自己编译的uboot启动失败,求大佬解答
自己编译的uboot,烧录进去之后打印下面的log,像是编译器不对,但是对比官方下载的固件,又像是烧录位置不对。
编译过程描述:
SDK刚解压出来的时候,编译UBOOT报错编译器找不到,后来将u-boot文件夹中的make.sh修改了编译器路径,可以正常编译了
SDK中的编译器路径
Linux_SDK/rk3588/prebuilts/gcc/linux-x86/aarch64/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu/bin
下面是make.sh编译的修改的两处
line 16
#CROSS_COMPILE_ARM64=../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-CROSS_COMPILE_ARM64=../prebuilts/gcc/linux-x86/aarch64/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-
line271 #CROSS_COMPILE_ARM64=$(cd dirname ${CROSS_COMPILE_ARM64}; pwd)“/aarch64-linux-gnu-”
CROSS_COMPILE_ARM64=$(cd dirname ${CROSS_COMPILE_ARM64}; pwd)“/aarch64-none-linux-gnu-”
启动失败的打印log:
/DDR Version V1.06 20220224
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=16 Size=4096MB
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-gbdb740d4da-220216 #cjh (Feb 24 2022 - 03:15:33)
Failed to set cpub01
Failed to set cpub23
unknown raw ID phN
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking uboot 0x00200000 … sha256(96bfd824a9…) + OK
## Checking fdt 0x00340cf8 … sha256(c07f4a4d71…) + OK
## Checking optee 0x08400000 … sha256(603cfbd25d…) + OK
Jumping to U-Boot(0x00200000)
启动成功的打印
LPDDR4X, 2112MHz
out
Boot1 Release Time: Mar 4 2022 16:17:33, version: 1.08
Emmc IO init.
Emmc IO init.
mmc_set_bus_width: 1
SetEmmcClk: 375000, 2, 64
mmc_set_bus_width: 8
SetEmmcClk: 200000000, 0, 3
Enable PHY CLK: 200000000, timing: 9
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=119276MB
FwPartOffset=2000 , 100000
UsbBoot …53536
powerOn 53793
SoftReset, 2518245 us
LPDDR4X, 2112MHz
out
unknown raw ID phN
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(4e081b1b07…) + OK
## Checking uboot 0x00200000 … sha256(15b8710b84…) + OK
## Checking fdt 0x00340ce8 … sha256(c07f4a4d71…) + OK
## Checking atf-2 0x000f0000 … sha256(6a00298af8…) + OK
## Checking atf-3 0xff100000 … sha256(19762d10e3…) + OK
## Checking atf-4 0xff009000 … sha256(2301cf73be…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 86.269 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-331-g7380d9813:derrick.huang
NOTICE: BL31: Built : 19:33:36, Mar 24 2022
INFO: timer_hp_init no valid 32k timer source, use normal mode
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing BL32
INFO: hdmirx_handler: dma not on, ret
I/TC:
I/TC: OP-TEE version: 3.13.0-639-g8e053a881-dev #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Mon Mar 14 09:09:01 CST 2022 aarch64
INFO: SPSR = 0x3c9
