固件文件名称:DR4018L-R
固件下载地址:PRODUCTS_Wallys Communications (Suzhou ) Co., LTD
Log日志:无线网卡.zip
IPQ4018 12V-56VDCPassive 24V-56V
IPQ4018 2*MMCX 27dbm Support MU-MIMO
DR4018L-R
Wallys Communications (Suzhou ) Co., LTD (http://www.wallystech.com) is a professional supplier of wireless communication products and has a complete industrial chain in China. Our biggest advantage is our independent research and development ability, which can support you in the later period. We are also a supplier to Facebook, the quality of the product is unquestionable
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/
EMAIL:sales3@wallystech.com
wifi6 router/network card
wifi 6E
WiFi 6
802.11ax/802.11ac
wireless solutions
Dipole/ panel //Dual Polarization Enclosure /Smart /omni /Antenna
Wireless Access Point/Point to Point /
Featuring with industrial-grade [b]IPQ4018[/b] chipset
Integrated with 2x 2 5G Radio module and 2x2 Radio module
Support 5.180GHz to 5.825GHz Frequency Range
Support 2.412GHz to2.482GHz
Support 2 x 5G UFL Connectors and 2x2.4G UFL
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/[b]802.11AC[/b] wave2 mode
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
12
V
Operating Temperature Range
-40 to +70
oC
Storage Temperature Range
-65 to +105
oC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
Antenna Connector
4xUFL
10/100/1000Mbps Gigabit Ethernet
5xRJ45
SFP connector
NO
3G/4G connector
NO
USB connector
1xUSB 3.0 connector
POE
NO
DC Jack
12 power supply
ROHS Compliance
YES
Dimension
NA
Max Power
15W
Radio TX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
802.11a
6 Mbps
20dBm
23dbm
±2dB
54 Mbps
18dBm
21dbm
±2dB
802.11n HT20
MCS0, MCS8
19dBm
22dbm
±2dB
MCS7, MCS15
17dBm
20dbm
±2dB
802.11n HT40
MCS0, MCS8
19dBm
22dbm
±2dB
MCS7, MCS15
17dBm
20dbm
±2dB
802.11ac
MCS0, MCS10,MCS20
19dBm
22dbm
±2dB
MCS9,MCS19,MCS29
16dBm
19dbm
±2dB
Radio RX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Sensitivity
802.11a
6 Mbps
-93dBm
54 Mbps
-78dBm
802.11n HT20
MCS0, MCS8
-92dBm
MCS7, MCS15
-73dBm
802.11n HT40
MCS0, MCS8
-90dBm
MCS7, MCS15
-70dBm
802.11AC HT40
MCS0, MCS10,MCS20
-90dBm
MCS9,MCS19,MCS29
-67dBm
802.11AC HT80
MCS0, MCS10,MCS20
-88dBm
MCS9,MCS19,MCS29
-62dBm
无线网卡.zip (49.6 KB)
