固件文件名称:Firefly-RK3288_Android5.1.1_Public_201023.img
Log日志:log.zip
shell@firefly:/ $ [ 43.859506] type=1400 audit(1293885477.150:13): avc: denied { execute } for pid=1086 comm="ActivityManager" name="sh" dev="mmcblk0p10" ino=326 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 43.859753] type=1400 audit(1293885477.150:14): avc: denied { read open } for pid=1086 comm="ActivityManager" path="/system/bin/sh" dev="mmcblk0p10" ino=326 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 43.861351] type=1400 audit(1293885477.150:15): avc: denied { execute_no_trans } for pid=1086 comm="ActivityManager" path="/system/bin/sh" dev="mmcblk0p10" ino=326 scontext=u:r:system_server:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 43.865240] type=1400 audit(1293885477.150:16): avc: denied { write } for pid=1089 comm="vm" name="server" dev="tmpfs" ino=1257 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=sock_file permissive=1
[ 43.888839] init: untracked pid 1091 exited with status 0
[ 43.889536] type=1400 audit(1293885477.180:17): avc: denied { read write } for pid=521 comm="ActivityManager" name="vmdrm0" dev="tmpfs" ino=1213 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 43.889727] type=1400 audit(1293885477.180:18): avc: denied { open } for pid=521 comm="ActivityManager" path="/dev/vmdrm0" dev="tmpfs" ino=1213 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 43.889830] type=1400 audit(1293885477.180:19): avc: denied { ioctl } for pid=521 comm="ActivityManager" path="/dev/vmdrm0" dev="tmpfs" ino=1213 ioctlcmd=b503 scontext=u:r:system_server:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[ 43.942212] init: untracked pid 1115 exited with status 0
[ 44.009724] init: untracked pid 1127 exited with status 0
[ 45.539440] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 45.695898] read channel() error: -110
[ 47.017420] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 47.299455] read channel() error: -110
[ 48.709493] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 48.874919] read channel() error: -110
[ 50.352423] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 50.449646] read channel() error: -110
[ 51.897583] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 52.013463] read channel() error: -110
[ 53.698287] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 53.833796] read channel() error: -110
[ 55.319744] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 55.477312] read channel() error: -110
[ 56.935046] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD25): error = -110, timeout = 8000ms
[ 56.993270] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 57.209565] read channel() error: -110
[ 57.357034] [mmc0] -- Timeout recovery procedure start --
[ 57.959525] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 58.211666] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 58.370023] init: untracked pid 1141 exited with status 0
[ 58.576720] [mmc0] -- Timeout recovery procedure finished --
[ 58.726400] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 59.057830] read channel() error: -110
[ 60.544992] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 60.672602] read channel() error: -110
[ 61.892472] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 62.011100] read channel() error: -110
[ 63.233180] saradc-reg[0x00-0x0c]: 0x000003ff 0x00000000 0x00000069 0x00000008
[ 63.419920] read channel() error: -110
[ 64.077916] fence timeout on [c5aa3e80] after 3000ms
[ 64.154656] objs:
fb-timeline sw_sync: 499
pt signaled@3.364518: 2
pt signaled@3.447855: 3
pt signaled@41.064526: 459
pt signaled@44.114546: 497
pt signaled@44.247859: 499
pt active: 500
pt active: 500
fb-timeline sw_sync: 0
malitl_161_0
[ 64.731276] INFO: rcu_preempt self-detected stall on CPU { 0} (t=2100 jiffies g=800 c=799 q=438)
[ 64.744852] Backtrace for cpu 0 (current):
[ 64.752233] CPU: 0 PID: 938 Comm: ndroid.systemui Tainted: P 3.10.0 #1
[ 64.765102] [<c0013ec4>] (unwind_backtrace+0x0/0xe0) from [<c001176c>] (show_stack+0x10/0x14)
[ 64.775701] [<c001176c>] (show_stack+0x10/0x14) from [<c0012ddc>] (smp_send_all_cpu_backtrace+0x60/0xcc)
[ 64.786349] [<c0012ddc>] (smp_send_all_cpu_backtrace+0x60/0xcc) from [<c00a4820>] (print_cpu_stall+0xb4/0x138)
[ 64.796895] [<c00a4820>] (print_cpu_stall+0xb4/0x138) from [<c00a5474>] (__rcu_pending+0x68/0x190)
[ 64.807298] [<c00a5474>] (__rcu_pending+0x68/0x190) from [<c00a7170>] (rcu_check_callbacks+0x160/0x230)
[ 64.818751] [<c00a7170>] (rcu_check_callbacks+0x160/0x230) from [<c0045278>] (update_process_times+0x38/0x64)
[ 64.829752] [<c0045278>] (update_process_times+0x38/0x64) from [<c008128c>] (tick_sched_timer+0xac/0xe0)
[ 64.840298] [<c008128c>] (tick_sched_timer+0xac/0xe0) from [<c0059364>] (__run_hrtimer+0x1a4/0x2b8)
[ 64.850908] [<c0059364>] (__run_hrtimer+0x1a4/0x2b8) from [<c0059f64>] (hrtimer_interrupt+0x11c/0x278)
[ 64.861461] [<c0059f64>] (hrtimer_interrupt+0x11c/0x278) from [<c05dfe14>] (arch_timer_handler_phys+0x28/0x30)
[ 64.872914] [<c05dfe14>] (arch_timer_handler_phys+0x28/0x30) from [<c00a0950>] (handle_percpu_devid_irq+0xf8/0x1b4)
[ 64.884118] [<c00a0950>] (handle_percpu_devid_irq+0xf8/0x1b4) from [<c009d544>] (generic_handle_irq+0x20/0x30)
[ 64.894773] [<c009d544>] (generic_handle_irq+0x20/0x30) from [<c000e3cc>] (handle_IRQ+0x64/0x8c)
[ 64.904702] [<c000e3cc>] (handle_IRQ+0x64/0x8c) from [<c000853c>] (gic_handle_irq+0x38/0x5c)
[ 64.914215] [<c000853c>] (gic_handle_irq+0x38/0x5c) from [<c000d600>] (__irq_svc+0x40/0x70)
[ 64.922512] Exception stack(0xdc965ef8 to 0xdc965f40)
[ 64.929656] 5ee0: 00000001 c0e4a1c0
[ 64.938559] 5f00: 00000000 00000000 dc964000 00000000 00000202 00000001 12c12400 b84a9300
[ 64.948507] 5f20: 12d56100 0000000a 00000000 dc965f40 c003cf64 c003de58 60030113 ffffffff
[ 64.959696] [<c000d600>] (__irq_svc+0x40/0x70) from [<c003de58>] (__do_softirq+0x78/0x2b4)
[ 64.970156] [<c003de58>] (__do_softirq+0x78/0x2b4) from [<c003e150>] (do_softirq+0x44/0x50)
[ 64.980785] [<c003e150>] (do_softirq+0x44/0x50) from [<c003e3bc>] (irq_exit+0x74/0xbc)
[ 64.990293] [<c003e3bc>] (irq_exit+0x74/0xbc) from [<c000e3d0>] (handle_IRQ+0x68/0x8c)
[ 64.999715] [<c000e3d0>] (handle_IRQ+0x68/0x8c) from [<c000853c>] (gic_handle_irq+0x38/0x5c)
[ 65.009081] [<c000853c>] (gic_handle_irq+0x38/0x5c) from [<c000d7bc>] (__irq_usr+0x3c/0x60)
[ 65.015803] Exception stack(0xdc965fb0 to 0xdc965ff8)
[ 65.022857] 5fa0: 0025891e 00000000 12c12400 b1d5b070
[ 65.031617] 5fc0: 0000004a 12d71000 7114c400 00000001 12c12400 b84a9300 12d56100 ffffffff
log.zip (25.8 KB)
