIQ tty driver
[ 0.081225] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.083834] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.093503] console [pstore-1] enabled
[ 0.093853] pstore: Registered ramoops as persistent store backend
[ 0.094428] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.134698] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.136000] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.137320] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.138603] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.139880] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.140622] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.158829] cryptd: max_cpu_qlen set to 1000
[ 0.161180] console [ttyFIQ0] enabled
[ 0.161861] bootconsole [uart8250] disabled
[ 0.162510] Registered fiq debugger ttyFIQ0
[ 0.163147] dc_12v: 12000 mV
[ 0.163383] reg-fixed-voltage dc-12v: dc_12v supplying 12000000uV
[ 0.163533] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[ 0.163547] vcc3v3_sys: supplied by dc_12v
[ 0.163581] dc_12v: could not add device link regulator.2 err -2
[ 0.163639] vcc3v3_sys: 3300 mV
[ 0.163878] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[ 0.164022] reg-fixed-voltage vcc5v0-sys: Looking up vin-supply from device tree
[ 0.164034] vcc5v0_sys: supplied by dc_12v
[ 0.164069] dc_12v: could not add device link regulator.3 err -2
[ 0.164155] vcc5v0_sys: 5000 mV
[ 0.164396] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[ 0.164671] vcc5v0_host: no parameters
[ 0.164898] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[ 0.165035] vcc3v3_lcd0_n: no parameters
[ 0.165270] reg-fixed-voltage vcc3v3-lcd0-n: vcc3v3_lcd0_n supplying 0uV
[ 0.165400] vcc3v3_lcd1_n: no parameters
[ 0.165617] reg-fixed-voltage vcc3v3-lcd1-n: vcc3v3_lcd1_n supplying 0uV
[ 0.165762] reg-fixed-voltage vcc2v5-ddr: Looking up vin-supply from device tree
[ 0.165776] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.165817] vcc3v3_sys: could not add device link regulator.7 err -2
[ 0.165867] vcc2v5-sys: 2500 mV
[ 0.166108] reg-fixed-voltage vcc2v5-ddr: vcc2v5-sys supplying 2500000uV
[ 0.166252] reg-fixed-voltage pcie30-avdd0v9: Looking up vin-supply from device tree
[ 0.166266] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.166300] vcc3v3_sys: could not add device link regulator.8 err -2
[ 0.166350] pcie30_avdd0v9: 900 mV
[ 0.166597] reg-fixed-voltage pcie30-avdd0v9: pcie30_avdd0v9 supplying 900000uV
[ 0.166735] reg-fixed-voltage pcie30-avdd1v8: Looking up vin-supply from device tree
[ 0.166749] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.166787] vcc3v3_sys: could not add device link regulator.9 err -2
[ 0.166837] pcie30_avdd1v8: 1800 mV
[ 0.167083] reg-fixed-voltage pcie30-avdd1v8: pcie30_avdd1v8 supplying 1800000uV
[ 0.167221] reg-fixed-voltage vcc3v3-bu: Looking up vin-supply from device tree
[ 0.167235] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.167267] vcc5v0_sys: could not add device link regulator.10 err -2
[ 0.167316] vcc3v3_bu: 3300 mV
[ 0.167580] reg-fixed-voltage vcc3v3-bu: vcc3v3_bu supplying 3300000uV
[ 0.167848] vcc_hub_power_en: no parameters
[ 0.168100] reg-fixed-voltage vcc-hub-power-regulator: vcc_hub_power_en supplying 0uV
[ 0.168353] vcc_hub_reset_en: no parameters
[ 0.168589] reg-fixed-voltage vcc-hub-reset-regulator: vcc_hub_reset_en supplying 0uV
[ 0.168840] pcie_pi6c_oe_en: no parameters
[ 0.169092] reg-fixed-voltage pcie-pi6c-oe-regulator: pcie_pi6c_oe_en supplying 0uV
[ 0.169322] vcc_4g_power_en: no parameters
[ 0.169544] reg-fixed-voltage vcc-4g-power-regulator: vcc_4g_power_en supplying 0uV
[ 0.170161] pcie30_3v3: 100 ↔ 3300 mV at 3300 mV
[ 0.171058] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_npu-supply from device tree
[ 0.171082] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_npu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.171142] rk_iommu fde4b000.iommu: version = 2
[ 0.171831] rk_iommu fdea0800.iommu: version = 2
[ 0.172114] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply from device tree
[ 0.172140] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vpu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.172327] rk_iommu fded0480.iommu: version = 2
[ 0.172605] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply from device tree
[ 0.172630] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@fdd90000/power-controller failed
[ 0.172876] rk_iommu fdee0800.iommu: version = 2
[ 0.173366] rk_iommu fdef0800.iommu: version = 2
[ 0.173817] rk_iommu fdf40f00.iommu: version = 2
[ 0.174185] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply from device tree
[ 0.174210] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[ 0.174409] rk_iommu fdf80800.iommu: version = 2
[ 0.174692] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply from device tree
[ 0.174718] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[ 0.174896] rk_iommu fdff1a00.iommu: version = 2
[ 0.175176] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply from device tree
[ 0.175200] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_vi-supply property in node /power-management@fdd90000/power-controller failed
[ 0.175366] rk_iommu fe043e00.iommu: version = 2
[ 0.176413] SCSI subsystem initialized
[ 0.176504] libata version 3.00 loaded.
[ 0.176764] usbcore: registered new interface driver usbfs
[ 0.176885] usbcore: registered new interface driver hub
[ 0.176963] usbcore: registered new device driver usb
[ 0.177098] media: Linux media interface: v0.10
[ 0.177165] videodev: Linux video capture interface: v2.00
[ 0.177288] pps_core: LinuxPPS API ver. 1 registered
[ 0.177315] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.177360] PTP clock support registered
[ 0.177800] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 0.180842] Advanced Linux Sound Architecture Driver Initialized.
[ 0.181454] Bluetooth: Core ver 2.22
[ 0.181527] NET: Registered protocol family 31
[ 0.181551] Bluetooth: HCI device and connection manager initialized
[ 0.181581] Bluetooth: HCI socket layer initialized
[ 0.181608] Bluetooth: L2CAP socket layer initialized
[ 0.181686] Bluetooth: SCO socket layer initialized
[ 0.182246] rockchip-cpuinfo cpuinfo: SoC : 35681000
[ 0.182277] rockchip-cpuinfo cpuinfo: Serial : 390eb518430f6ed0
[ 0.183864] clocksource: Switched to clocksource arch_sys_counter
[ 0.284637] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.285111] NET: Registered protocol family 2
[ 0.285334] IP idents hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.286719] tcp_listen_portaddr_hash hash table entries: 1024 (order: 3, 40960 bytes)
[ 0.286802] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.286984] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.287559] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.287725] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.287863] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.288182] NET: Registered protocol family 1
[ 0.288896] RPC: Registered named UNIX socket transport module.
[ 0.288922] RPC: Registered udp transport module.
[ 0.288942] RPC: Registered tcp transport module.
[ 0.288962] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.289772] PCI: CLS 0 bytes, default 64
[ 0.290879] Trying to unpack rootfs image as initramfs…
[ 0.747366] Freeing initrd memory: 8652K
[ 0.749349] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.752253] Initialise system trusted keyrings
[ 0.752509] workingset: timestamp_bits=61 max_order=19 bucket_order=0
[ 0.761170] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.762208] NFS: Registering the id_resolver key type
[ 0.762259] Key type id_resolver registered
[ 0.762272] Key type id_legacy registered
[ 0.762322] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.762626] fuse init (API version 7.27)
[ 0.763212] SGI XFS with security attributes, no debug enabled
[ 0.766711] NET: Registered protocol family 38
[ 0.766767] Key type asymmetric registered
[ 0.766782] Asymmetric key parser ‘x509’ registered
[ 0.766838] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.766866] io scheduler noop registered
[ 0.766887] io scheduler deadline registered
[ 0.767060] io scheduler cfq registered (default)
[ 0.767089] io scheduler mq-deadline registered
[ 0.767110] io scheduler kyber registered
[ 0.768526] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.768746] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.771957] phy phy-fe8b0000.usb2-phy.0: Looking up phy-supply from device tree
[ 0.771983] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.0 err -2
[ 0.772040] phy phy-fe8b0000.usb2-phy.0: Linked as a consumer to regulator.4
[ 0.772203] phy phy-fe8b0000.usb2-phy.1: Looking up phy-supply from device tree
[ 0.772223] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.1 err -2
[ 0.772273] phy phy-fe8b0000.usb2-phy.1: Linked as a consumer to regulator.4
[ 0.772410] phy phy-fe8b0000.usb2-phy.1: Looking up vbus-supply from device tree
[ 0.772423] phy phy-fe8b0000.usb2-phy.1: Looking up vbus-supply property in node /usb2-phy@fe8b0000/otg-port failed
[ 0.772450] phy phy-fe8b0000.usb2-phy.1: No vbus specified for otg port
[ 0.776369] phy phy-fe820000.phy.2: Looking up phy-supply from device tree
[ 0.776386] phy phy-fe820000.phy.2: Looking up phy-supply property in node /phy@fe820000 failed
[ 0.776941] phy phy-fe830000.phy.3: Looking up phy-supply from device tree
[ 0.776955] phy phy-fe830000.phy.3: Looking up phy-supply property in node /phy@fe830000 failed
[ 0.777531] phy phy-fe840000.phy.4: Looking up phy-supply from device tree
[ 0.777545] phy phy-fe840000.phy.4: Looking up phy-supply property in node /phy@fe840000 failed
[ 0.779032] phy phy-fe8c0000.phy.5: Looking up phy-supply from device tree
[ 0.779047] phy phy-fe8c0000.phy.5: Looking up phy-supply property in node /phy@fe8c0000 failed
[ 0.782867] rk-pcie 3c0800000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.782978] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.15
[ 0.783673] mpp_service mpp-srv: be32fafb08b3 author: Yandong Lin 2021-11-18 video: rockchip: mpp: Fix mpp_iommu_refresh crash issue
[ 0.783708] mpp_service mpp-srv: probe start
[ 0.784951] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.785007] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.785275] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.785859] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[ 0.785886] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.785917] rkvenc_init:1199: failed to add venc devfreq
[ 0.786373] mpp_rkvenc fdf40000.rkvenc: probing finish
[ 0.787874] iommu: Adding device fdea0400.vdpu to group 1
[ 0.787921] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.788157] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.788914] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.789654] iommu: Adding device fdee0000.vepu to group 3
[ 0.789709] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.789968] mpp_vepu2 fdee0000.vepu: probe device
[ 0.790786] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.791519] iommu: Adding device fdef0000.iep to group 4
[ 0.791574] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.791783] mpp-iep2 fdef0000.iep: probe device
[ 0.792400] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.792629] mpp-iep2 fdef0000.iep: probing finish
[ 0.793319] iommu: Adding device fded0000.jpegd to group 2
[ 0.793374] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.793579] mpp_jpgdec fded0000.jpegd: probe device
[ 0.794371] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.795113] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.795167] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.795178] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.795231] rk-pcie 3c0800000.pcie: Missing config reg space
[ 0.795269] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.795317] rk-pcie 3c0800000.pcie: err 0x380000000..0x3807fffff → 0x80000000
[ 0.795354] rk-pcie 3c0800000.pcie: IO 0x380800000..0x3808fffff → 0x80800000
[ 0.795380] rk-pcie 3c0800000.pcie: MEM 0x380900000..0x3bfffffff → 0x80900000
[ 0.795494] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.795740] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.796198] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.796228] rkvdec2_init:661: No niu aclk reset resource define
[ 0.796255] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.796276] rkvdec2_init:664: No niu hclk reset resource define
[ 0.796528] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[ 0.796558] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[ 0.796581] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[ 0.796602] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[ 0.796619] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[ 0.796692] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[ 0.796796] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[ 0.797315] mpp_service mpp-srv: probe success
[ 0.805035] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.805079] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.808390] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.808430] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.810253] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.811640] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.812766] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 66, base_baud = 1500000) is a 16550A
[ 0.813638] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 67, base_baud = 1500000) is a 16550A
[ 0.814522] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 68, base_baud = 1500000) is a 16550A
[ 0.818176] random: fast init done
[ 0.818524] random: crng init done
[ 0.818921] iommu: Adding device fe040000.vop to group 8
[ 0.818981] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.825476] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.827280] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.830003] rockchip-drm display-subsystem: dmc is disabled
[ 0.830370] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4
[ 0.830413] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1
[ 0.830446] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.830820] [drm] unsupported AFBC format[3432564e]
[ 0.830898] [drm] failed to init overlay plane Cluster0-win1
[ 0.830998] [drm] failed to init overlay plane Cluster1-win1
[ 0.831154] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008fca6d8)
[ 0.831443] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.832235] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.833010] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008fce1f8)
[ 0.833046] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.833068] [drm] No driver support for vblank timestamp query.
[ 0.833377] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 0.833469] rockchip-drm display-subsystem: can’t not find any loader display
[ 0.833506] rockchip-drm display-subsystem: failed to show loader logo
[ 0.833559] [drm] Cannot find any crtc or sizes
[ 0.834664] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.841963] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply from device tree
[ 0.842002] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@fdd90000/power-controller failed
[ 0.842075] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 0.842198] mali fde60000.gpu: Looking up mali-supply from device tree
[ 0.842204] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.842267] mali fde60000.gpu: Device initialization Deferred
[ 0.843152] brd: module loaded
[ 0.852335] loop: module loaded
[ 0.852973] zram: Added device: zram0
[ 0.853148] lkdtm: No crash points registered, enable through debugfs
[ 0.854908] ahci fc800000.sata: Looking up target-supply from device tree
[ 0.854926] ahci fc800000.sata: Looking up target-supply property in node /sata@fc800000 failed
[ 0.855061] ahci fc800000.sata: forcing port_map 0x0 → 0x1
[ 0.855145] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 0.855177] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 0.855215] ahci fc800000.sata: port 0 is not capable of FBS
[ 0.856526] scsi host0: ahci
[ 0.857019] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 irq 11
[ 0.859590] libphy: Fixed MDIO Bus: probed
[ 0.859670] CAN device driver interface
[ 0.864122] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[ 0.864145] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[ 0.864175] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 0.864218] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 0.864238] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[ 0.864253] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26).
[ 0.864273] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 0.864365] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 0.869404] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 0.869712] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.869750] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 0.869789] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 0.869812] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 0.869833] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 0.869854] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 0.869911] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 0.869935] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.869953] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[ 1.000572] libphy: stmmac: probed
[ 1.007739] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply from device tree
[ 1.007764] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply property in node /ethernet@fe2a0000 failed
[ 1.007795] rk_gmac-dwmac fe2a0000.ethernet: no regulator found
[ 1.007842] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input).
[ 1.007860] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c).
[ 1.007876] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f).
[ 1.007896] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 1.007987] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 1.013027] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[ 1.013366] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 1.013399] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5
[ 1.013426] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[ 1.013450] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[ 1.013473] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[ 1.013494] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[ 1.013553] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[ 1.013576] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.013593] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[ 1.143902] libphy: stmmac: probed
[ 1.150309] usbcore: registered new interface driver rndis_wlan
[ 1.150415] usbcore: registered new interface driver rtl8150
[ 1.150495] usbcore: registered new interface driver r8152
[ 1.150621] usbcore: registered new interface driver asix
[ 1.150707] usbcore: registered new interface driver ax88179_178a
[ 1.150783] usbcore: registered new interface driver cdc_ether
[ 1.150858] usbcore: registered new interface driver rndis_host
[ 1.150956] usbcore: registered new interface driver cdc_ncm
[ 1.151044] usbcore: registered new interface driver qmi_wwan_q
[ 1.151120] usbcore: registered new interface driver qmi_wwan
[ 1.151198] usbcore: registered new interface driver cdc_mbim
[ 1.152773] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.154563] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.157585] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.157630] ehci-pci: EHCI PCI platform driver
[ 1.157736] ehci-platform: EHCI generic platform driver
[ 1.160097] ehci-platform fd800000.usb: EHCI Host Controller
[ 1.160371] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 1.160983] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000
[ 1.170564] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.173903] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 1.174273] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.174304] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.174333] usb usb1: Product: EHCI Host Controller
[ 1.174357] usb usb1: Manufacturer: Linux 4.19.219 ehci_hcd
[ 1.174377] usb usb1: SerialNumber: fd800000.usb
[ 1.175038] hub 1-0:1.0: USB hub found
[ 1.175117] hub 1-0:1.0: 1 port detected
[ 1.177922] ehci-platform fd880000.usb: EHCI Host Controller
[ 1.178193] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 1.178767] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000
[ 1.190577] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 1.190912] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.190943] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.190968] usb usb2: Product: EHCI Host Controller
[ 1.190991] usb usb2: Manufacturer: Linux 4.19.219 ehci_hcd
[ 1.191012] usb usb2: SerialNumber: fd880000.usb
[ 1.191632] hub 2-0:1.0: USB hub found
[ 1.191696] hub 2-0:1.0: 1 port detected
[ 1.192799] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.192847] ohci-platform: OHCI generic platform driver
[ 1.193171] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 1.193433] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[ 1.193834] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000
[ 1.254841] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.254873] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.254889] usb usb3: Product: Generic Platform OHCI controller
[ 1.254903] usb usb3: Manufacturer: Linux 4.19.219 ohci_hcd
[ 1.254916] usb usb3: SerialNumber: fd840000.usb
[ 1.255539] hub 3-0:1.0: USB hub found
[ 1.255615] hub 3-0:1.0: 1 port detected
[ 1.256343] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[ 1.256610] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4
[ 1.257025] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000
[ 1.314821] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.314854] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.314869] usb usb4: Product: Generic Platform OHCI controller
[ 1.314883] usb usb4: Manufacturer: Linux 4.19.219 ohci_hcd
[ 1.314896] usb usb4: SerialNumber: fd8c0000.usb
[ 1.315565] hub 4-0:1.0: USB hub found
[ 1.315641] hub 4-0:1.0: 1 port detected
[ 1.317871] usbcore: registered new interface driver cdc_acm
[ 1.317905] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.317992] usbcore: registered new interface driver cdc_wdm
[ 1.318333] usbcore: registered new interface driver uas
[ 1.318511] usbcore: registered new interface driver usb-storage
[ 1.318668] usbcore: registered new interface driver usbserial_generic
[ 1.318728] usbserial: USB Serial support registered for generic
[ 1.318806] usbcore: registered new interface driver cp210x
[ 1.318861] usbserial: USB Serial support registered for cp210x
[ 1.318984] usbcore: registered new interface driver ftdi_sio
[ 1.319028] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.319282] usbcore: registered new interface driver keyspan
[ 1.319338] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.319390] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.319451] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.319504] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.319582] usbcore: registered new interface driver option
[ 1.319637] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.319982] usbcore: registered new interface driver oti6858
[ 1.320036] usbserial: USB Serial support registered for oti6858
[ 1.320120] usbcore: registered new interface driver pl2303
[ 1.320173] usbserial: USB Serial support registered for pl2303
[ 1.320273] usbcore: registered new interface driver qcserial
[ 1.320325] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.320439] usbcore: registered new interface driver sierra
[ 1.320495] usbserial: USB Serial support registered for Sierra USB modem
[ 1.322201] usbcore: registered new interface driver usbtouchscreen
[ 1.322275] ============ himax_hx83102_init 1742 jjlook ==========
[ 1.322300] ============ himax_hx83102_probe 1725 jjlook ==========
[ 1.322393] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0
[ 1.322421] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0
[ 1.322871] .. rk pwm remotectl v2.0 init
[ 1.323240] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0
[ 1.323720] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000
[ 1.323765] remotectl-pwm fe6e0030.pwm: cannot find PWR IRQ
[ 1.323791] remotectl-pwm fe6e0030.pwm: pwm sip wakeup config error!!
[ 1.323814] remotectl-pwm fe6e0030.pwm: Donot support ATF Wakeup
[ 1.324794] i2c /dev entries driver
[ 1.327242] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 1.327775] vdd_cpu: override max_uV, 1390000 → 1387500
[ 1.329082] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[ 1.329100] vdd_cpu: supplied by vcc5v0_sys
[ 1.329134] vcc5v0_sys: could not add device link regulator.16 err -2
[ 1.331555] vdd_cpu: 712 ↔ 1387 mV at 1025 mV
[ 1.334302] rk808 0-0020: chip id: 0x8090
[ 1.334381] rk808 0-0020: No cache defaults, reading back from HW
[ 1.358171] rk808 0-0020: source: on=0x40, off=0x00
[ 1.358209] rk808 0-0020: support dcdc3 fb mode:-22, 63
[ 1.358228] rk808 0-0020: support pmic reset mode:0,0
[ 1.363573] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.363644] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.363738] rk808 0-0020: Looking up vcc1-supply from device tree
[ 1.363757] vdd_logic: supplied by vcc3v3_sys
[ 1.363791] vcc3v3_sys: could not add device link regulator.17 err -2
[ 1.363943] vdd_logic: 500 ↔ 1350 mV at 900 mV
[ 1.364345] rk808 0-0020: Looking up vcc2-supply from device tree
[ 1.364360] vdd_gpu: supplied by vcc3v3_sys
[ 1.364396] vcc3v3_sys: could not add device link regulator.18 err -2
[ 1.364458] vdd_gpu: 500 ↔ 1350 mV at 900 mV
[ 1.364805] rk808 0-0020: Looking up vcc3-supply from device tree
[ 1.364820] vcc_ddr: supplied by vcc3v3_sys
[ 1.364855] vcc3v3_sys: could not add device link regulator.19 err -2
[ 1.364909] vcc_ddr: at 500 mV
[ 1.365277] rk808 0-0020: Looking up vcc4-supply from device tree
[ 1.365291] vdd_npu: supplied by vcc3v3_sys
[ 1.365326] vcc3v3_sys: could not add device link regulator.20 err -2
[ 1.365391] vdd_npu: 500 ↔ 1350 mV at 900 mV
[ 1.365765] rk808 0-0020: Looking up vcc9-supply from device tree
[ 1.365780] vcc_1v8: supplied by vcc3v3_sys
[ 1.365814] vcc3v3_sys: could not add device link regulator.21 err -2
[ 1.365869] vcc_1v8: 1800 mV
[ 1.366192] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.366208] vdda0v9_image: supplied by vcc3v3_sys
[ 1.366247] vcc3v3_sys: could not add device link regulator.22 err -2
[ 1.366325] vdda0v9_image: 900 mV
[ 1.366653] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.366669] vdda_0v9: supplied by vcc3v3_sys
[ 1.366693] vcc3v3_sys: could not add device link regulator.23 err -2
[ 1.366766] vdda_0v9: 900 mV
[ 1.367093] rk808 0-0020: Looking up vcc5-supply from device tree
[ 1.367108] vdda0v9_pmu: supplied by vcc3v3_sys
[ 1.367142] vcc3v3_sys: could not add device link regulator.24 err -2
[ 1.367248] vdda0v9_pmu: 900 mV
[ 1.367595] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.367610] vccio_acodec: supplied by vcc3v3_sys
[ 1.367644] vcc3v3_sys: could not add device link regulator.25 err -2
[ 1.367701] vccio_acodec: 3300 mV
[ 1.368054] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.368068] vccio_sd: supplied by vcc3v3_sys
[ 1.368102] vcc3v3_sys: could not add device link regulator.26 err -2
[ 1.368161] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 1.368537] rk808 0-0020: Looking up vcc6-supply from device tree
[ 1.368552] vcc3v3_pmu: supplied by vcc3v3_sys
[ 1.368586] vcc3v3_sys: could not add device link regulator.27 err -2
[ 1.368645] vcc3v3_pmu: 3300 mV
[ 1.369002] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.369017] vcca_1v8: supplied by vcc3v3_sys
[ 1.369051] vcc3v3_sys: could not add device link regulator.28 err -2
[ 1.369109] vcca_1v8: 1800 mV
[ 1.369454] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.369470] vcca1v8_pmu: supplied by vcc3v3_sys
[ 1.369507] vcc3v3_sys: could not add device link regulator.29 err -2
[ 1.369585] vcca1v8_pmu: 1800 mV
[ 1.369926] rk808 0-0020: Looking up vcc7-supply from device tree
[ 1.369941] vcca1v8_image: supplied by vcc3v3_sys
[ 1.369962] vcc3v3_sys: could not add device link regulator.30 err -2
[ 1.370039] vcca1v8_image: 1800 mV
[ 1.370369] rk808 0-0020: Looking up vcc9-supply from device tree
[ 1.370383] vcc_3v3: supplied by vcc3v3_sys
[ 1.370418] vcc3v3_sys: could not add device link regulator.31 err -2
[ 1.370471] vcc_3v3: at 3300 mV
[ 1.370852] rk808 0-0020: Looking up vcc8-supply from device tree
[ 1.370867] vcc3v3_sd: supplied by vcc3v3_sys
[ 1.370906] vcc3v3_sys: could not add device link regulator.32 err -2
[ 1.370958] vcc3v3_sd: at 3300 mV
[ 1.371468] rk817-battery rk817-battery: Failed to find matching dt id
[ 1.371796] rk817-charger rk817-charger: Failed to find matching dt id
[ 1.375228] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1
[ 1.375856] rk808-rtc rk808-rtc: device is disabled
[ 1.375902] rk808-rtc: probe of rk808-rtc failed with error -22
[ 1.377395] fusb302 0-0022: Can’t get property of role, set role to default DRP
[ 1.387074] fusb302 0-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.387342] input: Typec_Headphone as /devices/platform/fdd40000.i2c/i2c-0/0-0022/input/input2
[ 1.389096] pca953x 1-0021: Looking up vcc-supply from device tree
[ 1.389110] pca953x 1-0021: Looking up vcc-supply property in node /i2c@fe5a0000/gpio@21 failed
[ 1.389159] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 1.389263] pca953x 1-0021: Linked as a consumer to regulator.0
[ 1.389475] pca953x 1-0021: failed reading register
[ 1.389559] pca953x 1-0021: Dropping the link to regulator.0
[ 1.399130] rtc-hym8563 5-0051: rtc core: registered hym8563 as rtc0
[ 1.400212] rtc-hym8563 5-0051: setting system clock to 2022-06-15 03:17:29 UTC (1655263049)
[ 1.401961] gsensor_mc3230 5-004c: sensor_register_device: gs_mc3230, id = 27
[ 1.401999] i2c i2c-5: sensor_probe: gs_mc3230,00000000168eb355
[ 1.402060] gsensor_mc3230 5-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x00000000fdd4320e
[ 1.440585] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 1.440875] [Gsensor] init_3230_ctl_data 457 : error: -6
[ 1.440903] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor
[ 1.440919] gsensor_mc3230 5-004c: sensor_chip_init:fail to init sensor
[ 1.440933] i2c i2c-5: sensor_probe failed -2
[ 1.440933]
[ 1.445145] iommu: Adding device fdff0000.rkisp to group 7
[ 1.445203] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu
[ 1.445460] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[ 1.445482] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[ 1.445533] rkisp_hw fdff0000.rkisp: can’t request region for resource [mem 0xfdff0000-0xfdffffff]
[ 1.446752] rkisp rkisp-vir0: rkisp driver version: v01.07.00
[ 1.447147] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 1.447226] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 1.449891] usbcore: registered new interface driver uvcvideo
[ 1.449922] USB Video Class driver (1.1.1)
[ 1.450187] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[ 1.450336] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.27
[ 1.450406] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu
[ 1.450461] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[ 1.450626] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu
[ 1.450680] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[ 1.450765] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.25
[ 1.450825] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec
[ 1.450874] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[ 1.450890] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply property in node /syscon@fdc20000/io-domains failed
[ 1.450934] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[ 1.451039] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.26
[ 1.451088] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[ 1.451139] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[ 1.451220] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.21
[ 1.451280] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 1.451326] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[ 1.451410] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.31
[ 1.451471] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 1.451525] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[ 1.451647] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[ 1.451699] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[ 1.451813] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[ 1.456325] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[ 1.457917] Bluetooth: HCI UART driver ver 2.3
[ 1.457950] Bluetooth: HCI UART protocol H4 registered
[ 1.457971] Bluetooth: HCI UART protocol ATH3K registered
[ 1.458263] Bluetooth: HCI UART protocol Broadcom registered
[ 1.458377] usbcore: registered new interface driver bfusb
[ 1.458476] usbcore: registered new interface driver btusb
[ 1.458861] cpu cpu0: leakage=26
[ 1.458954] cpu cpu0: Looking up cpu-supply from device tree
[ 1.459694] cpu cpu0: Linked as a consumer to regulator.16
[ 1.489090] cpu cpu0: temp=41250, pvtm=86370 (86344 + 26)
[ 1.493445] cpu cpu0: Dropping the link to regulator.16
[ 1.493512] cpu cpu0: pvtm-volt-sel=1
[ 1.493940] cpu cpu0: Looking up cpu-supply from device tree
[ 1.494862] cpu cpu0: Linked as a consumer to regulator.16
[ 1.494940] cpu cpu0: Dropping the link to regulator.16
[ 1.495086] cpu cpu0: Looking up cpu-supply from device tree
[ 1.495836] cpu cpu0: Linked as a consumer to regulator.16
[ 1.496937] cpu cpu0: avs=0
[ 1.497037] energy_model: pd0: hertz/watts ratio non-monotonically decreasing: em_cap_state 2 >= em_cap_state1
[ 1.497428] energy_model: Created perf domain 0-3
[ 1.497482] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 1.502434] cpu cpu0: failed to find power_model node
[ 1.504503] sdhci: Secure Digital Host Controller Interface driver
[ 1.504527] sdhci: Copyright(c) Pierre Ossman
[ 1.504537] Synopsys Designware Multimedia Card Interface Driver
[ 1.505789] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.506136] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller.
[ 1.506165] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a
[ 1.506251] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo
[ 1.506292] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply from device tree
[ 1.506305] dwmmc_rockchip fe000000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe000000 failed
[ 1.506345] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.506354] dwmmc_rockchip fe000000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe000000 failed
[ 1.506434] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq
[ 1.506460] mmc_host mmc3: card is non-removable.
[ 1.588655] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[ 1.588774] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.588805] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 1.590513] hub 2-1:1.0: USB hub found
[ 1.590778] hub 2-1:1.0: 4 ports detected
[ 1.624405] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.631056] fusb302 0-0022: CC connected in CC1 as UFP
[ 1.637816] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.638404] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller.
[ 1.638434] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a
[ 1.638514] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 50,32 bit host data width,256 deep fifo
[ 1.638557] dwmmc_rockchip fe2b0000.dwmmc: Looking up vmmc-supply from device tree
[ 1.638663] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.32
[ 1.638680] dwmmc_rockchip fe2b0000.dwmmc: Looking up vqmmc-supply from device tree
[ 1.638747] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.26
[ 1.654271] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 1.667242] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.668355] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply from device tree
[ 1.668365] sdhci-dwcmshc fe310000.sdhci: Looking up vmmc-supply property in node /sdhci@fe310000 failed
[ 1.668398] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply from device tree
[ 1.668405] sdhci-dwcmshc fe310000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe310000 failed
[ 1.668425] mmc0: Unknown controller version (5). You may experience problems.
[ 1.699942] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA
[ 1.701811] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.702203] usbcore: registered new interface driver usbhid
[ 1.702221] usbhid: USB HID core driver
[ 1.702498] rockchip,bus bus-npu: Looking up bus-supply from device tree
[ 1.702585] rockchip,bus bus-npu: Linked as a consumer to regulator.17
[ 1.702613] rockchip,bus bus-npu: Failed to get leakage
[ 1.702674] rockchip,bus bus-npu: pvtm = 86370, form pvtm_value
[ 1.702697] rockchip,bus bus-npu: pvtm-volt-sel=1
[ 1.702948] rockchip,bus bus-npu: avs=0
[ 1.705180] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[ 1.705257] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.28
[ 1.706309] rksfc_base v1.1 2016-01-08
[ 1.706999] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000
[ 1.707059] rkflash_dev_init enter
[ 1.707082] sfc nor id: ef 60 19
[ 1.707109] rkflash[1] init success
[ 1.708087] sfc_nor_mtd_init register mtd succuss
[ 1.708106] rkflash_dev_init device register as mtd dev, ret= 0
[ 1.708775] usbcore: registered new interface driver snd-usb-audio
[ 1.710986] rk817-codec rk817-codec: DMA mask not set
[ 1.711744] rk817_codec_parse_dt_property: rk809 hp adc effective value of detection 976~1024
[ 1.711775] invalid rk817->hp_det_gpio: -2
[ 1.711787] invalid gpio: -2
[ 1.717576] Initializing XFRM netlink socket
[ 1.718067] NET: Registered protocol family 10
[ 1.718814] Segment Routing with IPv6
[ 1.718907] NET: Registered protocol family 17
[ 1.718937] NET: Registered protocol family 15
[ 1.718972] can: controller area network core (rev 20170425 abi 9)
[ 1.719100] NET: Registered protocol family 29
[ 1.719131] can: raw protocol (rev 20170425)
[ 1.719147] can: broadcast manager protocol (rev 20170425 t)
[ 1.719168] can: netlink gateway (rev 20170425) max_hops=1
[ 1.719430] Bluetooth: RFCOMM socket layer initialized
[ 1.719473] Bluetooth: RFCOMM ver 1.11
[ 1.719492] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.719511] Bluetooth: HIDP socket layer initialized
[ 1.719556] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.719570] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.720128] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.720176] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s
[ 1.720191] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.720203] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.720249] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0.
[ 1.720267] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.720280] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.720293] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 1.720305] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.720923] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73.
[ 1.720960] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96.
[ 1.720983] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 97.
[ 1.721006] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 98.
[ 1.721079] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.721174] [BT_RFKILL]: ** disable irq
[ 1.721298] [BT_RFKILL]: bt_default device registered.
[ 1.721433] Key type dns_resolver registered
[ 1.721823] flash vendor_init_thread!
[ 1.721840] flash vendor storage:20170308 ret = -1
[ 1.723671] Loading compiled-in X.509 certificates
[ 1.724268] pstore: Using compression: deflate
[ 1.725115] rga2: Driver loaded successfully ver:3.2.63318
[ 1.725464] rga2: Module initialized.
[ 1.732971] mmc0: new HS200 MMC card at address 0001
[ 1.734075] mmcblk0: mmc0:0001 Y2P032 29.1 GiB
[ 1.734684] mmcblk0boot0: mmc0:0001 Y2P032 partition 1 4.00 MiB
[ 1.735332] mmcblk0boot1: mmc0:0001 Y2P032 partition 2 4.00 MiB
[ 1.735651] mmcblk0rpmb: mmc0:0001 Y2P032 partition 3 16.0 MiB, chardev (239:0)
[ 1.738669] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 1.752269] phy phy-fe8a0000.usb2-phy.6: Looking up phy-supply from device tree
[ 1.752289] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.6 err -2
[ 1.752339] phy phy-fe8a0000.usb2-phy.6: Linked as a consumer to regulator.4
[ 1.752486] phy phy-fe8a0000.usb2-phy.7: Looking up phy-supply from device tree
[ 1.752494] phy phy-fe8a0000.usb2-phy.7: Looking up phy-supply property in node /usb2-phy@fe8a0000/otg-port failed
[ 1.752588] phy phy-fe8a0000.usb2-phy.7: Looking up vbus-supply from device tree
[ 1.752595] phy phy-fe8a0000.usb2-phy.7: Looking up vbus-supply property in node /usb2-phy@fe8a0000/otg-port failed
[ 1.752617] phy phy-fe8a0000.usb2-phy.7: No vbus specified for otg port
[ 1.754649] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 1.754654] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.754771] mali fde60000.gpu: Looking up mali-supply from device tree
[ 1.754859] mali fde60000.gpu: Linked as a consumer to regulator.18
[ 1.754879] mali fde60000.gpu: Looking up shadercores-supply from device tree
[ 1.754889] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[ 1.754953] mali fde60000.gpu: Looking up mali-supply from device tree
[ 1.754978] vdd_gpu: could not add device link fde60000.gpu err -17
[ 1.754986] vdd_gpu: Failed to create debugfs directory
[ 1.754995] mali fde60000.gpu: Looking up shadercores-supply from device tree
[ 1.755004] mali fde60000.gpu: Looking up shadercores-supply property in node /gpu@fde60000 failed
[ 1.755025] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19
[ 1.755126] mali fde60000.gpu: leakage=8
[ 1.755612] mali fde60000.gpu: avs=0
[ 1.755638] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 1.756148] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0
[ 1.756239] mali fde60000.gpu: No priority control manager is configured
[ 1.756252] mali fde60000.gpu: No memory group manager is configured
[ 1.756729] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.757655] mali fde60000.gpu: Probed as mali0
[ 1.760544] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.764267] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.764499] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5
[ 1.765051] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010
[ 1.765096] xhci-hcd xhci-hcd.4.auto: irq 82, io mem 0xfd000000
[ 1.765361] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.765377] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.765388] usb usb5: Product: xHCI Host Controller
[ 1.765399] usb usb5: Manufacturer: Linux 4.19.219 xhci-hcd
[ 1.765409] usb usb5: SerialNumber: xhci-hcd.4.auto
[ 1.765837] hub 5-0:1.0: USB hub found
[ 1.765874] hub 5-0:1.0: 1 port detected
[ 1.766110] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[ 1.766236] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 6
[ 1.766251] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed
[ 1.766311] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.766407] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 1.766421] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.766432] usb usb6: Product: xHCI Host Controller
[ 1.766442] usb usb6: Manufacturer: Linux 4.19.219 xhci-hcd
[ 1.766452] usb usb6: SerialNumber: xhci-hcd.4.auto
[ 1.766752] hub 6-0:1.0: USB hub found
[ 1.766785] hub 6-0:1.0: 1 port detected
[ 1.767445] input: adc-keys as /devices/platform/adc-keys/input/input3
[ 1.768600] asoc-simple-card hdmi-sound: i2s-hifi ↔ fe400000.i2s mapping ok
[ 1.774389] asoc-simple-card rk809-sound: rk817-hifi ↔ fe410000.i2s mapping ok
[ 1.774419] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 1.774432] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.774443] asoc-simple-card rk809-sound: ASoC: no source widget found for Mic Jack
[ 1.774453] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.774464] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 1.774474] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 1.774485] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 1.774494] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 1.776612] register spi return v = :0
[ 1.776634] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 1.776646] ======== dhd_wlan_init_plat_data ========
[ 1.776655] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.776707] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=111, oob_irq_flags=0x414
[ 1.776713] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 1.776720] dhd_wifi_platform_load: Enter
[ 1.776726] Power-up adapter ‘DHD generic adapter’
[ 1.776757] wifi_platform_set_power = 1, delay: 200 msec
[ 1.776768] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.776778] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.776788] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 1.776797] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 1.800336] mmc3: error -110 whilst initialising SDIO card
[ 1.823906] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 1.852843] vendor storage:20190527 ret = 0
[ 1.861278] devfreq fde60000.gpu: Couldn’t update frequency transition information.
[ 1.920752] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 2.080607] wifi_platform_bus_enumerate device present 1
[ 2.080634] ======== Card detection to detect SDIO card! ========
[ 2.080642] mmc3:mmc host rescan start!
[ 2.097042] mmc3: error -110 whilst initialising SDIO card
[ 2.394679] mmc3: error -110 whilst initialising SDIO card
[ 2.691338] mmc3: error -110 whilst initialising SDIO card
[ 2.837461] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 2.947554] phy phy-fe8a0000.usb2-phy.7: charger = USB_CDP_CHARGER
[ 3.050665] dwmmc_rockchip fe000000.dwmmc: Unexpected CMD11 timeout
[ 3.850768] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 4.117421] failed to power up DHD generic adapter, 0 retry left
[ 4.133564] wifi_platform_set_power = 0, delay: 0 msec
[ 4.133577] ======== PULL WL_REG_ON(-1) LOW! ========
[ 4.133583] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 4.133593] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 4.133598] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 4.133603] wifi_platform_bus_enumerate device present 0
[ 4.133608] ======== Card detection to remove SDIO card! ========
[ 4.133613] mmc3:mmc host rescan start!
[ 4.133618] failed to power up DHD generic adapter, max retry reached**
[ 4.133624] unregister wifi platform drivers
[ 4.133629] wifi_platform_bus_enumerate device present 0
[ 4.133633] ======== Card detection to remove SDIO card! ========
[ 4.133637] mmc3:mmc host rescan start!
[ 4.133641] ======== dhd_wlan_deinit_plat_data ========
[ 4.133654] dhd_module_init: Failed to load the driver, try cnt 0
[ 4.133691] dhd_module_init: Failed to load driver max retry reached**
[ 4.133701] dhd_module_init: Exit err=-19
[ 4.134079] ==gsl_ts_init==
[ 4.134142] ret=0
[ 4.134924] iommu: Adding device fde40000.npu to group 0
[ 4.134955] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu
[ 4.135402] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 4.135449] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[ 4.135512] RKNPU fde40000.npu: Linked as a consumer to regulator.20
[ 4.135530] RKNPU fde40000.npu: can’t request region for resource [mem 0xfde40000-0xfde4ffff]
[ 4.136008] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1
[ 4.136257] RKNPU fde40000.npu: leakage=4
[ 4.136690] RKNPU fde40000.npu: avs=0
[ 4.137257] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 4.137281] RKNPU fde40000.npu: failed to find power_model node
[ 4.137292] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 4.137301] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 4.138271] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.142883] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.142983] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.142998] cfg80211: failed to load regulatory.db
[ 4.144414] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 4.145548] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘02:54:25’, on ‘Mar 30 2022’.
[ 4.145920] Mali:
[ 4.145921] Mali device driver loaded
[ 4.146147] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02
[ 4.146381] xc7160 4-001b: Failed to get power-gpios, maybe no use
[ 4.146436] xc7160 4-001b: Looking up avdd-supply from device tree
[ 4.146444] xc7160 4-001b: Looking up avdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 4.146470] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator
[ 4.146543] xc7160 4-001b: Linked as a consumer to regulator.0
[ 4.146556] xc7160 4-001b: Looking up dovdd-supply from device tree
[ 4.146563] xc7160 4-001b: Looking up dovdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 4.146579] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator
[ 4.146615] xc7160 4-001b: Looking up dvdd-supply from device tree
[ 4.146621] xc7160 4-001b: Looking up dvdd-supply property in node /i2c@fe5d0000/XC7160b@1b failed
[ 4.146635] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator
[ 4.146674] xc7160 4-001b: could not get default pinstate
[ 4.146681] xc7160 4-001b: could not get sleep pinstate
[ 4.146695] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 4.146700] xc7160 4-001b: xc7160 num data lanes is 4
[ 4.163362] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed
[ 4.163559] xc7160: probe of 4-001b failed with error -5
[ 4.163616] rkisp rkisp-vir0: clear unready subdev num: 4
[ 4.163629] rockchip-csi2-dphy0: No link between dphy and sensor
[ 4.163965] rockchip-csi2-dphy0: No link between dphy and sensor
[ 4.163977] rkisp-vir0: update sensor failed
[ 4.171145] ret 1024 0
[ 4.171462] ALSA device list:
[ 4.171475] #0: rockchip,hdmi
[ 4.171480] #1: rockchip,rk809-codec
[ 4.173682] Freeing unused kernel memory: 1600K
[ 4.180611] Run /init as init process
[ 4.551369] fusb302 0-0022: PD disabled
[ 4.863914] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 5.877255] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x1
[ 6.117593] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 6.280799] EXT4-fs (mmcblk0p8): recovery complete
[ 6.281394] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
[ 6.525381] udevd[366]: starting version 3.2.7
[ 6.531716] udevd[366]: specified group ‘kvm’ unknown
[ 6.546253] udevd[367]: starting eudev-3.2.7
[ 6.565135] udevd[367]: specified group ‘kvm’ unknown
[ 6.890603] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 7.104463] EXT4-fs (mmcblk0p6): mounting ext2 file system using the ext4 subsystem
[ 7.109461] EXT4-fs (mmcblk0p6): mounted filesystem without journal. Opts: (null)
[ 7.155823] EXT4-fs (mmcblk0p6): mounting ext2 file system using the ext4 subsystem
[ 7.158329] EXT4-fs (mmcblk0p6): mounted filesystem without journal. Opts: (null)
[ 7.536585] Generic PHY stmmac-1:00: [phy_probe-1992] led_status_value = 0x6940
[ 7.537443] Generic PHY stmmac-1:00: phy_rtl8211f_led_fixup
[ 7.559661] Generic PHY stmmac-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 7.563034] dwmac4: Master AXI performs any burst length
[ 7.563114] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[ 7.563151] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 7.563546] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[ 7.564262] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.564846] Generic PHY stmmac-0:00: [phy_probe-1992] led_status_value = 0x6940
[ 7.565775] Generic PHY stmmac-0:00: phy_rtl8211f_led_fixup
[ 7.586558] Generic PHY stmmac-0:00: phy_rtl8211f_led_fixup
[ 7.607771] Generic PHY stmmac-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 7.619105] dwmac4: Master AXI performs any burst length
[ 7.619139] rk_gmac-dwmac fe2a0000.ethernet eth1: No Safety Features support found
[ 7.619159] rk_gmac-dwmac fe2a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[ 7.619374] rk_gmac-dwmac fe2a0000.ethernet eth1: registered PTP clock
[ 7.619800] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.682562] file system registered
[ 7.703718] Mass Storage Function, version: 2009/09/11
[ 7.703753] LUN: removable file: (no medium)
[ 7.748236] read descriptors
[ 7.748282] read strings
[ 7.904003] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 8.572178] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 8.572260] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.917236] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 8.984383] dwc3 fcc00000.dwc3: device reset
[ 9.051493] android_work: sent uevent USB_STATE=CONNECTED
[ 9.054792] configfs-gadget gadget: high-speed config #1: b
[ 9.054993] android_work: sent uevent USB_STATE=CONFIGURED
[ 9.930776] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 10.944150] rk-pcie 3c0800000.pcie: PCIe Linking… LTSSM is 0x0
[ 11.957485] rk-pcie 3c0800000.pcie: PCIe Link Fail
[ 11.957564] rk-pcie 3c0800000.pcie: failed to initialize host
[ 21.821959] adbd (892): /proc/892/oom_adj is deprecated, please use /proc/892/oom_score_adj instead.
[ 35.477481] vcc3v3_lcd0_n: disabling
[ 35.477561] vcc3v3_lcd1_n: disabling
[ 35.477600] pcie30_3v3: disabling
请求解决方案,能使用wifi
dmesg.zip (17.9 KB)
