uboot启动失败
SDK包名称:rk3588_repo_sdk_v0.1.0a.7z
SDK修改内容:无
Log日志:log.txt
自己编译的uboot,烧录进去之后打印下面的log,像是编译器不对,但是对比官方下载的固件,又像是烧录位置不对。
编译过程描述:
SDK刚解压出来的时候,编译UBOOT报错编译器找不到,后来将u-boot文件夹中的make.sh修改了编译器路径,可以正常编译了
SDK中的编译器路径
Linux_SDK/rk3588/prebuilts/gcc/linux-x86/aarch64/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu/bin
下面是make.sh编译的修改的两处
line 16
#CROSS_COMPILE_ARM64=../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-CROSS_COMPILE_ARM64=../prebuilts/gcc/linux-x86/aarch64/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-
line271 #CROSS_COMPILE_ARM64=$(cd dirname ${CROSS_COMPILE_ARM64}; pwd)“/aarch64-linux-gnu-”
CROSS_COMPILE_ARM64=$(cd dirname ${CROSS_COMPILE_ARM64}; pwd)“/aarch64-none-linux-gnu-”
启动失败的打印log:
/DDR Version V1.06 20220224
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-gbdb740d4da-220216 #cjh (Feb 24 2022 - 03:15:33)
Failed to set cpub01
Failed to set cpub23
unknown raw ID phN
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking uboot 0x00200000 … sha256(96bfd824a9…) + OK
## Checking fdt 0x00340cf8 … sha256(c07f4a4d71…) + OK
## Checking optee 0x08400000 … sha256(603cfbd25d…) + OK
Jumping to U-Boot(0x00200000)
启动成功的打印
LPDDR4X, 2112MHz
out
Boot1 Release Time: Mar 4 2022 16:17:33, version: 1.08
Emmc IO init.
Emmc IO init.
mmc_set_bus_width: 1
SetEmmcClk: 375000, 2, 64
mmc_set_bus_width: 8
SetEmmcClk: 200000000, 0, 3
Enable PHY CLK: 200000000, timing: 9
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=119276MB
FwPartOffset=2000 , 100000
UsbBoot …53536
powerOn 53793
SoftReset, 2518245 us
LPDDR4X, 2112MHz
out
unknown raw ID phN
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(4e081b1b07…) + OK
## Checking uboot 0x00200000 … sha256(15b8710b84…) + OK
## Checking fdt 0x00340ce8 … sha256(c07f4a4d71…) + OK
## Checking atf-2 0x000f0000 … sha256(6a00298af8…) + OK
## Checking atf-3 0xff100000 … sha256(19762d10e3…) + OK
## Checking atf-4 0xff009000 … sha256(2301cf73be…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 86.269 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-331-g7380d9813:derrick.huang
NOTICE: BL31: Built : 19:33:36, Mar 24 2022
INFO: timer_hp_init no valid 32k timer source, use normal mode
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing BL32
INFO: hdmirx_handler: dma not on, ret
I/TC:
I/TC: OP-TEE version: 3.13.0-639-g8e053a881-dev #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Mon Mar 14 09:09:01 CST 2022 aarch64
INFO: SPSR = 0x3c9
log.txt (4.62 KB)
看文档呀!需要更新 SDK
板蓝根 发表于 2022-6-16 18:54
看文档呀!需要更新 SDK
已经按照手册更新了
2. Download bundle. (Please download all files in the bundle directory)
3. Copy all the files in the bundle to the root directory of the sdk (mv bundle/* rk3588/)
4. ./update.sh
rk3588@ubuntu:~/rk3588/Linux_SDK/rk3588/u-boot$ git tag
linux_release_v1.0.0b
rk3588/linux_release_v0.0.1a
rk3588/linux_release_v0.0.1b
rk3588/linux_release_v0.0.1c
rk3588/linux_release_v0.1.0a
rk3588/linux_release_v0.1.1a
rk3588/linux_release_v1.0.0a
rk3588/linux_release_v1.0.0b
看文档呀!需要更新 SDK
大佬,能再指点一下吗?应该只需要烧录一级加载和uboot,就能进入uboot命令行了,现在情况就是跳转到uboot就没有下文了,一级加载的源码哪里找,自己可以编译吗
你先确定 bundle 更新 没有报任何错误。 git status 看一下每个仓库是不是干净的,git tag 看一下是不是 每个仓库目前都处于 linux_release_v1.0.0c 你那个 uboot 编译器的问题,如果更新到最新的 SDK 应该是不会出现
板蓝根 发表于 2022-7-18 10:26
你先确定 bundle 更新 没有报任何错误。 git status 看一下每个仓库是不是干净的,git tag 看一下是不是 每 …
是SDK没有更新好,谢谢大佬
你好麻烦问一下你是自己编译的的uboot 不采用官方的build.sh编译可以吗?
看文档呀!需要更新 SDK
麻烦问一下看那个文档呀,突然进来不知道说的那个文档
