ROC-RK3588S-PC DP 屏增加800*480 60HZ 分辨率 无效
SDK包名称:firefly_rk3588_android12.0_git_20220311
SDK修改内容:On branch firefly
Changes not staged for commit:
(use "git add <file>…" to update what will be committed)
(use "git checkout – <file>…" to discard changes in working directory)
modified: build/make/core/main.mk
modified: device/rockchip/common/resolution_white.xml
modified: kernel-5.10/arch/arm64/boot/dts/rockchip/roc-rk3588s-pc.dtsi
modified: kernel-5.10/drivers/gpu/drm/drm_edid.c
modified: packages/apps/Settings/res/values/arrays.xml
Untracked files:
(use "git add <file>…" to include in what will be committed)
.bundle/
It took 13.09 seconds to enumerate untracked files. 'status -uno'
may speed it up, but you have to be careful not to forget to add
new files yourself (see 'git help status').
no changes added to commit (use "git add" and/or "git commit -a")
Log日志:[Com COM7] (2022-06-20_161221).rar
修改后,实际没有该分辨率
Com COM7 (2022-06-20_161221).rar (29.4 KB)
解决了没?
ninver2018 发表于 2022-6-21 17:39
解决了没?
解决了,更新最新的sdk后,修改了kernel-5.10/drivers/gpu/drm/drm_edid.c,搞定!
