How to control GPIO in Android application?
Hi,
I want to create android application that is able to control GPIO, LED, Serial port.
I’ve searched a lot but can’t get enough of good solution.
The following is the programming path which I understand.
Android App (Java) —> Android JNI —> Android Native Code (C/C++) —> ??? —> Device Drivers
. How can I access the Device Drivers (GPIO, LED, Serial port) in Android Native C/C++ code?
. Do I need to modify or create existing device driver for using GPIO, LED, Serial port?
. Is there library provided to read/write specific resource like “/sys/class/gpio/gpio91/value”?
. Would you let me know how to access GPIO, LED, Serial port in Android App with sample source code or SDK?
Thanks.
http://developer.t-firefly.com/thread-2436-1-1.html
a sample for you
thanks.
in your sample, how can I build luobogpio.c (driver) file and put luobogpio.o (maybe..) file into dev/luobogpio?
zamster 发表于 2015-9-10 09:06
thanks.
in your sample, how can I build luobogpio.c (driver) file and put luobogpio.o (maybe..) f …
http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_android
I want to know how to build custom driver file. (not to build android sdk)
meaning of build custom driver file indicates that adding a new file (luobogpio.c into where?), modifying Makefile, creating object file, and so on.
still don’t get it enough…
Serial ------ demo ./base/tests/SerialChat/src/com/android/serialchat/SerialChat.java
gpoi --------- usage cd /sys/class/gpio&& echo 18 > export &&cd gpio18&echo out > direction &&echo 1 > value.
you also need add chmod 0666 /sys/class/gpio* init.rc
add ueventd.rc /sys/class/gpio/* 0666 root root
